path: root/patches/collateral-evolutions
2013-10-29backports: refresh on 3.12-rc7v3.12-rc7-1Hauke Mehrtens
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.10.17 [ OK ] 19 3.11.6 [ OK ] 20 3.12-rc7 [ OK ] 21 3.2.52 [ OK ] 22 3.3.8 [ OK ] 23 3.4.67 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-29backports: fix usb-sg for usbnetHauke Mehrtens
Upstream commit: ba0cdc6fb4891c9efc91f627698c8203583f0e52 This adapts the changes from: commit 60e453a940ac678565b6641d65f8c18541bb9f28 Author: Ming Lei <ming.lei@canonical.com> Date: Mon Sep 23 20:59:35 2013 +0800 USBNET: fix handling padding packet Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: refresh patches on next-20130913backports-20130913Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ OK ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: refresh patches on next-20130906backports-20130906-2backports-20130906Hauke Mehrtens
2013-10-23backports: use correct suspend/resume function for rtl8188eeHauke Mehrtens
The newly created function ends with _compat. This causes compile warnings and probably runtime problems on kernel < 2.6.29. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove addr_assign_type from usbnetHauke Mehrtens
addr_assign_type was added with kernel 2.6.36. This is just used to inform userspace, so removing it is no problem. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: refresh on next-20130830backports-20130830Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ FAIL ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: do not use uapi in includeHauke Mehrtens
2013-10-23backports: remove DRM driverHauke Mehrtens
Maintaining the DRM driver takes a lot of recourses as there they are depending on many API changes done to the core kernel code and currently we do not have that many recourses to follow them. On the other side one needs also new userspace drivers to make use of the new features added to the DRM kernel drivers and it is not easy to update the X drivers. Therefore we came to the conclusion to remove the drm drivers for now. There were also some problems with some DRM drivers, like the Intel i915 driver caused kernel panic on some systems and was probably only usable on some very recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: refresh patches on next-20130822Hauke Mehrtens
2013-10-21backports: remove reading of consumed energy from sysfsHauke Mehrtens
MSR_RAPL_POWER_UNIT is not available on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: backport new sysfs api in mediaHauke Mehrtens
2013-10-21backports: refresh patches for next-20130816backports-20130816Hauke Mehrtens
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.89 [ OK ] 17 3.1.10 [ OK ] 18 3.10.5 [ OK ] 19 3.11-rc4 [ OK ] 20 3.2.50 [ OK ] 21 3.3.8 [ OK ] 22 3.4.56 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: do not use DMA SG on old kernel versionsHauke Mehrtens
the usb net driver now uses the dma sg api which is not available on old kernels, this patch removed the usage of the dma sg api for old kernel versions. This backports the following upstream commit: commit 638c5115a794981441246fa8fa5d95c1875af5ba Author: Ming Lei <ming.lei@canonical.com> Date: Thu Aug 8 21:48:24 2013 +0800 USBNET: support DMA SG Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: use old led api on old kernel versions.Hauke Mehrtens
Usage of a new led api was introduced in mac80211, this patch make backports use the old api on older kernel versions. This could cause a problem with the led, the transmit led could stay on if nothing is transfered. This backports the following upstream commit: commit e47f2509e5f182f4df144406de6f2bc78179d57e Author: Fabio Baltieri <fabio.baltieri@gmail.com> Date: Thu Jul 25 12:00:26 2013 +0200 mac80211: use oneshot blink API for LED triggers Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: replace new portid usageHauke Mehrtens
In this upstream commit a new usage of portid was introduced: commit ac22ac466a659f1b2e02a2e2ee23fc5c42da2c95 Author: Samuel Ortiz <sameo@linux.intel.com> Date: Wed Jul 24 18:10:50 2013 +0200 NFC: Add a GET_SE netlink API Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: refresh patches for next-20130809backports-20130809Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.89 [ OK ] 17 3.1.10 [ OK ] 18 3.10.5 [ OK ] 19 3.11-rc4 [ OK ] 20 3.2.50 [ OK ] 21 3.3.8 [ OK ] 22 3.4.56 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: fix intel i915 drm driverHauke Mehrtens
The intel i915 drm driver uses the declarations from intel-gtt.h to interact with drivers/char/agp/intel-gtt.c which is not backported by backports project. To prevent some strange problems when using i915, use the headers from the kernel and do not use our own. This causes some compile problems which where runtime problems before and bumps the minimal kernel version to 3.7. This i915 still crash on my device with kernel 3.7. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-08-27backports: refresh patches for next-20130802 againLuis R. Rodriguez
For some reason some other changes were picked up again now. == ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.79 [ OK ] 17 3.1.10 [ OK ] 18 3.10-rc1 [ OK ] 19 3.2.45 [ OK ] 20 3.3.8 [ OK ] 21 3.4.46 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.13 [ OK ] 26 3.9.3 [ OK ] real 34m47.737s user 937m23.708s sys 129m50.928s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: remove alx patch for < 2.6.24Johannes Berg
Since we don't support kernels before 2.6.24 anymore there's no need to carry this patch. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27remove support for kernel 2.6.24Johannes Berg
By requiring 2.6.25 we can get rid of quite a lot of backport work. 2.6.25 was released more than five years ago (April 2011) and wasn't a long-term kernel either, so there's little point in supporting it now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backport: backport device_move() properlyJohannes Berg
