path: root/.gitignore
2018-02-13kbuild: rpm-pkg: keep spec file until make mrproperMasahiro Yamada
commit af60e207087975d069858741c44ed4f450330ac4 upstream. If build fails during (bin)rpm-pkg, the spec file is not cleaned by anyone until the next successful build of the package. We do not have to immediately delete the spec file in case somebody may want to take a look at it. Instead, make them ignored by git, and cleaned up by make mrproper. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13.gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignoreMasahiro Yamada
commit 10b62a2f785ab55857380f0c63d9fa468fd8c676 upstream. Most of DT files are compiled under arch/*/boot/dts/, but we have some other directories, like drivers/of/unittest-data/. We often miss to add gitignore patterns per directory. Since there are no source files that end with .dtb or .dtb.S, we can ignore the patterns globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-13.gitignore: sort normal pattern rules alphabeticallyMasahiro Yamada
commit 1377dd3e29878b8f5d9f5c9000975f50a428a0cd upstream. We are having more and more ignore patterns. Sort the list alphabetically. We will easily catch duplicated patterns if any. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-25kbuild: Add support to generate LLVM assembly filesVinícius Tinti
Add rules to kbuild in order to generate LLVM assembly files with the .ll extension when using clang. # from c code make CC=clang kernel/pid.ll Signed-off-by: Vinícius Tinti <viniciustinti@gmail.com> Signed-off-by: Behan Webster <behanw@converseincode.com> Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-02Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: - coccicheck script improvements by Luis Rodriguez and Deepa Dinamani - new coccinelle patches by Yann Droneaud and Vaishali Thakkar - debian packaging fixes by Wilfried Klaebe, Henning Schild and Marcin Mielniczuk * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Fix the Debian packaging script on systems with no codename builddeb: fix file permissions before packaging scripts/coccinelle: require coccinelle >= 1.0.4 on device_node_continue.cocci coccicheck: refer to Documentation/coccinelle.txt and wiki coccicheck: add support for requring a coccinelle version scripts: add Linux .cocciconfig for coccinelle coccicheck: replace --very-quiet with --quiet when debugging coccicheck: add support for DEBUG_FILE coccicheck: enable parmap support coccicheck: make SPFLAGS more useful coccicheck: move spatch binary check up builddeb: really include objtool binary in headers package coccinelle: catch krealloc() on devm_*() allocated memory coccinelle: recognize more devm_* memory allocation functions coccinelle: also catch kzfree() issues coccicheck: Allow for overriding spatch flags Coccinelle: noderef: Add new rules and correct the old rule
2016-07-22scripts: add Linux .cocciconfig for coccinelleLuis R. Rodriguez
Coccinelle supports reading .cocciconfig, the order of precedence for variables for .cocciconfig is as follows: o Your current user's home directory is processed first o Your directory from which spatch is called is processed next o The directory provided with the --dir option is processed last, if used Since coccicheck runs through make, it naturally runs from the kernel proper dir, as such the second rule above would be implied for picking up a .cocciconfig when using 'make coccicheck'. 'make coccicheck' also supports using M= targets.If you do not supply any M= target, it is assumed you want to target the entire kernel. The kernel coccicheck script has: if [ "$KBUILD_EXTMOD" = "" ] ; then OPTIONS="--dir $srctree $COCCIINCLUDE" else OPTIONS="--dir $KBUILD_EXTMOD $COCCIINCLUDE" fi KBUILD_EXTMOD is set when an explicit target with M= is used. For both cases the spatch --dir argument is used, as such third rule applies when whether M= is used or not, and when M= is used the target directory can have its own .cocciconfig file. When M= is not passed as an argument to coccicheck the target directory is the same as the directory from where spatch was called. If not using the kernel's coccicheck target, keep the above precedence order logic of .cocciconfig reading. If using the kernel's coccicheck target, override any of the kernel's .coccicheck's settings using SPFLAGS. We help Coccinelle when used against Linux with a set of sensible defaults options for Linux with our own Linux .cocciconfig. This hints to coccinelle git can be used for 'git grep' queries over coccigrep. A timeout of 200 seconds should suffice for now. The options picked up by coccinelle when reading a .cocciconfig do not appear as arguments to spatch processes running on your system, to confirm what options will be used by Coccinelle run: spatch --print-options-only You can override with your own preferred index option by using SPFLAGS. Coccinelle supports both glimpse and idutils. Glimpse had historically provided the best performance, however recent benchmarks reveal idutils is performing just as well. Due to some