1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc8 [ OK ]
manual changes done to:
patches/collateral-evolutions/media/0005-dma-no-sync/v4l2.patch
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
The media framework now uses the frame vector code which is only
available from kernel 4.2 onwards. This backports the code.
With kernel 3.12 a new locking was added to struct tty_struct. This
patch makes the code use the old locking.
The new locking was added in this commit:
commit 6a1c0680cf3ba94356ecd58833e1540c93472a57
Author: Peter Hurley <peter@hurleysoftware.com>
Date: Sat Jun 15 09:14:23 2013 -0400
tty: Convert termios_mutex to termios_rwsem
The file net/bluetooth/hci_ldisc.c contains references to tty->termios.
These changed from pointer to instance in 3.7.0. This patch backports
all references by introducing kernel version defines.
Signed-off-by: Florian Grandel <fgrandel@gmail.com>
Usage of the bt_tx_busylock variable was already patched but not the
declaration which caused a compile warning. This patch introduces a
define statement that also excludes the variable declaration.
Using expression is pretty flexible, in this case we
don't want that flexibility as it can override any
struct who also uses the same variable name. For a
specific example of the issue refer to the netdev-ops
demo git tree [0] which provide an example of the issue
with two SmPL rules.
We keep the expression on the last rule on NETLINK_CB(skb)
given that we know only an skb can possibly be used on it.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc8 [ OK ]
The failure on 4.1 is not related to this change,
its because we are using 4.1-rc1, it fails because of
the missing tty_set_termios() is not exported,
4.1-rc4 works.
[0] https://github.com/mcgrof/netdev-ops.git
Cc: cocci@systeme.lip6.fr
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ FAIL ]
Only kernel 4.1-rc1 will fail, because tty_set_termios() is not
exported, 4.1-rc4 works.
drivers/media/platform/vim2m.c
On kernel version < 3.4 we have to include linux/interrupt.h, because
it otherwise results in a long compile errors about missing HI_SOFTIRQ
for example.
The mt7601u driver makes use of __field_struct which was added in Linux
commit 4d4c9cc83. It is hard to backport this feature, so just remove
the code using it on kernel version < 3.16.
More v4l drivers are now accessing the vidioc_expbuf function pointer
in struct v4l2_ioctl_ops which we can not backport to kernel < 3.5.
This adds some more checks around the places.
We should convert this to an spatch.
The uuid member was added to the struct mei_cl_device_id in this commit:
commit c93b76b34b4d8dbe8e3443eb27e49ac60034342b
Author: Tomas Winkler <tomas.winkler@intel.com>
Date: Thu May 7 15:54:02 2015 +0300
mei: bus: report also uuid in module alias
This additional include is needed to prevent this error with kernel 3.10:
In file included from /home/hauke/compat-wireless/tmp/backport-include/linux/wait.h:3:0,
from include/linux/mmzone.h:9,
from include/linux/gfp.h:4,
from include/linux/kmod.h:22,
from include/linux/module.h:13,
from /home/hauke/compat-wireless/tmp/backport-include/linux/module.h:3,
from /home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c:21:
/home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c: In function ‘mei_nfc_send’:
include/linux/wait.h:296:33: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
prepare_to_wait(&wq, &__wait, TASK_INTERRUPTIBLE); \
On kernel 3.0 we have to include linux/interrupt.h, because it
otherwise results in a long compile errors about missing HI_SOFTIRQ for
example. It looks like it was not possible to activate tracing without
this patch on these drivers at all.
Commit 8e879bf1f in backports converted some bluetooth patches into an
spatch. There was a problem in this conversion, the second argument is
not struct socket, but struct sock. This causes some warnings in the
kernel build.
Cc: Luis R. Rodriguez <mcgrof@do-not-panic.com>
This refresh patches again after application of all pending
patches.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --verbose \
--refresh /home/mcgrof/linux-next /home/mcgrof/build/backports-20150525
real 3m25.658s
user 27m6.472s
sys 3m38.704s
mcgrof@drvbp1 ~/build/backports-20150525 $ time \
/home/mcgrof/backports/devel/ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
real 53m59.426s
user 1440m34.548s
sys 219m41.952s
This replaces the 436 line of unified diff with 152
lines of grammar Coccinelle SmPL patch. SmPL patch
equivalence proof tests reveals only cosmetic changes
between using Coccinelle SmPL and unified diff as shown
below. The difference shown are the results of two
trees, one in which we applied the SmPL patch, and another
in which the old unified patch series were used. This
gives us an idea of what Coccinelle did differently.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
mcgrof@ergon ~/backports (git::master)$ time \
./gentree.py --clean --prove-cocci \
patches/collateral-evolutions/network/0054-struct-proto_ops-sig.cocci \
/home/mcgrof/linux-next/ /home/mcgrof/build/backports-20150525
Copy original source files ...
Applying patches from patches to
/home/mcgrof/build/backports-20150525 ...
Proving Coccinelle SmPL patch: 0054-struct-proto_ops-sig.cocci
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: ieee802154.patch
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: nfc.patch
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: bluetooth.patch
Review the difference between what the tree looks like
by applying your SmPL patch, then reverting that and
only applying your the patches in the patch series.
