This patch seems to have originated from the 11.01.00 release
from Freescale, which is no longer available except through the
gitweb interface from Freescale.
http://opensource.freescale.com/git?p=imx/linux-2.6-imx.git;a=commit;h=27fdf7bae11978d21e8aba09bb635f49b07edd4a
This fixes a build error reported in vmware.c due to commit
9f242dc10e0c3c1eb32d8c83c18650a35fd7f80d
Reported-by: Sven Joachim <svenjoac@gmx.de>
Cc: Alok Kataria <akataria@vmware.com>
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream.
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 11ac552477e32835cb6970bf0a70c210807f5673 upstream.
We do in fact need to unmap the page table _before_ doing the whole
stack guard page logic, because if it is needed (mainly 32-bit x86 with
PAE and CONFIG_HIGHPTE, but other architectures may use it too) then it
will do a kmap_atomic/kunmap_atomic.
And those kmaps will create an atomic region that we cannot do
allocations in. However, the whole stack expand code will need to do
anon_vma_prepare() and vma_lock_anon_vma() and they cannot do that in an
atomic region.
Now, a better model might actually be to do the anon_vma_prepare() when
_creating_ a VM_GROWSDOWN segment, and not have to worry about any of
this at page fault time. But in the meantime, this is the
straightforward fix for the issue.
See https://bugzilla.kernel.org/show_bug.cgi?id=16588 for details.
Reported-by: Wylda <wylda@volny.cz>
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Reported-by: Mike Pagano <mpagano@gentoo.org>
Reported-by: François Valenduc <francois.valenduc@tvcablenet.be>
Tested-by: Ed Tomlinson <edt@aei.ca>
Cc: Pekka Enberg <penberg@kernel.org>
commit 96054569190bdec375fe824e48ca1f4e3b53dd36 upstream.
It's wrong for several reasons, but the most direct one is that the
fault may be for the stack accesses to set up a previous SIGBUS. When
we have a kernel exception, the kernel exception handler does all the
fixups, not some user-level signal handler.
Even apart from the nested SIGBUS issue, it's also wrong to give out
kernel fault addresses in the signal handler info block, or to send a
SIGBUS when a system call already returns EFAULT.
commit 5528f9132cf65d4d892bcbc5684c61e7822b21e9 upstream.
.. which didn't show up in my tests because it's a no-op on x86-64 and
most other architectures. But we enter the function with the last-level
page table mapped, and should unmap it at exit.
commit 320b2b8de12698082609ebbc1a17165727f4c893 upstream.
This is a rather minimally invasive patch to solve the problem of the
user stack growing into a memory mapped area below it. Whenever we fill
the first page of the stack segment, expand the segment down by one
page.
Now, admittedly some odd application might _want_ the stack to grow down
into the preceding memory mapping, and so we may at some point need to
make this a process tunable (some people might also want to have more
than a single page of guarding), but let's try the minimal approach
first.
Tested with trivial application that maps a single page just below the
stack, and then starts recursing. Without this, we will get a SIGSEGV
_after_ the stack has smashed the mapping. With this patch, we'll get a
nice SIGBUS just as the stack touches the page just above the mapping.
Requested-by: Keith Packard <keithp@keithp.com>
commit 437f88cc031ffe7f37f3e705367f4fe1f4be8b0f upstream.
Commit 6b0310fbf087ad6 caused a regression resulting in deadlocks
when freezing a filesystem which had active IO; the vfs_check_frozen
level (SB_FREEZE_WRITE) did not let the freeze-related IO syncing
through. Duh.
Changing the test to FREEZE_TRANS should let the normal freeze
syncing get through the fs, but still block any transactions from
starting once the fs is completely frozen.
I tested this by running fsstress in the background while periodically
snapshotting the fs and running fsck on the result. I ran into
occasional deadlocks, but different ones. I think this is a
fine fix for the problem at hand, and the other deadlocky things
will need more investigation.
Reported-by: Phillip Susi <psusi@cfl.rr.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 0b767f96164b2b27488e3daa722ff16e89d49314 upstream.