recent fixes however you however will need at least coccinelle >= 1.0.6 if using idutils. Coccinelle carries a script scripts/idutils_index.sh which creates the idutils database with as follows: mkid -i C --output .id-utils.index If using just "--use-idutils" coccinelle expects your idutils database to be on the top level of the kernel as a file named ".id-utils.index". If you do not use this you can symlink your database file to it, or you can specify the database file following the "--use-idutils" argument. Examples: make SPFLAGS=--use-idutils coccicheck This assumes you have $srctree/.id-utils.index, where $srctree is the top level of the kernel. make SPFLAGS="--use-idutils /full-path/to/ID" coccicheck Here you specify the full path of the idutils ID database. Using .cocciconfig is possible, however given the order of precedence followed by Coccinelle, and since the kernel now carries its own .cocciconfig, you will need to use SPFLAGS to use idutils if desired. v4: o Recommend upgrade for using idutils with coccinelle due to some recent fixes. o Refer to using --print-options-only for testing what options are picked up by .cocciconfig reading. o Expand commit log considerably explaining *why* .cocconfig from two precedence rules are used when using coccicheck, and how to properly override these if needed. o Expand Documentation/coccinelle.txt v3: Expand commit log a bit more Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-06-07GCC plugin infrastructureEmese Revfy
This patch allows to build the whole kernel with GCC plugins. It was ported from grsecurity/PaX. The infrastructure supports building out-of-tree modules and building in a separate directory. Cross-compilation is supported too. Currently the x86, arm, arm64 and uml architectures enable plugins. The directory of the gcc plugins is scripts/gcc-plugins. You can use a file or a directory there. The plugins compile with these options: * -fno-rtti: gcc is compiled with this option so the plugins must use it too * -fno-exceptions: this is inherited from gcc too * -fasynchronous-unwind-tables: this is inherited from gcc too * -ggdb: it is useful for debugging a plugin (better backtrace on internal errors) * -Wno-narrowing: to suppress warnings from gcc headers (ipa-utils.h) * -Wno-unused-variable: to suppress warnings from gcc headers (gcc_version variable, plugin-version.h) The infrastructure introduces a new Makefile target called gcc-plugins. It supports all gcc versions from 4.5 to 6.0. The scripts/gcc-plugin.sh script chooses the proper host compiler (gcc-4.7 can be built by either gcc or g++). This script also checks the availability of the included headers in scripts/gcc-plugins/gcc-common.h. The gcc-common.h header contains frequently included headers for GCC plugins and it has a compatibility layer for the supported gcc versions. The gcc-generate-*-pass.h headers automatically generate the registration structures for GIMPLE, SIMPLE_IPA, IPA and RTL passes. Note that 'make clean' keeps the *.so files (only the distclean or mrproper targets clean all) because they are needed for out-of-tree modules. Based on work created by the PaX Team. Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-04-28gitignore: fix wordingKyeongmin Cho
Git files are the files that we don't want to ignore even if they are dot-files. It must be "even if" but it says "even it". Signed-off-by: Kyeongmin Cho <korea.drzix@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-09-08Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: - deb-pkg: + module signing fix + dtb files are added to the package + do not require `hostname -f` to work during build + make deb-pkg generates a source package, bindeb-pkg has been added to only generate the binary package - rpm-pkg packages /lib/modules as well - new coccinelle patch and updates to existing ones - new stackusage & stackdelta script to collect and compare stack usage info (using gcc's -fstack-usage) - make tags understands trace_*_rcuidle() macros - .gitignore updates, misc cleanups * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (27 commits) deb-pkg: add source package package/Makefile: move source tar creation to a function scripts: add stackdelta script kbuild: remove *.su files generated by -fstack-usage .gitignore: add *.su pattern scripts: add stackusage script kbuild: avoid listing /lib/modules in kernel spec file fallback to hostname in scripts/package/builddeb coccinelle: api: extend spatch for dropping unnecessary owner deb-pkg: simplify directory creation scripts/tags.sh: Include trace_*_rcuidle() in tags scripts/package/Makefile: rpmbuild is needed for rpm targets Kbuild: Add ID files to .gitignore gitignore: Add MIPS vmlinux.32 to the list coccinelle: simple_return: Add a blank line coccinelle: irqf_oneshot.cocci: Improve the generated commit log coccinelle: api: add vma_pages.cocci scripts/coccinelle/misc/irqf_oneshot.cocci: Fix grammar scripts/coccinelle/misc/semicolon.cocci: Use imperative mood coccinelle: simple_open: Use imperative mood ...
