path: root/.gitignore
2007-07-31.gitignore updateAlexey Dobriyan
Somehow I ended up with the following in tree: $ git status ... # Untracked files: # (use "git add <file>..." to include in what will be committed) # # fs/proc/root.o.FuMxJQ # net/ipv4/tcp_minisocks.o.geCDYR These are presumably temporary gcc files, which aren't interesting. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20Un-ignore "vmlinux.lds.S" in .gitignoreLinus Torvalds
We ignore all the generated files called "vmlinux*" from the top-level gitignore, but that also ends up catching a few files that we track, and that people do edit. Notably the "vmlinux.lds.S" file, that each architecture has. You can always use "git add -f" to override the ignore file, but we might as well just make it explicit for this file. Bitten-by-and-tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16.gitignore updateAlexey Dobriyan
headers_install by default puts headers into usr/include/ . They're auto-generated, so should be ignored. Same for *.orig, *.rej . Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] Add cscope generated files to .gitignoreTobias Klauser
Ignore files generated by 'make cscope' Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] .gitignore: add miscellaneous filesFranck Bui-Huu
Prevent git from reporting this useless status: On branch refs/heads/master Untracked files: (use "git add" to add to commit) TAGS scripts/kconfig/lkc_defs.h scripts/kconfig/qconf.moc nothing to commit Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] Add symbol type files (*.symtypes) to .gitignoreJosh Triplett
The kernel build system supports making symbol type files (*.symtypes) from C source files. Add these files to .gitignore. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] Add mixed source and assembly listings (*.lst) to .gitignoreJosh Triplett
The kernel build system supports making mixed source and assembly listings (*.lst) from C source files. Add these files to .gitignore. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] Add preprocessed files (*.i) to .gitignoreJosh Triplett
The kernel build system supports making preprocessed files (*.i) from C source files. Add these files to .gitignore. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-01gitignore: gitignore quilt's filesQi Yong
gitignore: ignore quilt's files. Signed-off-by: Qi Yong <qiyong@fc-cn.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-08-01kbuild: .gitignore utsrelease.hSam Ravnborg
2006-03-22add "tags" to .gitignoreUwe Zeisberger
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-02-27V4L/DVB (3300b): .gitignore should also ignore StGit generated dirsMauro Carvalho Chehab
StGit genreates patches-* when you run stg export command. It makes no sense to show such directories as changes on git status. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-06gitignore: ignore shared objectsBrian Gerst
Many arches make shared objects for VDSOs. Generally exclude them. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-01gitignore: asm-offsets.hBrian Gerst
Ignore asm-offsets.h for all arches. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-10-18Add some basic .gitignore filesLinus Torvalds
This still leaves driver and architecture-specific subdirectories alone, but gets rid of the bulk of the "generic" generated files that we should ignore. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
