path: root/patches/collateral-evolutions
2014-07-28backports: refresh on next-20140725backports-20140725Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.60 [ OK ] 4 3.3.8 [ OK ] 5 3.4.93 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.43 [ OK ] 12 3.11.10 [ OK ] 13 3.12.22 [ OK ] 14 3.13.11 [ OK ] 15 3.14.7 [ OK ] 16 3.15.0 [ OK ] 17 3.16-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-07-27backports: add missing linux/mm.h to airspyHauke Mehrtens
Without this patch I get the following error message when compiling against kernel 3.2, all other kernel versions work: 3.2.60/drivers/media/usb/airspy/airspy.c: In function ‘airspy_queue_setup’: 3.2.60/drivers/media/usb/airspy/airspy.c:506:2: error: implicit declaration of function ‘PAGE_ALIGN’ [-Werror=implicit-function-declaration] sizes[0] = PAGE_ALIGN(s->buffersize); Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-07-27backports: do not use dma_buf_vmap() on kernel < 3.5Hauke Mehrtens
The dma function dma_buf_vmap() is not available on kernel < 3.5, remove the call from the media subsystem code. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-07-27backports: revert commit for mwifiex sido.Hauke Mehrtens
Revert this commit on kernel version < 3.7 mwifiex: card reset: enable rescan of non-removable card mmc_rescan will scan for non-removable cards only once, hence the card will not be rediscovered. Signed-off-by: Andreas Fenkart <afenkart@gmail.com> Acked-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-07-23backports: refresh patches on next-20140710backports-20140710Hauke Mehrtens
2014-07-23backports: add some ubuntu trusty specific changesHauke Mehrtens
It is now possible to detect a ubuntu kernel see: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1327619 This uses the new define and adds some code depending on the ubuntu trusty kernel. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-17backports: refresh patches on next-20140616Hauke Mehrtens
== ckmake-report.log == 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.60 [ OK ] 4 3.3.8 [ OK ] 5 3.4.93 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.43 [ OK ] 12 3.11.10 [ OK ] 13 3.12.22 [ OK ] 14 3.13.11 [ OK ] 15 3.14.7 [ OK ] 16 3.15.0 [ OK ] 17 3.16-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: refresh patches on next-20140606backports-20140606Hauke Mehrtens
There were manual changes ineeded in the following files: patches/collateral-evolutions/network/0034-ndo_set_vf_spoofchk/igb_ndo_set_vf_spoofchk.patch patches/collateral-evolutions/network/0037-ethtool_get_module/igb_get_module.patch patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.59 [ OK ] 4 3.3.8 [ OK ] 5 3.4.91 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.40 [ OK ] 12 3.11.10 [ OK ] 13 3.12.20 [ OK ] 14 3.13.11 [ OK ] 15 3.14.4 [ OK ] 16 3.15-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove useless git patch headerHauke Mehrtens
When exporting a patch from git it adds a header to it, but this header is not needed by backports, remove it from the patches. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove const from pci error handlers on kernel < 3.7Hauke Mehrtens
This fixes a warning on these older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: do not access user_ns on struct netHauke Mehrtens
The ieee802154 subsystem wants to access user_ns on struct net, but this member was added in kernel 3.8, check the general capabilities instead. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: handle rename of ndo_set_vf_tx_rate to ndo_set_vf_rateHauke Mehrtens
This member of struct net_device_ops was renamed and the function signature was also changed a bit. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: remove usage of get_ts_info in cdc_ncm.cHauke Mehrtens
2014-06-16backport: update drivers_net_wireless_iwlwifi_iwl-debug.patchEmmanuel Grumbach
The driver was updated - need to update the patch accordingly commit 7f715626a9ddfa7df13f076f59fc62e3c99066cf Author: Liad Kaufman <liad.kaufman@intel.com> Date: Thu May 8 15:24:54 2014 +0300 iwlwifi: use dev_printk instead of dev_dbg for debug logs Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-16backports: fix a compile warning in devnodeHauke Mehrtens
The mode parameter type was changed in the callback function devnode in struct device_type. commit 2c9ede55ecec58099b72e4bb8eab719f32f72c31 Author: Al Viro <viro@zeniv.linux.org.uk> Date: Sat Jul 23 20:24:48 2011 -0400 switch device_get_devnode() and ->devnode() to umode_t * Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-15backports: disable DMA shared buffer support for kernel < 3.5 in v4l2Hauke Mehrtens