By default, CONFIG_CRYPTO_MANAGER_TESTS will be enabled and thus
self-tests will still run, but it is now possible to disable them
to gain some time during bootup.
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
commit 4877c737283813bdb4bebfa3168c1585f6e3a8ca upstream.
In general the semantics of IPIs are that they are are expected to
continue functioning after dpm_suspend_noirq().
Specifically I have seen a deadlock between the callfunc IPI and the
stop machine used by xen's do_suspend() routine. If one CPU has already
called dpm_suspend_noirq() then there is a window where it can be sent
a callfunc IPI before all the other CPUs have entered stop_cpu().
If this happens then the first CPU ends up spinning in stop_cpu()
waiting for the other to rendezvous in state STOPMACHINE_PREPARE while
the other is spinning in csd_lock_wait().
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: xen-devel@lists.xensource.com
LKML-Reference: <1280398595-29708-4-git-send-email-ian.campbell@citrix.com>
commit 685fd0b4ea3f0f1d5385610b0d5b57775a8d5842 upstream.
A small number of users of IRQF_TIMER are using it for the implied no
suspend behaviour on interrupts which are not timer interrupts.
Therefore add a new IRQF_NO_SUSPEND flag, rename IRQF_TIMER to
__IRQF_TIMER and redefine IRQF_TIMER in terms of these new flags.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: linux-input@vger.kernel.org
Cc: linuxppc-dev@ozlabs.org
Cc: devicetree-discuss@lists.ozlabs.org
LKML-Reference: <1280398595-29708-1-git-send-email-ian.campbell@citrix.com>
commit 38117d1495e587fbb10d6e55733139a27893cef5 upstream.
commit aca0fa34bdaba39bfddddba8ca70dba4782e8fe6 upstream.
It's currently possible to bypass xattr namespace access rules by
prefixing valid xattr names with "os2.", since the os2 namespace stores
extended attributes in a legacy format with no prefix.
This patch adds checking to deny access to any valid namespace prefix
following "os2.".
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Reported-by: Sergey Vlasov <vsu@altlinux.ru>
commit 4565956dc0847985c0403c9ebbf274b6a122e1e2 upstream.
The header file l2tp.h should be exported to the installed include/linux/
tree for userspace programs.
This patch fixes compilation errors in L2TP userspace apps which want to
use the new L2TP support introduced in 2.6.35.
Signed-off-by: James Chapman <jchapman@katalix.com>
commit 81cbb0b17796d81cbd92defe113cf2a7c7a21fbb upstream.
This patch corrects a problem where gen_nand driver assumed there can be only
one chip and ignored the pdata->chip.nr_chips value.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 6a8cfcfb0de881735df4031eb5cc99be3d0971e9 upstream.
* preset should be done before sending the reset command
* without this, I get the following error on an i.MX35 :
[ 0.900000] ------------[ cut here ]------------
[ 0.900000] WARNING: at kernel/irq/manage.c:290 __enable_irq+0x4c/0x88()
[ 0.900000] Unbalanced enable for IRQ 33
[ 0.900000] Modules linked in:
[ 0.900000] [<c002ffb8>] (unwind_backtrace+0x0/0xf0) from [<c02f7d0c>] (dump_stack+0x18/0x1c)
[ 0.900000] [<c02f7d0c>] (dump_stack+0x18/0x1c) from [<c0049a44>] (warn_slowpath_common+0x54/0x6c)
