path: root/patches/collateral-evolutions/network/26-sdio-quirks
2013-08-27backports: refresh patches on next-20130802Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.89 [ OK ] 18 3.1.10 [ OK ] 19 3.10.5 [ OK ] 20 3.11-rc4 [ OK ] 21 3.2.50 [ OK ] 22 3.3.8 [ OK ] 23 3.4.56 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: refresh on next-20130726Hauke Mehrtens
2013-08-27backports: move the cw1200 sdio quirk into 26-sdio-quirksSolomon Peachy
Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backports: refresh patches on next-20130523Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-04-05refresh patches against next-20130328Johannes Berg
The patches were last refreshed against that same tree, so the only change is that now we have -p in there, which results in changes like this (only): -@@ -1593,7 +1593,7 @@ +@@ -1593,7 +1593,7 @@ static int nl80211_dump_wiphy(struct sk_ This makes the patches more readable. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-31rename patch files to .patchJohannes Berg
They can be named after the C files they apply to, but they should still be named .patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-03-30split patchesJohannes Berg
This splits all patches into per-file patches. I've added the little tool I wrote as well (but it's hard to use). Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
