path: root/patches
2014-01-19backports: fix unused hidp_get_raw_report() warningHauke Mehrtens
This fixes the following warning: /net/bluetooth/hidp/core.c:271:12: warning: ‘hidp_get_raw_report’ defined but not used [-Wunused-function] static int hidp_get_raw_report(struct hid_device *hid, ^ Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-19backports: fix unused atl1e_rx_mode() warningHauke Mehrtens
This fixes the following warning: /drivers/net/ethernet/atheros/atl1e/atl1e_main.c:328:13: warning: ‘atl1e_rx_mode’ defined but not used [-Wunused-function] static void atl1e_rx_mode(struct net_device *netdev, ^ Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-19backports: fix unused var ret warningHauke Mehrtens
This fixes the following warning: /drivers/net/wireless/mwifiex/sta_cmd.c: In function ‘mwifiex_cmd_cfg_data’: /drivers/net/wireless/mwifiex/sta_cmd.c:1196:6: warning: unused variable ‘ret’ [-Wunused-variable] int ret; ^ Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-19backports: fix unused mwifiex_sdio_resume() warningHauke Mehrtens
This fixes the following warning: /drivers/net/wireless/mwifiex/sdio.c:124:12: warning: ‘mwifiex_sdio_resume’ defined but not used [-Wunused-function] static int mwifiex_sdio_resume(struct device *dev) ^ Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-19backports: backport get_stats in alx driverHauke Mehrtens
alx_get_stats64() was added recently to alx driver, but on kernel < 2.6.30 only get_stats is available, convert the function on such kernels to use the old api. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-19backports: add ATTRIBUTE_GROUPS unconditionallyHauke Mehrtens
net/bluetooth/hci_sysfs.c uses ATTRIBUTE_GROUPS on all kernel versions. Now it has to be for older kernel versions as well and __ATTRIBUTE_GROUPS is also needed for these old versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-19backports: adapt to changes in netdev select_queue callHauke Mehrtens
This patch reverts the changes done in the following commit for older kernel versions: commit f663dd9aaf9ed124f25f0f8452edf238f087ad50 Author: Jason Wang <jasowang@redhat.com> Date: Fri Jan 10 16:18:26 2014 +0800 net: core: explicitly select a txq before doing l2 forwarding Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> CC: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-01-18backports: refresh on next-20140106backports-20140106Hauke Mehrtens
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.77 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.27 [ OK ] 27 3.11.10 [ OK ] 28 3.12.8 [ OK ] 29 3.13-rc8 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: fix iwlwifi threaded IRQ patchesEmmanuel Grumbach
Modifications upstream affected: * drivers_net_wireless_iwlwifi_pcie_internal.patch * drivers_net_wireless_iwlwifi_pcie_trans.patch Manually refresh the patches. Change-Id: Iad8218a243e644352c3b1029d12795c528259dde Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: refresh on next-20131224Hauke Mehrtens
manual changes done to: patches/collateral-evolutions/network/25-multicast-list_head/include_net_mac80211.patch patches/collateral-evolutions/network/25-multicast-list_head/net_mac80211_driver-ops.patch patches/collateral-evolutions/network/25-multicast-list_head/net_mac80211_iface.patch patches/collateral-evolutions/network/64-b44-32bit-stats/drivers_net_ethernet_broadcom_b44.patch patches/collateral-evolutions/network/70-umode_t-api-change/drivers_net_wireless_ath_ath9k_debug.patch 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.54 [ OK ] 19 3.3.8 [ OK ] 20 3.4.77 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.27 [ OK ] 27 3.11.10 [ OK ] 28 3.12.8 [ OK ] 29 3.13-rc8 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: backport multicast list handling in iwlwifi mvmJohannes Berg
Backport multicast list handling for kernel < 2.6.35 in iwlwifi mvm driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: remove usage of addr_assign_type in 6lowpan.cHauke Mehrtens
The bluetooth 6lowpan code now accesses the addr_assign_type member of struct netdev, which is not available in older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-01-18backports: remove usage of members of struct property for kernel < 2.6.39Hauke Mehrtens
struct property is missing in the general header files in older kernel versions. There are different versions of this header depending on the architecture code in use. This removed the access to any members of struct property for older kernel version when CONFIG_OF is not set. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-12-09backports: refresh patches for next-20131206 a second timebackports-20131206Luis R. Rodriguez
After a few changes were made we need a refresh of patches against next-20131206, this refreshes the patches and test compiles against all supported kernels again. $ time ckmake --allyesconfig 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.52 [ OK ] 19 3.3.8 [ OK ] 20 3.4.70 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.20 [ OK ] 27 3.11.9 [ OK ] 28 3.12.1 [ OK ] 29 3.13-rc1 [ OK ] real 33m3.982s user 892m21.988s sys 128m11.492s Current run time *without* the last two cocci patches applied: mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ --verbose \ --clean \ --refresh \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20131206 real 3m13.530s user 2m56.104s sys 0m16.180s With the last two cocci patch files applied and spatch version 1.0.0-rc17: mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ --verbose \ --clean \ --refresh \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20131206 real 23m2.521s user 19m19.436s sys 3m3.840s With the last two cocci patch files applied and spatch version 1.0.0-rc19: mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ --verbose \ --clean \ --refresh \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20131206 real 8m6.077s user 7m46.076s sys 0m18.124s Moving forward please make sure to have present at least spatch 1.0.0-rc19 on your system to generate releases. The gains of extending how we do backports more automatically with Coccinelle for the short cost observed on 1.0.0-rc19 makes it worth it to continue to embrace SmPL to backport further collateral evolutions. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-12-09backports: convert 11-dev-pm-ops patch series to SmPLLuis R. Rodriguez
The collateral evolution on pci power management ops can easily be expressed with SmPL, use that instead. spatch version 1.0.0-rc19 with Python support and with PCRE support mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ --verbose \ --clean \ --refresh \ /home/mcgrof/linux-next/ \ /home/mcgrof/build/next-20131206 real 8m6.077s user 7m46.076s sys 0m18.124s There are three exceptions that this patch does not address: libertas: this should be made a separate collateral evolution specifically for spi drivers iwlegacy: we'll deal with this as an evolution to our spatch, it deals with having to rely on grammar rules which go beyond just one file. mwifiex: coccinelle is not doing the transormation due to an isomorphism on how pm suspend ops are declared, although we may be able to deal with this within Coccinelle to teach it this isomorphism we can also address this by streamlining how pm ops are defined upstream in the meantime. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-12-08backports: convert the 62-usb_driver_lpm patch series to SmPLLuis R. Rodriguez
This is easily expressed instead as an SmPL patch for interpretation with Coccinelle. This replaces 336 lines patch code with 9 lines of SmPL. Cc: Peter Senna <peter.senna@gmail.com> Cc: Julia Lawall <julia.lawall@lip6.fr> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-12-08backports: refresh patches for next-20131206Luis R. Rodriguez
Run time of generation of release: real 5m28.543s user 3m4.536s sys 2m2.940s spatch version 1.0.0-rc17 with Python support and with PCRE support == ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.2.52 [ OK ] 19 3.3.8 [ OK ] 20 3.4.70 [ OK ] 21 3.5.7 [ OK ] 22 3.6.11 [ OK ] 23 3.7.10 [ OK ] 24 3.8.13 [ OK ] 25 3.9.11 [ OK ] 26 3.10.20 [ OK ] 27 3.11.9 [ OK ] 28 3.12.1 [ OK ] 29 3.13-rc1 [ OK ] real 37m43.297s user 1030m36.392s sys 138m31.368s Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-12-02backports: refresh patches on next-20131129Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.10.20 [ OK ] 19 3.11.9 [ OK ] 20 3.12.1 [ OK ] 21 3.13-rc1 [ OK ] 22 3.2.52 [ OK ] 23 3.3.8 [ OK ] 24 3.4.70 [ OK ] 25 3.5.7 [ OK ] 26 3.6.11 [ OK ] 27 3.7.10 [ OK ] 28 3.8.13 [ OK ] 29 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-11-24backports: refresh on next-20131122backports-20131122Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ FAIL ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.101 [ OK ] 18 3.1.10 [ OK ] 19 3.10.20 [ OK ] 20 3.11.9 [ OK ] 21 3.12.1 [ OK ] 22 3.13-rc1 [ OK ] 23 3.2.52 [ OK ] 24 3.3.8 [ OK ] 25 3.4.70 [ OK ] 26 3.5.7 [ OK ] 27 3.6.11 [ OK ] 28 3.7.10 [ OK ] 29 3.8.13 [ OK ] 30 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-21backports: refresh on next-20131121backports-20131121Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ FAIL ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.101 [ OK ] 18 3.1.10 [ OK ] 19 3.10.17 [ OK ] 20 3.11.6 [ OK ] 21 3.12-rc7 [ OK ] 22 3.2.52 [ OK ] 23 3.3.8 [ OK ] 24 3.4.67 [ OK ] 25 3.5.7 [ OK ] 26 3.6.11 [ OK ] 27 3.7.10 [ OK ] 28 3.8.13 [ OK ] 29 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-21backports: support new generic netlink APIsJohannes Berg
I recently changed the generic netlink registration and multicast group APIs to be safer. Backport these changes by implementing all the new APIs in terms of what was in the kernel before. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-21backports: replace netdev ops patch with spatchJohannes Berg
There's no need to carry a small netdev ops patch for each driver any more now, we can just write a small semantic patch. Only the ndo_ioctl() part is easier to keep as a separate patch. As some stupid drivers seem to set their ops to NULL just before freeing the netdev anyway, the attach function must gracefully handle that (but not doesn't really need to do anything.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-21backports: move part of multicast handling into an spatchJohannes Berg
The netdev_for_each_mc_addr() handling can be done with a semantic patch and a simple macro encapsulating the addr dereferencing for the two cases. In fact, this already fixed a bug in dvb_net.c, although I think that depends on a newer kernel anyway. Thanks Julia for the help with iterator name! Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-13backports: refresh on next-20131113backports-20131113Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.101 [ OK ] 17 3.1.10 [ OK ] 18 3.10.17 [ OK ] 19 3.11.6 [ OK ] 20 3.12-rc7 [ OK ] 21 3.2.52 [ OK ] 22 3.3.8 [ OK ] 23 3.4.67 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-07backports: refresh on next-20131107backports-20131107Hauke Mehrtens
