path: root/.mailmap
2017-11-10.mailmap: Add Maciej W. Rozycki's Imagination e-mail addressMaciej W. Rozycki
Following my recent transition from Imagination Technologies to the=20 reincarnated MIPS company add a .mailmap mapping for my work address, so that `scripts/get_maintainer.pl' gets it right for past commits. Signed-off-by: Maciej W. Rozycki <macro@mips.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-02MIPS: Update email address for Marcin NowakowskiMarcin Nowakowski
MIPS is no longer part of Imagination Technologies and my @imgtec.com address will soon stop working. Update any files containing my address as well as the .mailmap to point to my new @mips.com address. Signed-off-by: Marcin Nowakowski <marcin.nowakowski@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/17579/ Signed-off-by: James Hogan <jhogan@kernel.org>
2017-11-01MIPS: Update Goldfish RTC driver maintainer email addressAleksandar Markovic
Change all relevant instances of miodrag.dinic@imgtec.com email address to miodrag.dinic@mips.com. Signed-off-by: Miodrag Dinic <miodrag.dinic@mips.com> Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/17515/ [jhogan@kernel.org: Fix .mailmap direction] Signed-off-by: James Hogan <jhogan@kernel.org>
2017-11-01MIPS: Update RINT emulation maintainer email addressAleksandar Markovic
Change all relevant instances of aleksandar.markovic@imgtec.com email address to aleksandar.markovic@mips.com. Signed-off-by: Miodrag Dinic <miodrag.dinic@mips.com> Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com> Patchwork: https://patchwork.linux-mips.org/patch/17514/ Signed-off-by: James Hogan <jhogan@kernel.org>
2017-10-31Update MIPS email addressesPaul Burton
MIPS will soon not be a part of Imagination Technologies, and as such many @imgtec.com email addresses will no longer be valid. This patch updates the addresses for those who: - Have 10 or more patches in mainline authored using an @imgtec.com email address, or any patches dated within the past year. - Are still with Imagination but leaving as part of the MIPS business unit, as determined from an internal email address list. - Haven't already updated their email address (ie. JamesH) or expressed a desire to be excluded (ie. Maciej). - Acked v2 or earlier of this patch, which leaves Deng-Cheng, Matt & myself. New addresses are of the form firstname.lastname@mips.com, and all verified against an internal email address list. An entry is added to .mailmap for each person such that get_maintainer.pl will report the new addresses rather than @imgtec.com addresses which will soon be dead. Instances of the affected addresses throughout the tree are then mechanically replaced with the new @mips.com address. Signed-off-by: Paul Burton <paul.burton@mips.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@mips.com> Acked-by: Dengcheng Zhu <dengcheng.zhu@mips.com> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Matt Redfearn <matt.redfearn@mips.com> Acked-by: Matt Redfearn <matt.redfearn@mips.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: trivial@kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17540/ Signed-off-by: James Hogan <jhogan@kernel.org>
2017-10-04Update James Hogan's email addressJames Hogan
Update my imgtec.com and personal email address to my kernel.org one in a few places as MIPS will soon no longer be part of Imagination Technologies, and add mappings in .mailcap so get_maintainer.pl reports the right address. Signed-off-by: James Hogan <jhogan@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-12Merge tag 'for-v4.12-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply Pull more power-supply updates from Sebastian Reichel: "The power-supply subsystem has a few more changes for the v4.12 merge window: - New battery driver for AXP20X and AXP22X PMICs - Improve max17042_battery for usage on x86 - Misc small cleanups & fixes" * tag 'for-v4.12-2' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (34 commits) power: supply: cpcap-charger: Keep trickle charger bits disabled power: supply: cpcap-charger: Fix enable for 3.8V charge setting power: supply: cpcap-charger: Fix charge voltage configuration power: supply: cpcap-charger: Fix charger name power: supply: twl4030-charger: make twl4030_bci_property_is_writeable static power: supply: sbs-battery: Add alert callback mailmap: add Sebastian Reichel power: supply: avoid unused twl4030-madc.h power: supply: sbs-battery: Correct supply status with current draw power: supply: sbs-battery: Don't ignore the first external power change power: supply: pda_power: move from timer to delayed_work power: supply: max17042_battery: Add support for the SCOPE property power: supply: max17042_battery: Add support for the CHARGE_NOW property power: supply: max17042_battery: Add support for the CHARGE_FULL_DESIGN property power: supply: max17042_battery: mAh readings depend on r_sns value power: supply: max17042_battery: Add support for the VOLT_MIN property power: supply: max17042_battery: Add support for the TECHNOLOGY attribute power: supply: max17042_battery: Add external_power_changed callback power: supply: max17042_battery: Add support for the STATUS property power: supply: max17042_battery: Add default platform_data fallback data ...
