NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
This consists of ensuring that the left operand of each shift is
unsigned when the operation might overflow into the sign bit.
Change-Id: Ib63ef6e2e4616dd56828bfd3800d5fe2df109934
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
The old version of the macro is deprecated.
Commit cc5859ca19ff ("Multi-console: Deprecate the
`finish_console_register` macro") provides more details.
Change-Id: I3d1cdf6496db7d8e6cfbb5804f508ff46ae7e67e
Also, update platform_def.h guidelines about includes in the porting
guide.
Change-Id: I1ae338c9dd3242b309f6d53687ba2cb755d488c3
Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Many parts of the code were duplicating symbols that are defined in
include/common/bl_common.h. It is better to only use the definitions in
this header.
As all the symbols refer to virtual addresses, they have to be
uintptr_t, not unsigned long. This has also been fixed in bl_common.h.
Change-Id: I204081af78326ced03fb05f69846f229d324c711
The definitions in bl1/bl1_private.h and bl2/bl2_private.h are useful for
platforms that may need to access them.
Change-Id: Ifd1880f855ddafcb3bfcaf1ed4a4e0f121eda174
Enforce full include path for includes. Deprecate old paths.
The following folders inside include/lib have been left unchanged:
- include/lib/cpus/${ARCH}
- include/lib/el3_runtime/${ARCH}
The reason for this change is that having a global namespace for
includes isn't a good idea. It defeats one of the advantages of having
folders and it introduces problems that are sometimes subtle (because
you may not know the header you are actually including if there are two
of them).
For example, this patch had to be created because two headers were
called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform
to avoid collision."). More recently, this patch has had similar
problems: 46f9b2c3a282 ("drivers: add tzc380 support").
This problem was introduced in commit 4ecca33988b9 ("Move include and
source files to logical locations"). At that time, there weren't too
many headers so it wasn't a real issue. However, time has shown that
this creates problems.
Platforms that want to preserve the way they include headers may add the
removed paths to PLAT_INCLUDES, but this is discouraged.
Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f
MULTI_CONSOLE_API fixes and cleanups
This patch makes the build system link the console framework code by
default, like it already does with other common libraries (e.g. cache
helpers). This should not make a difference in practice since TF is
linked with --gc-sections, so the linker will garbage collect all
functions and data that are not referenced by any other code. Thus, if a
platform doesn't want to include console code for size reasons and
doesn't make any references to console functions, the code will not be
included in the final binary.
To avoid compatibility issues with older platform ports, only make this
change for the MULTI_CONSOLE_API.
Change-Id: I153a9dbe680d57aadb860d1c829759ba701130d3
Add tzc380 support.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Bai Ping <ping.bai@nxp.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
The macro EL_IMPLEMENTED() has been deprecated in favour of the new
function el_implemented().
Change-Id: Ic9b1b81480b5e019b50a050e8c1a199991bf0ca9
include/plat/arm/common isn't needed by them, and is removed to avoid
dependency on Arm platform code.
Change-Id: Id9fccba33326fd075b3d1029bf1e4b012dfa0483
The `finish_console_register` macro is used by the multi console
framework to register the `console_t` driver callbacks. It relied
on weak references to the `ldr` instruction to populate 0 to the
callback in case the driver has not defined the appropriate
function. Use of `ldr` instruction to load absolute address to a
reference makes the binary position dependant. These instructions
should be replaced with adrp/adr instruction for position independant
executable(PIE). But adrp/adr instructions don't work well with weak
references as described in GNU ld bugzilla issue 22589.
This patch defines a new version of `finish_console_register` macro
which can spcify which driver callbacks are valid and deprecates the
old one. If any of the argument is not specified, then the macro
populates 0 for that callback. Hence the functionality of the previous
deprecated macro is preserved. The USE_FINISH_CONSOLE_REG_2 define
is used to select the new variant of the macro and will be removed
once the deprecated variant is removed.
All the upstream console drivers have been migrated to use the new
macro in this patch.
NOTE: Platforms be aware that the new variant of the
`finish_console_register` should be used and the old variant is
deprecated.
Change-Id: Ia6a67aaf2aa3ba93932992d683587bbd0ad25259
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
The "Secure" prefix (S-ELx) is valid only for S-EL0 and S-EL1 but is
meaningless for EL3, since EL3 is always secure. Hence, the "S" prefix
has been removed from wherever it was used as "S-EL3".
Change-Id: Icdeac9506d763f9f83d7297c7113aec7b85e9dbe
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
- Migrate to new GIC interfaces.
- Remove references to removed build options.
Change-Id: I6f90a33d5438a9d7b71be3f93e8d9da278c8c6e6
Change-Id: I5993b425445ee794e6d2a792c244c0af53640655
The codebase was using non-standard headers. It is needed to replace
them by the correct ones so that we can use the new libc headers.
Change-Id: I530f71d9510cb036e69fe79823c8230afe890b9d
Acked-by: Sumit Garg <sumit.garg@linaro.org>
Change-Id: I3d16b247a0fa457e6293e2d2c4503dfde1e51c1d
Also change header guards to fix defects of MISRA C-2012 Rule 21.1.
Change-Id: Ied0d4b0e557ef6119ab669d106d2ac5d99620c57
Acked-by: Anson Huang <Anson.Huang@nxp.com>
Assert before actually using.
Signed-off-by: Jiafei Pan <Jiafei.Pan@nxp.com>
This patch introduce TF-A support for NXP's ls1043a platform.
more details information of ls1043a chip and ls1043ardb board
can be found at docs/plat/ls1043a.rst.
Boot sequence on ls1043a is: bootrom loads bl1 firstly, then bl1
loads bl2, bl2 will load bl31, bl32 and bl33, bl31 will boot
bl32(tee os) and bl33(u-boot or uefi), bl33 boot Linux kernel.
Now TF-A on ls1043ardb platform has the following features in this patch:
* Support boot from Nor flash.
* TF-A can boot bl33 which runs in el2 of non-secure world.
* TF-A boot OPTee OS.
* Support PSCI
Signed-off-by: Chenyin.Ha <Chenyin.Ha@nxp.com>
Signed-off-by: Chenhui Zhao <chenhui.zhao@nxp.com>
Signed-off-by: jiaheng.fan <jiaheng.fan@nxp.com>
Signed-off-by: Wen He <wen.he_1@nxp.com>
