path: root/patches/collateral-evolutions/network/43-rename_pm_qos_request
2013-04-05refresh patches against next-20130328Johannes Berg
The patches were last refreshed against that same tree, so the only change is that now we have -p in there, which results in changes like this (only): -@@ -1593,7 +1593,7 @@ +@@ -1593,7 +1593,7 @@ static int nl80211_dump_wiphy(struct sk_ This makes the patches more readable. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-31rename patch files to .patchJohannes Berg
They can be named after the C files they apply to, but they should still be named .patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-03-30split patchesJohannes Berg
This splits all patches into per-file patches. I've added the little tool I wrote as well (but it's hard to use). Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
