MISRA C-2012 Rule 7.3 violation: lowercase l shall not be used as literal suffixes.
This patch resolves this for the ULL() macro by using ULL suffix instead
of the ull suffix.
Change-Id: Ia8183c399e74677e676956e8653e82375d0e0a01
Signed-off-by: David Cunado <david.cunado@arm.com>
Support ARMv7 architectures
If an implementation of ARMv8.2 includes ARMv8.2-LPA, the value 0b0110
is permitted in ID_AA64MMFR0_EL1.PARange, which means that the Physical
Address range supported is 52 bits (4 PiB). It is a reserved value
otherwise.
Change-Id: Ie0147218e9650aa09f0034a9ee03c1cca8db908a
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
ARCH_SUPPORTS_LARGE_PAGE_ADDRESSING allows build environment to
handle specific case when target ARMv7 core only supports 32bit MMU
descriptor mode.
If ARMv7 based platform does not set ARM_CORTEX_Ax=yes, platform
shall define ARMV7_SUPPORTS_LARGE_PAGE_ADDRESSING to enable
large page addressing support.
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
In the S-EL1&0 translation regime we aren't using the higher VA range,
whose translation table base address is held in TTBR1_EL1. The bit
TCR_EL1.EPD1 can be used to disable translations using TTBR1_EL1, but
the code wasn't setting it to 1. Additionally, other fields in TCR1_EL1
associated with the higher VA range (TBI1, TG1, SH1, ORGN1, IRGN1 and
A1) weren't set correctly as they were left as 0. In particular, 0 is a
reserved value for TG1. Also, TBBR1_EL1 was not explicitly set and its
reset value is UNKNOWN.
Therefore memory accesses to the higher VA range would result in
unpredictable behaviour as a translation table walk would be attempted
using an UNKNOWN value in TTBR1_EL1.
On the FVP and Juno platforms accessing the higher VA range resulted in
a translation fault, but this may not always be the case on all
platforms.
This patch sets the bit TCR_EL1.EPD1 to 1 so that any kind of
unpredictable behaviour is prevented.
This bug only affects the AArch64 version of the code, the AArch32
version sets this bit to 1 as expected.
Change-Id: I481c000deda5bc33a475631301767b9e0474a303
Fix the type length and signedness of some of the constants and
variables used in the translation table library.
This patch supersedes Pull Request #1018:
https://github.com/ARM-software/arm-trusted-firmware/pull/1018
Change-Id: Ibd45faf7a4fb428a0bf71c752551d35800212fb2
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Move the header files that provide translation tables architectural
definitions from the library v2 source files to the library include
directory. This allows to share these definitions between both
versions (v1 and v2) of the library.
Create a new header file that includes the AArch32 or AArch64
definitions based on the AARCH32 build flag, so that the library user
doesn't have to worry about handling it on their side.
Also repurpose some of the definitions the header files provide to
concentrate on the things that differ between AArch32 and AArch64.
As a result they now contain the following information:
- the first table level that allows block descriptors;
- the architectural limits of the virtual address space;
- the initial lookup level to cover the entire address space.
Additionally, move the XLAT_TABLE_LEVEL_MIN macro from
xlat_tables_defs.h to the AArch32/AArch64 architectural definitions.
This new organisation eliminates duplicated information in the AArch32
and AArch64 versions. It also decouples these architectural files from
any platform-specific information. Previously, they were dependent on
the address space size, which is platform-specific.
Finally, for the v2 of the library, move the compatibility code for
ADDR_SPACE_SIZE into a C file as it is not needed outside of this
file. For v1, this code hasn't been changed and stays in a header
file because it's needed by several files.
Change-Id: If746c684acd80eebf918abd3ab6e8481d004ac68
A recent commit 030567e6f51731982a7e71cbd387de93bc0e35fd added U()/ULL()
macro to TF constants. This has caused some signed-unsigned comparison
warnings / errors in the TF static analysis.
This patch addresses these issues by migrating impacted variables from
signed ints to unsigned ints and vice verse where applicable.
Change-Id: I4b4c739a3fa64aaf13b69ad1702c66ec79247e53
TLBI instructions for monitor mode won't have the desired effect under
specific circumstances in Cortex-A57 r0p0. The workaround is to
execute DSB and TLBI twice each time.
