path: root/patches/collateral-evolutions/network/0028-select_queue
2014-06-16backports: refresh patches on next-20140606backports-20140606Hauke Mehrtens
There were manual changes ineeded in the following files: patches/collateral-evolutions/network/0034-ndo_set_vf_spoofchk/igb_ndo_set_vf_spoofchk.patch patches/collateral-evolutions/network/0037-ethtool_get_module/igb_get_module.patch patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.59 [ OK ] 4 3.3.8 [ OK ] 5 3.4.91 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.40 [ OK ] 12 3.11.10 [ OK ] 13 3.12.20 [ OK ] 14 3.13.11 [ OK ] 15 3.14.4 [ OK ] 16 3.15-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove useless git patch headerHauke Mehrtens
When exporting a patch from git it adds a header to it, but this header is not needed by backports, remove it from the patches. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: refresh patches on next-20140501Hauke Mehrtens
2014-06-02backports: select_queue patch: fix callback kernel versionHauke Mehrtens
The patch changing the callback function signature was backported to kernel 3.14, this was already fixed in backports for mac80211, but that commit missed mwifiex. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01backports: select_queue patch: fix callback kernel versionJohannes Berg
The callback argument has been passed since kernel 3.14, not only 3.15 - fix that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: refresh patches for next-20140409 and next-20140411Luis R. Rodriguez
We were required to refresh patches for next-20140409 but for next-20140411 no changes were required. Since no actual commit is necessary next time this happens (which can often, hence -- automatic backports --) I'll just peg the results on the PGP signed tag for the release. I'll peg this commit with both next tags because of this. Just run git describe to find out the respective linux-next tag you should be using as that is the latest validated one. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh \ /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.437s user 9m22.812s sys 0m24.484s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 28m21.215s user 786m8.468s sys 86m46.564s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
