commit 924dd584b198a58aa7cb3efefd8a03326550ce8f upstream.
BUG: sleeping function called from invalid context at kernel/workqueue.c:2752
in_atomic(): 1, irqs_disabled(): 1, pid: 360, name: zfcperp0.0.1700
CPU: 1 Not tainted 3.9.3+ #69
Process zfcperp0.0.1700 (pid: 360, task: 0000000075b7e080, ksp: 000000007476bc30)
<snip>
Call Trace:
([<00000000001165de>] show_trace+0x106/0x154)
[<00000000001166a0>] show_stack+0x74/0xf4
[<00000000006ff646>] dump_stack+0xc6/0xd4
[<000000000017f3a0>] __might_sleep+0x128/0x148
[<000000000015ece8>] flush_work+0x54/0x1f8
[<00000000001630de>] __cancel_work_timer+0xc6/0x128
[<00000000005067ac>] scsi_device_dev_release_usercontext+0x164/0x23c
[<0000000000161816>] execute_in_process_context+0x96/0xa8
[<00000000004d33d8>] device_release+0x60/0xc0
[<000000000048af48>] kobject_release+0xa8/0x1c4
[<00000000004f4bf2>] __scsi_iterate_devices+0xfa/0x130
[<000003ff801b307a>] zfcp_erp_strategy+0x4da/0x1014 [zfcp]
[<000003ff801b3caa>] zfcp_erp_thread+0xf6/0x2b0 [zfcp]
[<000000000016b75a>] kthread+0xf2/0xfc
[<000000000070c9de>] kernel_thread_starter+0x6/0xc
[<000000000070c9d8>] kernel_thread_starter+0x0/0xc
Apparently, the ref_count for some scsi_device drops down to zero,
triggering device removal through execute_in_process_context(), while
the lldd error recovery thread iterates through a scsi device list.
Unfortunately, execute_in_process_context() decides to immediately
execute that device removal function, instead of scheduling asynchronous
execution, since it detects process context and thinks it is safe to do
so. But almost all calls to shost_for_each_device() in our lldd are
inside spin_lock_irq, even in thread context. Obviously, schedule()
inside spin_lock_irq sections is a bad idea.
Change the lldd to use the proper iterator function,
__shost_for_each_device(), in combination with required locking.
Occurences that need to be changed include all calls in zfcp_erp.c,
since those might be executed in zfcp error recovery thread context
with a lock held.
Other occurences of shost_for_each_device() in zfcp_fsf.c do not
need to be changed (no process context, no surrounding locking).
The problem was introduced in Linux 2.6.37 by commit
b62a8d9b45b971a67a0f8413338c230e3117dff5
"[SCSI] zfcp: Use SCSI device data zfcp_scsi_dev instead of zfcp_unit".
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com>
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit d79ff142624e1be080ad8d09101f7004d79c36e1 upstream.
This patch adds wait_event_interruptible_lock_irq_timeout(), which is a
straight-forward descendant of wait_event_interruptible_timeout() and
wait_event_interruptible_lock_irq().
The zfcp driver used to call wait_event_interruptible_timeout()
in combination with some intricate and error-prone locking. Using
wait_event_interruptible_lock_irq_timeout() as a replacement
nicely cleans up that locking.
This rework removes a situation that resulted in a locking imbalance
in zfcp_qdio_sbal_get():
BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10
last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp]
It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194
"[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new
code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit
without a required lock being held. The problem occured when a
special, non-SCSI I/O request was being submitted in process context,
when the adapter's queues had been torn down. In this case the bug
surfaced when the Fibre Channel port connection for a well-known address
was closed during a concurrent adapter shut-down procedure, which is a
rare constellation.
This patch also fixes these warnings from the sparse tool (make C=1):
drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in
'zfcp_qdio_sbal_check' - wrong count at exit
drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in
'zfcp_qdio_sbal_get' - unexpected unlock
Last but not least, we get rid of that crappy lock-unlock-lock
sequence at the beginning of the critical section.
It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
commit 8ffff94d20b7eb446e848e0046107d51b17a20a8 upstream.
Fixing support for the Silicon Image 3826 port multiplier, by applying
to it the same quirks applied to the Silicon Image 3726. Specifically
fixes the repeated timeout/reset process which previously afflicted
the 3726, as described from line 290. Slightly based on notes from:
https://bugzilla.redhat.com/show_bug.cgi?id=890237
Signed-off-by: Terry Suereth <terry.suereth@gmail.com>
commit 909bd5926d474e275599094acad986af79671ac9 upstream.
