path: root/patches/collateral-evolutions/network/0062-acpi-gpio-remove
2015-11-15patches: refresh on next-20151115backports-20151115Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] Bigger, manual changes were needed on patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07patches: refresh on next-20151013backports-20151013Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] manual changes done to the following patches: * patches/collateral-evolutions/network/0059-uuid-in-mei/nfc.patch * patches/collateral-evolutions/network/0013-fix-makefile-includes/brcmfmac.patch * patches/collateral-evolutions/network/0062-acpi-gpio-remove/hci_bcm.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-02patches: refresh patches on next-20150923Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-09-22patches: refresh patches on next-20150903backports-20150903Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.71 [ OK ] 4 3.3.8 [ OK ] 5 3.4.108 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.88 [ OK ] 12 3.11.10 [ OK ] 13 3.12.47 [ OK ] 14 3.13.11 [ OK ] 15 3.14.52 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.21 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.7 [ OK ] 23 4.2.0 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-09-22patches: remove usage of gpio/consumer.h from hci_intel.cHauke Mehrtens
hci_intel.c now also uses gpio/consumer.h which is only available in kernel >= 3.13. devm_gpiod_get_optional() with the current parameter list is only available in kernel 3.17. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-09-14patches: make ACPI gpio configuration depend on kernel >= 3.19Hauke Mehrtens
The GPIO configuration in the hci_bcm driver is now fetched from ACPI, which only works in kernel version >= 3.19. In addition it used these GPIO informations with the gpio consumer framework which was added in 3.13, deactivate these new features if the kernel does not support them. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