v4l2 uses the DMA shared buffers API of kernel >= 3.5. When the v4l2 backport is be compiled against older kernel versions a backport of the DMA shared buffers is used. Instead of using this backport this patch will remove usage of the DMA shared buffers on these old kernel versions. This allows us to remove DMA shared buffers from backports. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-08backports: refresh patches on next-20140516backports-20140516Hauke Mehrtens
== ckmake-report.log == 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.59 [ OK ] 4 3.3.8 [ OK ] 5 3.4.91 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.40 [ OK ] 12 3.11.10 [ OK ] 13 3.12.20 [ OK ] 14 3.13.11 [ OK ] 15 3.14.4 [ OK ] 16 3.15-rc7 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-07backports: handle changes to vlan_rx_add/kill pointers in cdc_mbim.cHauke Mehrtens
These callback pointers are now also used in cdc_mbim.c Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-07backports: fix class/bus attribute group spatch conversionJohannes Berg
The spatch conversion (commit 05d44557c6a83b4ecb935cb6306f62, "backports: transform group attribute backport to SmPL form") added an #ifdef that shouldn't be there - remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: refresh patches on next-20140501Hauke Mehrtens
2014-06-02backports: remove unused functions from bluetoothHauke Mehrtens
hidp_set_raw_report() and hidp_output_report() are not used with kernel < 3.15. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: add patch to prevent section mismatch againHauke Mehrtens
This patch was removed in: commit be4a0f9ad7e17670d7a30c9e94d5dd918425f90a Author: Luis R. Rodriguez <mcgrof@do-not-panic.com> Date: Fri Apr 11 01:45:20 2014 +0000 backports: nuke support for kernels < 3.0 It is still needed for some still supported kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: select_queue patch: fix callback kernel versionHauke Mehrtens
The patch changing the callback function signature was backported to kernel 3.14, this was already fixed in backports for mac80211, but that commit missed mwifiex. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle pci_error_handlers change to constStefan Assmann
In kernel 3.7 struct pci_driver changed pci_error_handlers to const. Address this by putting ifdef around the code. commit 494530284f16298050ab99f54b7b12dd7d1418a1 Author: Stephen Hemminger <shemminger@vyatta.com> Date: Fri Sep 7 09:33:14 2012 -0700 PCI: Make pci_error_handlers const git describe --contains 494530284f16298050ab99f54b7b12dd7d1418a1 v3.7-rc1~177^2~9^2~3 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle hwmon_device_register_with_groups API callsStefan Assmann
The new hwmon_device_register_with_groups API has not been backported yet. Address this by putting ifdef around the code using the API. commit 74188cba088192e14cd7fd5433876e8c947bcdd8 Author: Guenter Roeck <linux@roeck-us.net> Date: Thu Jul 11 20:00:12 2013 -0700 hwmon: Provide managed hwmon registration git describe --contains 74188cba088192e14cd7fd5433876e8c947bcdd8 v3.13-rc1~126^2~30 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle struct ethtool_cmd MDI changesStefan Assmann
In kernel 3.7 struct ethtool_cmd received eth_tp_mdix and eth_tp_mdix_ctrl. Address this by putting ifdef around the code using these struct components. commit 6f6bbc186dc8e4e0c628db7decbd1a5e02cb5fd8 Author: Jesse Brandeburg <jesse.brandeburg@intel.com> Date: Thu Jul 26 02:30:53 2012 +0000 ethtool.h: MDI setting support git describe --contains 6f6bbc186dc8e4e0c628db7decbd1a5e02cb5fd8 v3.7-rc1~145^2~300^2~5 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle argument type change of get_rxnfc in struct ethtool_opsStefan Assmann
In kernel 3.2 an argument type of function pointer get_rxnfc in struct ethtool_ops changed from void to u32. Address this by putting ifdef around the code. commit 815c7db5c809ea3d5735de3131ecdf758b0e14ff Author: Ben Hutchings <bhutchings@solarflare.com> Date: Tue Sep 6 13:49:12 2011 +0000 ethtool: Clean up definitions of rule location arrays in RX NFC git describe --contains 815c7db5c809ea3d5735de3131ecdf758b0e14ff v3.2-rc1~129^2~272 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle new rxfh_ndir pointers in struct ethtool_opsStefan Assmann
In kernel 3.3 struct ethtool_ops received 3 new function pointers get_rxfh_indir_size, get_rxfh_indir, set_rxfh_indir. Address this by putting ifdef around the code. commit 7850f63f1620512631445b901ae11cd149e7375c Author: Ben Hutchings <bhutchings@solarflare.com> Date: Thu Dec 15 13:55:01 2011 +0000 ethtool: Centralise validation of ETHTOOL_{G, S}RXFHINDIR parameters git describe --contains 7850f63f1620512631445b901ae11cd149e7375c v3.3-rc1~182^2~192 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle new get_module_info and get_module_eeprom pointers in ↵Stefan Assmann