Even though this errata is only needed in r0p0, the current errata
framework is not prepared to apply run-time workarounds. The current one
is always applied if compiled in, regardless of the CPU or its revision.
The `DSB` instruction used when initializing the translation tables has
been changed to `DSB ISH` as an optimization and to be consistent with
the barriers used for the workaround.
NOTE: This workaround is present in AArch64 TF and already enabled by
default on Juno.
Change-Id: I10b0baa304ed64b13b7b26ea766e61461e759dfa
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Fix execute-never permissions in xlat tables libs
Use SPDX license identifiers
To make software license auditing simpler, use SPDX[0] license
identifiers instead of duplicating the license text in every file.
NOTE: Files that have been imported by FreeBSD have not been modified.
[0]: https://spdx.org/
Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a
Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
Translation regimes that only support one virtual address space (such as
the ones for EL2 and EL3) can flag memory regions as execute-never by
setting to 1 the XN bit in the Upper Attributes field in the translation
tables descriptors. Translation regimes that support two different
virtual address spaces (such as the one shared by EL1 and EL0) use bits
PXN and UXN instead.
The Trusted Firmware runs at EL3 and EL1, it has to handle translation
tables of both translation regimes, but the previous code handled both
regimes the same way, as if both had only 1 VA range.
When trying to set a descriptor as execute-never it would set the XN
bit correctly in EL3, but it would set the XN bit in EL1 as well. XN is
at the same bit position as UXN, which means that EL0 was being
prevented from executing code at this region, not EL1 as the code
intended. Therefore, the PXN bit was unset to 0 all the time. The result
is that, in AArch64 mode, read-only data sections of BL2 weren't
protected from being executed.
This patch adds support of translation regimes with two virtual address
spaces to both versions of the translation tables library, fixing the
execute-never permissions for translation tables in EL1.
The library currently does not support initializing translation tables
for EL0 software, therefore it does not set/unset the UXN bit. If EL1
software needs to initialize translation tables for EL0 software, it
should use a different library instead.
Change-Id: If27588f9820ff42988851d90dc92801c8ecbe0c9
xlat lib: Don't set mmap_attr_t enum to be -1
-1 is not a defined mmap_attr_t type. Instead of using invalid enum
types, we can either choose to define a INVALID type OR handle the
condition specifically.
Since the usage of mmap_region_attr is limited, it is easier to just
handle the error condition specifically and return 0 or -1 depending
on success or fail.
Fixes: ARM-Software/tf-issues#473
Fixes: 28fa2e9ee8f4 ("xlat lib: Use mmap_attr_t type consistently")
Signed-off-by: Nishanth Menon <nm@ti.com>
utils.h is included in various header files for the defines in it.
Some of the other header files only contain defines. This allows the
header files to be shared between host and target builds for shared defines.
Recently types.h has been included in utils.h as well as some function
prototypes.
Because of the inclusion of types.h conflicts exist building host tools
abd these header files now. To solve this problem,
move the defines to utils_def.h and have this included by utils.h and
change header files to only include utils_def.h and not pick up the new
types.h being introduced.
Fixes ARM-software/tf-issues#461
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
Remove utils_def.h from utils.h
This patch removes utils_def.h from utils.h as it is not required.
And also makes a minor change to ensure Juno platform compiles.
Change-Id: I10cf1fb51e44a8fa6dcec02980354eb9ecc9fa29
This patch modifies both versions of the translation table library
to use the mmap_attr_t type consistently wherever it is manipulating
MT_* attributes variables. It used to use mmap_attr_t or plain integer
types interchangeably, which compiles fine because an enumeration type
can be silently converted to an integer, but which is semantically
incorrect.
This patch removes this assumption by using the abstract type
'mmap_attr_t' all the time.
Change-Id: Id1f099025d2cb962b275bb7e39ad2c4dbb4e366c
Many asserts depend on code that is conditionally compiled based on the
DEBUG define. This patch modifies the conditional inclusion of such code
so that it is based on the ENABLE_ASSERTIONS build option.
Change-Id: I6406674788aa7e1ad7c23d86ce94482ad3c382bd
This patch adds an additional flag `XLAT_TABLE_NC` which marks the
translation tables as Non-cacheable for MMU accesses.
