path: root/patches/collateral-evolutions/network/0035-skb_no_fcs
2014-06-16backports: refresh patches on next-20140606backports-20140606Hauke Mehrtens
There were manual changes ineeded in the following files: patches/collateral-evolutions/network/0034-ndo_set_vf_spoofchk/igb_ndo_set_vf_spoofchk.patch patches/collateral-evolutions/network/0037-ethtool_get_module/igb_get_module.patch patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.59 [ OK ] 4 3.3.8 [ OK ] 5 3.4.91 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.40 [ OK ] 12 3.11.10 [ OK ] 13 3.12.20 [ OK ] 14 3.13.11 [ OK ] 15 3.14.4 [ OK ] 16 3.15-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove useless git patch headerHauke Mehrtens
When exporting a patch from git it adds a header to it, but this header is not needed by backports, remove it from the patches. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: refresh patches on next-20140501Hauke Mehrtens
2014-06-02backports: handle no_fcs change in struct sk_buffStefan Assmann
In kernel 3.4 a new field no_fcs was introduced to struct sk_buff. Address this by putting ifdef around the code. commit 3bdc0eba0b8b47797f4a76e377dd8360f317450f Author: Ben Greear <greearb@candelatech.com> Date: Sat Feb 11 15:39:30 2012 +0000 net: Add framework to allow sending packets with customized CRC. git describe --contains 3bdc0eba0b8b47797f4a76e377dd8360f317450f v3.4-rc1~177^2~207 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