2017-05-05Merge tag 'staging-4.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging/IIO updates from Greg KH: "Here is the big staging tree update for 4.12-rc1. It's a big one, adding about 350k new lines of crap^Wcode, mostly all in a big dump of media drivers from Intel. But there's other new drivers in here as well, yet-another-wifi driver, new IIO drivers, and a new crypto accelerator. We also deleted a bunch of stuff, mostly in patch cleanups, but also the Android ION code has shrunk a lot, and the Android low memory killer driver was finally deleted, much to the celebration of the -mm developers. All of these have been in linux-next with a few build issues that will show up when you merge to your tree" Merge conflicts in the new rtl8723bs driver (due to the wifi changes this merge window) handled as per linux-next, courtesy of Stephen Rothwell. * tag 'staging-4.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1182 commits) staging: fsl-mc/dpio: add cpu <--> LE conversion for dpaa2_fd staging: ks7010: remove line continuations in quoted strings staging: vt6656: use tabs instead of spaces staging: android: ion: Fix unnecessary initialization of static variable staging: media: atomisp: fix range checking on clk_num staging: media: atomisp: fix misspelled word in comment staging: media: atomisp: kmap() can't fail staging: atomisp: remove #ifdef for runtime PM functions staging: atomisp: satm include directory is gone atomisp: remove some more unused files atomisp: remove hmm_load/store/clear indirections atomisp: kill off mmgr_free atomisp: clean up the hmm init/cleanup indirections atomisp: handle allocation calls before init in the hmm layer staging: fsl-dpaa2/eth: Add maintainer for Ethernet driver staging: fsl-dpaa2/eth: Add TODO file staging: fsl-dpaa2/eth: Add trace points staging: fsl-dpaa2/eth: Add driver specific stats staging: fsl-dpaa2/eth: Add ethtool support staging: fsl-dpaa2/eth: Add Freescale DPAA2 Ethernet driver ...
2017-05-01mailmap: add Sebastian ReichelSebastian Reichel
Add two entries to map to my primary kernel address. Signed-off-by: Sebastian Reichel <sre@kernel.org>
2017-04-13mailmap: add Martin Kepplinger's emailMartin Kepplinger
Set the partly deprecated companies' email addresses as alias for the personal one. Link: http://lkml.kernel.org/r/1491984622-17321-1-git-send-email-martin.kepplinger@ginzinger.com Signed-off-by: Martin Kepplinger <martin.kepplinger@ginzinger.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-04-10Merge 4.11-rc6 into staging-nextGreg Kroah-Hartman
We want the staging and iio fixes in here to handle merging easier. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08mailmap: update Yakir Yang email addressJeffy Chen
Set current email address to replace previous employers email addresses. Link: http://lkml.kernel.org/r/1491450722-6633-1-git-send-email-jeffy.chen@rock-chips.com Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-06Merge tag 'iio-for-4.12a' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: First set of IIO new device support, features and cleanup for the 4.12 cycle. Quite a bit of outreachy activity here with a driver from a current intern and a number of cleanup patches as part of the next round. Getting a pull request in early this cycle as it's looking like another large cycle for IIO. New device support * adxl345 - initial device support. Note, once complete support is done the intent is to superceded the driver in input/misc. - bindings. - conversion from i2c direct calls to regmap and driver split. - spi support. * chromeos light and proximity. - new driver. * devantech srf04 ultrasonic ranger - new driver with device tree bindings. * hid temperature - new driver for environemntal temperature support from hid devices. * max30102 oximeter - new driver with device tree bindings. * st lsm6dsx - refactor and addition of device support for lsm6dsl and lsm6ds3h. Staging graduation * isl29028 including copyright notice update to reflect Brian's work. * lpc32xx_adc. * spear adc. It's not perfect and there are some datasheet