This concept is no longer required since we now support loading of
images at fixed addresses only.
The image loader now automatically detects the position of the image
inside the current memory layout and updates the layout such that
memory fragmentation is minimised.
The 'attr' field of the meminfo data structure, which used to hold
the bottom/top loading information, has been removed. Also the 'next'
field has been removed as it wasn't used anywhere.
The 'init_bl2_mem_layout()' function has been moved out of common
code and put in BL1-specific code. It has also been renamed into
'bl1_init_bl2_mem_layout'.
Fixes ARM-software/tf-issues#109
Change-Id: I3f54642ce7b763d5ee3b047ad0ab59eabbcf916d
bl2_main() was overwriting any platform set X1 parameter for BL3-1
with the value zero.
This patch ensure that any platform set value is correctly passed
to BL3-1. The FVP port adds a check to verify this parameter is
being passed correctly.
Fixes ARM-software/tf-issues#173
Change-Id: Ifbcda73d3d41d2b04a4baf5614e9d2d21f1717c8
Some platform porting functions were in BL specific header files.
These have been moved to platform.h so that all porting functions
are in the same place. The functions are now grouped by BL.
Obsolete BL headers files have been removed.
Also, the weak declaration of the init_bl2_mem_layout() function
has been moved out the header file and into the source file
(bl_common.c) using the more succinct #pragma syntax. This
mitigates the risk of 2 weak definitions being created and the
wrong one being picked up by the compiler.
Change-Id: Ib19934939fd755f3e5a5a5bceec88da684308a83
Previously, platform.h contained many declarations and definitions
used for different purposes. This file has been split so that:
* Platform definitions used by common code that must be defined
by the platform are now in platform_def.h. The exact include
path is exported through $PLAT_INCLUDES in the platform makefile.
* Platform definitions specific to the FVP platform are now in
/plat/fvp/fvp_def.h.
* Platform API declarations specific to the FVP platform are now
in /plat/fvp/fvp_private.h.
* The remaining platform API declarations that must be ported by
each platform are still in platform.h but this file has been
moved to /include/plat/common since this can be shared by all
platforms.
Change-Id: Ieb3bb22fbab3ee8027413c6b39a783534aee474a
Function declarations implicitly have external linkage so do not
need the extern keyword.
Change-Id: Ia0549786796d8bf5956487e8996450a0b3d79f32
Currently the platform code gets to define the base address of each
boot loader image. However, the linker scripts couteract this
flexibility by enforcing a fixed overall layout of the different
images. For example, they require that the BL3-1 image sits below
the BL2 image. Choosing BL3-1 and BL2 base addresses in such a way
that it violates this constraint makes the build fail at link-time.
This patch requires the platform code to now define a limit address
for each image. The linker scripts check that the image fits within
these bounds so they don't rely anymore on the position of a given
image in regard to the others.
Fixes ARM-software/tf-issues#163
Change-Id: I8c108646825da19a6a8dfb091b613e1dd4ae133c
The generic image loading and IO FIP code no longer forces the
platform to create BL3-2 (Secure-EL1 Payload) specific
definitions. The BL3-2 loading code in bl2/bl2main.c is wrapped
by a #ifdef BL32_BASE blocks, allowing the BL3-2 definitions to
be optional. Similarly for the name_uuid array defintion in
drivers/io/io_fip.c.
Also update the porting guide to reflect this change.
The BL3-2 platform definitions remain non-configurably present
in the FVP port.
Fixes ARM-software/tf-issues#68
Change-Id: Iea28b4e94d87a31f5522f271e290919a8a955460
The issues addressed in this patch are:
1. Remove meminfo_t from the common interfaces in BL3-x,
expecting that platform code will find a suitable mechanism
to determine the memory extents in these images and provide
it to the BL3-x images.
2. Remove meminfo_t and bl31_plat_params_t from all FVP BL3-x
code as the images use link-time information to determine
memory extents.
meminfo_t is still used by common interface in BL1/BL2 for
loading images
Change-Id: I4e825ebf6f515b59d84dc2bdddf6edbf15e2d60f
This patch is based on spec published at
https://github.com/ARM-software/tf-issues/issues/133
It rearranges the bl31_args struct into
bl31_params and bl31_plat_params which provide the
information needed for Trusted firmware and platform
specific data via x0 and x1
On the FVP platform BL3-1 params and BL3-1 plat params
and its constituents are stored at the start of TZDRAM.
The information about memory availability and size for
BL3-1, BL3-2 and BL3-3 is moved into platform specific data.