We want the data stored in "addr" and "qual", but the extra ampersands
mean we are copying stack data instead.
error detection
commit 4bf93b50fd04118ac7f33a3c2b8a0a1f9fa80bc9 upstream.
Fix the issue with improper counting number of flying bio requests for
BIO_EOPNOTSUPP error detection case.
The sb_nbio must be incremented exactly the same number of times as
complete() function was called (or will be called) because
nilfs_segbuf_wait() will call wail_for_completion() for the number of
times set to sb_nbio:
do {
wait_for_completion(&segbuf->sb_bio_event);
} while (--segbuf->sb_nbio > 0);
Two functions complete() and wait_for_completion() must be called the
same number of times for the same sb_bio_event. Otherwise,
wait_for_completion() will hang or leak.
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
error
commit 2df37a19c686c2d7c4e9b4ce1505b5141e3e5552 upstream.
Remove double call of bio_put() in nilfs_end_bio_write() for the case of
BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter
and he suggests first version of the fix too.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 9e40127526e857fa3f29d51e83277204fbdfc6ba upstream.
Already existing property flags are filled wrong for properties created from
initial FDT. This could cause problems if this DYNAMIC device-tree functions
are used later, i.e. properties are attached/detached/replaced. Simply dumping
flags from the running system show, that some initial static (not allocated via
kzmalloc()) nodes are marked as dynamic.
I putted some debug extensions to property_proc_show(..) :
+ if (OF_IS_DYNAMIC(pp))
+ pr_err("DEBUG: xxx : OF_IS_DYNAMIC\n");
+ if (OF_IS_DETACHED(pp))
+ pr_err("DEBUG: xxx : OF_IS_DETACHED\n");
when you operate on the nodes (e.g.: ~$ cat /proc/device-tree/*some_node*) you
will see that those flags are filled wrong, basically in most cases it will dump
a DYNAMIC or DETACHED status, which is in not true.
(BTW. this OF_IS_DETACHED is a own define for debug purposes which which just
make a test_bit(OF_DETACHED, &x->_flags)
If nodes are dynamic kernel is allowed to kfree() them. But it will crash
attempting to do so on the nodes from FDT -- they are not allocated via
kzmalloc().
Signed-off-by: Wladislav Wiebe <wladislav.kw@gmail.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com>
commit 84ca7a8e45dafb49cd5ca90a343ba033e2885c17 upstream.
The sizeof() argument in init_evtchn_cpu_bindings() is incorrect
resulting in only the first 64 (or 32 in 32-bit guests) ports having
their bindings being initialized to VCPU 0.
In most cases this does not cause a problem as request_irq() will set
the irq affinity which will set the correct local per-cpu mask.
However, if the request_irq() is called on a VCPU other than 0, there
is a window between the unmasking of the event and the affinity being
set were an event may be lost because it is not locally unmasked on
any VCPU. If request_irq() is called on VCPU 0 then local irqs are
disabled during the window and the race does not occur.
Fix this by initializing all NR_EVENT_CHANNEL bits in the local
per-cpu masks.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 1206ff4ff9d2ef7468a355328bc58ac6ebf5be44 upstream.
Patch fixes zd1201 not to use stack as URB transfer_buffer. URB buffers need
to be DMA-able, which stack is not.
Patch is only compile tested.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
This reverts commit bba2a9f0d381e510ba32f2f984e5ae1e705c90d1 which is
commit 58ad436fcf49810aa006016107f494c9ac9013db upstream, as there are
reported problems with it.
Cc: Johannes Berg <johannes.berg@intel.com>
Cc: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
commit ea077b1b96e073eac5c3c5590529e964767fc5f7 upstream.
Explicitly truncate the second operand of do_div() to 32 bits to guard
against bogus code calling it with a 64-bit divisor.