struct ethtool_ops In kernel 3.5 struct ethtool_ops received 2 new function pointers get_module_info and get_module_eeprom. Address this by putting ifdef around the code. commit 41c3cb6d20f0252308e9796fa4f3dacb4960de91 Author: Stuart Hodgson <smhodgson@solarflare.com> Date: Thu Apr 19 09:44:42 2012 +0100 ethtool: Extend the ethtool API to obtain plugin module eeprom data git describe --contains 41c3cb6d20f0252308e9796fa4f3dacb4960de91 v3.5-rc1~109^2~124^2~2 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle new get_ts_info pointer in struct ethtool_opsStefan Assmann
In kernel 3.5 struct ethtool_ops received a new function pointer get_ts_info. Address this by putting ifdef around the code. commit c8f3a8c31069137fe0100e6920558f1a7487ef3c Author: Richard Cochran <richardcochran@gmail.com> Date: Tue Apr 3 22:59:17 2012 +0000 ethtool: Introduce a method for getting time stamping capabilities. git describe --contains c8f3a8c31069137fe0100e6920558f1a7487ef3c v3.5-rc1~109^2~632 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle new get_eee and set_eee pointers in struct ethtool_opsStefan Assmann
In kernel 3.6 struct ethtool_ops received 2 new function pointers get_eee and set_eee. Address this by putting ifdef around the code. commit 80f12eccce775dc6bb93dba9b52529740f929237 Author: Yuval Mintz <yuvalmin@broadcom.com> Date: Wed Jun 6 17:13:06 2012 +0000 Added kernel support in EEE Ethtool commands git describe --contains 80f12eccce775dc6bb93dba9b52529740f929237 v3.6-rc1~125^2~587 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle no_fcs change in struct sk_buffStefan Assmann
In kernel 3.4 a new field no_fcs was introduced to struct sk_buff. Address this by putting ifdef around the code. commit 3bdc0eba0b8b47797f4a76e377dd8360f317450f Author: Ben Greear <greearb@candelatech.com> Date: Sat Feb 11 15:39:30 2012 +0000 net: Add framework to allow sending packets with customized CRC. git describe --contains 3bdc0eba0b8b47797f4a76e377dd8360f317450f v3.4-rc1~177^2~207 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle new ndo_set_vf_spoofchk pointer in struct net_device_opsStefan Assmann
In kernel 3.2 struct net_device_ops got a new function pointer ndo_set_vf_spoofchk. Address this by putting ifdef around the code. commit 5f8444a3fa617076f8da51a3e8ecce01a5d7f738 Author: Greg Rose <gregory.v.rose@intel.com> Date: Sat Oct 8 03:05:24 2011 +0000 if_link: Add additional parameter to IFLA_VF_INFO for spoof checking git describe --contains 5f8444a3fa617076f8da51a3e8ecce01a5d7f738 v3.2-rc1~129^2~87 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle changes to vlan_rx_add/kill pointers in struct net_device_opsStefan Assmann
In kernel 3.3 and 3.10 struct net_device_ops function pointers ndo_vlan_rx_add_vid and ndo_vlan_rx_kill_vid changed. Address this by putting ifdef around the code. commit 8e586137e6b63af1e881b328466ab5ffbe562510 Author: Jiri Pirko <jpirko@redhat.com> Date: Thu Dec 8 19:52:37 2011 -0500 net: make vlan ndo_vlan_rx_[add/kill]_vid return error value git describe --contains 8e586137e6b63af1e881b328466ab5ffbe562510 v3.3-rc1~182^2~291 commit 80d5c3689b886308247da295a228a54df49a44f6 Author: Patrick McHardy <kaber@trash.net> Date: Fri Apr 19 02:04:28 2013 +0000 net: vlan: prepare for 802.1ad VLAN filtering offload git describe --contains 80d5c3689b886308247da295a228a54df49a44f6 v3.10-rc1~66^2~97^2~4 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: handle new sriov_configure pointer in struct pci_driverStefan Assmann
In kernel 3.8 struct pci_driver got a new function pointer sriov_configure. Address this by putting ifdef around the code. commit 1789382a72a537447d65ea4131d8bcc1ad85ce7b Author: Donald Dutile <ddutile@redhat.com> Date: Mon Nov 5 15:20:36 2012 -0500 PCI: SRIOV control and status via sysfs git describe --contains 1789382a72a537447d65ea4131d8bcc1ad85ce7b v3.8-rc1~128^2~6^2~4 Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01backports: select_queue patch: fix callback kernel versionJohannes Berg
The callback argument has been passed since kernel 3.14, not only 3.15 - fix that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: formalize struct sock sk_data_ready() backport with SmPLLuis R. Rodriguez
