path: root/pending-stable
2010-11-09compat-wireless: support ignoring some stable linux-next patchesLuis R. Rodriguez
Right before and during the merge window the amount of stable patches queue up on the linux-next.git tree gets pretty big and some of these patches may not apply cleanly on the existing stable release of the kernel so you may want to ignore them and backport them manually. Add support for this by allowing the packager to specify which patches should be ignored through the pending-stable/.ignore file. You can stuff your backported patch instead then into pending-stable/backport/ manually. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2010-09-27compat-wireless: add support for generating pending-stable/ fixesLuis R. Rodriguez
Often right before the merge window we get a block on non oops/regression fixes for stable fixes. Some stable fixes often get propagated afterwards during the extraversion maintenance of the kernels. Right before the merge window circa rc4 and rc5 subsystem maintainers get pegged if they throw in non oops/regression fixes for Linus or their respective upstream maintainer. While this makes sense for tree management and stable release considerations we still need to get users some stable patches propagated. We can achieve this in compat-wireless with the -s option to ./scripts/admin-update.sh which this patch implements. You will need to use a stable branch of compat-wireless, point it to a stable git tree, and have present a linux-next git tree. The -s option will get your $(git describe --abbrev=0) from your stable tree and then get all pending fixes via: git format-patch --grep="stable@kernel.org" \ -o pending-stable/ $(git describe --abbrev=0)..HEAD $WSTABLE Where WSTABLE is: export WSTABLE=" net/wireless/ net/wireless/ net/mac80211/ net/rfkill/ drivers/net/wireless/ net/bluetooth/ drivers/bluetooth/ drivers/net/atl1c/ drivers/net/atl1e/ drivers/net/atlx/ include/linux/nl80211.h include/linux/rfkill.h include/net/cfg80211.h include/net/regulatory.h include/net/cfg80211.h" What this does is get us all pending stable fixes on linux-next.git not yet merged onto Linus' tree. This lets us hurry in stable fixes for users for stable releases of compat-wireless based on the RC series. This accelerates the pace of fix propagation right before the merge window. To generate and apply your own stable fixes to your stable compa-wireless releases you will then use: ./scripts/admin-updates.sh -s The -s both generates new pending stable fix patches applies the patches from the pending-stable/ directory. I'm up to support stable releases with pending-stable/ applied, not sure if its worth it to have two releases, one with it and one without buf if there are considerations for this please let me know and I'll just make two releases. For now I'll make the releases with the stable patches merged with the requirement they must at least be on the linux-next.git tree to promote upstreamabilty (is that a word?). If you want to review the pending-stable/ picked patches check out the pending-stable/ directory on the respective stable compat-wireless release. Note that for non-stable releases you can also use the linux-next-cherry-picks/ directory, that gives distributions/vendors the flexibility to cherry pick out non-stable fixes from linux-next.git for a stable release. For the big fat warning as why this should be avoided check the README on that directory. The pending-stable/ directory may also help the stable team maintainers on their crusade when applying patches onto stable, it also means we will need respective backports at least to Linus' tree for each stable patch. Right now I get 23 pending stable patches based on today's linux-next.git and Linus' v2.6.36-rc5 tag, which *should* in theory get propagated to the first extraversion release of the kernel onto v2.6.36.1 (we'll see!). Cc: Greg KH <greg@kroah.com> Cc: linux-kernel@vger.kernel.org Cc: stable-review@linux.kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