[Thorsten]
After upgrading from 3.2 to 3.10, mounting a btrfs volume fails with:
btrfs: setting nodatacow, compression disabled
btrfs: enabling auto recovery
btrfs: disk space caching is enabled
*** ZERO DIVIDE *** FORMAT=2
Current process id is 722
BAD KERNEL TRAP: 00000000
Modules linked in: evdev mac_hid ext4 crc16 jbd2 mbcache btrfs xor lzo_compress zlib_deflate raid6_pq crc32c libcrc32c
PC: [<319535b2>] __btrfs_map_block+0x11c/0x119a [btrfs]
SR: 2000 SP: 30c1fab4 a2: 30f0faf0
d0: 00000000 d1: 00001000 d2: 00000000 d3: 00000000
d4: 00010000 d5: 00000000 a0: 3085c72c a1: 3085c72c
Process mount (pid: 722, task=30f0faf0)
Frame format=2 instr addr=319535ae
Stack from 30c1faec:
00000000 00000020 00000000 00001000 00000000 01401000 30253928 300ffc00
00a843ac 3026f640 00000000 00010000 0009e250 00d106c0 00011220 00000000
00001000 301c6830 0009e32a 000000ff 00000009 3085c72c 00000000 00000000
30c1fd14 00000000 00000020 00000000 30c1fd14 0009e26c 00000020 00000003
00000000 0009dd8a 300b0b6c 30253928 00a843ac 00001000 00000000 00000000
0000a008 3194e76a 30253928 00a843ac 00001000 00000000 00000000 00000002
Call Trace: [<00001000>] kernel_pg_dir+0x0/0x1000
Code: 222e ff74 2a2e ff5c 2c2e ff60 4c45 1402 <2d40> ff64 2d41 ff68 2205 4c2e 1800 ff68 4c04 0800 2041 d1c0 2206 4c2e 1400 ff68
[Geert]
As diagnosed by Andreas, fs/btrfs/volumes.c:__btrfs_map_block()
calls
do_div(stripe_nr, stripe_len);
with stripe_len u64, while do_div() assumes the divisor is a 32-bit number.
Due to the lack of truncation in the m68k-specific implementation of
do_div(), the division is performed using the upper 32-bit word of
stripe_len, which is zero.
This was introduced by commit 53b381b3abeb86f12787a6c40fee9b2f71edc23b
("Btrfs: RAID5 and RAID6"), which changed the divisor from
map->stripe_len (struct map_lookup.stripe_len is int) to a 64-bit temporary.
Reported-by: Thorsten Glaser <tg@debian.org>
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Tested-by: Thorsten Glaser <tg@debian.org>
commit 3c0b9de6d37a481673e81001c57ca0e410c72346 upstream.
I think we could just move the full vm_iomap_memory() function into
util.h or similar, but I didn't get any reply from anybody actually
using nommu even to this trivial patch, so I'm not going to touch it any
more than required.
Here's the fairly minimal stub to make the nommu case at least
potentially work. It doesn't seem like anybody cares, though.
commit bac7e6ecf60933b68af910eb4c83a775a8b20b19 upstream.
Fighting unfixed U-Boots and other beasts that may the cache in
a locked-down state when starting the kernel, we make sure to
disable all cache lock-down when initializing the l2x0 so we
are in a known state.
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reported-by: Jan Rinze <janrinze@gmail.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: Adrian Bunk <adrian.bunk@movial.com>
Cc: Rob Herring <robherring2@gmail.com>
Tested-by: Robert Marklund <robert.marklund@stericsson.com>
commit e8184e10f89736a23ea6eea8e24cd524c5c513d2 upstream.
As pointed out by Andreas Schwab, pointers passed to ARAnyM NatFeat calls
should be physical addresses, not virtual addresses.
Fortunately on Atari, physical and virtual kernel addresses are the same,
as long as normal kernel memory is concerned, so this usually worked fine
without conversion.
But for modules, pointers to literal strings are located in vmalloc()ed
memory. Depending on the version of ARAnyM, this causes the nf_get_id()
call to just fail, or worse, crash ARAnyM itself with e.g.
Gotcha! Illegal memory access. Atari PC = $968c
This is a big issue for distro kernels, who want to have all drivers as
loadable modules in an initrd.
Add a wrapper for nf_get_id() that copies the literal to the stack to
work around this issue.
commit af9719c3062dfe216a0c3de3fa52be6d22b4456c upstream.
gcc 4.7 will be more strict about parsing the -mtraceback option:
gcc: error: unrecognized argument in option '-mtraceback=none'
gcc: note: valid arguments to '-mtraceback=' are: full no part
gcc used to do a 2 char compare so both "no" and "none" would
match. Switch to using -mtraceback=no should work everywhere.
commit 74c7b28953d4eaa6a479c187aeafcfc0280da5e8 upstream.
