crypto: mxs-dcp: remove merge conflict markers
4.14 2.0.x imx
This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit 2aacace6dbbb6b6ce4e177e6c7ea901f389c0472 ]
In attach_node_and_children memory is allocated for full_name via
kasprintf. If the condition of the 1st if is not met the function
returns early without freeing the memory. Add a kfree() to fix that.
This has been detected with kmemleak:
Link: https://bugzilla.kernel.org/show_bug.cgi?id=205327
It looks like the leak was introduced by this commit:
Fixes: 5babefb7f7ab ("of: unittest: allow base devicetree to have symbol metadata")
Signed-off-by: Erhard Furtner <erhard_f@mailbox.org>
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au>
Reviewed-by: Tyrel Datwyler <tyreld@linux.ibm.com>
Signed-off-by: Rob Herring <robh@kernel.org>
[ Upstream commit a7ede3d16808b8f3915c8572d783530a82b2f027 ]
With commit 6ce220dd2f8ea71d6afc29b9a7524c12e39f374a ("raid5: don't set
STRIPE_HANDLE to stripe which is in batch list"), we don't want to set
STRIPE_HANDLE flag for sh which is already in batch list.
However, the stripe which is the head of batch list should set this flag,
otherwise panic could happen inside init_stripe at BUG_ON(sh->batch_head),
it is reproducible with raid5 on top of nvdimm devices per Xiao oberserved.
Thanks for Xiao's effort to verify the change.
Fixes: 6ce220dd2f8ea ("raid5: don't set STRIPE_HANDLE to stripe which is in batch list")
Reported-by: Xiao Ni <xni@redhat.com>
Tested-by: Xiao Ni <xni@redhat.com>
Signed-off-by: Guoqing Jiang <guoqing.jiang@cloud.ionos.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
[ Upstream commit 2727315df3f5ffbebcb174eed3153944a858b66f ]
The Terra Pad 1061 has the usual micro-USB-B id-pin handler, but instead
of controlling the actual micro-USB-B it turns the 5V boost for the
tablet's USB-A connector and its keyboard-cover connector off.
The actual micro-USB-B connector on the tablet is wired for charging only,
and its id pin is *not* connected to the GPIO which is used for the
(broken) id-pin event handler in the DSDT.
While at it not only add a comment why the Terra Pad 1061 is on the
blacklist, but also fix the missing comment for the Minix Neo Z83-4 entry.
Fixes: 61f7f7c8f978 ("gpiolib: acpi: Add gpiolib_acpi_run_edge_events_on_boot option and blacklist")
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
[ Upstream commit 5d603311615f612320bb77bd2a82553ef1ced5b7 ]
Fix the race between load and unload a kernel module.
sys_delete_module()
try_stop_module()
mod->state = _GOING
add_unformed_module()
old = find_module_all()
(old->state == _GOING =>
wait_event_interruptible())
During pre-condition
finished_loading() rets 0
schedule()
(never gets waken up later)
free_module()
mod->state = _UNFORMED
list_del_rcu(&mod->list)
(dels mod from "modules" list)
return
The race above leads to modprobe hanging forever on loading
a module.
Error paths on loading module call wake_up_all(&module_wq) after
freeing module, so let's do the same on straight module unload.
Fixes: 6e6de3dee51a ("kernel/module.c: Only return -EEXIST for modules that have finished loading")
Reviewed-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Konstantin Khorenko <khorenko@virtuozzo.com>
Signed-off-by: Jessica Yu <jeyu@kernel.org>
[ Upstream commit fe5e7ba11fcf1d75af8173836309e8562aefedef ]
Commit 9287c6452d2b fixed a situation in which gfs2 could use a glock
after it had been freed. To do that, it temporarily added a new glock
reference by calling gfs2_glock_hold in function gfs2_add_revoke.
However, if the bd element was removed by gfs2_trans_remove_revoke, it
failed to drop the additional reference.
This patch adds logic to gfs2_trans_remove_revoke to properly drop the
additional glock reference.
Fixes: 9287c6452d2b ("gfs2: Fix occasional glock use-after-free")
Cc: stable@vger.kernel.org # v5.2+
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
[ Upstream commit c431f8597863a91eea6024926e0c1b179cfa4852 ]
SFF 8472 eeprom length is 512 bytes. Fix module info return value to
support 512 bytes read.