Commit 676d2369 by David removed the skb->len arguments passed onto the struct sock sk_data_ready() callback. This was done as its racy, a few drivers were passing 0 to it, and it was not really used. By removing it the raciness is addresed but to backport this we are going to have to deal with the races as-is on older kernels. This was merged as of v3.15: mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 676d2369 v3.15-rc1~8^2~10 Since this is not a define or static inline we can't easily replace this with the backports module or header files, instead we use SmPL grammar to generalize the backport for all use cases. Note that in order to backport this we won't know what older kernel drivers were using before this change, it could have been 0 or skb->len for the length parameter, since we have to infer something we choose skb->len *iff* skb_queue_tail() was used right before it, otherwise we infer to throw 0. Adding this SmPL patch to our series only incurs an additional ~9 seconds on run time code generation. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140415-clean Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m25.128s user 12m49.380s sys 0m44.892s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 18m42.577s user 498m48.572s sys 64m0.560s commit 676d23690fb62b5d51ba5d659935e9f7d9da9f8e Author: David S. Miller <davem@davemloft.net> Date: Fri Apr 11 16:15:36 2014 -0400 net: Fix use after free by removing length arg from sk_data_ready callbacks. Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: transform group attribute backport to SmPL formLuis R. Rodriguez
The struct attribute_group collateral evolution by Greg and Oliver was introduced as of v3.11: mcgrof@ergon ~/linux (git::master)$ git describe --contains f2f37f58b v3.11-rc2~18^2~9 mcgrof@ergon ~/linux (git::master)$ git describe --contains 3493f69f4 v3.11-rc2~18^2~2 We backport them with our own respective set of helpers. Each new data structure that gets an attribute group needs a respective SmPL set of rules for the transformation, specially if they were introduced in different kernel versions, which in this case we have two which were. By using SmPL we can automatically backport the collateral evolutions moving forward for *any* driver that makes use of these group attributes on both data structure we are addressing in these SmPL patches. This is a great example of the level of atomicity that we want to ideally strive to reach for backporting, as it lets us automatically backport a collateral evolution through grammer for *any* device driver we backport, and lets us be lazier. We provided backports of introduction of the group attribute onto two data structures: * struct class: added via commit d05a6f96c * struct bus_type: added via commit fa6fdb33b mcgrof@ergon ~/linux (git::master)$ git describe --contains d05a6f96c v3.11-rc2~18^2~3 mcgrof@ergon ~/linux (git::master)$ git describe --contains fa6fdb33b v3.12-rc1~184^2~89 This patch generalizes the backport the introduction of the group attribute to each data structure into separate SmPL patch files. One change the SmPL patches pick up on was #ifdef'ing over the init_foogroup_attrs() calls which would only have been introduced when ATTRIBUTE_GROUPS_BACKPORT() was used, which *is* #idefd's. The changes that added the new APIs are below, the respective commits for each data structure change are documented on each SmPL patch. commit f2f37f58b1b933b06d6d84e80a31a1b500fb0db2 Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Date: Sun Jul 14 16:05:52 2013 -0700 sysfs.h: add ATTRIBUTE_GROUPS() macro To make it easier for driver subsystems to work with attribute groups, create the ATTRIBUTE_GROUPS macro to remove some of the repetitive typing for the most common use for attribute groups. Reviewed-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> commit 3493f69f4c4e8703961919a9a56c2d2e6a25b46f Author: Oliver Schinagl <oliver@schinagl.nl> Date: Sun Jul 14 16:05:59 2013 -0700 sysfs: add more helper macro's for (bin_)attribute(_groups) With the recent changes to sysfs there's various helper macro's. However there's no RW, RO BIN_ helper macro's. This patch adds them. Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> mcgrof@drvbp1 ~/backports (git::master)$ time \ ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m14.635s user 5m17.308s sys 0m39.216s == ckmake-report.log == 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 28m18.533s user 785m28.844s sys 86m25.548s Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Oliver Schinagl <oliver@schinagl.nl> Cc: linux-kernel@vger.kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: refresh patches for next-20140409 and next-20140411Luis R. Rodriguez