Otherwise if no references exist in the static kernel image,
we won't export the symbol properly to modules.
commit de36e66d5fa52bc6e2dacd95c701a1762b5308a7 upstream.
Based on copy from microblaze add ucmpdi2 implementation.
This fixes build of niu driver which failed with:
drivers/built-in.o: In function `niu_get_nfc':
niu.c:(.text+0x91494): undefined reference to `__ucmpdi2'
This driver will never be used on a sparc32 system,
but patch added to fix build breakage with all*config builds.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
commit ef6c8c1d733e244f0499035be0dabe1f4ed98c6f upstream.
The parallel-port code of the drivers used a stack allocated
control-request buffer for asynchronous (and possibly deferred) control
requests. This not only violates the no-DMA-from-stack requirement but
could also lead to corrupt control requests being submitted.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 304ab4ab079a8ed03ce39f1d274964a532db036b upstream.
These devices tend to become unresponsive after S3
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 58ad436fcf49810aa006016107f494c9ac9013db upstream.
When dumping generic netlink families, only the first dump call
is locked with genl_lock(), which protects the list of families,
and thus subsequent calls can access the data without locking,
racing against family addition/removal. This can cause a crash.
Fix it - the locking needs to be conditional because the first
time around it's already locked.
A similar bug was reported to me on an old kernel (3.4.47) but
the exact scenario that happened there is no longer possible,
on those kernels the first round wasn't locked either. Looking
at the current code I found the race described above, which had
also existed on the old kernel.
Reported-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
commit 85dfb745ee40232876663ae206cba35f24ab2a40 upstream.
This field was left uninitialized. Some user daemons perform check against this
field.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Luis Henriques <luis.henriques@canonical.com>
commit 473e162eea465e60578edb93341752e7f1c1dacc upstream.
Fixes link error:
LD vmlinux
kernel/built-in.o: In function `core_kernel_data':
(.text+0x13e44): undefined reference to `_sdata'
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
Cc: Mike Galbraith <mgalbraith@suse.de>
commit d0528b5d71faf612014dd7672e44225c915344b2 upstream.
Judging anonymous memory's vm_area_struct, perf_mmap_event's filename
will be set to "//anon" indicating this vma belongs to anonymous
memory.
Once hugepage is used, vma's vm_file points to hugetlbfs. In this way,
this vma will not be regarded as anonymous memory by is_anon_memory() in
perf user space utility.
Signed-off-by: Joshua Zhu <zhu.wen-jie@hp.com>
Cc: Akihiro Nagai <akihiro.nagai.hw@hitachi.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Joshua Zhu <zhu.wen-jie@hp.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Vinson Lee <vlee@freedesktop.org>
Link: http://lkml.kernel.org/r/1357363797-3550-1-git-send-email-zhu.wen-jie@hp.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit b911a6bdeef5848c468597d040e3407e0aee04ce upstream.
NFS appears to use d_obtain_alias() to create the root dentry rather than
d_make_root. This can cause 'prepend_path()' to complain that the root
has a weird name if an NFS filesystem is lazily unmounted. e.g. if
"/mnt" is an NFS mount then
{ cd /mnt; umount -l /mnt ; ls -l /proc/self/cwd; }
will cause a WARN message like
WARNING: at /home/git/linux/fs/dcache.c:2624 prepend_path+0x1d7/0x1e0()
Root dentry has weird name <>
to appear in kernel logs.
So change d_obtain_alias() to use "/" rather than "" as the anonymous
name.
Signed-off-by: NeilBrown <neilb@suse.de>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
[bwh: Backported to 3.2: use named initialisers instead of QSTR_INIT()]
commit b497ceb964a80ebada3b9b3cea4261409039e25a upstream.
ARM cannot handle udelay for more than 2 miliseconds, so we
should use mdelay instead for those.
Acked-by: GOTO Masanori <gotom@debian.or.jp>
Cc: YOKOTA Hiroshi <yokota@netlab.is.tsukuba.ac.jp>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit b2a3ad9ca502169fc4c11296fa20f56059c7c031 upstream.
gcc-4.7.0 has started throwing these warnings when building cifs.ko.
