1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit: d260afa8c4aecde4abdecfa299713bc473c0dba4
The patch changing the callback function signature was backported to
kernel 3.14, this was already fixed in backports for mac80211, but that
commit missed mwifiex.
Upstream commit: 44554cd57d0016c52aeed2ce4f27081b9d9c915f
The callback argument has been passed since kernel 3.14, not
only 3.15 - fix that.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
mcgrof@drvbp1 ~/backports (git::linux-3.14.y)$ time \
./gentree.py --clean
--verbose --refresh /home/mcgrof/linux /home/mcgrof/build/linux-3.14/
real 1m32.443s
user 23m35.088s
sys 0m29.280s
$ time ckmake --allyesconfig
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
real 39m53.331s
user 1090m4.292s
sys 147m15.968s
This is only needed for code coming in from v3.15.
This seems to commonly be missing in the random kernels
people use, so just provide a backport.
manual changes were needed on these files:
* patches/backport-adjustments/flow_dissector.patch
* patches/collateral-evolutions/network/16-bluetooth/net_bluetooth_hidp_core.patch
* patches/collateral-evolutions/network/83-select_queue/mac80211.patch
* patches/collateral-evolutions/network/83-select_queue/mwifiex.patch
* patches/collateral-evolutions/network/85-hid_ll_driver/net_bluetooth_hidp_core.patch
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
This member was added ion more recent kernel versions.
Instead of using an own version of sch_fq_codel.c make backports copy
that code from the kernel and use that. This ensures that we will
always use the latest version.
This also includes flow_dissector.c which provides a function used by
sch_fq_codel.c.
Instead of using an own version of sch_codel.c make backports copy that
code from the kernel and use that. This ensures that we will always use
the latest version.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
Manual changes were needed in
The function pointer raw_request and output_report in struct
hid_ll_driver will be added with kernel 3.15, remove useage on
older kernel versions.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
- add IFF_UNICAST_FLT define
- add PCI_DEV_FLAGS_ASSIGNED define
- add skb_frag_size_sub()
- add skb_frag_address()
- add patches/collateral-evolutions/network/84-ethernet/0011-igb_ethtool_ops.patch
- add patches/collateral-evolutions/network/84-ethernet/0012-igb_ndo_set_vf_spoofchk.patch
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
- add patches/collateral-evolutions/network/84-ethernet/0009-igb_vlan_rx_vid.patch
- add patches/collateral-evolutions/network/84-ethernet/0010-igb_ethtool_ops.patch
- add IFF_SUPP_NOFCS define
- add patches/collateral-evolutions/network/84-ethernet/0008-igb_no_fcs.patch
Is there a better way to handle struct sk_buff changes?
- add struct timestamp_event_queue
- add struct ptp_clock
- add ptp_clock_index()
- add patches/collateral-evolutions/network/84-ethernet/0007-igb_ethtool_ops.patch
- add EEE defines
- backport __skb_alloc_page and __skb_alloc_pages
- add patches/collateral-evolutions/network/84-ethernet/0006-igb_eee.patch
- backport mmd_eee_adv_to_ethtool_adv_t
- add define to map ptp_clock_register() to old version
- add patches/collateral-evolutions/network/84-ethernet/0004-igb_err_handler.patch
- add patches/collateral-evolutions/network/84-ethernet/0005-igb_mdi.patch
- add pci_sriov_set_totalvfs()
- add patches/collateral-evolutions/network/84-ethernet/0002-igb_pci_sriov_configure.patch
Several ifdefs in igb_main.c to avoid compiler warnings.
