path: root/patches/collateral-evolutions/network/0028-select_queue/mac80211.patch
2015-06-16patches: refresh patches on next-20150612Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ FAIL ] Only kernel 4.1-rc1 will fail, because tty_set_termios() is not exported, 4.1-rc4 works. manual changes done to: drivers/media/platform/vim2m.c Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-05-11patches: refresh patches on next-20150511backports-20150511Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.107 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.75 [ OK ] 12 3.11.10 [ OK ] 13 3.12.40 [ OK ] 14 3.13.11 [ OK ] 15 3.14.39 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.12 [ OK ] 20 3.19.5 [ OK ] 21 4.0.0 [ OK ] 22 4.1-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-26patches: refresh patches on next-20150424backports-20150424Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.73 [ OK ] 12 3.11.10 [ OK ] 13 3.12.39 [ OK ] 14 3.13.11 [ OK ] 15 3.14.37 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.10 [ OK ] 20 3.19.3 [ OK ] 21 4.0-rc6 [ OK ] manual changes done to patches/collateral-evolutions/network/0053-remove_wait_on_bit_timeout/btusb.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-03patches: refresh patches on next-20150222Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.73 [ OK ] 12 3.11.10 [ OK ] 13 3.12.39 [ OK ] 14 3.13.11 [ OK ] 15 3.14.37 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.10 [ OK ] 20 3.19.3 [ OK ] 21 4.0-rc6 [ OK ] manual changes done to: patches/collateral-evolutions/network/0020-tty-termios/drivers_bluetooth_hci_ath.patch - removed patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch - handled added CONFIG_HAS_DMA Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: refresh patches on next-20141221backports-20141221Hauke Mehrtens
2014-11-16backports: refresh patches on next-20141114Hauke Mehrtens
2014-10-20backports: refresh on next-20140919backports-20140919Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.103 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.54 [ OK ] 12 3.11.10 [ OK ] 13 3.12.27 [ OK ] 14 3.13.11 [ OK ] 15 3.14.18 [ OK ] 16 3.15.10 [ OK ] 17 3.16.2 [ OK ] 18 3.17-rc3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-07-23backports: add some ubuntu trusty specific changesHauke Mehrtens
It is now possible to detect a ubuntu kernel see: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1327619 This uses the new define and adds some code depending on the ubuntu trusty kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: refresh patches on next-20140606backports-20140606Hauke Mehrtens
There were manual changes ineeded in the following files: patches/collateral-evolutions/network/0034-ndo_set_vf_spoofchk/igb_ndo_set_vf_spoofchk.patch patches/collateral-evolutions/network/0037-ethtool_get_module/igb_get_module.patch patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.59 [ OK ] 4 3.3.8 [ OK ] 5 3.4.91 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.40 [ OK ] 12 3.11.10 [ OK ] 13 3.12.20 [ OK ] 14 3.13.11 [ OK ] 15 3.14.4 [ OK ] 16 3.15-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove useless git patch headerHauke Mehrtens
When exporting a patch from git it adds a header to it, but this header is not needed by backports, remove it from the patches. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: refresh patches on next-20140501Hauke Mehrtens
2014-05-01backports: select_queue patch: fix callback kernel versionJohannes Berg
The callback argument has been passed since kernel 3.14, not only 3.15 - fix that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: refresh patches for next-20140409 and next-20140411Luis R. Rodriguez
We were required to refresh patches for next-20140409 but for next-20140411 no changes were required. Since no actual commit is necessary next time this happens (which can often, hence -- automatic backports --) I'll just peg the results on the PGP signed tag for the release. I'll peg this commit with both next tags because of this. Just run git describe to find out the respective linux-next tag you should be using as that is the latest validated one. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh \ /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.437s user 9m22.812s sys 0m24.484s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 28m21.215s user 786m8.468s sys 86m46.564s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