CC [M] fs/cifs/cifssmb.o
fs/cifs/cifssmb.c: In function ‘CIFSSMBSetCIFSACL’:
fs/cifs/cifssmb.c:3905:9: warning: array subscript is above array bounds [-Warray-bounds]
fs/cifs/cifssmb.c: In function ‘CIFSSMBSetFileInfo’:
fs/cifs/cifssmb.c:5711:8: warning: array subscript is above array bounds [-Warray-bounds]
fs/cifs/cifssmb.c: In function ‘CIFSSMBUnixSetFileInfo’:
fs/cifs/cifssmb.c:6001:25: warning: array subscript is above array bounds [-Warray-bounds]
This patch cleans up the code a bit by using the offsetof macro instead
of the funky "&pSMB->hdr.Protocol" construct.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 776164c1faac4966ab14418bb0922e1820da1d19 upstream.
debugfs_remove_recursive() is wrong,
1. it wrongly assumes that !list_empty(d_subdirs) means that this
dir should be removed.
This is not that bad by itself, but:
2. if d_subdirs does not becomes empty after __debugfs_remove()
it gives up and silently fails, it doesn't even try to remove
other entries.
However ->d_subdirs can be non-empty because it still has the
already deleted !debugfs_positive() entries.
3. simple_release_fs() is called even if __debugfs_remove() fails.
Suppose we have
dir1/
dir2/
file2
file1
and someone opens dir1/dir2/file2.
Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes
away.
But debugfs_remove_recursive(dir1) silently fails and doesn't remove
this directory. Because it tries to delete (the already deleted)
dir1/dir2/file2 again and then fails due to "Avoid infinite loop"
logic.
Test-case:
#!/bin/sh
cd /sys/kernel/debug/tracing
echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events
sleep 1000 < events/probe/sigprocmask/id &
echo -n >| kprobe_events
[ -d events/probe ] && echo "ERR!! failed to rm probe"
And after that it is not possible to create another probe entry.
With this patch debugfs_remove_recursive() skips !debugfs_positive()
files although this is not strictly needed. The most important change
is that it does not try to make ->d_subdirs empty, it simply scans
the whole list(s) recursively and removes as much as possible.
Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 96f97a83910cdb9d89d127c5ee523f8fc040a804 upstream.
If a port gets unplugged while a user is blocked on read(), -ENODEV is
returned. However, subsequent read()s returned 0, indicating there's no
host-side connection (but not indicating the device went away).
This also happened when a port was unplugged and the user didn't have
any blocking operation pending. If the user didn't monitor the SIGIO
signal, they won't have a chance to find out if the port went away.
Fix by returning -ENODEV on all read()s after the port gets unplugged.
write() already behaves this way.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
commit 92d3453815fbe74d539c86b60dab39ecdf01bb99 upstream.
SIGIO should be sent when a port gets unplugged. It should only be sent
to prcesses that have the port opened, and have asked for SIGIO to be
delivered. We were clearing out guest_connected before calling
send_sigio_to_port(), resulting in a sigio not getting sent to
processes.
Fix by setting guest_connected to false after invoking the sigio
function.
commit ea3768b4386a8d1790f4cc9a35de4f55b92d6442 upstream.
We used to keep the port's char device structs and the /sys entries
around till the last reference to the port was dropped. This is
actually unnecessary, and resulted in buggy behaviour:
1. Open port in guest
2. Hot-unplug port
3. Hot-plug a port with the same 'name' property as the unplugged one
This resulted in hot-plug being unsuccessful, as a port with the same
name already exists (even though it was unplugged).
This behaviour resulted in a warning message like this one:
-------------------8<---------------------------------------
WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted)
Hardware name: KVM
sysfs: cannot create duplicate filename
'/devices/pci0000:00/0000:00:04.0/virtio0/virtio-ports/vport0p1'
Call Trace:
[<ffffffff8106b607>] ? warn_slowpath_common+0x87/0xc0
[<ffffffff8106b6f6>] ? warn_slowpath_fmt+0x46/0x50
[<ffffffff811f2319>] ? sysfs_add_one+0xc9/0x130
[<ffffffff811f23e8>] ? create_dir+0x68/0xb0
[<ffffffff811f2469>] ? sysfs_create_dir+0x39/0x50
[<ffffffff81273129>] ? kobject_add_internal+0xb9/0x260
[<ffffffff812733d8>] ? kobject_add_varg+0x38/0x60
[<ffffffff812734b4>] ? kobject_add+0x44/0x70
[<ffffffff81349de4>] ? get_device_parent+0xf4/0x1d0
[<ffffffff8134b389>] ? device_add+0xc9/0x650
Instead of relying on guest applications to release all references to
the ports, we should go ahead and unregister the port from all the core
layers. Any open/read calls on the port will then just return errors,
and an unplug/plug operation on the host will succeed as expected.