Change-Id: I8b32057a3d0dd3968ea26c2541a0714177820da9
This patch reworks the handover interface from: BL1 to BL2 and
BL2 to BL3-1. It removes the raise_el(), change_el(), drop_el()
and run_image() functions as they catered for code paths that were
never exercised.
BL1 calls bl1_run_bl2() to jump into BL2 instead of doing the same
by calling run_image(). Similarly, BL2 issues the SMC to transfer
execution to BL3-1 through BL1 directly. Only x0 and x1 are used
to pass arguments to BL31. These arguments and parameters for
running BL3-1 are passed through a reference to a
'el_change_info_t' structure. They were being passed value in
general purpose registers earlier.
Change-Id: Id4fd019a19a9595de063766d4a66295a2c9307e1
This patch introduces macros (SPSR_64 and SPSR_32) to
create a SPSR for both aarch32 and aarch64 execution
states. These macros allow the user to set fields
in the SPSR depending upon its format.
The make_spsr() function which did not allow
manipulation of all the fields in the aarch32 SPSR
has been replaced by these new macros.
Change-Id: I9425dda0923e8d5f03d03ddb8fa0e28392c4c61e
Instead of using the system register helper functions to read
or write system registers, assembler coded functions should
use MRS/MSR instructions. This results in faster and more
compact code.
This change replaces all usage of the helper functions with
direct register accesses.
Change-Id: I791d5f11f257010bb3e6a72c6c5ab8779f1982b3
The current code does not always use data and instruction
barriers as required by the architecture and frequently uses
barriers excessively due to their inclusion in all of the
write_*() helper functions.
Barriers should be used explicitly in assembler or C code
when modifying processor state that requires the barriers in
order to enable review of correctness of the code.
This patch removes the barriers from the helper functions and
introduces them as necessary elsewhere in the code.
PORTING NOTE: check any port of Trusted Firmware for use of
system register helper functions for reliance on the previous
barrier behaviour and add explicit barriers as necessary.
Fixes ARM-software/tf-issues#92
Change-Id: Ie63e187404ff10e0bdcb39292dd9066cb84c53bf
Reduce the number of header files included from other header
files as much as possible without splitting the files. Use forward
declarations where possible. This allows removal of some unnecessary
"#ifndef __ASSEMBLY__" statements.
Also, review the .c and .S files for which header files really need
including and reorder the #include statements alphabetically.
Fixes ARM-software/tf-issues#31
Change-Id: Iec92fb976334c77453e010b60bcf56f3be72bd3e
Add tag names to all unnamed structs in header files. This
allows forward declaration of structs, which is necessary to
reduce header file nesting (to be implemented in a subsequent
commit).
Also change the typedef names across the codebase to use the _t
suffix to be more conformant with the Linux coding style. The
coding style actually prefers us not to use typedefs at all but
this is considered a step too far for Trusted Firmware.
Also change the IO framework structs defintions to use typedef'd
structs to be consistent with the rest of the codebase.
Change-Id: I722b2c86fc0d92e4da3b15e5cab20373dd26786f
Move the BL function prototypes out of arch.h and into the
appropriate header files to allow more efficient header file
inclusion. Create new BL private header files where there is no
sensible existing header file.
Change-Id: I45f3e10b72b5d835254a6f25a5e47cf4cfb274c3
Remove all usage of the vpath keyword in makefiles as it was prone
to mistakes. Specify the relative paths to source files instead.
Also reorder source files in makefiles alphabetically.
Fixes ARM-software/tf-issues#121
Change-Id: Id15f60655444bae60e0e2165259efac71a50928b
Make codebase consistent in its use of #include "" syntax for
user includes and #include <> syntax for system includes.
Fixes ARM-software/tf-issues#65
Change-Id: If2f7c4885173b1fd05ac2cde5f1c8a07000c7a33
Move almost all system include files to a logical sub-directory
under ./include. The only remaining system include directories
not under ./include are specific to the platform. Move the
corresponding source files to match the include directory
structure.
Also remove pm.h as it is no longer used.
Change-Id: Ie5ea6368ec5fad459f3e8a802ad129135527f0b3
This extends the --gc-sections behaviour to the many assembler
support functions in the firmware images by placing each function
into its own code section. This is achieved by creating a 'func'
macro used to declare each function label.
Fixes ARM-software/tf-issues#80
Change-Id: I301937b630add292d2dec6d2561a7fcfa6fec690
All common functions are being built into all binary images,
whether or not they are actually used. This change enables the
use of -ffunction-sections, -fdata-sections and --gc-sections
in the compiler and linker to remove unused code and data from
the images.
