1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.17 [ OK ]
20 3.11.6 [ FAIL ]
21 3.12-rc7 [ FAIL ]
22 3.2.52 [ OK ]
23 3.3.8 [ OK ]
24 3.4.67 [ OK ]
25 3.5.7 [ OK ]
26 3.6.11 [ OK ]
27 3.7.10 [ OK ]
28 3.8.13 [ OK ]
29 3.9.11 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ FAIL ]
19 3.11.3 [ FAIL ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Upstream commit: 6bc60d332b7109c99cd5f5d5f8b7791f921289d6
The newly created function ends with _compat. This causes compile
warnings and probably runtime problems on kernel < 2.6.29.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.2.45 [ OK ]
20 3.3.8 [ OK ]
21 3.4.46 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.13 [ OK ]
26 3.9.3 [ OK ]
real 33m18.960s
user 900m1.540s
sys 125m0.580s
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.85 [ OK ]
18 3.1.10 [ OK ]
19 3.10.0 [ OK ]
20 3.2.48 [ OK ]
21 3.3.8 [ OK ]
22 3.4.52 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.9 [ OK ]
Upstream commit afe18ac2454e8ba8c3a45a837da7c7fca65c5aae
This backports the new upstream alx driver and
properly splits up each required backports into
its respective collateral evolution bucket.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m50.520s
user 815m12.233s
sys 127m49.075s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.012s
user 814m18.301s
sys 127m38.575s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m53.044s
user 815m38.362s
sys 127m50.187s
This addresses the last remaining components to
backport the ethernet vlan changes introduced by
9356b8fc d314774c and f646968f8f on next-20130423.
The new code for the "critical protocol indication" uses
snd_portid and must be adjusted in the backport patches.
This is required as of next-20130423.
commit 5de17984898c5758fc6ebe08eccea9f4b6548914
Author: Arend van Spriel <arend@broadcom.com>
Date: Thu Apr 18 15:49:00 2013 +0200
cfg80211: introduce critical protocol indication from user-space
Some protocols need a more reliable connection to complete
successful in reasonable time. This patch adds a user-space
API to indicate the wireless driver that a critical protocol
is about to commence and when it is done, using nl80211 primitives
NL80211_CMD_CRIT_PROTOCOL_START and NL80211_CRIT_PROTOCOL_STOP.
There can be only on critical protocol session started per
registered cfg80211 device.
The driver can support this by implementing the cfg80211 callbacks
.crit_proto_start() and .crit_proto_stop(). Examples of protocols
that can benefit from this are DHCP, EAPOL, APIPA. Exactly how the
link can/should be made more reliable is up to the driver. Things
to consider are avoid scanning, no multi-channel operations, and
alter coexistence schemes.
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
[mcgrof@do-not-panic.com]: Required as of next-20130423
and provided commit log message that introduced this
change.
There's not much point in backporting rfkill, if the base kernel
doesn't have it then providing the it as /dev/rfkill_backport
won't be picked up by any apps, and if the base kernel has it
then it would cause odd behaviour as the base kernel's platform
drivers using the rfkill API would not talk to the backported
modules rfkill.
An unusable backported rfkill isn't much better than not having
it at all, so change the way we backport rfkill and don't carry
the code but simply provide the API as wrappers.
If the base kernel is 3.10 or higher (the current version) then
don't change anything at all.
If the base kernel is 2.6.33 or higher (with the new rfkill API)
then just wrap the API and disable rfkill registrations for any
types that the base kernel doesn't know about.
For all other kernels, provide only static inlines that behave
like the rfkill API when rfkill isn't compiled in.
The downside is that we need to copy the rfkill API. This is,
however, very very stable (it essentially hasn't changed since
2.6.33), so that's not a problem.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m44.234s
user 813m54.992s
sys 126m44.115s
Commit b4f34d8d9 on next-20130419 added new bluetooth hidp
session-management helper, then commit 520518 also on
next-20130419 replaced the old management code with
the new one. Thanks to David Herrmann for his review and
his changes for this backport.
commit b4f34d8d9d26b2428fa7cf7c8f97690a297978e6
Author: David Herrmann <dh.herrmann@gmail.com>
Date: Sat Apr 6 20:28:46 2013 +0200
Bluetooth: hidp: add new session-management helpers
This is a rewrite of the HIDP session management. It implements HIDP as an
l2cap_user sub-module so we get proper notification when the underlying
connection goes away.
The helpers are not yet used but only added in this commit. The old
session management is still used and will be removed in a following patch.
The old session-management was flawed. Hotplugging is horribly broken and
we have no way of getting notified when the underlying connection goes
down. The whole idea of removing the HID/input sub-devices from within the
session itself is broken and suffers from major dead-locks. We never can
guarantee that the session can unregister itself as long as we use
synchronous shutdowns. This can only work with asynchronous shutdowns.
However, in this case we _must_ be able to unregister the session from the
outside as otherwise the l2cap_conn object might be unlinked before we
are.
The new session-management is based on l2cap_user. There is only one
way how to add a session and how to delete a session: "probe" and "remove"
callbacks from l2cap_user.
This guarantees that the session can be registered and unregistered at
_any_ time without any synchronous shutdown.
On the other hand, much work has been put into proper session-refcounting.
We can unregister/unlink the session only if we can guarantee that it will
stay alive. But for asynchronous shutdowns we never know when the last
user goes away so we must use proper ref-counting.