This was causing conflicts again when updating against wireless-next, so instead of adjusting the patches just provide a proper static inline backport. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: refresh patches on next-20130802Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.89 [ OK ] 18 3.1.10 [ OK ] 19 3.10.5 [ OK ] 20 3.11-rc4 [ OK ] 21 3.2.50 [ OK ] 22 3.3.8 [ OK ] 23 3.4.56 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: use genl_info_snd_portid() at an other place.Hauke Mehrtens
2013-08-27backports: add sysfs api backport for ieee802154Hauke Mehrtens
2013-08-27backports: refresh on next-20130726Hauke Mehrtens
2013-08-27backports: backport pci power save for mwifiexHauke Mehrtens
This patch makes mwifiex use the old suspend resume functions on older kernels. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: do not access hw_features in wil6210Hauke Mehrtens
wil6210 now uses netdev->hw_features which is not available in all kernel versions, do not set it then. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: backport sysfs api in wirelessHauke Mehrtens
Older kernel versions do not support the new sysfs api with dev_groups. This makes net/wireless/sysfs.c use the old api on older kernels. This is a backport of this commit: commit f0bc99c84349ce87af5b35839d19bfb17bb9b27f Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Date: Wed Jul 24 15:05:35 2013 -0700 net: wireless: convert class code to use dev_groups This was mostly done by Johannes Berg <johannes@sipsolutions.net>. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: cw1200 needs the multicast API changes to support <=2.6.35Solomon Peachy
Also, update the dependencies: cw1200_wlan_sdio needs >=2.6.34 due to missing sdio_set_host_pm_flags() cw1200_wlan_spi needs >=2.6.35 due to missing request_any_context_irq() Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: cw1200 utilizes kthreads for <= 2.6.35Solomon Peachy
The new workqueue APIs in 2.6.36 allowed us to scrap the old kthread worker that had been used; unfortunately the backported API isn't complete so in order to support older kernels, resurrect this patch. Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: move the cw1200 sdio quirk into 26-sdio-quirksSolomon Peachy
2013-08-15backports: Add patch for cw1200_sdio with kernels < 3.2Solomon Peachy
Without this patch, the hardware *will* hang on <3.2 kernels when a 512-byte SDIO transfer occurs. 3.2-rc added an SDIO quirk to work around this, so this code was stripped from the driver when committed to the mainline. Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-15backports: add wwan device driversPatrick Ziegler
Add cdc_mbim, cdc_ncm, sierra_net, qmi_wwan device drivers. Signed-off-by: Patrick Ziegler <patrick.ziegler@fh-kl.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-12backports: refresh patches for next-20130719Hauke Mehrtens
2013-08-12backports: the shrinkers api did not made it into 3.11Hauke Mehrtens
Change the conditions to use the backported code also in 3.11 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-12backprots: fix logic in calling intel_enable_gtt()Hauke Mehrtens
The old patch changed the or condition to an and condition which is wrong. This patch fixes the logic again. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-29backports: refresh patches for next-20130712backports-20130712Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] real 34m34.417s user 933m25.264s sys 129m41.580s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-29backports: refresh patches for next-20130709Luis R. Rodriguez
2013-07-29backports: fix patches for next-20130709Luis R. Rodriguez
A hunk context was off for alx. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-29backports: refresh patches for next-20130703Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] real 32m59.877s user 880m31.524s sys 124m11.996s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-19backports: simplify swiotlb_nr_tbl() backportLuis R. Rodriguez
swiotlb_nr_tbl() was available since 3.2 but was exported since 3.3. Since it uses an internal global state variable, it is impossible to backport it to. Instead of reverting the changes added just let this return 0 as the code will not do anything. This simplifies the backport. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-19backports: refresh patches for next-20130627Luis R. Rodriguez
2013-07-19backports: fix patches required for next-20130627Luis R. Rodriguez
2013-07-01backports: add new alx upstream backportLuis R. Rodriguez
This backports the new upstream alx driver and properly splits up each required backports into its respective collateral evolution bucket. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-26backports: remove alx extra patchLuis R. Rodriguez
The alx driver was upstreamed by Johannes, so this is no longer required. Note that this driver is now GPLv2 or later, BSD folks will have to look at the old unified tree for a permissive licensed port. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-19backports: refresh patches on next-20130617backports-20130617Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-06-19backports: add ieee802154Hauke Mehrtens
This adds the ieee802154 subsystem. == ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-06-13backports: fix tracing on wil6210Hauke Mehrtens
This includes the trace.h file like it is done for the other drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-13backports: adapt shrinkers api patch to next-20130607Hauke Mehrtens
The shrinkers api changed a little in the last version, this patch makes the patches apply again. == ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