Fixes: ace329f4ab3b ("net/mlx5e: ethtool, Remove unsupported SFP EEPROM high pages query")
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
Reviewed-by: Aya Levin <ayal@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit 5fcaf6982d1167f1cd9b264704f6d1ef4c505d54 ]
I was investigating a crash in our Virtuozzo7 kernel which happened in
in svcauth_unix_set_client. I found out that we access m_client field
in ip_map structure, which was received from sunrpc_cache_lookup (we
have a bit older kernel, now the code is in sunrpc_cache_add_entry), and
these field looks uninitialized (m_client == 0x74 don't look like a
pointer) but in the cache_head in flags we see 0x1 which is CACHE_VALID.
It looks like the problem appeared from our previous fix to sunrpc (1):
commit 4ecd55ea0742 ("sunrpc: fix cache_head leak due to queued
request")
And we've also found a patch already fixing our patch (2):
commit d58431eacb22 ("sunrpc: don't mark uninitialised items as VALID.")
Though the crash is eliminated, I think the core of the problem is not
completely fixed:
Neil in the patch (2) makes cache_head CACHE_NEGATIVE, before
cache_fresh_locked which was added in (1) to fix crash. These way
cache_is_valid won't say the cache is valid anymore and in
svcauth_unix_set_client the function cache_check will return error
instead of 0, and we don't count entry as initialized.
But it looks like we need to remove cache_fresh_locked completely in
sunrpc_cache_lookup:
In (1) we've only wanted to make cache_fresh_unlocked->cache_dequeue so
that cache_requests with no readers also release corresponding
cache_head, to fix their leak. We with Vasily were not sure if
cache_fresh_locked and cache_fresh_unlocked should be used in pair or
not, so we've guessed to use them in pair.
Now we see that we don't want the CACHE_VALID bit set here by
cache_fresh_locked, as "valid" means "initialized" and there is no
initialization in sunrpc_cache_add_entry. Both expiry_time and
last_refresh are not used in cache_fresh_unlocked code-path and also not
required for the initial fix.
So to conclude cache_fresh_locked was called by mistake, and we can just
safely remove it instead of crutching it with CACHE_NEGATIVE. It looks
ideologically better for me. Hope I don't miss something here.
Here is our crash backtrace:
[13108726.326291] BUG: unable to handle kernel NULL pointer dereference at 0000000000000074
[13108726.326365] IP: [<ffffffffc01f79eb>] svcauth_unix_set_client+0x2ab/0x520 [sunrpc]
[13108726.326448] PGD 0
[13108726.326468] Oops: 0002 [#1] SMP
[13108726.326497] Modules linked in: nbd isofs xfs loop kpatch_cumulative_81_0_r1(O) xt_physdev nfnetlink_queue bluetooth rfkill ip6table_nat nf_nat_ipv6 ip_vs_wrr ip_vs_wlc ip_vs_sh nf_conntrack_netlink ip_vs_sed ip_vs_pe_sip nf_conntrack_sip ip_vs_nq ip_vs_lc ip_vs_lblcr ip_vs_lblc ip_vs_ftp ip_vs_dh nf_nat_ftp nf_conntrack_ftp iptable_raw xt_recent nf_log_ipv6 xt_hl ip6t_rt nf_log_ipv4 nf_log_common xt_LOG xt_limit xt_TCPMSS xt_tcpmss vxlan ip6_udp_tunnel udp_tunnel xt_statistic xt_NFLOG nfnetlink_log dummy xt_mark xt_REDIRECT nf_nat_redirect raw_diag udp_diag tcp_diag inet_diag netlink_diag af_packet_diag unix_diag rpcsec_gss_krb5 xt_addrtype ip6t_rpfilter ipt_REJECT nf_reject_ipv4 ip6t_REJECT nf_reject_ipv6 ebtable_nat ebtable_broute nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_mangle ip6table_raw nfsv4