disagreements, but it works and is good enough to graduate. New features * documentation - abi docs for in_proximity_sampling_frequency_available. - generalise counting direction ABI docs as a second driver is going to use them. * hid-sensor-prox - Add support for HID_USAGE_SENSOR_HUMAN_PRESENCE if used on a particular device. * isl29028 - runtime pm. * meson-saradc - switch from polling to interrupt mode and improved read_raw_sample function to avoid unnecessary loop. * tmp007 - interrupt and threshold event support. Cleanups and minor fixes * ad2s1210 - permissions to octal. * ad7192 - permissions to octal. - use BIT macro. * ad9832 - merge header definitions into source file. * ad9834 - merge header definitions into source file. * ade7753 - merge header definitions into source file. - cleanup include ordering. * ade7854 - simplify return logic. * adis16201 - merge header definitions into source file. - rename _core.c to .c as there is nothing else. * adis16203 - merge header definitions into source file. - rename _core.c to .c as there is nothing else. * adis16209 - merge header definitions into source file. - rename _core.c to .c as there is nothing else. * adis16240 - permissions to octal. - merge header definitions into source file. - rename _core.c to .c as there is nothing else. * adt7136 - permissions to octal. * cio-dac - set missing parent device. * documentation - update version numbers on sysfs ABI for counter bits that didn't quite. make 4.9. * isl29028 - mdelay to msleep. - incorrrect sleep time when taking first proximity reading. * lmp91000 - set missing parent device. * lpc32xx - Consistent prefixes for defines. - rename local state structure to _state. * max30100 - set missing parent device. * max30102 - set missing parent device. * maxim-thermocouple - set missing parent device. * meter driver header - permissions to octal. * pulsedlight-lidar-lite-v2 - set missing parent device. * quad-8 - set missing parent device. * st104 - set missing parent device. Other * Mailmap - update Matt Ranostay's email address to the Konsolko one.
2017-02-04mailmap: Change email to new Konsulko emailMatt Ranostay
Signed-off-by: Matt Ranostay <matt@ranostay.consulting> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2017-01-10mailmap: add codeaurora.org names for nameless email commitsStephen Boyd
Some codeaurora.org emails have crept in but the names don't exist for them. Add the names for the emails so git can match everyone up. Link: http://lkml.kernel.org/r/20170104194611.25933-1-sboyd@codeaurora.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Sarangdhar Joshi <spjoshi@codeaurora.org> Cc: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Subhash Jadavani <subhashj@codeaurora.org> Cc: Thomas Pedersen <twp@codeaurora.org> Cc: Andy Gross <andy.gross@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main MIPS pull request for 4.9: MIPS core arch code: - traps: 64bit kernels should read CP0_EBase 64bit - traps: Convert ebase to KSEG0 - c-r4k: Drop bc_wback_inv() from icache flush - c-r4k: Split user/kernel flush_icache_range() - cacheflush: Use __flush_icache_user_range() - uprobes: Flush icache via kernel address - KVM: Use __local_flush_icache_user_range() - c-r4k: Fix flush_icache_range() for EVA - Fix -mabi=64 build of vdso.lds - VDSO: Drop duplicated -I*/-E* aflags - tracing: move insn_has_delay_slot to a shared header - tracing: disable uprobe/kprobe on compact branch instructions - ptrace: Fix regs_return_value for kernel context - Squash lines for simple wrapper functions - Move identification of VP(E) into proc.c from smp-mt.c - Add definitions of SYNC barrierstype values - traps: Ensure full EBase is written - tlb-r4k: If there are wired entries, don't use TLBINVF - Sanitise coherentio semantics - dma-default: Don't check hw_coherentio if device is non-coherent - Support per-device DMA coherence - Adjust MIPS64 CAC_BASE to reflect Config.K0 - Support generating Flattened Image Trees (.itb) - generic: Introduce generic DT-based board support - generic: Convert SEAD-3 to a generic board - Enable hardened usercopy - Don't specify STACKPROTECTOR in defconfigs Octeon: - Delete dead code and files across the platform. - Change to use all memory into use by default. - Rename upper case variables in setup code to lowercase. - Delete legacy hack for broken bootloaders. - Leave maintaining the link state to the actual ethernet/PHY drivers. - Add DTS for D-Link DSR-500N. - Fix PCI interrupt routing on D-Link DSR-500N. Pistachio: - Remove ANDROID_TIMED_OUTPUT from defconfig TX39xx: - Move GPIO setup from .mem_setup() to .arch_init() - Convert to Common Clock Framework TX49xx: - Move GPIO setup from .mem_setup() to .arch_init() - Convert to Common Clock Framework txx9wdt: - Add missing clock (un)prepare calls for CCF BMIPS: - Add PW, GPIO SDHCI and NAND device node names - Support APPENDED_DTB - Add missing bcm97435svmb to DT_NONE - Rename bcm96358nb4ser to bcm6358-neufbox4-sercom - Add DT examples for BCM63268, BCM3368 and BCM6362 - Add support for BCM3368 and BCM6362 PCI - Reduce stack frame usage - Use struct list_head lists - Support for CONFIG_PCI_DOMAINS_GENERIC - Make pcibios_set_cache_line_size an initcall - Inline pcibios_assign_all_busses - Split pci.c into pci.c & pci-legacy.c - Introduce CONFIG_PCI_DRIVERS_LEGACY - Support generic drivers CPC - Convert bare 'unsigned' to 'unsigned int' - Avoid lock when MIPS CM >= 3 is present GIC: - Delete unused file smp-gic.c mt7620: - Delete unnecessary assignment for the field "owner" from PCI BCM63xx: - Let clk_disable() return immediately if clk is NULL pm-cps: - Change FSB workaround to CPU blacklist - Update comments on barrier instructions - Use MIPS standard lightweight ordering barrier - Use MIPS standard completion barrier - Remove selection of sync types - Add MIPSr6 CPU support - Support CM3 changes to Coherence Enable Register SMP: - Wrap call to mips_cpc_lock_other in mips_cm_lock_other - Introduce mechanism for freeing and allocating IPIs cpuidle: - cpuidle-cps: Enable use with MIPSr6 CPUs. SEAD3: - Rewrite to use DT and generic kernel feature. USB: - host: ehci-sead3: Remove SEAD-3 EHCI code FBDEV: - cobalt_lcdfb: Drop SEAD3 support dt-bindings: - Document a binding for simple ASCII LCDs auxdisplay: - img-ascii-lcd: driver for simple ASCII LCD displays irqchip i8259: - i8259: Add domain before mapping parent irq - i8259: Allow platforms to override poll function - i8259: Remove unused i8259A_irq_pending Malta: - Rewrite to use DT of/platform: - Probe "isa" busses by default CM: - Print CM error reports upon bus errors Module: - Migrate exception table users off module.h and onto extable.h - Make various drivers explicitly non-modular: - Audit and remove any unnecessary uses of module.h mailmap: - Canonicalize to Qais' current email address. Documentation: - MIPS supports HAVE_REGS_AND_STACK_ACCESS_API Loongson1C: - Add CPU support for Loongson1C - Add board support - Add defconfig - Add RTC support for Loongson1C board All this except one Documentation fix has sat in linux-next and has survived Imagination's automated build test system" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits) Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API MIPS: ptrace: Fix regs_return_value for kernel context MIPS: VDSO: Drop duplicated -I*/-E* aflags MIPS: Fix -mabi=64 build of vdso.lds MIPS: Enable hardened usercopy MIPS: generic: Convert SEAD-3 to a generic board MIPS: generic: Introduce generic DT-based board support MIPS: Support generating Flattened Image Trees (.itb) MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0 MIPS: Print CM error reports upon bus errors MIPS: Support per-device DMA coherence MIPS: dma-default: Don't check hw_coherentio if device is non-coherent MIPS: Sanitise coherentio semantics MIPS: PCI: Support generic drivers MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY MIPS: PCI: Split pci.c into pci.c & pci-legacy.c MIPS: PCI: Inline pcibios_assign_all_busses MIPS: PCI: Make pcibios_set_cache_line_size an initcall MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC MIPS: PCI: Use struct list_head lists ...