Change directory to /home/mcgrof/build/backports-20150525 and run 'git diff'
diff stat of the changes:
net/bluetooth/hci_sock.c | 11 +++++------
1 file changed, 5 insertions(+), 6 deletions(-)
Done!
real 0m21.965s
user 0m45.947s
sys 0m4.072s
Now when I change directory to /home/mcgrof/build/backports-20150525 and
run 'git diff' I get:
diff --git a/net/bluetooth/hci_sock.c b/net/bluetooth/hci_sock.c
index 9326bc8..9ca0166 100644
--- a/net/bluetooth/hci_sock.c
+++ b/net/bluetooth/hci_sock.c
@@ -956,7 +956,8 @@ static int hci_sock_recvmsg(struct socket *sock,
struct msghdr *msg, size_t len,
#if LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0)
static int backport_hci_sock_recvmsg(struct kiocb *iocb, struct socket
*sock,
- int flags){
+ int flags)
return hci_sock_recvmsg(sock, msg, len, flags);
#endif /* LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) */
@@ -1198,7 +1199,8 @@ drop:
static int backport_hci_sock_sendmsg(struct kiocb *iocb, struct socket
*sock,
- struct msghdr *msg, size_t len){
+ struct msghdr *msg, size_t len)
return hci_sock_sendmsg(sock, msg, len);
@@ -1360,12 +1362,9 @@ static const struct proto_ops hci_sock_ops = {
.getname = hci_sock_getname,
#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0)
.sendmsg = hci_sock_sendmsg,
-#else
- .sendmsg = backport_hci_sock_sendmsg,
-#endif /* LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) */
-#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0)
.recvmsg = hci_sock_recvmsg,
#else
+ .sendmsg = backport_hci_sock_sendmsg,
.recvmsg = backport_hci_sock_recvmsg,
.ioctl = hci_sock_ioctl,
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
This modifies we backport the struct proto_ops and struct proto
declarations from adding #idefs around the function prototype
arguments to just declaring our own new backport callback for
older kernels with the extra argument which calls the the
upstream function. This is done because we cannot write an
SmPL grammar patch to backport the collateral evolution as we
do it now. The backport strategy we provide now is equivalent
in terms of functionality but also a lot more clear, it also
leaves the upstream code unmodified as much as possible, this
should enable anyone reviewing the code to be able to more
easily determine exactly what is going on.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
real 53m48.791s
user 1437m15.048s
sys 217m20.652s
Both bt_sock_recvmsg() and bt_sock_stream_recvmsg() are used
within bluetooth code but the backport actually required is only
for the struct proto_ops and struct proto sendmsg and recvmsg
callbacks. The bt_sock_recvmsg() and bt_sock_stream_recvmsg()
are not callbacks, they are exported but are used all within
the code we provide and carry.
This will help simplify the network/0054-struct-proto_ops-sig
collateral evolution port to Coccinelle SmPL.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
Given a correct spatch, there's no need for the other manual
patch. Thanks to Julia for pointing out my error in building
the original spatch, and how to fix it.
Change-Id: I0226a6c4d0fb7630abee315f1839ba63534aacbb
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
There are some new places where vb2_ioctl_expbuf() is used, add ifdefs
around these palaces.
This should be replaced by a spatch or something else.
This adds the necessary backporting to handle netdev->tstats which
was introduced in 3.14 (and some helper macros in 3.15).
For some reason my spatch isn't reliably patching the occurrence
in net/mac80211/tx.c, so for now I'm including a manual patch.
Change-Id: Ib22e307a9bd31f6c31372ef8cc2828ca6e14fce4
The recent mac80211 LED changes broke the patch, fix it
up and make it apply again.
Change-Id: I4bf9595fb947886e68fa08592bd2cd3b7965f223
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
patches/collateral-evolutions/network/0053-remove_wait_on_bit_timeout/btusb.patch
This was added in commit 4f528afc.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
struct net_device now has a new member name_assign_type which contains
the type of the mac address. It is currently only used to be shown in
sysfs. It should be save to just ignore it on older kernel versions.
This caused a warning on recent kernel versions.
In kernel 4.1 struct ptp_clock_info changes function pointers gettime,
settime to gettime64, settime64.
In kernel 3.19 function pointer ndo_gso_check is changed into
ndo_features_check in struct net_device_ops.
As newer versions of spatch are now capable of declaring an
attribute, use that feature to create an spatch for the change
that changes const to __genl_const.
This bumps the required version of coccinelle to 1.0.0-rc23
(which was released over three months ago.)
Instead of just assuming CONFIG_NET_NS is defined, deal with
this better. Sadly, it needs a header file patch (as an spatch
doesn't deal properly with header files.)
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This patch is no longer needed due to commit
commit 69dbc7cf6d34b903c1dc80f1d4f880fc9acfe6fb
Author: Mathieu Olivari <mathieu@qca.qualcomm.com>
Date: Sun Jan 25 09:46:02 2015 -0800
backport: add hwmon group registration functions
which provides the missing functionality now
There's still some manual patching done because igb_pci_disable_sriov()
will not be used on kernel older than 3.8, which would generate a
compile warning.
Also required a refreshed of patch
patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch
The context change, update the patch.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
The function signature of the members recvmsg sendmsg of the structure
proto_ops changed. The first parameter was removed for kernel 4.1 in
commit 1b7841404. This patch adds back the old signature of older
kernel versions.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.106 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.73 [ OK ]
12 3.11.10 [ OK ]
13 3.12.39 [ OK ]
14 3.13.11 [ OK ]
15 3.14.37 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.10 [ OK ]
20 3.19.3 [ OK ]
21 4.0-rc6 [ OK ]
patches/collateral-evolutions/network/0020-tty-termios/drivers_bluetooth_hci_ath.patch
- removed
patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch
- handled added CONFIG_HAS_DMA
