On i.MX8MP, the SRC GPR9(0x94) is used by memory repair, so choose
SRC GPR10(0x98) as the LPA status sync register. Add use '==' instead
of '&' for LPA active statue check.
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
Support stop M7 with SIP call.
Per IC team, to rekick M7 need follow steps.
If M7 already in WFI, perform below steps.
a) Set [0x303A_002C].0=0 [ request SLEEPHOLDREQn ]
b) Wait [0x303A_00EC].1 = 0 [ wait SLEEPHOLDACKn ]
c) Set GPR.CPUWAIT=1
d) Set [0x303A_002C].0=1 [ de-assert SLEEPHOLDREQn ]
e) Set SRC_M7_RCR[3:0] = 0xE0 [ reset M7 core/plat ]
f) Wait SRC_M7_RCR[3:0] = 0x8
g) Init TCM or DDR
h) Set GPR.INITVTOR
i) Set GPR.CPUWAIT=0, M7 starting running
Add a timeout check, if timeout, still perform force reset, in this
way no need to rely on M7 team's image wfi support ready.
Return a1,a2 to caller to check timeout or reset fail.
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
On i.MX8MN & i.MX8MP, the M core enabled check should
relay on the IOMUX GPR CPU_WAIT bit, when this bit is
cleared, it means M core is active & running, so refine
the m4 enabled check method.
move the gpc reg offset, bit define & macro to a separate header
file for code reuse.
Port and cleanup OP-TEE support.
Signed-off-by: Silvano di Ninno <silvano.dininno@nxp.com>
Add the M core low power audio support on i.MX8M.
Add the SRC SiP handler for M4/M7 boot support on i.MX8M SoC.
Add the HAB secure boot support for the i.MX8M SoC family.
Signed-off-by: Ye Li <ye.li@nxp.com>
Add the PU power domain support for imx8mm/mn.
Add the DDR frequency change support.
Change-Id: I84f0ef51b04b84da8ba2cbeca86a07338a4903de
Add imx8mn basic support