2016-10-07mailmap: add Johan HovoldJohan Hovold
Add two entries to map to my primary address. Link: http://lkml.kernel.org/r/1473850348-19177-1-git-send-email-johan@kernel.org Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-05Merge tag 'staging-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging and IIO updates from Greg KH: "Here is the big staging and IIO driver pull request for 4.9-rc1. There are a lot of patches in here, the majority due to the drivers/staging/greybus/ subsystem being merged in with full development history that went back a few years, in order to preserve the work that those developers did over time. Lots and lots of tiny cleanups happened in the tree as well, due to the Outreachy application process and lots of other developers showing up for the first time to clean code up. Along with those changes, we deleted a wireless driver, and added a raspberrypi driver (currently marked broken), and lots of new iio drivers. Overall the tree still shrunk with more lines removed than added, about 10 thousand lines removed in total. Full details are in the very long shortlog below. All of this has been in the linux-next tree with no issues. There will be some merge problems with other subsystem trees, but those are all minor problems and shouldn't be hard to work out when they happen (MAINTAINERS and some lustre build problems with the IB tree)" And furter from me asking for clarification about greybus: "Right now there is a phone from Motorola shipping with this code (a slightly older version, but the same tree), so even though Ara is not alive in the same form, the functionality is happening. We are working with the developers of that phone to merge the newer stuff in with their fork so they can use the upstream version in future versions of their phone product line. Toshiba has at least one chip shipping in their catalog that needs/uses this protocol over a Unipro link, and rumor has it that there might be more in the future. There are also other users of the greybus protocols, there is a talk next week at ELC that shows how it is being used across a network connection to control a device, and previous ELC talks have showed the protocol stack being used over USB to drive embedded Linux boards. I've also talked to some people who are starting to work to add a host controller driver to control arduinos as the greybus PHY protocols are very useful to control a serial/i2c/spio/whatever device across a random physical link, as it is a way to have a self-describing device be attached to a host without needing manual configuration. So yes, people are using it, and there is still the chance that it will show up in a phone/laptop/tablet/whatever from Google in the future as well, the tech isn't dead, even if the original large phone project happens to be" * tag 'staging-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (3703 commits) Staging: fbtft: Fix bug in fbtft-core staging: rtl8188eu: fix double unlock error in rtw_resume_process() staging:r8188eu: remove GEN_MLME_EXT_HANDLER macro staging:r8188eu: remove GEN_DRV_CMD_HANDLER macro staging:r8188eu: remove GEN_EVT_CODE macro staging:r8188eu: remove GEN_CMD_CODE macro staging:r8188eu: remove pkt_newalloc member of the recv_buf structure staging:r8188eu: remove rtw_handle_dualmac declaration staging:r8188eu: remove (RGTRY|BSSID)_(OFT|SZ) macros staging:r8188eu: change rtl8188e_process_phy_info function argument type Staging: fsl-mc: Remove blank lines Staging: fsl-mc: Fix unaligned * in block comments Staging: comedi: Align the * in block comments Staging : ks7010 : Fix block comments warninig Staging: vt6655: Remove explicit NULL comparison using Coccinelle staging: rtl8188eu: core: rtw_xmit: Use macros instead of constants staging: rtl8188eu: core: rtw_xmit: Move constant of the right side staging: dgnc: Fix lines longer than 80 characters Staging: dgnc: constify attribute_group structures Staging: most: hdm-dim2: constify attribute_group structures ...