[ 0.900000] [<c0049a44>] (warn_slowpath_common+0x54/0x6c) from [<c0049b00>] (warn_slowpath_fmt+0x38/0x40)
[ 0.900000] [<c0049b00>] (warn_slowpath_fmt+0x38/0x40) from [<c008f65c>] (__enable_irq+0x4c/0x88)
[ 0.900000] [<c008f65c>] (__enable_irq+0x4c/0x88) from [<c008fca0>] (enable_irq+0x54/0x98)
[ 0.900000] [<c008fca0>] (enable_irq+0x54/0x98) from [<c021e618>] (wait_op_done+0x40/0x134)
[ 0.900000] [<c021e618>] (wait_op_done+0x40/0x134) from [<c021e808>] (send_cmd+0x30/0x38)
[ 0.900000] [<c021e808>] (send_cmd+0x30/0x38) from [<c021eb8c>] (mxc_nand_command+0x26c/0x328)
[ 0.900000] [<c021eb8c>] (mxc_nand_command+0x26c/0x328) from [<c021aa60>] (nand_scan_ident+0x188/0x6c0)
[ 0.900000] [<c021aa60>] (nand_scan_ident+0x188/0x6c0) from [<c001a9cc>] (mxcnd_probe+0x2b8/0x3d0)
[ 0.900000] [<c001a9cc>] (mxcnd_probe+0x2b8/0x3d0) from [<c01f9e88>] (platform_drv_probe+0x20/0x24)
[ 0.900000] [<c01f9e88>] (platform_drv_probe+0x20/0x24) from [<c01f8c38>] (driver_probe_device+0xb0/0x164)
[ 0.900000] [<c01f8c38>] (driver_probe_device+0xb0/0x164) from [<c01f8d54>] (__driver_attach+0x68/0x8c)
[ 0.900000] [<c01f8d54>] (__driver_attach+0x68/0x8c) from [<c01f8348>] (bus_for_each_dev+0x50/0x84)
[ 0.900000] [<c01f8348>] (bus_for_each_dev+0x50/0x84) from [<c01f8a9c>] (driver_attach+0x20/0x28)
[ 0.900000] [<c01f8a9c>] (driver_attach+0x20/0x28) from [<c01f7c00>] (bus_add_driver+0x144/0x2dc)
[ 0.900000] [<c01f7c00>] (bus_add_driver+0x144/0x2dc) from [<c01f906c>] (driver_register+0xb0/0x13c)
[ 0.900000] [<c01f906c>] (driver_register+0xb0/0x13c) from [<c01fa13c>] (platform_driver_register+0x4c/0x60)
[ 0.900000] [<c01fa13c>] (platform_driver_register+0x4c/0x60) from [<c01fa170>] (platform_driver_probe+0x20/0xa0)
[ 0.900000] [<c01fa170>] (platform_driver_probe+0x20/0xa0) from [<c001a708>] (mxc_nd_init+0x18/0x24)
[ 0.900000] [<c001a708>] (mxc_nd_init+0x18/0x24) from [<c002938c>] (do_one_initcall+0x64/0x1bc)
[ 0.900000] [<c002938c>] (do_one_initcall+0x64/0x1bc) from [<c00084c4>] (kernel_init+0xe8/0x1ac)
[ 0.900000] [<c00084c4>] (kernel_init+0xe8/0x1ac) from [<c002aee8>] (kernel_thread_exit+0x0/0x8)
[ 0.900000] ---[ end trace 8bf72ac6ba089a19 ]---
[ 1.140000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit)
Signed-off-by: Eric Bénard <eric@eukrea.com>
commit 396e894d289d69bacf5acd983c97cd6e21a14c08 upstream.
Norbert reported that nohz_ratelimit() causes his laptop to burn about
4W (40%) extra. For now back out the change and see if we can adjust
the power management code to make better decisions.
Reported-by: Norbert Preining <preining@logic.at>
Acked-by: Mike Galbraith <efault@gmx.de>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <new-submission>
commit 0a79f67445de50ca0a8dc1d34f3cc406d89c28b2 upstream.
Device class is ff(vend.) instead of e0(wlcon).
Output from command `usb-devices`:
T: Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=05ac ProdID=8215 Rev=01.82
S: Manufacturer=Apple Inc.
S: Product=Bluetooth USB Host Controller
S: SerialNumber=7C6D62936607
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=00 Driver=(none)
Signed-off-by: Cyril Lacoux <clacoux@ifeelgood.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit b58af4066d240b18b43f202e07b9ec7461d90b17 upstream.