This also caused buggy behaviour in case of the device removal (not just
a port): when the device was removed (which means all ports on that
device are removed automatically as well), the ports with active
users would clean up only when the last references were dropped -- and
it would be too late then to be referencing char device pointers,
resulting in oopses:
PID: 6162 TASK: ffff8801147ad500 CPU: 0 COMMAND: "cat"
#0 [ffff88011b9d5a90] machine_kexec at ffffffff8103232b
#1 [ffff88011b9d5af0] crash_kexec at ffffffff810b9322
#2 [ffff88011b9d5bc0] oops_end at ffffffff814f4a50
#3 [ffff88011b9d5bf0] die at ffffffff8100f26b
#4 [ffff88011b9d5c20] do_general_protection at ffffffff814f45e2
#5 [ffff88011b9d5c50] general_protection at ffffffff814f3db5
[exception RIP: strlen+2]
RIP: ffffffff81272ae2 RSP: ffff88011b9d5d00 RFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880118901c18 RCX: 0000000000000000
RDX: ffff88011799982c RSI: 00000000000000d0 RDI: 3a303030302f3030
RBP: ffff88011b9d5d38 R8: 0000000000000006 R9: ffffffffa0134500
R10: 0000000000001000 R11: 0000000000001000 R12: ffff880117a1cc10
R13: 00000000000000d0 R14: 0000000000000017 R15: ffffffff81aff700
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#6 [ffff88011b9d5d00] kobject_get_path at ffffffff8126dc5d
#7 [ffff88011b9d5d40] kobject_uevent_env at ffffffff8126e551
#8 [ffff88011b9d5dd0] kobject_uevent at ffffffff8126e9eb
#9 [ffff88011b9d5de0] device_del at ffffffff813440c7
So clean up when we have all the context, and all that's left to do when
the references to the port have dropped is to free up the port struct
itself.
Reported-by: chayang <chayang@redhat.com>
Reported-by: YOGANANTH SUBRAMANIAN <anantyog@in.ibm.com>
Reported-by: FuXiangChun <xfu@redhat.com>
Reported-by: Qunfang Zhang <qzhang@redhat.com>
Reported-by: Sibiao Luo <sluo@redhat.com>
commit 671bdea2b9f210566610603ecbb6584c8a201c8c upstream.
Between open() being called and processed, the port can be unplugged.
Check if this happened, and bail out.
A simple test script to reproduce this is:
while true; do for i in $(seq 1 100); do echo $i > /dev/vport0p3; done; done;
This opens and closes the port a lot of times; unplugging the port while
this is happening triggers the bug.
commit 057b82be3ca3d066478e43b162fc082930a746c9 upstream.
There's a window between find_port_by_devt() returning a port and us
taking a kref on the port, where the port could get unplugged. Fix it
by taking the reference in find_port_by_devt() itself.
Problem reported and analyzed by Mateusz Guzik.
Reported-by: Mateusz Guzik <mguzik@redhat.com>
commit 93d783bcca69bfacc8dc739d8a050498402587b5 upstream.
In adt7470_write_word_data(), which writes two bytes using
i2c_smbus_write_byte_data(), the return codes are incorrectly AND-ed
together when they should be OR-ed together.
The return code of i2c_smbus_write_byte_data() is zero for success.
The upshot is only the first byte was ever written to the hardware.
The 2nd byte was never written out.
I noticed that trying to set the fan speed limits was not working
correctly on my system. Setting the fan speed limits is the only
code that uses adt7470_write_word_data(). After making the change
the limit settings work and the alarms work also.
Signed-off-by: Curt Brune <curt@cumulusnetworks.com>
[ Upstream commit 8cb3b9c3642c0263d48f31d525bcee7170eedc20 ]
The "pvc" struct has a hole after pvc.sap_family which is not cleared.
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit ff862a4668dd6dba962b1d2d8bd344afa6375683 ]
This is inspired by a5cc68f3d6 "af_key: fix info leaks in notify
messages". There are some struct members which don't get initialized
and could disclose small amounts of private information.
Acked-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit a0db856a95a29efb1c23db55c02d9f0ff4f0db48 ]
Make sure the reserved fields, and padding (if any), are
fully initialized.
Based upon a patch by Dan Carpenter and feedback from
Joe Perches.