The old ->conn field has been renamed to ->hconn so we can reuse ->conn in
the new session management. No other existing HIDP code is modified.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 5205185d461d5902325e457ca80bd421127b7308
Date: Sat Apr 6 20:28:47 2013 +0200
Bluetooth: hidp: remove old session-management
We have the full new session-management now available so lets switch over
and remove all the old code. Few semantics changed, so we need to adjust
the sock.c callers a bit. But this mostly simplifies the logic.
As of next-20130419 the atl1.c driver uses
atl1_pm_ops directly instead of the ATL1_PM_OPS
macro. This fixes that hunk.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m38.595s
user 808m49.549s
sys 127m31.602s
This is no longer required thanks to commit cc5569f6
present on next-20130415.
commit cc5569f63ecb82965f3fe2fde5e60bf1689d107a
Author: Johannes Berg <johannes.berg@intel.com>
Date: Thu Apr 11 16:22:08 2013 +0200
ath5k: use more idiomatic tracing include style
Pretty much everywhere that uses a trace definition
header that's not in include/trace/events/ uses the
make system for the include path rather than putting
it into the sources, so do that in ath5k as well.
This came up during backporting work (where this is
required), but since all other drivers do it this
way upstream it seemed applicable.
These are now upstream thanks to commit 8e8d4ff0 on
next-20130415.
commit 8e8d4ff051672d4a2939e7d6925c4acd234b0220
Date: Thu Apr 11 16:15:28 2013 +0200
brcm80211: simplify makefiles
This came up during my backporting work but it seems
perfectly appropriate for the kernel as well.
Acked-by: Arend van Spriel <arend@broadcom.com>
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m38.751s
user 810m14.462s
sys 126m48.932s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m33.717s
user 809m9.794s
sys 125m18.510s
Some day we will use SmPL for this...
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ FAIL ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m33.959s
user 809m11.262s
sys 126m15.477s
[Luis says the "FAIL" was due to a test setup issue only]
This is no longer needed since now the compat headers
don't pre-include half the world any more.
New kernels do this, and some users rely on it.
This allows getting rid of the cfg80211 and ath6kl
patches to include it directly.
The files these patch already include the headers
that are patched in, so the patches are entirely
unnecessary.
This allows us to get rid of the mac80211.h patch to
include net/if_inet6.h to get that declaration. Newer
kernels implicitly declare the struct by using it for
a pointer in struct net_device.
This reverts commit 41a5d256482183aed7b863bc0bdbf95955cdf23b.
These still seem to be needed ... need to fix first.
All that should be handled by the new header files in
the backports, if not we need to fix those.
The type netdev_tx_t already gets a typedef to int on old
kernels, so the ifdef in bluetooth code isn't necessary.
netdev_attach_ops() will already set everything (to NULL unless
the driver has the callback) so these patches aren't needed.
The network namespace support was ifdef'ed out for
kernels < 2.6.24, but we don't support those any
more so remove the patches.
There's no need to have those patches as struct device_type,
with its name field, has been available since kernel 2.6.22.
We can thus make the macro SET_NETDEV_DEVTYPE() an inline
instead (to avoid "unused variable" warnings) and thus get
rid of the patches for it.
We'll resolve all the other compat-*.h files next.
To keep it compiling, we now also need to remove all
the pr_fmt patches (they add printk.h which can't be
included as the first header file any more.)
I attempted to simply not include anything from the
command line, but very old kernels (e.g. 2.6.24)
don't include kconfig.h from the command line but
include/linux/autoconf.h directly, and thus won't
get our override. Thus we need to keep a very small
backport.h.
For some reason the tracing on older kernels requires
the tracing to be declared before it's defined; it's
broken when the trace header is only included to create
the tracepoints.
Since new kernels don't, add patches for the two places
that rely on the new behaviour.
Apparently I missed this during the conversion to the new
copy-list etc. The rndis_wlan driver requires some usbnet
and rndis code, if that's not present then it is either
not selectable or can be compiled but won't link against
older kernels that don't have the right requirements (or
don't have the symbols exported.)
For now, because the makefile parser is stupid, patch out
the asix driver objects because otherwise it's possible
to select it and fail the build. Improving the parser is
possible but I need to finish other things first.
The Linux kernel uses srctree to help prefix header files
and scripts. When backporting we want to be able to override
driver's Makefiles' usage of srctree with our own. Since we
can't easily and sanely override the srctree itself without
causing a lot of issues just use the python generator to
do the change for us on the target Makefiles. This addresses
the srctree usage case and where ccflags was used without
prefixing any parent directory when used with drivers, the
kernel tends to fix that with addtree command.
[also remove now unnecessary patches]
There's no way to build wireless extensions out of tree,
remove the Kconfig support for them entirely.
It's not efficient to have a large number of patches,
but necessary to split patches per driver or subsystem
to allow copying only parts. I had split them per file
as that was easy to generate, now combine a few again
and move some into the higher directory level.
Also combine some that would otherwise have
the same names (where .c and .h files with
the same name exist)
With the previous two patches, next-20130404 passes ckmake --allyesconfig.
The patches were last refreshed against that same tree,
so the only change is that now we have -p in there, which
results in changes like this (only):
-@@ -1593,7 +1593,7 @@
+@@ -1593,7 +1593,7 @@ static int nl80211_dump_wiphy(struct sk_
This makes the patches more readable.
The recent kconfig shuffle broke this.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
The simple parser doesn't understand the variable
indirection (yet) and right now it's simpler and
faster to patch the makefiles rather than improve
the parser.
Also need to rename it in the patch.
They can be named after the C files they apply to,
but they should still be named .patch.
These are causing issues and it seems like the
current approach should work even without them.
This splits all patches into per-file patches. I've added the little
tool I wrote as well (but it's hard to use).