We were required to refresh patches for next-20140409 but for next-20140411 no changes were required. Since no actual commit is necessary next time this happens (which can often, hence -- automatic backports --) I'll just peg the results on the PGP signed tag for the release. I'll peg this commit with both next tags because of this. Just run git describe to find out the respective linux-next tag you should be using as that is the latest validated one. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh \ /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140411 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.437s user 9m22.812s sys 0m24.484s 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 28m21.215s user 786m8.468s sys 86m46.564s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: refresh patches for next-20140320backports-20140320Luis R. Rodriguez
The wil6210 driver gets NETIF_F_GRO but not that we haven't been backporting this feature, which was added as of v2.6.29 via commit d565b0a1a. The driver is only enabled on the dependencies file down to 2.6.31 though so we simply reuse the check against kernels >= 2.6.39 to use the netdev->hw_features. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains d565b0a1a v2.6.29-rc1~581^2~181 mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140320 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m59.391s user 19m26.468s sys 0m45.128s mcgrof@drvbp1 ~/build/next-20140320 $ time ckmake --allyesconfig 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.79 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.29 [ OK ] 27 3.11.10 [ OK ] 28 3.12.10 [ OK ] 29 3.13.2 [ OK ] 30 3.14-rc1 [ OK ] real 36m11.856s user 994m29.360s sys 124m49.936s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: enhance 0001-netdev_ops.cocci with data structure specificsLuis R. Rodriguez
The 0001-netdev_ops.cocci is fine but is uses Expression which makes the interpretation loose. We can reduce the namespace of the change by using struct. We have to keep expression on the right hand side as that can even be macros. For a full example test coverage of this change see the test netdev-ops github tree and run: make test1 git checkout -f make test2 The benefits should be clear, we are *not* modifying data structures that have similar names. This increases accuracy and security of our changes. The added run time penalty however is 50 seconds since we had to use --recursive-includes. The time penatly is worth it for the accuracy provided and since we'll likley need this flag elsewhere for other rules. mcgrof@drvbp1 ~/backports (git::master)$ time \ ./gentree.py --clean --refresh \ /home/mcgrof/linux-next \ /home/mcgrof/build/next-20140311 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m56.339s user 19m31.428s sys 0m50.100s 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.79 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.29 [ OK ] 27 3.11.10 [ OK ] 28 3.12.10 [ OK ] 29 3.13.2 [ OK ] 30 3.14-rc1 [ OK ] [0] https://github.com/mcgrof/netdev-ops Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: convert threaded IRQ suport into an SmPL patchLuis R. Rodriguez
We leave two patches under the 09-threaded-irq series, but there are six things worth mentioning on this commit that are important. I'll clarify that this SmPL port is simply done as a proof of concept on testing the complexity of a backport for with Coccinelle, this backport is only relevant for kernels older than 2.6.31 which at this point is ancient and we should probably stop caring for soon. 1) patches/collateral-evolutions/network/0015-threaded-irq.cocci We rename the collateral evolution backport from the 09-threaded-irq as this backport is now formalized and properly atomically split up. We use 4 digit prefixes for formalized and atomically split up collateral evolutions. The rest of the patch series that do not have 4 digits imply that those series could use some love to be formally split up atomically. 2) 0015-threaded-irq/ We keep a directory for backported collateral evolutions for either legacy backports without SmPL Coccinelle patches *or* for series that are addressed with SmPL but that had some shortcomings with Coccinelle that we are looking to address. Legacy backports also had an INFO file in its directory, we keep it around for now for this series as we have one legacy patch lingering around still but since Coccinelle lets us put comments on top and the series is for all drivers we can just rely on the comment section of an SmPL patch for this as patches get translated. 