This patch invokes the new function gicv3_rdistif_probe() in the
ARM platform specific gicv3 driver. Since this API modifies the
shared GIC related data structure, it must be invoked coherently
by using the platform specific pwr_domain_on_finish_late hook.
Change-Id: I6efb17d5da61545a1c5a6641b8f58472b31e62a8
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
Signed-off-by: Julius Werner <jwerner@chromium.org>
Fixed the path to a source file specified in tsp makefile
Created a platform specific tsp makefile
Change-Id: I89565127c67eff510e48e21fd450af4c3088c2d4
The BL1 stage setup code for ARM platforms sets up the SP805 watchdog
controller as the secure watchdog. But not all ARM platforms use SP805
as the secure watchdog controller.
So introduce two new ARM platform code specific wrapper functions to
start and stop the secure watchdog. These functions then replace the
calls to SP805 driver in common BL1 setup code. All the ARM platforms
implement these wrapper functions by either calling into SP805 driver
or the SBSA watchdog driver.
Change-Id: I1a9a11b124cf3fac2a84f22ca40acd440a441257
Signed-off-by: Aditya Angadi <aditya.angadi@arm.com>
There is a bug in the shared heap implementation for SGM. Until the bug
is solved, the default implementation is used.
Change-Id: I010911a3f00ed860f742b14daad1d99b9e7ce711
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
* changes:
Mbed TLS: Remove weak heap implementation
sgm: Fix bl2 sources
The weak version of plat_get_mbedtls_heap() was being used.
Change-Id: I6da331a098dd1af5bb64729d5b914cfb74b8869e
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
This file is used when building the cert_create tool without using
the 'standard' set of Arm OID values as defined in the TBBR
specification (see tbbr_oid.h). This configuration is enabled by
setting USE_TBBR_DEFS to 0 during build.
At the moment this will fail because the header file included by
this file was removed in commit bb41eb7a9dc3 ("cert: move
platform_oid.h to include/tools_share for all platforms"). For
the SGM platform this means that there is no current use for
this file.
Change-Id: I3c82983ada62330f1ab6be6d6c0cf489adabae7b
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
Improved support for W=1 compilation flag by solving missing-prototypes
and old-style-definition warnings.
The libraries are compiling with warnings (which turn into errors with
the Werror flag).
Outside of libraries, some warnings cannot be fixed without heavy
structural changes.
Change-Id: I1668cf99123ac4195c2a6a1d48945f7a64c67f16
MHU doorbell driver requires arm platform specific
macro "PLAT_CSS_MHU_BASE".
Rename it to "PLAT_MHUV2_BASE", so that platforms other than arm
can use generic MHU doorbell driver.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Replace all uses of 'SGI_CLARK' with 'RD_N1E1_EDGE' and
'SGI_CLARK_HELIOS' with 'RD_E1_EDGE' as per the updated product
names
Change-Id: Ib8136e421b1a46da1e5df58c6b1432d5c78d279b
Signed-off-by: Chandni Cherukuri <chandni.cherukuri@arm.com>
Change-Id: Ideb49011da35f39ff1959be6f5015fa212ca2b6b
Many parts of the code were duplicating symbols that are defined in
include/common/bl_common.h. It is better to only use the definitions in
this header.
As all the symbols refer to virtual addresses, they have to be
uintptr_t, not unsigned long. This has also been fixed in bl_common.h.
Change-Id: I204081af78326ced03fb05f69846f229d324c711
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Change-Id: Ia601d5ad65ab199e747fb60af4979b7db477d249
Change-Id: Ida5dae39478654405d0ee31a6cbddb4579e76a7f
Change-Id: Icc59cdaf2b56f6936e9847f1894594c671db2e94
Change-Id: I656753a1825ea7340a3708b950fa6b57455e9056
Change-Id: I8989d2aa0258bf3b50a856c5b81532d578600124
Use full include paths like it is done for common includes.
This cleanup was started in commit d40e0e08283a ("Sanitise includes
across codebase"), but it only cleaned common files and drivers. This
patch does the same to Arm platforms.