Change-Id: I7c28ab87f0ce67da237fadc3627beb6792860fd4
Signed-off-by: Summer Qin <summer.qin@arm.com>
TLBI instructions for EL3 won't have the desired effect under specific
circumstances in Cortex-A57 r0p0. The workaround is to execute DSB and
This errata has been enabled for Juno.
Change-Id: Ifc1d70b79cb5e0d87e90d88d376a59385667d338
In AArch64, depending on the granularity of the translation tables,
level 0 and/or level 1 of the translation tables may not support block
descriptors, only table descriptors.
This patch introduces a check to make sure that, even if theoretically
it could be possible to create a block descriptor to map a big memory
region, a new subtable will be created to describe its mapping.
Change-Id: Ieb9c302206bfa33fbaf0cdc6a5a82516d32ae2a7
Added the definitions `PLAT_PHY_ADDR_SPACE_SIZE` and
`PLAT_VIRT_ADDR_SPACE_SIZE` which specify respectively the physical
and virtual address space size a platform can use.
`ADDR_SPACE_SIZE` is now deprecated. To maintain compatibility, if any
of the previous defines aren't present, the value of `ADDR_SPACE_SIZE`
will be used instead.
For AArch64, register ID_AA64MMFR0_EL1 is checked to calculate the
max PA supported by the hardware and to verify that the previously
mentioned definition is valid. For AArch32, a 40 bit physical
address space is considered.
Added asserts to check for overflows.
Porting guide updated.
Change-Id: Ie8ce1da5967993f0c94dbd4eb9841fc03d5ef8d6
Each translation table level entry can only map a given virtual
address onto physical addresses of the same granularity. For example,
with the current configuration, a level 2 entry maps blocks of 2 MB,
so the physical address must be aligned to 2 MB. If the address is not
aligned, the MMU will just ignore the lower bits.
This patch adds an assertion to make sure that physical addresses are
always aligned to the correct boundary.
Change-Id: I0ab43df71829d45cdbe323301b3053e08ca99c2c
Instead of hardcoding a level 1 table as the base translation level
table, let the code decide which level is the most appropriate given
the virtual address space size.
As the table granularity is 4 KB, this allows the code to select
level 0, 1 or 2 as base level for AArch64. This way, instead of
limiting the virtual address space width to 39-31 bits, widths of
48-25 bit can be used.
For AArch32, this change allows the code to select level 1 or 2
as the base translation level table and use virtual address space
width of 32-25 bits.
Also removed some unused definitions related to translation tables.
Fixes ARM-software/tf-issues#362
Change-Id: Ie3bb5d6d1a4730a26700b09827c79f37ca3cdb65
This patch adds translation library supports for AArch32 platforms.
The library only supports long descriptor formats for AArch32.
The `enable_mmu_secure()` enables the MMU for secure world with
`TTBR0` pointing to the populated translation tables.
Change-Id: I061345b1779391d098e35e7fe0c76e3ebf850e08
This patch fixes the translation table library for wraparound cases. These
cases are not expected to occur on AArch64 platforms because only the
48 bits of the 64 bit address space are used. But it is a possibility for
AArch32 platforms.
Change-Id: Ie7735f7ba2977019381e1c124800381471381499
This patch reworks type usage in generic code, drivers and ARM platform files
to make it more portable. The major changes done with respect to
type usage are as listed below:
* Use uintptr_t for storing address instead of uint64_t or unsigned long.
* Review usage of unsigned long as it can no longer be assumed to be 64 bit.
* Use u_register_t for register values whose width varies depending on
whether AArch64 or AArch32.
* Use generic C types where-ever possible.
In addition to the above changes, this patch also modifies format specifiers
in print invocations so that they are AArch64/AArch32 agnostic. Only files
related to upcoming feature development have been reworked.
Change-Id: I9f8c78347c5a52ba7027ff389791f1dad63ee5f8
This patch introduces a new header file: include/lib/utils.h.
Its purpose is to provide generic macros and helper functions that
are independent of any BL image, architecture, platform and even
not specific to Trusted Firmware.
For now, it contains only 2 macros: ARRAY_SIZE() and
IS_POWER_OF_TWO(). These were previously defined in bl_common.h and
xlat_tables.c respectively.
bl_common.h includes utils.h to retain compatibility for platforms
that relied on bl_common.h for the ARRAY_SIZE() macro. Upstream
platform ports that use this macro have been updated to include
utils.h.