Change-Id: Ia9f78c01054ac4fa15d145af38b88a0d6fb7d409
bl1/aarch64/early_exceptions.S used to be re-used by BL2, BL3-1 and
BL3-2. There was some early SMC handling code in there that was not
required by the other bootloader stages. Therefore this patch
introduces an even simpler exception vector source file for BL2,
BL3-1 and BL3-2.
Fixes ARM-software/tf-issues#38
Change-Id: I0244b80e9930b0f8035156a0bf91cc3e9a8f995d
At present, the entry point for each BL image is specified via the
Makefiles and provided on the command line to the linker. When using a
link script the entry point should rather be specified via the ENTRY()
directive in the link script.
This patch updates linker scripts of all BL images to specify the entry
point using the ENTRY() directive. It also removes the --entry flag
passed to the linker through Makefile.
Fixes issue ARM-software/tf-issues#66
Change-Id: I1369493ebbacea31885b51185441f6b628cf8da0
So it updates each time a bootloader changes, not just when bl*_main.c
files are recompiled.
Fixes ARM-software/tf-issues#33
Change-Id: Ie8e1a7bd7e1913d2e96ac268606284f76af8c5ab
Signed-off-by: Jon Medhurst <tixy@linaro.org>
This change requires all platforms to now specify a list of source files
rather than object files.
New source files should preferably be specified by using the path as
well and we should add this in the future for all files so we can remove
use of vpath. This is desirable because vpath hides issues like the fact
that BL2 currently pulls in a BL1 file bl1/aarch64/early_exceptions.S
and if in the future we added bl2/aarch64/early_exceptions.S then it's
likely only one of the two version would be used for both bootloaders.
This change also removes the 'dump' build target and simply gets
bootloaders to always generate a dump file. At the same time the -x
option is added so the section headers and symbols table are listed.
Fixes ARM-software/tf-issues#11
Change-Id: Ie38f7be76fed95756c8576cf3f3ea3b7015a18dc
The BL31 and BL2 linker scripts ended up having duplicate descriptions
for xlat_tables section. This patch removes those duplicate
descriptions.
Change-Id: Ibbdda0902c57fca5ea4e91e0baefa6df8f0a9bb1
This patch factors out the ARM FVP specific code to create MMU
translation tables so that it is possible for a boot loader stage to
create a different set of tables instead of using the default ones.
The default translation tables are created with the assumption that
the calling boot loader stage executes out of secure SRAM. This might
not be true for the BL3_2 stage in the future.
A boot loader stage can define the `fill_xlation_tables()` function as
per its requirements. It returns a reference to the level 1
translation table which is used by the common platform code to setup
the TTBR_EL3.
This patch is a temporary solution before a larger rework of
translation table creation logic is introduced.
Change-Id: I09a075d5da16822ee32a411a9dbe284718fb4ff6
This patch adds support for loading a BL3-2 image in BL2. In case a
BL3-2 image is found, it also passes information to BL3-1 about where it
is located and the extents of memory available to it. Information about
memory extents is populated by platform specific code.
The documentation has also been updated to reflect the above changes.
Change-Id: I526b2efb80babebab1318f2b02e319a86d6758b0
Co-authored-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
This patch reworks BL2 to BL3-1 hand over interface by introducing a
composite structure (bl31_args) that holds the superset of information
that needs to be passed from BL2 to BL3-1.
- The extents of secure memory available to BL3-1
- The extents of memory available to BL3-2 (not yet implemented) and
BL3-3
- Information to execute BL3-2 (not yet implemented) and BL3-3 images
This patch also introduces a new platform API (bl2_get_bl31_args_ptr)
that needs to be implemented by the platform code to export reference to
bl31_args structure which has been allocated in platform-defined memory.
The platform will initialize the extents of memory available to BL3-3
during early platform setup in bl31_args structure. This obviates the
need for bl2_get_ns_mem_layout platform API.
BL2 calls the bl2_get_bl31_args_ptr function to get a reference to
bl31_args structure. It uses the 'bl33_meminfo' field of this structure
to load the BL3-3 image. It sets the entry point information for the
BL3-3 image in the 'bl33_image_info' field of this structure. The
reference to this structure is passed to the BL3-1 image.
Also fixes issue ARM-software/tf-issues#25
Change-Id: Ic36426196dd5ebf89e60ff42643bed01b3500517
This patch ensures that VBAR_EL3 points to the simple stack-less
'early_exceptions' when the C runtime stack is not correctly setup to
use the more complex 'runtime_exceptions'. It is initialised to
'runtime_exceptions' once this is done.
This patch also moves all exception vectors into a '.vectors' section
and modifies linker scripts to place all such sections together. This
will minimize space wastage from alignment restrictions.