2015-08-28.gitignore: add *.su patternRasmus Villemoes
Ignore the *.su files generated by using the gcc option -fstack-usage. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Michal Marek <mmarek@suse.com>
2015-08-07modsign: Use single PEM file for autogenerated keyDavid Woodhouse
The current rule for generating signing_key.priv and signing_key.x509 is a classic example of a bad rule which has a tendency to break parallel make. When invoked to create *either* target, it generates the other target as a side-effect that make didn't predict. So let's switch to using a single file signing_key.pem which contains both key and certificate. That matches what we do in the case of an external key specified by CONFIG_MODULE_SIG_KEY anyway, so it's also slightly cleaner. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-06-15Kbuild: Add ID files to .gitignoreAndi Kleen
I use GNU id-utils to find code (essentially a database backed grep), which generates an ID file to maintain its data. Add ID to the .gitignore file. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-06-15gitignore: Add MIPS vmlinux.32 to the listFlorian Fainelli
MIPS64 kernels builds will produce a vmlinux.32 kernel image for compatibility, ignore them. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-04-17.gitignore: ignore *.tarAndrey Skvortsov
Running make tar-pkg results in following: # Untracked files: # (use "git add <file>..." to include in what will be committed) # # linux-4.0.0-rc3-next-20150313-150225--x86.tar This patch makes git ignore *.tar files. Running 'git ls-files -i --exclude-standard' does not show any tar files excluded from tracking after the change. Signed-off-by: Andrey Skvortsov <andrej.skvortzov@gmail.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Benjamin Romer <benjamin.romer@unisys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17scripts/gdb: ignore byte-compiled python filesDaniel Thompson
Using the gdb scripts leaves byte-compiled python files in the scripts/ directory. These should be ignored by git. [jan.kiszka@siemens.com: drop redundant mrproper rule as suggested by Michal] Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12gitignore: ignore tar-install build directoryAndrey Skvortsov
Have git ignore the Debian directory created when running: make tar-pkg / targz-pkg / tarbz2-pkg / tarxz-pkg Signed-off-by: Andrey Skvortsov <andrej.skvortzov@gmail.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-25.gitignore: Add Kdevelop4 project filesBoaz Harrosh
I'm not sure what is the costume with such IDE project files. Most might be dot-files. It is kind of annoying for the Kdevelop4 user. So please consider adding *.kdev4 files to be ignored? Signed-off-by: Boaz Harrosh <boaz@plexistor.com> [mmarek: Moved at the and and added a comment] Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-30kbuild: Support split debug info v4Andi Kleen
This is an alternative approach to lower the overhead of debug info (as we discussed a few days ago) gcc 4.7+ and newer binutils have a new "split debug info" debug info model where the debug info is only written once into central ".dwo" files. This avoids having to copy it around multiple times, from the object files to the final executable. It lowers the disk space requirements. In addition it defaults to compressed debug data. More details here: http://gcc.gnu.org/wiki/DebugFission This patch adds a new option to enable it. It has to be an option, because it'll undoubtedly break everyone's debuginfo packaging scheme. gdb/objdump/etc. all still work, if you have new enough versions. I don't see big compile wins (maybe a second or two faster or so), but the object dirs with debuginfo get significantly smaller. My standard kernel config (slightly bigger than defconfig) shrinks from 2.9G disk space to 1.1G objdir (with non reduced debuginfo). I presume if you are IO limited the compile time difference will be larger. Only problem I've seen so far is that it doesn't play well with older versions of ccache (apparently fixed, see https://bugzilla.samba.org/show_bug.cgi?id=10005) v2: various fixes from Dirk Gouders. Improve commit message slightly. v3: Fix clean rules and improve Kconfig slightly v4: Fix merge error in last version (Sam Ravnborg) Clarify description that it mainly helps disk size. Cc: Dirk Gouders <dirk@gouders.net> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-16.gitignore: ignore Module.symvers in all directoriesZhao, Gang
When using `make M=/path/to/driver modules` to build a module, file Module.symvers will be created in that directory, so it's better to ignore it in all directories. Slightly reordered, let specific file names behind general ones. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Cc: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Zhao, Gang <gamerh2o@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-02-10gitignore: add all.configBorislav Petkov
