Handle usb suspend/resume, currently the BSP doesn't
support usb plug/unplug wakeup.
Signed-off-by: Jingchang Lu <b35083@freescale.com>
The ASRC driver supports stereo audio streams resample,
the ASRCK1 serial clock using audio external clock source
can not support 44.1K sample rate due to divider and
prescaler restriction.
Update power management part for DSPI driver.
Signed-off-by: Alison Wang <b18965@freescale.com>
Fix layers blending and reinitialization issue for DCU driver.
Update power management part for DCU driver.
System could run into STOP and LPRun modes. When system was working in STOP mode,
pressing SW1 button or inserting or removing SD card could wake up it.
Port the L2 switch driver from CF platform for Vybridi plaform.
This driver usually should work together with the RSTP demo
applications provided by fsl.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Add platform support for Vybrid L2 switch driver.
Add second FEC support for Vybrid.
Add watchdog driver support for Vybrid.
Signed-off-by: Wang Xiaojun <b41435@freescale.com>
Add platform support for watchdog driver.
Add hardware flow control support,
Add transmit DMA support,
Add FIFO operation support,
Add MSB/LSB on data support,
Add 9-bits MARK/SPACE support.
Add Quad SPI driver support for Vybrid.
Xiaochun Li <b41219@freescale.com>
Add platform support for Quad SPI driver.
Add Compaq touch screen interface for nano-x.
Nano-x work with touch screen driver via Compaq touch
screen event format, this patch could add the support
above mouse device.
Add touch screen driver support for Vybird.
Add platform support for touch screen driver.
Update dspi driver support for Vybrid after debugging on board.
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Update platform support for dspi driver after debugging on board.
Four LEDS are connected to FTM0 ch0~3 on TWR-MVF600 board,
the PWM signal can use control these LEDS on/off or demo.
The FlexTimer work on PWM mode with EPWM and CPWM supported.
The API configures each FTM channels the same due to pwm subsystem
interface restriction.
This patch enable the ADMA2 function for the SDHC module used
on Faraday board. Please note that the ADMA address should be 16
bytes aligned other than 4 byte in the spec.
This patch also increased the SDHC module frequency to 200MHz.
Only disable the high-speed device disconnection detction for
level-1 device, or the connection detecting would fail.
Enable the softecc in the config to make the NFC use softecc.
also include the defconfig update for:
ENGR220009:The LCD panel goes blank after a long time
If framebuffer console support is enabled, blanking the screen will
occur after a long time. To avoid it, the option for disabling blanking
is added.
This patch is to update Edma driver after debugging on board.
mainly, fixed the bug that resulting the request source of DMA1 overflow
Signed-off-by: Xiaochun Li <b41219@freescale.com>
The call trace introduced by the card interrupt. This patch try to fix
this by disabling the card interrupt.
This patch increase the delay time for the pll clock to lock. otherwise
the kernel will panic for the locking failure.
The PKE and PUE should be declared for the GPIO pull up, otherwise the pin
will not be pulled up for the SDHC card detect input.
Add default kernel config for Faraday.
This patch is to tests eDMA driver.
a simple memory to memory transfer with a 32 bit
source and destination transfer size that generates
an interrupt when the transfer is complete.
Detection of high-speed USB device disconnection should be enable
on connection and disable on disconnection.
OTG1 acts as gadget and OTG2 acts as host on TWR-MVF600 board.
Add dspi driver support for Faraday.
Add platform support for dspi driver.
Add SAI driver support for Faraday.
Add platform support for SAI driver.
Add dcu driver support for Faraday.
The penguin logo could be shown correctly and the microwindows
application was also tested.
Add platform support for dcu driver.
Add NFC driver support for Faraday.
Add platform support for NFC driver.
Add platform support for RTC driver.
Add the I2C controller support for Faraday.
Enable the I2C0 for Faraday. There are some different with I.MX
for I2C controller, The i2c enable bit is invert with i.mx and the
interrupt clear is w1c on Faraday but w0c on i.mx
As there are more than one devices on the bus, the drive strength
is set to 50ohm, otherwise, some device can not be found.