Change-Id: I960450f54134f25d1710bfbdc4184f12c049a9a9
This patch introduces the MT_EXECUTE/MT_EXECUTE_NEVER memory mapping
attributes in the translation table library to specify the
access permissions for instruction execution of a memory region.
These new attributes should be used only for normal, read-only
memory regions. For other types of memory, the translation table
library still enforces the following rules, regardless of the
MT_EXECUTE/MT_EXECUTE_NEVER attribute:
- Device memory is always marked as execute-never.
- Read-write normal memory is always marked as execute-never.
Change-Id: I8bd27800a8c1d8ac1559910caf4a4840cf25b8b0
This patch clarifies the mmap_desc() function by adding some comments
and reorganising its code. No functional change has been introduced.
Change-Id: I873493be17b4e60a89c1dc087dd908b425065401
This patch fixes the computation of the bitmask used to isolate
the level 1 field of a virtual address. The whole computation needs
to work on 64-bit values to produce the correct bitmask value.
XLAT_TABLE_ENTRIES_MASK being a C constant, it is a 32-bit value
so it needs to be extended to a 64-bit value before it takes part
in any other computation.
This patch fixes this bug by casting XLAT_TABLE_ENTRIES_MASK as
an unsigned long long.
Note that this bug doesn't manifest itself in practice because
address spaces larger than 39 bits are not yet supported in the
Trusted Firmware.
Change-Id: I955fd263ecb691ca94b29b9c9f576008ce1d87ee
The only case in which regions can now overlap is if they are
identity mapped or they have the same virtual to physical address
offset (identity mapping is just a particular case of the latter).
They must overlap completely (i.e. one of them must be completely
inside the other one) and not cover the same area.
This allow future enhancements to the xlat_tables library without
having to support unnecessarily complex edge cases.
Outer regions are now sorted by mmap_add_region() before inner
regions with the same base virtual address for consistency: all
regions contained inside another one must be placed after the outer
one in the list.
If an inner region has the same attributes as the outer ones it will
be merged when creating the tables with init_xlation_table(). This
cannot be done as regions are added because there may be cases where
adding a region makes previously mergeable regions no longer
mergeable.
If the attributes of an inner region are different than the outer
region, new pages will be generated regardless of how "restrictive"
they are. For example, RO memory is more restrictive than RW. The
old implementation would give priority to RO if there is an overlap,
the new one doesn't.
NOTE: THIS IS THEORETICALLY A COMPATABILITY BREAK FOR PLATFORMS THAT
USE THE XLAT_TABLES LIBRARY IN AN UNEXPECTED WAY. PLEASE RAISE A
TF-ISSUE IF YOUR PLATFORM IS AFFECTED.
Change-Id: I75fba5cf6db627c2ead70da3feb3cc648c4fe2af
The AArch32 long descriptor format and the AArch64 descriptor format
correspond to each other which allows possible sharing of xlat_tables
library code between AArch64 and AArch32. This patch refactors the
xlat_tables library code to seperate the common functionality from
architecture specific code. Prior to this patch, all of the xlat_tables
library code were in `lib/aarch64/xlat_tables.c` file. The refactored code
is now in `lib/xlat_tables/` directory. The AArch64 specific programming
for xlat_tables is in `lib/xlat_tables/aarch64/xlat_tables.c` and the rest
of the code common to AArch64 and AArch32 is in
`lib/xlat_tables/xlat_tables_common.c`. Also the data types used in
xlat_tables library APIs are reworked to make it compatible between AArch64
and AArch32.
The `lib/aarch64/xlat_tables.c` file now includes the new xlat_tables
library files to retain compatibility for existing platform ports.
The macros related to xlat_tables library are also moved from
`include/lib/aarch64/arch.h` to the header `include/lib/xlat_tables.h`.
NOTE: THE `lib/aarch64/xlat_tables.c` FILE IS DEPRECATED AND PLATFORM PORTS
ARE EXPECTED TO INCLUDE THE NEW XLAT_TABLES LIBRARY FILES IN THEIR MAKEFILES.
Change-Id: I3d17217d24aaf3a05a4685d642a31d4d56255a0f