3) Rename of 09-threaded-irq/drivers_net_wireless_ti_wlcore_main_extra.patch to 0016-threaded-irq-one-shot.patch This patch is kept as it deals with driver specific IRQ changes which are completely unrelated to the 09-threaded-irq series but that we had tucked under in the older legacy backport. Because of this we make emphasis by moving out out under the series. This can be generalized as another backport series if other drivers wish to backport. This new seires backports commit b25c340c1 added by Thomas through kernel v2.6.32 which added support for IRQF_ONESHOT. This lets drivers that use threaded IRQ support to request that the IRQ is not masked after the hard interrupt handler as this requires device access in hard IRQ context and for buses such as i2c and spi this at times is not possible. Note that the TI driver uses this when a platform quirk with WL12XX_PLATFORM_QUIRK_EDGE_IRQ is detected. In retrospect this quirk does not seem backportable unless IRQF_ONESHOT is really not a requirement, but desired. If WL12XX_PLATFORM_QUIRK_EDGE_IRQ is indeed a requirement for IRQF_ONESHOT then we should not probe complete. Its unclear if this is a universal thing or not. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains b25c340c1 v2.6.32-rc1~722^2~3 4) 0015-threaded-irq/drivers_net_wireless_iwlwifi_iwl-trans.patch A data structure change to struct iwl_trans is not being done by Coccinelle given that the driver's Makefile for iwlwifi uses this for its includes: ccflags-y += -D__CHECK_ENDIAN__ -I$(src) Coccinelle doesn't pick up on this even if we use --recursive-includes. This issue has been reported. An interesting thing about this is that struct iwl_trans was *not* used before this patch which is why you see the removal of the file drivers_net_wireless_iwlwifi_pcie_internal.patch and as a replacement have added drivers_net_wireless_iwlwifi_iwl-trans.patch. What happened is Coccinelle is consistent and the change, as expressed in grammar, which reveleas that we were *not* consistent with our manual backport! The older backport still worked though as it did not really matter what data structure got changed so long as its an internal data structure. This also means this backport could be modified to use a generic backport data structure, which we don't yet have but could be a good idea to stuff in general backport data structure extensions, which we typically have not been able to address through backports unless we use #ifdef's. This would however require some sort of driver specific backport_device_alloc(), backport_device_init() and a respective backport_device_free(). The overhead would need to be considered unless some fancy trickery is introduced. Since 09-threaded-irq is a backport for kernels >= 2.6.31 I don't recommend we consider this now. The effort for using SmPL for this series was done simply as a way to demonstrate the power of Coccinelle. 5) Space fixes for extra code on Coccinelle modified branches: This SmPL patch does some space modifications on the wil6210 [0], the reason could be that Coccinelle is introducing some code on a branch and when it detects this it puts the code it is adding with braces. This is another great feature of Coccinelle but the space fixes that Julia has completed may not be treated in that situation yet. 6) This requires at least spatch 1.0.0-rc20. [0] hunk in question shown below: @@ -499,11 +518,21 @@ int wil6210_init_irq(struct wil6210_priv *wil, int irq) int rc; if (wil->n_msi == 3) rc = wil6210_request_3msi(wil, irq); - else + else { +#if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,31) rc = request_threaded_irq(irq, wil6210_hardirq, - wil6210_thread_irq, - wil->n_msi ? 0 : IRQF_SHARED, - WIL_NAME, wil); + wil6210_thread_irq, + wil->n_msi ? 0 : IRQF_SHARED, + WIL_NAME, wil); +#else + rc = compat_request_threaded_irq(&wil->irq_compat, irq, + wil6210_hardirq, + wil6210_thread_irq, + wil->n_msi ? 0 : IRQF_SHARED, + WIL_NAME, + wil); +#endif + } if (rc) return rc; Code generation time: real 1m6.023s user 10m0.276s sys 0m26.196s $ time ckmake --allyesconfig 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.79 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.29 [ OK ] 27 3.11.10 [ OK ] 28 3.12.10 [ OK ] 29 3.13.2 [ OK ] 30 3.14-rc1 [ OK ] real 41m12.052s user 1125m30.996s sys 151m39.096s Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: backports: reshufle the threaded IRQ backport seriesLuis R. Rodriguez
This reshufles the patches that deal with backported threaded IRQ support. The purpose of this reshufle is to try get them into a consistent style. Only the b43 driver takes a major change in that the the workqueue used for threading work is now also destroyed upon its b43_wireless_core_stop() call. This change was tested by pkgadd from #linux-wireless on b43 on an older kernel. The b43 driver just fails to unload but that issue was present before this change. The non-general changes to the b43 driver are also moved out to a helper patch to help separate the general collateral evolution changes from driver specific required changes. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: refresh patches based on next-20140311backports-20140311Luis R. Rodriguez