As David VomLehn points out, it was possible to receive an interrupt
before clearing the free-urb flag which could lead to the urb being
incorrectly marked as busy.
For the same reason, move tx_bytes accounting so that it will never be
negative.
Note that the free-flags set and clear operations do not need any
additional locking as they are manipulated while USB_SERIAL_WRITE_BUSY
is set.
Reported-by: David VomLehn <dvomlehn@cisco.com>
Tested-by: David VomLehn <dvomlehn@cisco.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit b3e670443b7fb8a2d29831b62b44a039c283e351 upstream.
This patch fixes a race condition in two utility routines
related to the removal/unlinking of urbs from an anchor.
If two threads are concurrently accessing the same anchor,
both could end up with the same urb - thinking they are
the exclusive owner.
Alan Stern pointed out a related issue in
usb_unlink_anchored_urbs:
"The URB isn't removed from the anchor until it completes
(as a by-product of completion, in fact), which might not
be for quite some time after the unlink call returns.
In the meantime, the subroutine will keep trying to unlink
it, over and over again."
Cc: Oliver Neukum <oneukum@suse.de>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit e10e1bec8e6654de4591ef45ddd6a6d1e5b2591c upstream.
This patch fixes the warning below:
[30753.755998] ------------[ cut here ]------------
[30753.755998] WARNING: at /home/tom/git/linux-2.6/linux-2.6-next/arch/x86/include/asm/dma-mapping.h:155 hcd_buffer_free+0xb1/0xd4 [usbcore]()
[30753.755998] Hardware name: 6475EK2
[30753.755998] Modules linked in: uvcvideo ehci_hcd usbtest cdc_ether usbnet vfat fat usb_storage nfsd lockd nfs_acl auth_rpcgss exportfs mii tun videodev v4l1_compat v4l2_compat_ioctl32 fuse bridge stp llc sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf kvm_intel kvm arc4 ecb ath5k usbhid mac80211 snd_hda_codec_conexant ch341 usbserial ath cfg80211 thinkpad_acpi snd_hda_intel pcspkr wmi hwmon yenta_socket iTCO_wdt iTCO_vendor_support i2c_i801 e1000e snd_hda_codec snd_hwdep snd_pcm snd_timer snd soundcore snd_page_alloc pata_acpi uhci_hcd ohci_hcd usbcore i915 drm_kms_helper drm i2c_algo_bit i2c_core video output [last unloaded: uvcvideo]
[30753.755998] Pid: 0, comm: swapper Tainted: G W 2.6.35-rc6-gkh-wl+ #49
[30753.755998] Call Trace:
[30753.755998] <IRQ> [<ffffffff8104478a>] warn_slowpath_common+0x80/0x98
[30753.755998] [<ffffffff810447b7>] warn_slowpath_null+0x15/0x17
[30753.755998] [<ffffffffa00ce02d>] hcd_buffer_free+0xb1/0xd4 [usbcore]
[30753.755998] [<ffffffffa00c1345>] usb_free_coherent+0x1c/0x1e [usbcore]
[30753.755998] [<ffffffffa00b13e4>] simple_free_urb+0x23/0x2f [usbtest]
[30753.755998] [<ffffffffa00b210b>] iso_callback+0xbb/0x10f [usbtest]
[30753.755998] [<ffffffffa00c7390>] usb_hcd_giveback_urb+0x8c/0xc0 [usbcore]
[30753.755998] [<ffffffffa0449b35>] ehci_urb_done+0x84/0x95 [ehci_hcd]
[30753.755998] [<ffffffffa044b5a5>] ehci_work+0x41a/0x7dd [ehci_hcd]
[30753.755998] [<ffffffffa044e298>] ehci_irq+0x33b/0x370 [ehci_hcd]
[30753.755998] [<ffffffff8100fb05>] ? sched_clock+0x9/0xd
[30753.755998] [<ffffffff8105e641>] ? sched_clock_local+0x1c/0x82
[30753.755998] [<ffffffff8105e76a>] ? sched_clock_cpu+0xc3/0xce