2016-10-05mailmap: Canonicalize to Qais' current email address.Ralf Baechle
2016-09-30MAINTAINERS: Switch to kernel.org email address for Javi MerinoJavi Merino
Change my email address to my kernel.org account instead of the ARM one. Signed-off-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-14Merge tag 'iio-for-4.9b' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: Second set of iio new device support, features and cleanups for the 4.9 cycle. New device support * ad8801 dac - new driver supporting ad8801 and ad8803 DACs. * adc12138 - new driver supporting TI adc12130/adc12132 and adc12138 ADCs. * ltc2485 adc - new driver * mxc6255 - add support for the mxc6225 part name and fixup the ID check so it works. * vz89x VOC sensor - add support for the vz89te part which drops the voc_short channel and adds CRCs compared to other supported parts. New features * core - immutable triggers. These effectively grant exclusive control over a trigger. The typical usecase is a device representing an analog part (perhaps a MUX) that needs to control the sampling of a downstream ADC. - resource managed trigger registration and triggered_buffer_init. - iio_push_event now protected against case of the event interface registration not having yet occured. Only matters if an interrupt can occur during this window - might happen on shared interrupt lines. - helper to let a driver query if the trigger it is using is provided by itself (using the convention of both device and trigger having the same parent). * tools - iio-utils. Used channel modifier scaling in preference to generic scaling when both exist. * at91-adc - Add support for touchscreen switches closure time needed by some newer parts. * stx104 - support the ADC channels on this ADC/DAC board. As these are the primary feature of the board also move the driver to the iio/adc directory. * sx9500 - device tree bindings. Cleanups / Fixes * ad5755 - fix an off-by-one on devnr limit check (introduced earlier this cycle) * ad7266 - drop NULL check on devm_regulator_get_optional as it can't return NULL. * ak8974 - avoid an unused functional warning due to rework in PM core code. - remove .owner field setting as done by i2c_core. * ina2xx - clear out a left over debug field from chip global data. * hid-sensors - avoid an unused functional warning due to rework in PM core code. * maxim-thermocouple - fix non static symbol warnings. * ms5611 - fetch and enable regulators unconditionally when they aren't optional. * sca3000 - whitespace cleanup. * st_sensors - fetch and enable regulators unconditionally rather than having them supported as optional regulators (missunderstanding on my part amongst others a while back) - followup to previous patch fixes error checking on the regulators. - mark symbols static where possible. - use the 'is it my trigger' help function. This prevents the odd case of another device triggering from the st-sensors trigger whilst the st-sensors trigger is itself not using it but rather using say an hrtimer. * ti-ads1015 - add missing of_node_put. * vz89x - rework to all support of new devices. - prevent reading of a corrupted buffer. - fixup a return value of 0/1 in a bool returning function. Address updates - Vlad Dogaru email address change.
2016-09-08Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "This is a slightly larger batch of fixes that we've been sitting on a few -rcs. Most of them are simple oneliners, but there are two sets that are slightly larger and worth pointing out: - A set of patches to OMAP to deal with hwmod for RTC on am33xx (beaglebone SoC, among others). It's the only clock that ever has a valid offset of 0, so a new flag needed introduction once this problem was discovered. - A collection of CCI fixes for performance counters discovered once people started using it on X-Gene CPUs" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits) arm-cci: pmu: Fix typo in event name Revert "ARM: tegra: fix erroneous address in dts" ARM: dts: imx6qdl: Fix SPDIF regression ARM: imx6: add missing BM_CLPCR_BYPASS_PMIC_READY setting for imx6sx ARM: dts: imx7d-sdb: fix ti,x-plate-ohms property name ARM: dts: kirkwood: Fix PCIe label on OpenRD ARM: kirkwood: ib62x0: fix size of u-boot environment partition bus: arm-ccn: make event groups reliable bus: arm-ccn: fix hrtimer registration bus: arm-ccn: fix PMU interrupt flags ARM: tegra: Correct polarity for Tegra114 PMIC interrupt MAINTAINERS: add tree entry for ARM/UniPhier architecture ARM: sun5i: Fix typo in trip point temperature MAINTAINERS: Switch to kernel.org account for Krzysztof Kozlowski ARM: imx6ul: populates platform device at .init_machine bus: arm-ccn: Add missing event attribute exclusions for host/guest bus: arm-ccn: Correct required arguments for XP PMU events bus: arm-ccn: Fix XP watchpoint settings bitmask bus: arm-ccn: Do not attempt to configure XPs for cycle counter bus: arm-ccn: Fix PMU handling of MN ...