This is used by kbuild to load preset Kconfig options. We need to ignore it, otherwise git clean kills it. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31.gitignore: ignore *.lz4 filesMarkus Trippelsdorf
Now that lz4 kernel compression is available, add *.lz4 to .gitignore. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Acked-by: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17.gitignore: remove stale entry for generated version.hJonathan Austin
Since userspace headers were moved to generated/uapi it possible to have a stale copy of linux/version.h at that file's old location. This causes confusion after building an older kernel version, then checking out and building a new one; the old (stale) version header will still get picked up until it is manually removed. This upsets the C library. Since the uapi changes, include/linux/version.h is no longer generated and should not be ignored, so this patch removes it from .gitignore. Signed-off-by: Jonathan Austin <jonathan.austin@arm.com> Reported-by: Kevin Petit <kevin.petit@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-19MODSIGN: Cleanup .gitignoreDavid Howells
The module build process no longer creates intermediate files for module signing, so remove them from .gitignore. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-10MODSIGN: Provide gitignore and make clean rules for extra filesDavid Howells
Provide gitignore and make clean rules for extra files to hide and clean up the extra files produced by module signing stuff once it is added. Also add a clean up rule for the module content extractor program used to extract the data to be signed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-01gitignore: ignore debian build directoryGreg Dietsche
Have git ignore the Debian directory created when running: make deb-pkg Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-28kbuild: asm-generic supportSam Ravnborg
There is an increasing amount of header files shared between individual architectures in asm-generic. To avoid a lot of dummy wrapper files that just include the corresponding file in asm-generic provide some basic support in kbuild for this. With the following patch an architecture can maintain a list of files in the file arch/$(ARCH)/include/asm/Kbuild To use a generic file just add: generic-y += <name-of-header-file.h> For each file listed kbuild will generate the necessary wrapper in arch/$(ARCH)/include/generated/asm. When installing userspace headers a wrapper is likewise created. The original inspiration for this came from the unicore32 patchset - although a different method is used. The patch includes several improvements from Arnd Bergmann. Michael Marek contributed Makefile.asm-generic. Remis Baima did an intial implementation along to achive the same - see https://patchwork.kernel.org/patch/13352/ Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn> Tested-by: Guan Xuetao <guanxuetao@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-22.gitignore: ignore *.xz filesRomain Francoise
Building with CONFIG_KERNEL_XZ results in the following: # Untracked files: # (use "git add <file>..." to include in what will be committed) # # arch/x86/boot/compressed/vmlinux.bin.xz So ignore xz-compressed files at the top level like we already do for other compression types. Signed-off-by: Romain Francoise <romain@orebokech.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-03-23.gitignore: ignore *.lzo filesPhilipp Kohlbecher
Ignore files compressed with lzop. Signed-off-by: Philipp Kohlbecher <xt28@gmx.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-03-12Fix up .gitignore for top-level file patternsLinus Torvalds
Some of the gitignore file patters were explicitly meant to be only for the top level, but weren't marked that way, so they would trigger recursively in subdirectories too. Normally that was harmless, but at least "linux" happened to trigger elsewhere too. Fix it up. And other patterns in that section weren't necessarily top-level at all. Reported-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06um: tell git to ignore generated filesWANG Cong
Tell git to ignore the generated files under um, except: include/shared/kern_constants.h include/shared/user_constants.h which will be moved to include/generated. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11.gitignore: ignore vmlinuzFlorian Fainelli
MIPS compressed kernels output a vmlinuz file in the top-level directory (maybe others do). Add vmlinuz to the list of files to ignore by git. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12kbuild: generate modules.builtinMichal Marek