[30753.755998] [<ffffffff81067c7e>] ? trace_hardirqs_off+0xd/0xf
[30753.755998] [<ffffffff8105e7b8>] ? cpu_clock+0x43/0x5e
[30753.755998] [<ffffffffa00c6999>] usb_hcd_irq+0x45/0xa1 [usbcore]
[30753.755998] [<ffffffff81092e02>] handle_IRQ_event+0x20/0xa5
[30753.755998] [<ffffffff81094cea>] handle_fasteoi_irq+0x92/0xd2
[30753.755998] [<ffffffff8100c0ed>] handle_irq+0x1f/0x2a
[30753.755998] [<ffffffff8100b75d>] do_IRQ+0x57/0xbe
[30753.755998] [<ffffffff8136a693>] ret_from_intr+0x0/0x16
[30753.755998] <EOI> [<ffffffff81223baa>] ? acpi_idle_enter_bm+0x231/0x269
[30753.755998] [<ffffffff81223ba3>] ? acpi_idle_enter_bm+0x22a/0x269
[30753.755998] [<ffffffff812c4b6b>] cpuidle_idle_call+0x99/0xce
[30753.755998] [<ffffffff81008dd5>] cpu_idle+0x61/0xaa
[30753.755998] [<ffffffff8136374b>] start_secondary+0x1c2/0x1c6
[30753.755998] ---[ end trace 904cfaf7ab4cb1a2 ]---
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 356c5a4834a74c621715f7a7f16ded914eecbd3c upstream.
Signed-off-by: Alessio Igor Bogani <abogani@texware.it>
commit b6180ef7c99574c3350bbffa2a3a9d675321543d upstream.
This patch is to add a US Interface, Inc. "Navigator" USB device.
Specifically, it's a HAM Radio USB sound modem that also
incorporates three pairs of unique FTDI serial ports. The standard
Linux FTDI serial driver will only recognize the first two serial
ports of an unknown FDTI derived device and this patch adds in
recognition to these specific new IDs.
Signed-off-by: David A. Ranch <dranch@trinnet.net>
commit 0372a754be9aa43e19fd86c9bc04796d43b55e38 upstream.
This patch adds the product IDs of Huawei's K3765 and K4505 mobile
broadband usb modems to option.c. It also adds a quirk to the option
probe function so that binding to the device's network interface(class
0xff) is avoided. This is necessary to allow another driver to bind to
that, and to avoid programs like wvdial opening a nonfunctioning tty
during modem discovery.
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
commit b972302b0a13aaddc9e90da2b4b52722e5d0e776 upstream.
The patch adds Huawei ETS 1220 product id into the list of supported
devices in 'option' usb serial driver.
Signed-off-by: Pavel Kazlou <p.i.kazlou@gmail.com>
commit afad19648f70c6493193e0a774bd754b7790b4a0 upstream.
I have added the ProductID=0xe729 VendorID=FTDI_VID=0x0403 which will
enable support for the Segway Robotic Mobility Platform (RMP200) in the
ftdi_sio kernel module. Currently, users of the Segway RMP200 must use
a RUN+="/sbin/modprobe -q ftdi-sio product=0xe729 vendor=0x0403 in a
udev rule to get the ftdi_sio module to handle the usb interface and
mount it on /dev/ttyXXX. This is not a good solution because some users
will have multiple USB to Serial converters which will use the ftdi_sio
module.
Signed-off-by: John Rogers <jgrogers@gmail.com>
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
commit 33d973ad88ceb83ed1449592b7574b5b5bb33ac6 upstream.
Enlarging the buffer size via the MON_IOCT_RING_SIZE ioctl causes
general protection faults. It appears the culprit is an incorrect
argument to mon_free_buff: instead of passing the size of the current
buffer being freed, the size of the new buffer is passed.
Use the correct size argument to mon_free_buff when changing the size of
the buffer.