Change-Id: If982e6450bbe84dceb56d464e282bcf5d6d9ab9b
On ARM platforms, the BL2 memory can be overlaid by BL31/BL32. The memory
descriptors describing the list of executable images are created in BL2
R/W memory, which could be possibly corrupted later on by BL31/BL32 due
to overlay. This patch creates a reserved location in SRAM for these
descriptors and are copied over by BL2 before handing over to next BL
image.
Also this patch increases the PLAT_ARM_MAX_BL2_SIZE for juno when TBBR
is enabled.
Fixes ARM-Software/tf-issues#626
Change-Id: I755735706fa702024b4032f51ed4895b3687377f
Signed-off-by: Sathees Balya <sathees.balya@arm.com>
synquacer: add SPM support
Move BL1 and BL2 private defines to bl_common.h
Correct typographical errors
Corrects typos in core code, documentation files, drivers, Arm
platforms and services.
None of the corrections affect code; changes are limited to comments
and other documentation.
Change-Id: I5c1027b06ef149864f315ccc0ea473e2a16bfd1d
From now on, platform_def.h must include any header with definitions that
are platform-specific (like arm_def.h) and the included headers mustn't
include back platform_def.h, and shouldn't be used by other files. Only
platform_def.h should be included in other files. This will ensure that all
needed definitions are present, rather than needing to include all the
headers in all the definitions' headers just in case.
This also prevents problems like cyclic dependencies.
Change-Id: I9d3cf4d1de4b956fa035c79545222697acdaf5ca
The definitions in bl1/bl1_private.h and bl2/bl2_private.h are useful for
platforms that may need to access them.
Change-Id: Ifd1880f855ddafcb3bfcaf1ed4a4e0f121eda174
Update some asserts that refer to #defines that only occur in
ARM platforms, preventing this code to be used on other platforms.
Instead, use a platform agnostic name, and update all the existing
users.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fix a variable expansion in Arm platform makefiles
This patch removes the dependency of the N1SDP on soc
css defines in order to let the N1SDP platform port
define the uart related constants.
Change-Id: If13796f278586a01512ee99615502b30e478189e
Signed-off-by: Deepak Pandey <Deepak.Pandey@arm.com>
The top level makefile defines the PLAT variable, not PLATFORM.
This mistake was causing an empty variable expansion and showing an
incomplete error message.
Change-Id: I5da1275c73c61a7c1823643a76300f255841719d
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
Even though this is not used unless SPD=tspd, only defining it when
SPD_tspd is defined doesn't have any advantage and it makes it harder to
read the code.
Change-Id: I3d93135e05f39be071d16f8a47394a9a3ff54bc8
SGI-Clark.Helios platform support patches
For SGI-Clark.Helios platform, at present, only the CPU power ON/OFF
ops are supported. So override the PSCI ops to allow callbacks only
for CPU power ON/OFF operations.
Change-Id: Idc0a3deb78cb850310cbe849d77604fa9881579c
SGI-Clark.Helios platform is based on multi-threaded CPUs and uses an
additional thread power domain level as well.
Define a power domain tree descriptor 'sgi_clark_helios_pd_tree_desc'
for SGI-Clark.Helios platform and let the function
'plat_get_power_domain_tree_desc' pick up the correct power
domain tree descriptor based on the platform.
Change-Id: Ibc6d551b570bc740053316a3608c455679d9155b
With the two new APIs 'plat_arm_sgi_get_platform_id' and
'plat_arm_sgi_get_config_id' that are available now, BL31 need not
depend on hw_config device tree to identify the platform. In addition
to this, the existing hardware description in hw_config can be limited
to use by BL33 and not by the operating system.
So the hardware description from hw_config dts can be moved into
nt_fw_config dts and the use of hw_config dts can be removed.
Change-Id: I873b7e1e72823d3ec5d253a848e85ae724f09e49
plat/arm/sgi: Use platform specific functions to get platform ids
Add support to implement multi-threaded platforms for SGI
Add two new functions 'plat_arm_sgi_get_platform_id' and
'plat_arm_sgi_get_config_id' which will be implemented by all the
SGI platforms. These functions can be used to determine the part
number and configuration id of the SGI platforms.