- add struct pci_sriov
- add pci_vfs_assigned()
- add PCI_SRIOV defines
- add patches/collateral-evolutions/network/84-ethernet/0001-igb_net_device_ops.patch
- add patches/collateral-evolutions/network/84-ethernet/0013-igb_hwmon.patch
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
This fixes the following warning:
/net/bluetooth/hidp/core.c:271:12: warning: ‘hidp_get_raw_report’ defined but not used [-Wunused-function]
static int hidp_get_raw_report(struct hid_device *hid,
/drivers/net/ethernet/atheros/atl1e/atl1e_main.c:328:13: warning: ‘atl1e_rx_mode’ defined but not used [-Wunused-function]
static void atl1e_rx_mode(struct net_device *netdev,
/drivers/net/wireless/mwifiex/sta_cmd.c: In function ‘mwifiex_cmd_cfg_data’:
/drivers/net/wireless/mwifiex/sta_cmd.c:1196:6: warning: unused variable ‘ret’ [-Wunused-variable]
int ret;
/drivers/net/wireless/mwifiex/sdio.c:124:12: warning: ‘mwifiex_sdio_resume’ defined but not used [-Wunused-function]
static int mwifiex_sdio_resume(struct device *dev)
alx_get_stats64() was added recently to alx driver, but on kernel <
2.6.30 only get_stats is available, convert the function on such
kernels to use the old api.
net/bluetooth/hci_sysfs.c uses ATTRIBUTE_GROUPS on all kernel versions.
Now it has to be for older kernel versions as well and
__ATTRIBUTE_GROUPS is also needed for these old versions.
This patch reverts the changes done in the following commit for older
kernel versions:
commit f663dd9aaf9ed124f25f0f8452edf238f087ad50
Author: Jason Wang <jasowang@redhat.com>
Date: Fri Jan 10 16:18:26 2014 +0800
net: core: explicitly select a txq before doing l2 forwarding
CC: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
Modifications upstream affected:
* drivers_net_wireless_iwlwifi_pcie_internal.patch
* drivers_net_wireless_iwlwifi_pcie_trans.patch
Manually refresh the patches.
Change-Id: Iad8218a243e644352c3b1029d12795c528259dde
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
manual changes done to:
patches/collateral-evolutions/network/25-multicast-list_head/include_net_mac80211.patch
patches/collateral-evolutions/network/25-multicast-list_head/net_mac80211_driver-ops.patch
patches/collateral-evolutions/network/25-multicast-list_head/net_mac80211_iface.patch
patches/collateral-evolutions/network/64-b44-32bit-stats/drivers_net_ethernet_broadcom_b44.patch
patches/collateral-evolutions/network/70-umode_t-api-change/drivers_net_wireless_ath_ath9k_debug.patch
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
Backport multicast list handling for kernel < 2.6.35 in iwlwifi mvm
driver.
The bluetooth 6lowpan code now accesses the addr_assign_type member of
struct netdev, which is not available in older kernel versions.
struct property is missing in the general header files in older kernel
versions. There are different versions of this header depending on the
architecture code in use. This removed the access to any members of
struct property for older kernel version when CONFIG_OF is not set.
After a few changes were made we need a refresh of patches
against next-20131206, this refreshes the patches and test
compiles against all supported kernels again.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.52 [ OK ]
19 3.3.8 [ OK ]
20 3.4.70 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.20 [ OK ]
27 3.11.9 [ OK ]
28 3.12.1 [ OK ]
29 3.13-rc1 [ OK ]
real 33m3.982s
user 892m21.988s
sys 128m11.492s
Current run time *without* the last two cocci patches applied:
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \
--verbose \
--clean \
--refresh \
/home/mcgrof/linux-next/ \
/home/mcgrof/build/next-20131206
real 3m13.530s
user 2m56.104s
sys 0m16.180s
With the last two cocci patch files applied and spatch version 1.0.0-rc17:
--verbose \
--clean \
--refresh \
real 23m2.521s
user 19m19.436s
sys 3m3.840s
With the last two cocci patch files applied and spatch version 1.0.0-rc19:
--verbose \
--clean \
--refresh \
real 8m6.077s
user 7m46.076s
sys 0m18.124s
Moving forward please make sure to have present at least spatch
1.0.0-rc19 on your system to generate releases. The gains of extending
how we do backports more automatically with Coccinelle for the
short cost observed on 1.0.0-rc19 makes it worth it to continue to
embrace SmPL to backport further collateral evolutions.