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.79 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.29 [ OK ] 27 3.11.10 [ OK ] 28 3.12.10 [ OK ] 29 3.13.2 [ OK ] 30 3.14-rc1 [ OK ] Generation time: real 1m32.523s user 23m51.796s sys 0m28.872s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: backport ieee802154 6lowpan support down to 3.5Luis R. Rodriguez
Commit 633fc86ff62 added the ieee802154_6lowpan namespace and 7240cdec60b extended it (as on linux-next next-20140311). Its important to note though that 633fc86ff62 also extends the global net namespace. Since we cannot extend the global net namespace we define our own backport namespace for 6lowpan that can be used only be used by our backported subsystems, nothing more. Since ieee802154_6lowpan requires support for net_get_random_once() which uses static keys and a slew of new skb fragment support we simply require at least 3.5 to use 6lowpan. I did my best effort to backport this to kernels older than 3.5 but quickly ran into a slew of hairy issues. The last thing we needed to address was usage of the helper inet_frag_evictor() added by Alexander via commit 6b102865e7 through v3.7. Since we can't backport that with macros or inline helpers we add a patch to carry the changes there. If that grows we can consider using Coccinelle. If you are going to try to backport 6lowpan to kernels older than 3.5 be warned that the litmus test for patches will be to pass ckmake --allyesconfig for all supported kernels for every patch you provide. Cc: Alexander Aring <alex.aring@gmail.com> Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: linux-zigbee-devel@lists.sourceforge.net Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: 6lowpan domain specific backport of inet_frag_lru_move()Luis R. Rodriguez
We can't generalize a backport of inet_frag_lru_move() as it requires modifying an internal struct netns_frags struct. We work around this by extending the parent struct used within 6lowpan. We have two changes, one data structure change and then a domain specific defines. Other subsystems which require similar work can backport usage through similar techniques. The respective change upstream that put the lock on struct netns_frags is commit 3ef0eb0db4 added by through v3.9. mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 3ef0eb0db4 v3.9-rc1~139^2~232^2 commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206 Author: Jesper Dangaard Brouer <brouer@redhat.com> Date: Mon Jan 28 23:45:51 2013 +0000 net: frag, move LRU list maintenance outside of rwlock Updating the fragmentation queues LRU (Least-Recently-Used) list, required taking the hash writer lock. However, the LRU list isn't tied to the hash at all, so we can use a separate lock for it. Original-idea-by: Florian Westphal <fw@strlen.de> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: linux-zigbee-devel@lists.sourceforge.net Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-08backports: address move of 6lowpan.c to 6lowpan_rtnl.cLuis R. Rodriguez
Commit 01348b3448 moved 6lowpan.c to 6lowpan_rtnl.c which means we have to adjust the respective backport patches. commit 01348b34485eceace5d9ca9756ba40679cf22ac6 Author: Alexander Aring <alex.aring@gmail.com> Date: Fri Feb 28 07:32:47 2014 +0100 6lowpan: move 6lowpan.c to 6lowpan_rtnl.c We have a 6lowpan.c file and 6lowpan.ko file. To avoid confusing we should move 6lowpan.c to 6lowpan_rtnl.c. Then we can support multiple source files for 6lowpan module. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Alexander Aring <alex.aring@gmail.com> Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: linux-zigbee-devel@lists.sourceforge.net Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-02-24backports: refresh patches on next-20140221backports-20140221Hauke Mehrtens
manual changes were needed on these files: * patches/backport-adjustments/flow_dissector.patch * patches/collateral-evolutions/network/16-bluetooth/net_bluetooth_hidp_core.patch * patches/collateral-evolutions/network/83-select_queue/mac80211.patch * patches/collateral-evolutions/network/83-select_queue/mwifiex.patch * patches/collateral-evolutions/network/85-hid_ll_driver/net_bluetooth_hidp_core.patch 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.79 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.29 [ OK ] 27 3.11.10 [ OK ] 28 3.12.10 [ OK ] 29 3.13.2 [ OK ] 30 3.14-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-02-24backports: remove usage of net_device member qdisc_tx_busylockHauke Mehrtens
This member was added ion more recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
