path: root/patches/collateral-evolutions/network/0002-disable-dump-adjust-on-old-kernels.patch
2015-04-25patches: refresh patches on next-20150402backports-20150402Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.73 [ OK ] 12 3.11.10 [ OK ] 13 3.12.39 [ OK ] 14 3.13.11 [ OK ] 15 3.14.37 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.10 [ OK ] 20 3.19.3 [ OK ] 21 4.0-rc6 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-03patches: refresh patches on next-20150222Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.73 [ OK ] 12 3.11.10 [ OK ] 13 3.12.39 [ OK ] 14 3.13.11 [ OK ] 15 3.14.37 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.10 [ OK ] 20 3.19.3 [ OK ] 21 4.0-rc6 [ OK ] manual changes done to: patches/collateral-evolutions/network/0020-tty-termios/drivers_bluetooth_hci_ath.patch - removed patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch - handled added CONFIG_HAS_DMA Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22patches: refresh patches on next-20150129backports-20150129Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.67 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.69 [ OK ] 12 3.11.10 [ OK ] 13 3.12.38 [ OK ] 14 3.13.11 [ OK ] 15 3.14.33 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.7 [ OK ] 20 3.19.0 [ OK ] manual changes do to: patches/collateral-evolutions/network/0049-no-pfmemalloc/igb.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: refresh on next-20141201Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.65 [ OK ] 4 3.3.8 [ OK ] 5 3.4.105 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.63 [ OK ] 12 3.11.10 [ OK ] 13 3.12.35 [ OK ] 14 3.13.11 [ OK ] 15 3.14.27 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.7 [ OK ] 19 3.18.1 [ OK ] manual changed were needed for the following patches: backport-adjustments/crypto-ccm.patch backport-adjustments/devcoredump.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-16backports: refresh patches on next-20141114Hauke Mehrtens
2014-10-20backports: refresh on next-20140919backports-20140919Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.103 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.54 [ OK ] 12 3.11.10 [ OK ] 13 3.12.27 [ OK ] 14 3.13.11 [ OK ] 15 3.14.18 [ OK ] 16 3.15.10 [ OK ] 17 3.16.2 [ OK ] 18 3.17-rc3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: refresh patches on next-20140606backports-20140606Hauke Mehrtens
There were manual changes ineeded in the following files: patches/collateral-evolutions/network/0034-ndo_set_vf_spoofchk/igb_ndo_set_vf_spoofchk.patch patches/collateral-evolutions/network/0037-ethtool_get_module/igb_get_module.patch patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.59 [ OK ] 4 3.3.8 [ OK ] 5 3.4.91 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.40 [ OK ] 12 3.11.10 [ OK ] 13 3.12.20 [ OK ] 14 3.13.11 [ OK ] 15 3.14.4 [ OK ] 16 3.15-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: refresh patches on next-20140501Hauke Mehrtens
2014-04-17backports: refresh patches for next-20140409 and next-20140411Luis R. Rodriguez
We were required to refresh patches for next-20140409 but for next-20140411 no changes were required. Since no actual commit is necessary next time this happens (which can often, hence -- automatic backports --) I'll just peg the results on the PGP signed tag for the release. I'll peg this commit with both next tags because of this. Just run git describe to find out the respective linux-next tag you should be using as that is the latest validated one. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh \ /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.437s user 9m22.812s sys 0m24.484s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 28m21.215s user 786m8.468s sys 86m46.564s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