Cc: Peter Senna <peter.senna@gmail.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Gilles Muller <Gilles.Muller@lip6.fr>
The collateral evolution on pci power management ops can easily
be expressed with SmPL, use that instead.
spatch version 1.0.0-rc19 with Python support and with PCRE support
--verbose \
--clean \
--refresh \
real 8m6.077s
user 7m46.076s
sys 0m18.124s
There are three exceptions that this patch does not address:
libertas: this should be made a separate collateral evolution
specifically for spi drivers
iwlegacy: we'll deal with this as an evolution to our spatch,
it deals with having to rely on grammar rules which
go beyond just one file.
mwifiex: coccinelle is not doing the transormation due to
an isomorphism on how pm suspend ops are declared,
although we may be able to deal with this within
Coccinelle to teach it this isomorphism we can
also address this by streamlining how pm ops are
defined upstream in the meantime.
This is easily expressed instead as an SmPL patch for
interpretation with Coccinelle. This replaces 336 lines
patch code with 9 lines of SmPL.
Run time of generation of release:
real 5m28.543s
user 3m4.536s
sys 2m2.940s
spatch version 1.0.0-rc17 with Python support and with PCRE support
== ckmake-report.log ==
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.52 [ OK ]
19 3.3.8 [ OK ]
20 3.4.70 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.20 [ OK ]
27 3.11.9 [ OK ]
28 3.12.1 [ OK ]
29 3.13-rc1 [ OK ]
real 37m43.297s
user 1030m36.392s
sys 138m31.368s
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.20 [ OK ]
19 3.11.9 [ OK ]
20 3.12.1 [ OK ]
21 3.13-rc1 [ OK ]
22 3.2.52 [ OK ]
23 3.3.8 [ OK ]
24 3.4.70 [ OK ]
25 3.5.7 [ OK ]
26 3.6.11 [ OK ]
27 3.7.10 [ OK ]
28 3.8.13 [ OK ]
29 3.9.11 [ OK ]
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.20 [ OK ]
20 3.11.9 [ OK ]
21 3.12.1 [ OK ]
22 3.13-rc1 [ OK ]
23 3.2.52 [ OK ]
24 3.3.8 [ OK ]
25 3.4.70 [ OK ]
26 3.5.7 [ OK ]
27 3.6.11 [ OK ]
28 3.7.10 [ OK ]
29 3.8.13 [ OK ]
30 3.9.11 [ OK ]
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.17 [ OK ]
20 3.11.6 [ OK ]
21 3.12-rc7 [ OK ]
22 3.2.52 [ OK ]
23 3.3.8 [ OK ]
24 3.4.67 [ OK ]
25 3.5.7 [ OK ]
26 3.6.11 [ OK ]
27 3.7.10 [ OK ]
28 3.8.13 [ OK ]
29 3.9.11 [ OK ]
I recently changed the generic netlink registration and multicast
group APIs to be safer. Backport these changes by implementing all
the new APIs in terms of what was in the kernel before.
There's no need to carry a small netdev ops patch for
each driver any more now, we can just write a small
semantic patch. Only the ndo_ioctl() part is easier
to keep as a separate patch.
As some stupid drivers seem to set their ops to NULL
just before freeing the netdev anyway, the attach
function must gracefully handle that (but not doesn't
really need to do anything.)
The netdev_for_each_mc_addr() handling can be done with a
semantic patch and a simple macro encapsulating the addr
dereferencing for the two cases.
In fact, this already fixed a bug in dvb_net.c, although
I think that depends on a newer kernel anyway.
Thanks Julia for the help with iterator name!
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
We can not easily backport ipv6_stub which provides some IPv6 function
callbacks. These patches are removing usage of ipv6_stub which was
introduces in this commit:
commit 5f81bd2e5d804ca93f3ec8873451b22d2f454721
Author: Cong Wang <amwang@redhat.com>
Date: Sat Aug 31 13:44:30 2013 +0800
ipv6: export a stub for IPv6 symbols used by vxlan
