1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit: ba0cdc6fb4891c9efc91f627698c8203583f0e52
This adapts the changes from:
commit 60e453a940ac678565b6641d65f8c18541bb9f28
Author: Ming Lei <ming.lei@canonical.com>
Date: Mon Sep 23 20:59:35 2013 +0800
USBNET: fix handling padding packet
== ckmake-report.log ==
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
The newly created function ends with _compat. This causes compile
warnings and probably runtime problems on kernel < 2.6.29.
addr_assign_type was added with kernel 2.6.36. This is just used to
inform userspace, so removing it is no problem.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Maintaining the DRM driver takes a lot of recourses as there they are
depending on many API changes done to the core kernel code and
currently we do not have that many recourses to follow them. On the
other side one needs also new userspace drivers to make use of the new
features added to the DRM kernel drivers and it is not easy to update
the X drivers. Therefore we came to the conclusion to remove the drm
drivers for now.
There were also some problems with some DRM drivers, like the Intel
i915 driver caused kernel panic on some systems and was probably only
usable on some very recent kernel versions.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
MSR_RAPL_POWER_UNIT is not available on older kernel versions.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.89 [ OK ]
17 3.1.10 [ OK ]
18 3.10.5 [ OK ]
19 3.11-rc4 [ OK ]
20 3.2.50 [ OK ]
21 3.3.8 [ OK ]
22 3.4.56 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.11 [ OK ]
the usb net driver now uses the dma sg api which is not available on
old kernels, this patch removed the usage of the dma sg api for old
kernel versions.
This backports the following upstream commit:
commit 638c5115a794981441246fa8fa5d95c1875af5ba
Date: Thu Aug 8 21:48:24 2013 +0800
USBNET: support DMA SG
Usage of a new led api was introduced in mac80211, this patch make
backports use the old api on older kernel versions. This could cause a
problem with the led, the transmit led could stay on if nothing is
transfered.
commit e47f2509e5f182f4df144406de6f2bc78179d57e
Author: Fabio Baltieri <fabio.baltieri@gmail.com>
Date: Thu Jul 25 12:00:26 2013 +0200
mac80211: use oneshot blink API for LED triggers
In this upstream commit a new usage of portid was introduced:
commit ac22ac466a659f1b2e02a2e2ee23fc5c42da2c95
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Wed Jul 24 18:10:50 2013 +0200
NFC: Add a GET_SE netlink API
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.89 [ OK ]
17 3.1.10 [ OK ]
18 3.10.5 [ OK ]
19 3.11-rc4 [ OK ]
20 3.2.50 [ OK ]
21 3.3.8 [ OK ]
22 3.4.56 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.11 [ OK ]
The intel i915 drm driver uses the declarations from intel-gtt.h to
interact with drivers/char/agp/intel-gtt.c which is not
backported by backports project. To prevent some strange problems when
using i915, use the headers from the kernel and do not use our own. This
causes some compile problems which where runtime problems before and
bumps the minimal kernel version to 3.7.
This i915 still crash on my device with kernel 3.7.
For some reason some other changes were picked up again now.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.79 [ OK ]
17 3.1.10 [ OK ]
18 3.10-rc1 [ OK ]
19 3.2.45 [ OK ]
20 3.3.8 [ OK ]
21 3.4.46 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.13 [ OK ]
26 3.9.3 [ OK ]
real 34m47.737s
user 937m23.708s
sys 129m50.928s
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Since we don't support kernels before 2.6.24 anymore
there's no need to carry this patch.
By requiring 2.6.25 we can get rid of quite a lot of backport work.
2.6.25 was released more than five years ago (April 2011) and wasn't
a long-term kernel either, so there's little point in supporting it
now.
This was causing conflicts again when updating against
wireless-next, so instead of adjusting the patches just
provide a proper static inline backport.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.89 [ OK ]
18 3.1.10 [ OK ]
19 3.10.5 [ OK ]
20 3.11-rc4 [ OK ]
21 3.2.50 [ OK ]
22 3.3.8 [ OK ]
23 3.4.56 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.89 [ OK ]
18 3.1.10 [ OK ]
19 3.10.5 [ OK ]
20 3.11-rc4 [ OK ]
21 3.2.50 [ OK ]
22 3.3.8 [ OK ]
23 3.4.56 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
This patch makes mwifiex use the old suspend resume functions on older
kernels.
wil6210 now uses netdev->hw_features which is not available in all
kernel versions, do not set it then.
Older kernel versions do not support the new sysfs api with dev_groups.
This makes net/wireless/sysfs.c use the old api on older kernels.
This is a backport of this commit:
commit f0bc99c84349ce87af5b35839d19bfb17bb9b27f
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Date: Wed Jul 24 15:05:35 2013 -0700
net: wireless: convert class code to use dev_groups
This was mostly done by Johannes Berg <johannes@sipsolutions.net>.
Cc: Johannes Berg <johannes@sipsolutions.net>
Also, update the dependencies:
cw1200_wlan_sdio needs >=2.6.34 due to missing sdio_set_host_pm_flags()
cw1200_wlan_spi needs >=2.6.35 due to missing request_any_context_irq()
Signed-off-by: Solomon Peachy <pizza@shaftnet.org>
The new workqueue APIs in 2.6.36 allowed us to scrap the old kthread worker
that had been used; unfortunately the backported API isn't complete so
in order to support older kernels, resurrect this patch.
Without this patch, the hardware *will* hang on <3.2 kernels when a
512-byte SDIO transfer occurs.
3.2-rc added an SDIO quirk to work around this, so this code was
stripped from the driver when committed to the mainline.
Add cdc_mbim, cdc_ncm, sierra_net, qmi_wwan device drivers.
Signed-off-by: Patrick Ziegler <patrick.ziegler@fh-kl.de>
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.89 [ OK ]
18 3.1.10 [ OK ]
19 3.10.5 [ OK ]
20 3.11-rc4 [ OK ]
21 3.2.50 [ OK ]
22 3.3.8 [ OK ]
23 3.4.56 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Change the conditions to use the backported code also in 3.11
The old patch changed the or condition to an and condition which is
wrong. This patch fixes the logic again.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 34m34.417s
user 933m25.264s
sys 129m41.580s
A hunk context was off for alx.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
real 32m59.877s
user 880m31.524s
sys 124m11.996s
swiotlb_nr_tbl() was available since 3.2 but was exported since 3.3.
Since it uses an internal global state variable, it is impossible
to backport it to. Instead of reverting the changes added just
let this return 0 as the code will not do anything. This simplifies
the backport.
This backports the new upstream alx driver and
properly splits up each required backports into
its respective collateral evolution bucket.
The alx driver was upstreamed by Johannes, so this is
no longer required. Note that this driver is now GPLv2
or later, BSD folks will have to look at the old unified
tree for a permissive licensed port.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
This adds the ieee802154 subsystem.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
This includes the trace.h file like it is done for the other drivers.
The shrinkers api changed a little in the last version, this patch
makes the patches apply again.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.79 [ OK ]
18 3.1.10 [ OK ]
19 3.10-rc1 [ OK ]
20 3.2.45 [ OK ]
21 3.3.8 [ OK ]
22 3.4.46 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.3 [ OK ]