Signed-off-by: Steven Robertson <steven@strobe.cc>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
commit ae68a83bdc1971cb02fefc7a686ba6d077065e71 upstream.
This patch (as1405) fixes a small bug in ehci-hcd's isochronous
scheduler. Not all EHCI controllers are PCI, and the code shouldn't
assume that they are. Instead, introduce a special flag for
controllers which need to delay iso scheduling for full-speed devices
beyond the scheduling threshold.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
CC: David Brownell <david-b@pacbell.net>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 0936fb5e92a90476959447ad8ae5d780afbbd930 upstream.
DMA_ADDR and DMA_COUNT are 32-bit registers, not 16-bit.
Marking them as 16-bit in the table causes only the lower
16-bits to be dumped and this is misleading.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Acked-by: Felipe Balbi <felipe.balbi@nokia.com>
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
<linux/spinlock.h>
commit 868003ca7ad17ac6c1606dc36101f10a7825b399 upstream.
This is a follow up to
14cb0de (arm/imx/gpio: add spinlock protection)
and fixes the following build failure:
CC arch/arm/mach-imx/pcm970-baseboard.o
In file included from arch/arm/include/asm/gpio.h:6,
from include/linux/gpio.h:8,
from arch/arm/mach-imx/pcm970-baseboard.c:20:
arch/arm/plat-mxc/include/mach/gpio.h:40: error: expected specifier-qualifier-list before 'spinlock_t'
faulty ASID
commit cdf357f1e13a08a11261edacb3083746f65c1ed9 upstream.
On versions of the Cortex-A9 prior to r2p0, performing TLB invalidations by
ASID match can result in the incorrect ASID being broadcast to other CPUs.
As a consequence of this, the targetted TLB entries are not invalidated
across the system.
This workaround changes the TLB flushing routines to invalidate entries
regardless of the ASID.
Tested-by: Rob Clark <rob@ti.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 492c5d943d6a04b124ba3a719dc746dc36b14cfb upstream.
On SMP systems, the SMSC911x registers may be accessed by multiple CPUs
and this seems to put the chip in an inconsistent state. The patch adds
spinlocks to the smsc911x_reg_read, smsc911x_reg_write,
smsc911x_rx_readfifo and smsc911x_tx_writefifo functions.
commit a6cd7eb374647b572ae9e7dbfe49871e6996e8e0 upstream.
ffuart is available on cm-x300 only with pxa300.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit a2a20c412c86e0bb46a9ab0dd31bcfe6d201b913 upstream.
If signalfd is used to consume a signal generated by a POSIX interval
timer or POSIX message queue, the ssi_int field does not reflect the data
(sigevent->sigev_value) supplied to timer_create(2) or mq_notify(3). (The
ssi_ptr field, however, is filled in.)
This behavior differs from signalfd's treatment of sigqueue-generated
signals -- see the default case in signalfd_copyinfo. It also gives
results that differ from the case when a signal is handled conventionally
via a sigaction-registered handler.
So, set signalfd_siginfo->ssi_int in the remaining cases (__SI_TIMER,
__SI_MESGQ) where ssi_ptr is set.
akpm: a non-back-compatible change. Merge into -stable to minimise the
number of kernels which are in the field and which miss this feature.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
BIO_RW_* bits
commit aca27ba9618276dd2f777bcd5a1419589ccf1ca8 upstream.
Commit a82afdf (block: use the same failfast bits for bio and request)
moved BIO_RW_* bits around such that they match up with REQ_* bits.
Unfortunately, fs.h hard coded RW_MASK, RWA_MASK, READ, WRITE, READA
and SWRITE as 0, 1, 2 and 3, and expected them to match with BIO_RW_*
bits. READ/WRITE didn't change but BIO_RW_AHEAD was moved to bit 4
instead of bit 1, breaking RWA_MASK, READA and SWRITE.
This patch updates RWA_MASK, READA and SWRITE such that they match the
BIO_RW_* bits again. A follow up patch will update the definitions to
directly use BIO_RW_* bits so that this kind of breakage won't happen
again.