2016-09-01MAINTAINERS: Vladimir has movedVladimir Davydov
vdavydov@{parallels,virtuozzo}.com will bounce from now on. Link: http://lkml.kernel.org/r/20160831180752.GB10353@esperanza Signed-off-by: Vladimir Davydov <vdavydov.dev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-29mailmap: update Vlad Dogaru email addressVlad Dogaru
Replace my previous employer address. Signed-off-by: Vlad Dogaru <vlad.dogaru@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2016-08-17MAINTAINERS: Switch to kernel.org account for Krzysztof KozlowskiKrzysztof Kozlowski
Change my email address to kernel.org account instead of Samsung one. Add Bartlomiej Zolnierkiewicz as a co-maintainer of Maxim and Samsung PMIC drivers. These are used on many of our boards along with Exynos SoCs and Samsung R&D Institute Poland can still take care of them. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Cc: Kukjin Kim <kgene@kernel.org> Cc: linux-samsung-soc@vger.kernel.org Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Kukjin Kim <kgene@kernel.org>
2016-08-06Merge tag 'media/v4.8-6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull mailcap fixlets from Mauro Carvalho Chehab: "A small fixup for my and Shuah's entries in .mailcap. Basically, those entries were with a syntax that makes get_maintainer.pl to do the wrong thing" * tag 'media/v4.8-6' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: .mailmap: Correct entries for Mauro Carvalho Chehab and Shuah Khan
2016-08-04.mailmap: Correct entries for Mauro Carvalho Chehab and Shuah KhanJoe Perches
mailmap entries may not use more than 2 email addresses per line. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-08-02mailmap: add Linus LüssingLinus Lüssing
For one thing, summarizes all non-umlaut versions into the umlaut one (Linus Luessing -> Linus Lüssing). For another, maps obsolete email addresses to the current @c0d3.blue one. Link: http://lkml.kernel.org/r/1467805371-2773-1-git-send-email-linus.luessing@c0d3.blue Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-04Merge 4.7-rc6 into staging-nextGreg Kroah-Hartman
We want the staging fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-29Merge tag 'iio-for-4.8b' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-next Jonathan writes: Second round of new iio device support, features and cleanups in the 4.8 cycle Firstly some contact detail updates: * NXP took over freescale. Update the mma8452 header to reflect this. * Martin Kepplinger email address change in mma8452 header. * Adriana Reus has changed email address. Update .mailmap. * Matt Ranostay has changed email address. Update .mailmap. New Device Support * max1363 - add the missing i2c_device_ids for a couple of parts so they can actually be used. * ms5867 - add device ids for ms5805 and ms5837 parts. New Features * ad5755 - DT support. This one was a bit controversial and under review for a long time. Still no one could come up with a better solution. * stx104 - add gpio support * ti-adc081c - Add ACPI device ID matching. Core changes * Refuse to register triggers with duplicate names. There is no way to distinguish between them so this makes no sense. A few drivers do not generate unique names for each instance of the device present. We can't fix this without changing ABI so leave them and wait for someone to actually take the rare step of two identical accelerometers on the same board. * buffer-dma - use ARRAY_SIZE in a few appropriate locations. Tools * Fix the fact that the --trigger-num option in generic_buffer didn't allow 0 which is perfectly valid in the ABI. Cleanups * as3935 - improve error reporting. - remove redundant zeroing of a field in iio_priv. * gp2ap020a00f - use the iio_device_claim_*_mode helpers rather than open coding locking around mode changes. * isl29125 - use the iio_device_claim_*_mode helpers rather than open coding locking. * lidar - use the iio_device_claim_*_mode helpers rather than open coding locking. * mma8452 - more detail in devices supported description in comments (addresses and similar) * sca3000 - add a missing error check. * tcs3414 - use the iio_device_claim_*_mode helpers rather than open coding locking. * tcs3472 - use the iio_device_claim_*_mode helpers rather than open coding locking.