[ Upstream commit 20f0170377264e8449b6987041f0bcc4d746d3ed ]
usbnet doesn't support yet SG, so drivers should not advertise SG or TSO
capabilities, as they allow TCP stack to build large TSO packets that
need to be linearized and might use order-5 pages.
This adds an extra copy overhead and possible allocation failures.
Current code ignore skb_linearize() return code so crashes are even
possible.
Best is to not pretend SG/TSO is supported, and add this again when/if
usbnet really supports SG for devices who could get a performance gain.
Based on a prior patch from Freddy Xin <freddy@asix.com.tw>
[ Upstream commit 905a6f96a1b18e490a75f810d733ced93c39b0e5 ]
Otherwise we end up dereferencing the already freed net->ipv6.mrt pointer
which leads to a panic (from Srivatsa S. Bhat):
BUG: unable to handle kernel paging request at ffff882018552020
IP: [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
PGD 290a067 PUD 207ffe0067 PMD 207ff1d067 PTE 8000002018552060
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: ebtable_nat ebtables nfs fscache nf_conntrack_ipv4 nf_defrag_ipv4 ipt_REJECT xt_CHECKSUM iptable_mangle iptable_filter ip_tables nfsd lockd nfs_acl exportfs auth_rpcgss autofs4 sunrpc 8021q garp bridge stp llc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter
+ip6_tables ipv6 vfat fat vhost_net macvtap macvlan vhost tun kvm_intel kvm uinput iTCO_wdt iTCO_vendor_support cdc_ether usbnet mii microcode i2c_i801 i2c_core lpc_ich mfd_core shpchp ioatdma dca mlx4_core be2net wmi acpi_cpufreq mperf ext4 jbd2 mbcache dm_mirror dm_region_hash dm_log dm_mod
CPU: 0 PID: 7 Comm: kworker/u33:0 Not tainted 3.11.0-rc1-ea45e-a #4
Hardware name: IBM -[8737R2A]-/00Y2738, BIOS -[B2E120RUS-1.20]- 11/30/2012
Workqueue: netns cleanup_net
task: ffff8810393641c0 ti: ffff881039366000 task.ti: ffff881039366000
RIP: 0010:[<ffffffffa0366b02>] [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
RSP: 0018:ffff881039367bd8 EFLAGS: 00010286
RAX: ffff881039367fd8 RBX: ffff882018552000 RCX: dead000000200200
RDX: 0000000000000000 RSI: ffff881039367b68 RDI: ffff881039367b68
RBP: ffff881039367bf8 R08: ffff881039367b68 R09: 2222222222222222
R10: 2222222222222222 R11: 2222222222222222 R12: ffff882015a7a040
R13: ffff882014eb89c0 R14: ffff8820289e2800 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88103fc00000(0000) knlGS:0000000000000000
CR2: ffff882018552020 CR3: 0000000001c0b000 CR4: 00000000000407f0
Stack:
ffff881039367c18 ffff882014eb89c0 ffff882015e28c00 0000000000000000
ffff881039367c18 ffffffffa034d9d1 ffff8820289e2800 ffff882014eb89c0
ffff881039367c58 ffffffff815bdecb ffffffff815bddf2 ffff882014eb89c0
Call Trace:
[<ffffffffa034d9d1>] rawv6_close+0x21/0x40 [ipv6]
[<ffffffff815bdecb>] inet_release+0xfb/0x220
[<ffffffff815bddf2>] ? inet_release+0x22/0x220
[<ffffffffa032686f>] inet6_release+0x3f/0x50 [ipv6]
[<ffffffff8151c1d9>] sock_release+0x29/0xa0
[<ffffffff81525520>] sk_release_kernel+0x30/0x70
[<ffffffffa034f14b>] icmpv6_sk_exit+0x3b/0x80 [ipv6]
[<ffffffff8152fff9>] ops_exit_list+0x39/0x60
[<ffffffff815306fb>] cleanup_net+0xfb/0x1a0
[<ffffffff81075e3a>] process_one_work+0x1da/0x610
[<ffffffff81075dc9>] ? process_one_work+0x169/0x610
[<ffffffff81076390>] worker_thread+0x120/0x3a0
[<ffffffff81076270>] ? process_one_work+0x610/0x610
[<ffffffff8107da2e>] kthread+0xee/0x100
[<ffffffff8107d940>] ? __init_kthread_worker+0x70/0x70
[<ffffffff8162a99c>] ret_from_fork+0x7c/0xb0
Code: 20 48 89 5d e8 4c 89 65 f0 4c 89 6d f8 66 66 66 66 90 4c 8b 67 30 49 89 fd e8 db 3c 1e e1 49 8b 9c 24 90 08 00 00 48 85 db 74 06 <4c> 39 6b 20 74 20 bb f3 ff ff ff e8 8e 3c 1e e1 89 d8 4c 8b 65
RIP [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
RSP <ffff881039367bd8>