2013-11-07backports: remove usage of ipv6_stubHauke Mehrtens
We can not easily backport ipv6_stub which provides some IPv6 function callbacks. These patches are removing usage of ipv6_stub which was introduces in this commit: commit 5f81bd2e5d804ca93f3ec8873451b22d2f454721 Author: Cong Wang <amwang@redhat.com> Date: Sat Aug 31 13:44:30 2013 +0800 ipv6: export a stub for IPv6 symbols used by vxlan Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-31backports: refresh on next-20131031backports-20131031Hauke Mehrtens
2013-10-31backports: replace netlink portid by semantic patchJohannes Berg
Introduce the infrastructure to apply semantic patches and make use of it for the (frequently breaking) portid patch for netlink. Unfortunately this is significantly slower: before: real 0m14.312s user 0m12.144s sys 0m1.784s after: real 0m25.932s user 0m21.768s sys 0m2.932s Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-27backports: refresh on next-20131025backports-20131025Hauke Mehrtens
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ OK ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-27backports: add missing header for struct in6_addrHauke Mehrtens
fw-api-d3.h in the iwlwifi driver uses struct in6_addr and somehow it does not get included on all kernel versions like 2.6.25. This patch adds the missing include for linux/in6.h to fix the problem. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-27backports: refresh on next-20131018Hauke Mehrtens
2013-10-27backports: backport new sysfs API for bcma and ssbHauke Mehrtens
bcma and ssb are using the new sysfs API starting with kernel 3.12. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-27backports: use sysfs api backport independent from kernel versionHauke Mehrtens
In struct class the new sysfs dev_groups member was added with kernel 3.11, but in other structs, like struct bus_type the new member was added with kernel 3.12. This backport is now needed on different kernel versions depending on the struct where is was used. With this patch ATTRIBUTE_GROUPS() will always be used with the new API and ATTRIBUTE_GROUPS_BACKPORT() will always be used used with the old API and the patch has to add a KERNEL_VERSION check to add the correct macro. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-26backports: refresh patches on next-20131011backports-20131011Hauke Mehrtens
2013-10-26backports: remove struct platform_device_id from wcn36xxHauke Mehrtens
2013-10-25backports: refresh patches on next-20131004backports-20131004Hauke Mehrtens
Manual fixes where needed in: patches/collateral-evolutions/network/09-threaded-irq/drivers_net_wireless_ti_wlcore_main.patch patches/collateral-evolutions/network/40-netdev-hw-features/drivers_net_ethernet_atheros_atl1e_atl1e_main.patch 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ OK ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-25backports: fix usb-sg for usbnetHauke Mehrtens
This adapts the changes from: commit 60e453a940ac678565b6641d65f8c18541bb9f28 Author: Ming Lei <ming.lei@canonical.com> Date: Mon Sep 23 20:59:35 2013 +0800 USBNET: fix handling padding packet Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-24backports: refresh on next-20130927backports-20130927Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ OK ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-24backports: refresh patches on next-20130920backports-20130920Hauke Mehrtens
2013-10-23backports: refresh patches on next-20130913backports-20130913Hauke Mehrtens
2013-10-23backports: refresh patches on next-20130906backports-20130906-2backports-20130906Hauke Mehrtens
2013-10-23backports: use correct suspend/resume function for rtl8188eeHauke Mehrtens
The newly created function ends with _compat. This causes compile warnings and probably runtime problems on kernel < 2.6.29. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove addr_assign_type from usbnetHauke Mehrtens
addr_assign_type was added with kernel 2.6.36. This is just used to inform userspace, so removing it is no problem. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: refresh on next-20130830backports-20130830Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ FAIL ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: do not use uapi in includeHauke Mehrtens
2013-10-23backports: remove DRM driverHauke Mehrtens
Maintaining the DRM driver takes a lot of recourses as there they are depending on many API changes done to the core kernel code and currently we do not have that many recourses to follow them. On the other side one needs also new userspace drivers to make use of the new features added to the DRM kernel drivers and it is not easy to update the X drivers. Therefore we came to the conclusion to remove the drm drivers for now. There were also some problems with some DRM drivers, like the Intel i915 driver caused kernel panic on some systems and was probably only usable on some very recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: refresh patches on next-20130822Hauke Mehrtens
2013-10-21backports: remove reading of consumed energy from sysfsHauke Mehrtens
MSR_RAPL_POWER_UNIT is not available on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: backport new sysfs api in mediaHauke Mehrtens
2013-10-21backports: refresh patches for next-20130816backports-20130816Hauke Mehrtens
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.89 [ OK ] 17 3.1.10 [ OK ] 18 3.10.5 [ OK ] 19 3.11-rc4 [ OK ] 20 3.2.50 [ OK ] 21 3.3.8 [ OK ] 22 3.4.56 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