Neil also spotted missing RWA_MASK conversion.
Stable: The offending commit a82afdf was released with v2.6.32, so
this patch should be applied to all kernels since then but it must
_NOT_ be applied to kernels earlier than that.
Reported-and-bisected-by: Vladislav Bolkhovitin <vst@vlnb.net>
Root-caused-by: Neil Brown <neilb@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 6710a5760355be8f2e51682f41b0d3fc76550309 upstream.
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
commit 85f4cc17a62c3ac9edeaf120cdae7261df458053 upstream.
commit ceeab92971e8af05c1e81a4ff2c271124b55bb9b upstream.
The comments in the code indicate that file_info should be released if the
function fails. This releasing is done at the label out_free, not out.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = kmem_cache_zalloc(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return <+...x...+>;
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmem_cache_zalloc %s" % (p1[0].file,p1[0].line)
// </smpl>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 31f73bee3e170b7cabb35db9e2f4bf7919b9d036 upstream.
In ecryptfs_lookup_and_interpose_lower() the lower mount is not decremented
if allocation of a dentry info struct failed. As a result the lower filesystem
cant be unmounted any more (since it is considered busy). This patch corrects
the reference counting.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
commit c43f7b8fb03be8bcc579bfc4e6ab70eac887ab55 upstream.
Lower filesystems that only implemented unlocked_ioctl weren't being
passed ioctl calls because eCryptfs only checked for
lower_file->f_op->ioctl and returned -ENOTTY if it was NULL.
eCryptfs shouldn't implement ioctl(), since it doesn't require the BKL.
This patch introduces ecryptfs_unlocked_ioctl() and
ecryptfs_compat_ioctl(), which passes the calls on to the lower file
system.
https://bugs.launchpad.net/ecryptfs/+bug/469664
Reported-by: James Dupin <james.dupin@gmail.com>
commit b7300b78d1a87625975a799a109a2f98d77757c8 upstream.
The cgroup device whitelist code gets confused when trying to grant
permission to a disk partition that is not currently open. Part of
blkdev_open() includes __blkdev_get() on the whole disk.
Basically, the only ways to reliably allow a cgroup access to a partition
on a block device when using the whitelist are to 1) also give it access
to the whole block device or 2) make sure the partition is already open in
a different context.
The patch avoids the cgroup check for the whole disk case when opening a
partition.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=589662
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Serge E. Hallyn <serue@us.ibm.com>
Reported-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: "Daniel P. Berrange" <berrange@redhat.com>
commit 7a4dec53897ecd3367efb1e12fe8a4edc47dc0e9 upstream.
If sget() finds a matching superblock being set up, it'll
grab an active reference to it and grab s_umount. That's
fine - we'll wait for completion of foofs_get_sb() that way.
However, if said foofs_get_sb() fails we'll end up holding
the halfway-created superblock. deactivate_locked_super()
called by foofs_get_sb() will just unlock the sucker since
we are holding another active reference to it.
What we need is a way to tell if superblock has been successfully
set up. Unfortunately, neither ->s_root nor the check for
MS_ACTIVE quite fit. Cheap and easy way, suitable for backport:
new flag set by the (only) caller of ->get_sb(). If that flag
isn't present by the time sget() grabbed s_umount on preexisting
superblock it has found, it's seeing a stillborn and should
just bury it with deactivate_locked_super() (and repeat the search).
Longer term we want to set that flag in ->get_sb() instances (and
check for it to distinguish between "sget() found us a live sb"
and "sget() has allocated an sb, we need to set it up" in there,
instead of checking ->s_root as we do now).
commit 556ab45f9a775bfa4762bacc0a4afb5b44b067bc upstream.
On some platforms (MacPro3,1) the BIOS assigns the ioatdma device to the
incorrect iommu causing faults when the driver initializes. Add a quirk
to catch this misconfiguration and try falling back to untranslated
operation (which works in the MacPro3,1 case).
