Fixes issues with CAN stopping when overwhelmed by data RX\TX.
Keeps can in freezemode until explicitly activated.
CANINTF_TX is now a CAN TX in progress flag.
Runtime asserts are now disabled.
Default value is maximum priority, that's not what we want.
Bump version to 1.1
Tester build includes:
-Disabled CAN,
-No debug interface,
-Most GPIOs configured as input and accesible from linux driver
-Special fw version number (0xFE)
Implement support for single transfer register
read in GPIO mode.
CAN:
-clear CANINTF_TX on read, this improves TX performance,
-fix possible race-condition and implement errata 5641
ADC
-allow for non-bulk read
SPI:
-move to single transfer read
-clear interrupt register on read
-perform multibyte read transfers with DMA
-make frame format consistant
CAN:
-move from mailbox to CAN FIFO
-implement buffering
-support for reading multiple frames per transfer
General:
-use PLL at 100MHz
-remove debug task
-do not compile release with debug console enabled
-bumped version to 0.13
Limited number of boards appear to have issues with previous method.
This include FreeRTOS update to version 9.0.0
Includes CAN support and fw version bump to 0.9
Support for Communication between TK1 SoC and K20 MCU
This patch includes ADC, TSC and GPIO functionality.
commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial commitk20_tester: Initial