In BL2, these functions are used to populate the 'system-id' node.
In BL31, these functions are used to populate the 'sgi_plat_info_t'
structure with the part number and configuration id of the platform.
Change-Id: I3bacda933527724a3b4074ad4ed5b53a81ea4689
In order to allow Arm platforms to override the default list of PSCI
callbacks, remove the existing weak implementation of
'plat_arm_psci_override_pm_ops' function and let all the Arm platforms
implement their own 'plat_arm_psci_override_pm_ops' function.
For platforms that support SCMI protocol, the function
'css_scmi_override_pm_ops' can be additionally used as well to
override the default PSCI callbacks.
Change-Id: If7c27468bd51a00ea9c2a3716b5894163f5a9f3c
For platforms with multi-threaded CPUs, the number of power domains
supported would be more than the value currently defined by
PLAT_MAX_PWR_LVL. So move the PLAT_MAX_PWR_LVL macro to platform
specific code and let the platform define the number of power domain
levels.
Change-Id: I21c0682e62b397860b2999031a0c9c5ce0d28eed
To support platforms which are based on multi-threaded CPUs, override
the weak implementation of plat_arm_get_cpu_pe_count function to return
the number of threads supported by the CPU used in the platform.
Change-Id: Ia680773f1277b17e2d3d2414d87943dcece33e89
The CSS_SYSTEM_PWR_DMN_LVL macro that defines the system power domain
level is fixed at ARM_PWR_LVL2 for all CSS platforms. However, the
system power domain level can be different for CSS platforms that
use multi-threaded CPUs.
So, in preparation towards adding support for platforms that use
multi-threaded CPUs, refactor the definition of CSS_SYSTEM_PWR_DMN_LVL
such that CSS_SYSTEM_PWR_DMN_LVL is uniquely defined for each of the
CSS platform.
Change-Id: Ia837b13f6865e71da01780993c048b45b7f36d85
Remove the platform common plat_arm_security_setup function to allow
platform specific implementations of the security setup function
implemented in the board directory of the platform.
For use by secure software, configure region0 of DMC-620 trustzone
controller to protect the upper 16MB of memory of the first DRAM block
from non-secure accesses.
Change-Id: I9a8c19656702c4fa4f6917b3655b692d443bb568
Signed-off-by: Vijayenthiran Subramaniam <vijayenthiran.subramaniam@arm.com>
Register a priority level, PLAT_SP_PRI, for secure partition with EL3
exception handling framework(ehf) module.
The secure partition manager(SPM) would raise the core's priority to
PLAT_SP_PRI before entering the secure partition, to protect the core
from getting interrupted while in secure partition.
Change-Id: I686897f052a4371e0efa9b929c07d3ad77249e95
Signed-off-by: Sughosh Ganu <sughosh.ganu@arm.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
Sgiclark ares support
This patch makes use of mov_imm macro where possible to load
immediate values within ARM platform layer.
Change-Id: I02bc7fbc1fa334c9fccf76fbddf515952f9a1298
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
SGI-Clark platform is the next version in the Arm's SGI platform
series. One of the primary difference between the SGI-575 platform and
the SGI-Clark platform is the MHU version (MHUv2 in case of SGI-Clark).
Add the required base support for SGI-Clark platform.
Change-Id: If396e5279fdf801d586662dad0b55195e81371e4
On SGI platforms that include Ares CPUs, the 'CORE_PWRDN_EN' bit of
'CPUPWRCTLR_EL1' register requires an explicit write to clear it to
enable hotplug and idle to function correctly.
The reset value of the CORE_PWRDN_EN bit is zero but it still requires
this explicit clear to zero. This indicates that this could be a model
related issue but for now this issue can be fixed be clearing the
CORE_PWRDN_EN bit in the platform specific reset handler function.
Change-Id: I8b9884ae27a2986d789bfec2e9ae792ef930944e