Assuming there are other platforms with misconfigured iommus teach the
ioatdma driver to treat initialization failures as non-fatal (just fail
the driver load and emit a warning instead of triggering a BUG_ON).
This can be classified as a boot regression since 2.6.32 on affected
platforms since the ioatdma module did not autoload prior to that
kernel.
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Reported-by: Chris Li <lkml@chrisli.org>
Tested-by: Chris Li <lkml@chrisli.org>
commit 2d0bb1c1f4524befe9f0fcf0d0cd3081a451223f upstream.
Based on patches from Sonny Rao and Milton Miller...
Combined the patches to fix up clean_tx_irq and clean_rx_irq.
The PowerPC architecture does not require loads to independent bytes
to be ordered without adding an explicit barrier.
In ixgbe_clean_rx_irq we load the status bit then load the packet data.
With packet split disabled if these loads go out of order we get a
stale packet, but we will notice the bad sequence numbers and drop it.
The problem occurs with packet split enabled where the TCP/IP header
and data are in different descriptors. If the reads go out of order
we may have data that doesn't match the TCP/IP header. Since we use
hardware checksumming this bad data is never verified and it makes it
all the way to the application.
This bug was found during stress testing and adding this barrier has
been shown to fix it. The bug can manifest as a data integrity issue
(bad payload data) or as a BUG in skb_pull().
This was a nasty bug to hunt down, if people agree with the fix I think
it's a candidate for stable.
Previously Submitted to e1000-devel only for ixgbe
http://marc.info/?l=e1000-devel&m=126593062701537&w=3
We've now seen this problem hit with other device drivers (e1000e mostly)
So I'm resubmitting with fixes for other Intel Device Drivers with
similar issues.
CC: Milton Miller <miltonm@bga.com>
CC: Anton Blanchard <anton@samba.org>
CC: Sonny Rao <sonnyrao@us.ibm.com>
commit 51e9ac77035a3dfcb6fc0a88a0d80b6f99b5edb1 upstream.
If the 'bio_split' path in raid10-read is used while
resync/recovery is happening it is possible to deadlock.
Fix this be elevating ->nr_waiting for the duration of both
parts of the split request.
This fixes a bug that has been present since 2.6.22
but has only started manifesting recently for unknown reasons.
It is suitable for and -stable since then.
Reported-by: Justin Bronder <jsbronder@gentoo.org>
Tested-by: Justin Bronder <jsbronder@gentoo.org>
Signed-off-by: NeilBrown <neilb@suse.de>
commit bb4f1e9d0e2ef93de8e36ca0f5f26625fcd70b7d upstream.
Move the deletion of sysfs attributes from reconfig_mutex to
open_mutex didn't really help as a process can try to take
open_mutex while holding reconfig_mutex, so the same deadlock can
happen, just requiring one more process to be involved in the chain.
I looks like I cannot easily use locking to wait for the sysfs
deletion to complete, so don't.
The only things that we cannot do while the deletions are still
pending is other things which can change the sysfs namespace: run,
takeover, stop. Each of these can fail with -EBUSY.
So set a flag while doing a sysfs deletion, and fail run, takeover,
stop if that flag is set.
This is suitable for 2.6.35.x
commit 147e0b6a639ac581ca3bf627bedc3f4a6d3eca66 upstream.
Commit b821eaa5 "md: remove ->changed and related code" moved
revalidate_disk() under open_mutex, and lockdep noticed.
[ INFO: possible circular locking dependency detected ]
2.6.32-mdadm-locking #1
mdadm/3640 is trying to acquire lock:
(&bdev->bd_mutex){+.+.+.}, at: [<ffffffff811acecb>] revalidate_disk+0x5b/0x90
but task is already holding lock:
(&mddev->open_mutex){+.+...}, at: [<ffffffffa055e07a>] do_md_stop+0x4a/0x4d0 [md_mod]
which lock already depends on the new lock.
It is suitable for 2.6.35.x
Reported-by: Przemyslaw Czarnowski <przemyslaw.hawrylewicz.czarnowski@intel.com>