2016-06-24mailmap: add Boris Brezillon's emailAntoine Tenart
There are different versions of Boris' name and email in the log, and one typo. Add his emails in mailmap to have all of his contributions under the same name/email tuple. Link: http://lkml.kernel.org/r/20160609130323.27706-2-antoine.tenart@free-electrons.com Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-24mailmap: add Antoine Tenart's emailAntoine Tenart
I used "Antoine Ténart" at first but then moved to a name without accent as this cause some issues from time to time... Add my email in the mailmap file to have a consistent shortlog output. Link: http://lkml.kernel.org/r/20160609130323.27706-1-antoine.tenart@free-electrons.com Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Cc: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-15Update email addresses in MAINTAINERS and .mailmapShuah Khan
Updating email addresses in MAINTAINERS and .mailmap files. Cc: stable@vger.kernel.org Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-15Update my main e-mails at the Kernel treeMauro Carvalho Chehab
For the third time in three years, I'm changing my e-mail at Samsung. That's bad, as it may stop communications with me for a while. So, this time, I'll also add the mchehab@kernel.org e-mail, as it remains stable since ever. Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-11mailmap: update Matt Ranostay email addressMatt Ranostay
Set current email address to replace previous employers email addresses. Cc: Jonathan Cameron <jic23@kernel.org> Cc: Daniel Baluta <daniel.baluta@intel.com> Cc: linux-iio@vger.kernel.org Signed-off-by: Matt Ranostay <mranostay@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2016-06-11mailmap: update Adriana Reus email addressAdriana Reus
Set current email address instead of previous employers email address. Signed-off-by: Adriana Reus <adi.reus@gmail.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2016-05-05mailmap: add John Paul Adrian GlaubitzLinus Torvalds
Apparently patchwork ended up truncating the full name. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-28.mailmap: add Frank RowandFrank Rowand
Set current email address to replace obsolete email addresses. Signed-off-by: Frank Rowand <frank.rowand@sonymobile.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-28mailmap: fix Krzysztof Kozlowski's misspelled nameKrzysztof Kozlowski
Patchwork introduced a garbled Polish character in commit 1e3012d0fdc5 ("crypto: s5p-sss - Use memcpy_toio for iomem annotated memory") so fix the mail mapping. Additionally prefer to use kernel.org account for personal work, instead of my gmail address. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-01.mailmap: add Christophe RicardChristophe Ricard
Different computers had different settings in the mail client. Some contributions appear as Christophe Ricard, others as Christophe RICARD. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-27mailmap: redirect inactive address <ao2@amarulasolutions.com>Antonio Ospite
The email address <ao2@amarulasolutions.com> is not active anymore, use Antonio's personal email address <ao2@ao2.it> in case someone wants to get in touch for the code wrote for Amarula Solutions. Signed-off-by: Antonio Ospite <ao2@ao2.it> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-23mailmap: update Javier Martinez Canillas' emailJavier Martinez Canillas
The get_maintainer script still reports my old Collabora email based on old commits but that address no longer exist so update mailmap to report my current email and avoid people sending to the old address. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-14.mailmap: Andrey Ryabinin has movedAndrey Ryabinin
Update my email address. Signed-off-by: Andrey Ryabinin <ryabinin.a.a@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mailmap: update Sudeep Holla's email idSudeep Holla
Since the get_maintainer script still reports my old email id based on few old commits, update mailmap to report new/updated address. It also helps to fix email address for 'git shortlog' Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25mailmap: add rdunlap email auto-correctionKees Cook
To avoid having xenotime bounce when things like get_maintainers gives me addresses, add Randy's current address. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Mohit Kumar has movedPratyush Anand
Mohit's email-id doesn't exist anymore as he has left the company. Replace ST's id with mohit.kumar.dhaka@gmail.com. Signed-off-by: Pratyush Anand <pratyush.anand@gmail.com> Cc: Mohit Kumar <mohit.kumar.dhaka@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Pratyush Anand has movedPratyush Anand
pratyush.anand@st.com email-id doesn't exist anymore as I have left the company. Replace ST's id with pratyush.anand@gmail.com. Signed-off-by: Pratyush Anand <pratyush.anand@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15.mailmap: add Ricardo RibaldaRicardo Ribalda Delgado
Work and Home computer had different settings in the mail client. Some contributions appear as Ricardo Ribalda, others as Ricardo Ribalda Delgado (and one as just Ricardo). Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-05.mailmap: update Konstantin Khlebnikov's email addressKim Phillips
get_maintainer.pl returns k.khlebnikov@samsung.com via git history, for which emails get rejected: RCPT TO:<k.khlebnikov@samsung.com> 550 5.1.1 Recipient address rejected: User unknown Use his other address that passes vger's mxverify: RCPT TO:<koct9i@gmail.com> 250 2.1.5 OK ir10si13843754pbc.62 - gsmtp and add his old email address in the wrong email address field. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