Reported-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Tested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
[ Upstream commit c5c7774d7eb4397891edca9ebdf750ba90977a69 ]
In commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86
(refactor sctp_outq_teardown to insure proper re-initalization)
we modified sctp_outq_teardown to use sctp_outq_init to fully re-initalize the
outq structure. Steve West recently asked me why I removed the q->error = 0
initalization from sctp_outq_teardown. I did so because I was operating under
the impression that sctp_outq_init would properly initalize that value for us,
but it doesn't. sctp_outq_init operates under the assumption that the outq
struct is all 0's (as it is when called from sctp_association_init), but using
it in __sctp_outq_teardown violates that assumption. We should do a memset in
sctp_outq_init to ensure that the entire structure is in a known state there
instead.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: "West, Steve (NSN - US/Fort Worth)" <steve.west@nsn.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: netdev@vger.kernel.org
CC: davem@davemloft.net
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 651e92716aaae60fc41b9652f54cb6803896e0da ]
Limit the min/max value passed to the
/proc/sys/net/ipv4/tcp_syn_retries.
Signed-off-by: Michal Tesar <mtesar@redhat.com>
[ Upstream commit 087d273caf4f7d3f2159256f255f1f432bc84a5b ]
This patch doesn't change the compiled code because ARC_HDR_SIZE is 4
and sizeof(int) is 4, but the intent was to use the header size and not
the sizeof the header size.
commit 9c5da09d266ca9b32eb16cf940f8161d949c2fe5 upstream.
An rmdir pushes css's ref count to zero. However, if the associated
directory is open at the time, the dentry ref count is non-zero. If
the fd for this directory is then passed into perf_event_open, it
does a css_get(). This bounces the ref count back up from zero. This
is a problem by itself. But what makes it turn into a crash is the
fact that we end up doing an extra dput, since we perform a dput
when css_put sees the ref count go down to zero.
css_tryget() does not fall into that trap. So, we use that instead.
Reproduction test-case for the bug:
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <linux/unistd.h>
#include <linux/perf_event.h>
#include <string.h>
#include <errno.h>
#include <stdio.h>
#define PERF_FLAG_PID_CGROUP (1U << 2)
int perf_event_open(struct perf_event_attr *hw_event_uptr,
pid_t pid, int cpu, int group_fd, unsigned long flags) {
return syscall(__NR_perf_event_open,hw_event_uptr, pid, cpu,
group_fd, flags);
* Directly poke at the perf_event bug, since it's proving hard to repro
* depending on where in the kernel tree. what moved?
int main(int argc, char **argv)
int fd;
struct perf_event_attr attr;
memset(&attr, 0, sizeof(attr));
attr.exclude_kernel = 1;
attr.size = sizeof(attr);
mkdir("/dev/cgroup/perf_event/blah", 0777);
fd = open("/dev/cgroup/perf_event/blah", O_RDONLY);
perror("open");
rmdir("/dev/cgroup/perf_event/blah");
sleep(2);
perf_event_open(&attr, fd, 0, -1, PERF_FLAG_PID_CGROUP);
perror("perf_event_open");
close(fd);
return 0;
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20120614223108.1025.2503.stgit@dungbeetle.mtv.corp.google.com
Cc: Li Zefan <lizefan@huawei.com>
commit eaa5a990191d204ba0f9d35dbe5505ec2cdd1460 upstream.
GCC will optimize mxcsr_feature_mask_init in arch/x86/kernel/i387.c:
memset(&fx_scratch, 0, sizeof(struct i387_fxsave_struct));
asm volatile("fxsave %0" : : "m" (fx_scratch));
mask = fx_scratch.mxcsr_mask;
if (mask == 0)
mask = 0x0000ffbf;
to
mask = 0x0000ffbf;
since asm statement doesn’t say it will update fx_scratch. As the
result, the DAZ bit will be cleared. This patch fixes it. This bug
dates back to at least kernel 2.6.12.