Change-Id: I8c3e596ea3412c8bd582af9e8d622bb1cb2e049d
This patch moves the translation tables into their own section. This
saves space that would otherwise have been lost in padding due to page
table alignment constraints. The BL31 and BL32 bases have been
consequently adjusted.
Change-Id: Ibd65ae8a5ce4c4ea9a71a794c95bbff40dc63e65
The Firmware Image Package (FIP) driver allows for data to be loaded
from a FIP on platform storage. The FVP supports loading bootloader
images from a FIP located in NOR FLASH.
The implemented FVP policy states that bootloader images will be
loaded from a FIP in NOR FLASH if available and fall back to loading
individual images from semi-hosting.
NOTE:
- BL3-3(e.g. UEFI) is loaded into DRAM and needs to be configured
to run from the BL33_BASE address. This is currently set to
DRAM_BASE+128MB for the FVP.
Change-Id: I2e4821748e3376b5f9e467cf3ec09509e43579a0
Tidy up the spacing of variable definitions within the makefiles to make
them more consistent, easier to read and amend.
Change-Id: Ic6d7c8489ca4330824abb5cd1ead8f1d449d1a85
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
Move all explicit platform or architecture specific references
into a new platform.mk file that is defined for each platform.
Change-Id: I9d6320d1ba957e0cc8d9b316b3578132331fa428
This patch replaces the empty definition of display_boot_progress() in
bl2_main.c with a weak definition. The former allowed bl2 to use the
early_exceptions(). It is possible to do that with a simple weak
definition as well.
Change-Id: Idb3f425a5e265f3579b638e3d26bd8c9bb78f80d
Ctags seem to have a problem with generating tags for assembler symbols
when a comment immediately follows an assembly label.
This patch inserts a single space character between the label
definition and the following comments to help ctags.
The patch is generated by the command:
git ls-files -- \*.S | xargs sed -i 's/^\([^:]\+\):;/\1: ;/1'
Change-Id: If7a3c9d0f51207ea033cc8b8e1b34acaa0926475
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
- This change is split into two separate patches in order to
simplify the history as interpreted by 'git'. The split is
between the move/rename and addition of new files.
- Remove dependency on toolchain C library headers and functions in
order to ensure behavioural compatibility between toolchains.
- Use FreeBSD as reference for C library implementation.
- Do not let GCC use default library include paths.
- Remove unused definitions in modified headers and implementations.
- Move C library files to 'lib/stdlib' and 'include/stdlib'.
- Break std.c functions out into separate files.
Change-Id: I91cddfb3229775f770ad781589670c57d347a154
Change-Id: Icef68e314e6ba0f3694189b57f4b1dbbea5ba255
Platform setup code has to reserve some memory for storing the
memory layout information. It is populated in early platform setup
code.
blx_get_sec_mem_layout() functions used to return a copy of this
structure. This patch modifies blx_get_sec_mem_layout() functions
so that they now directly return a pointer to their memory layout
structure. It ensures that the memory layout returned by
blx_get_sec_mem_layout() is always up-to-date and also avoids a
useless copy of the meminfo structure.
Also rename blx_get_sec_mem_layout() to blx_plat_sec_mem_layout()
to make it clear those functions are platform specific.
Change-Id: Ic7a6f9d6b6236b14865ab48a9f5eff545ce56551
- Add instructions for contributing to ARM Trusted Firmware.
- Update copyright text in all files to acknowledge contributors.
Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
This patch makes sure the C runtime environment is properly
initialised before executing any C code.
- Zero-initialise NOBITS sections (e.g. the bss section).
- Relocate BL1 data from ROM to RAM.
Change-Id: I0da81b417b2f0d1f7ef667cc5131b1e47e22571f
- Check at link-time that bootloader images will fit in memory
at run time and that they won't overlap each other.
- Remove text and rodata orphan sections.
- Define new linker symbols to remove the need for platform setup
code to know the order of sections.
- Reduce the size of the raw binary images by cutting some sections
out of the disk image and allocating them at load time, whenever
possible.
- Rework alignment constraints on sections.
- Remove unused linker symbols.
- Homogenize linker symbols names across all BLs.
- Add some comments in the linker scripts.
Change-Id: I47a328af0ccc7c8ab47fcc0dc6e7dd26160610b9
blx_plat_arch_setup() should only perform platform-specific
architectural setup, e.g. enabling the MMU. This patch moves
generic architectural setup code out of blx_plat_arch_setup().
Change-Id: I4ccf56b8c4a2fa84909817779a2d97a14aaafab6