To make it easier for module-init-tools and scripts like mkinitrd to distinguish builtin and missing modules, install a modules.builtin file listing all builtin modules. This is done by generating an additional config file (tristate.conf) with tristate options set to uppercase 'Y' or 'M'. If we source that config file, the builtin modules appear in obj-Y. Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move autoconf.h to include/generatedSam Ravnborg
2009-12-12kbuild: move compile.h to include/generatedSam Ravnborg
2009-12-12kbuild: drop include/asmSam Ravnborg
We no longer use this directory for generated files and all architectures has moved their header files so no symlink tricks are needed either. Drop the symlink and drop the ARCH check. If we really need to check that the SRCARCH has not changed when we build a kernel we can add this check back - but then we will find a more convenient way to store the info. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move asm-offsets.h to include/generatedSam Ravnborg
The simplest method was to add an extra asm-offsets.h file in arch/$ARCH/include/asm that references the generated file. We can now migrate the architectures one-by-one to reference the generated file direct - and when done we can delete the temporary arch/$ARCH/include/asm/asm-offsets.h file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move bounds.h to include/generatedSam Ravnborg
2009-11-30.gitignore: Add bzip2 compressed filesGertjan van Wingerde
We can have bzip2 compressed images nowadays. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-27gitignore: ignore gcov output filesAmerigo Wang
Ignore *.gcno files which are generated by gcov. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-14Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (53 commits) .gitignore: ignore *.lzma files kbuild: add generic --set-str option to scripts/config kbuild: simplify argument loop in scripts/config kbuild: handle non-existing options in scripts/config kallsyms: generalize text region handling kallsyms: support kernel symbols in Blackfin on-chip memory documentation: make version fix kbuild: fix a compile warning gitignore: Add GNU GLOBAL files to top .gitignore kbuild: fix delay in setlocalversion on readonly source README: fix misleading pointer to the defconf directory vmlinux.lds.h update kernel-doc: cleanup perl script Improve vmlinux.lds.h support for arch specific linker scripts kbuild: fix headers_exports with boolean expression kbuild/headers_check: refine extern check kbuild: fix "Argument list too long" error for "make headers_check", ignore *.patch files Remove bashisms from scripts menu: fix embedded menu presentation ...
2009-06-14.gitignore: ignore *.lzma filesArne Janbu
2009-06-14gitignore: Add GNU GLOBAL files to top .gitignoreJani Nikula
Ignore GPATH, GRTAGS, GSYMS, and GTAGS generated by GNU GLOBAL. Signed-off-by: Jani Nikula <ext-jani.1.nikula@nokia.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-12trivial: Remove the hyphen from git commandsMatt Kraai
Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-09ignore *.patch filesMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-19kbuild: support include/generatedSam Ravnborg
We need a location for generated files. Today they are spread over several places and bringing them together to a common place makes it obvious hat is generated and what isreal files. Al Viro originally suggested: include/gen Linus suggested to spell it out. This patch implement support for include/generated All files in include/generated are ignored by git. include/generated is removed during "make mrproper". With this we are ready to implement support for include/generated in the various architctures and in the base kernel. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-29Fix and clean top .gitignoreEduard - Gabriel Munteanu
Removed vmlinux* rule because it matches too many useful files, replacing it with rules matching filetype by filename (e.g. *.gz). Also unignored .mailmap from the top directory. Added a comment telling the user how to check for tracked files being ignored. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-17Unignore vmlinux.lds.h from Git.Eduard - Gabriel Munteanu
Added !vmlinux.lds.h to .gitignore because it would otherwise be ignored. Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-25.gitignore: match ncscope.outJike Song
Sometimes I got this: $ git-status {snip} # On branch master # Untracked files: # (use "git add <file>..." to include in what will be committed) # # ncscope.out nothing added to commit but untracked files present (use "git add" to track) Fix it. Signed-off-by: Jike Song <albcamus@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
