path: root/patches/collateral-evolutions/network/0049-no-pfmemalloc/igb.patch
2015-02-22patches: refresh patches on next-20150129backports-20150129Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.67 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.69 [ OK ] 12 3.11.10 [ OK ] 13 3.12.38 [ OK ] 14 3.13.11 [ OK ] 15 3.14.33 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.7 [ OK ] 20 3.19.0 [ OK ] manual changes do to: patches/collateral-evolutions/network/0049-no-pfmemalloc/igb.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: refresh patches on next-20141221backports-20141221Hauke Mehrtens
2014-12-21patches: refresh on next-20141201Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.65 [ OK ] 4 3.3.8 [ OK ] 5 3.4.105 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.63 [ OK ] 12 3.11.10 [ OK ] 13 3.12.35 [ OK ] 14 3.13.11 [ OK ] 15 3.14.27 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.7 [ OK ] 19 3.18.1 [ OK ] manual changed were needed for the following patches: backport-adjustments/crypto-ccm.patch backport-adjustments/devcoredump.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-20backports: refresh patches for next-20141117backports-20141117Luis R. Rodriguez
This required no manual changes. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ /home/mcgrof/linux-next /home/mcgrof/build/backports-20141117 Copy original source files ... Applying patches from patches to /home/mcgrof/build/backports-20141117 ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m28.499s user 13m25.112s sys 0m47.804s mcgrof@drvbp1 ~/build/backports-20141117 $ time \ /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m18.874s user 1179m40.500s sys 138m54.452s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-16patches: igb: remove usage of pfmemalloc in struct pageHauke Mehrtens
The member pfmemalloc was added to struct page in kernel 3.6, it should be same to just ignore it in most situation, so do so on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
