DTC generates warnings when unit names begin with 0, or
when a node containing a reg or range property doesn't have a unit name
in the node name. This patch fixes those cases.
Change-Id: If24ec68ef3034fb3fcefb96c5625c47a0bbd8474
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
FreeBSD does not understand #interrupt-map in a device tree. This prevents the
GIC from being set up correctly. This patch removes the #interrupt-map in the
device trees for the Base and Foundation FVPs. This enables correct boot of
FreeBSD on these platforms.
These changes have been tested with FreeBSD and an Ubuntu cloud image
(ubuntu-16.04-server-cloudimg-arm64-uefi1.img) to ensure compatibility with
Linux.
Change-Id: I1347acdcf994ec4b1dd843ba32af9951aa54db73
Signed-off-by: Achin Gupta <achin.gupta@arm.com>
This patch adds support for SYSTEM_OFF and SYSTEM_RESET PSCI
operations. A platform should export handlers to complete the
requested operation. The FVP port exports fvp_system_off() and
fvp_system_reset() as an example.
If the SPD provides a power management hook for system off and
system reset, then the SPD is notified about the corresponding
operation so it can do some bookkeeping. The TSPD exports
tspd_system_off() and tspd_system_reset() for that purpose.
Versatile Express shutdown and reset methods have been removed
from the FDT as new PSCI sys_poweroff and sys_reset services
have been added. For those kernels that do not support yet these
PSCI services (i.e. GICv3 kernel), the original dtsi files have
been renamed to *-no_psci.dtsi.
Fixes ARM-software/tf-issues#218
Change-Id: Ic8a3bf801db979099ab7029162af041c4e8330c8
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
- Add instructions for contributing to ARM Trusted Firmware.
- Update copyright text in all files to acknowledge contributors.
Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