[13108726.327173] dns_resolver cls_u32 binfmt_misc arptable_filter arp_tables ip6table_filter ip6_tables devlink fuse_kio_pcs ipt_MASQUERADE nf_nat_masquerade_ipv4 xt_nat iptable_nat nf_nat_ipv4 xt_comment nf_conntrack_ipv4 nf_defrag_ipv4 xt_wdog_tmo xt_multiport bonding xt_set xt_conntrack iptable_filter iptable_mangle kpatch(O) ebtable_filter ebt_among ebtables ip_set_hash_ip ip_set nfnetlink vfat fat skx_edac intel_powerclamp coretemp intel_rapl iosf_mbi kvm_intel kvm irqbypass fuse pcspkr ses enclosure joydev sg mei_me hpwdt hpilo lpc_ich mei ipmi_si shpchp ipmi_devintf ipmi_msghandler xt_ipvs acpi_power_meter ip_vs_rr nfsv3 nfsd auth_rpcgss nfs_acl nfs lockd grace fscache nf_nat cls_fw sch_htb sch_cbq sch_sfq ip_vs em_u32 nf_conntrack tun br_netfilter veth overlay ip6_vzprivnet ip6_vznetstat ip_vznetstat
[13108726.327817] ip_vzprivnet vziolimit vzevent vzlist vzstat vznetstat vznetdev vzmon vzdev bridge pio_kaio pio_nfs pio_direct pfmt_raw pfmt_ploop1 ploop ip_tables ext4 mbcache jbd2 sd_mod crc_t10dif crct10dif_generic mgag200 i2c_algo_bit drm_kms_helper scsi_transport_iscsi 8021q syscopyarea sysfillrect garp sysimgblt fb_sys_fops mrp stp ttm llc bnx2x crct10dif_pclmul crct10dif_common crc32_pclmul crc32c_intel drm dm_multipath ghash_clmulni_intel uas aesni_intel lrw gf128mul glue_helper ablk_helper cryptd tg3 smartpqi scsi_transport_sas mdio libcrc32c i2c_core usb_storage ptp pps_core wmi sunrpc dm_mirror dm_region_hash dm_log dm_mod [last unloaded: kpatch_cumulative_82_0_r1]
[13108726.328403] CPU: 35 PID: 63742 Comm: nfsd ve: 51332 Kdump: loaded Tainted: G W O ------------ 3.10.0-862.20.2.vz7.73.29 #1 73.29
[13108726.328491] Hardware name: HPE ProLiant DL360 Gen10/ProLiant DL360 Gen10, BIOS U32 10/02/2018
[13108726.328554] task: ffffa0a6a41b1160 ti: ffffa0c2a74bc000 task.ti: ffffa0c2a74bc000
[13108726.328610] RIP: 0010:[<ffffffffc01f79eb>] [<ffffffffc01f79eb>] svcauth_unix_set_client+0x2ab/0x520 [sunrpc]
[13108726.328706] RSP: 0018:ffffa0c2a74bfd80 EFLAGS: 00010246
[13108726.328750] RAX: 0000000000000001 RBX: ffffa0a6183ae000 RCX: 0000000000000000
[13108726.328811] RDX: 0000000000000074 RSI: 0000000000000286 RDI: ffffa0c2a74bfcf0
[13108726.328864] RBP: ffffa0c2a74bfe00 R08: ffffa0bab8c22960 R09: 0000000000000001
[13108726.328916] R10: 0000000000000001 R11: 0000000000000001 R12: ffffa0a32aa7f000
[13108726.328969] R13: ffffa0a6183afac0 R14: ffffa0c233d88d00 R15: ffffa0c2a74bfdb4
[13108726.329022] FS: 0000000000000000(0000) GS:ffffa0e17f9c0000(0000) knlGS:0000000000000000
[13108726.329081] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[13108726.332311] CR2: 0000000000000074 CR3: 00000026a1b28000 CR4: 00000000007607e0
[13108726.334606] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[13108726.336754] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[13108726.338908] PKRU: 00000000
[13108726.341047] Call Trace:
[13108726.343074] [<ffffffff8a2c78b4>] ? groups_alloc+0x34/0x110
[13108726.344837] [<ffffffffc01f5eb4>] svc_set_client+0x24/0x30 [sunrpc]
[13108726.346631] [<ffffffffc01f2ac1>] svc_process_common+0x241/0x710 [sunrpc]
[13108726.348332] [<ffffffffc01f3093>] svc_process+0x103/0x190 [sunrpc]
[13108726.350016] [<ffffffffc07d605f>] nfsd+0xdf/0x150 [nfsd]
[13108726.351735] [<ffffffffc07d5f80>] ? nfsd_destroy+0x80/0x80 [nfsd]
[13108726.353459] [<ffffffff8a2bf741>] kthread+0xd1/0xe0
[13108726.355195] [<ffffffff8a2bf670>] ? create_kthread+0x60/0x60
[13108726.356896] [<ffffffff8a9556dd>] ret_from_fork_nospec_begin+0x7/0x21
[13108726.358577] [<ffffffff8a2bf670>] ? create_kthread+0x60/0x60
[13108726.360240] Code: 4c 8b 45 98 0f 8e 2e 01 00 00 83 f8 fe 0f 84 76 fe ff ff 85 c0 0f 85 2b 01 00 00 49 8b 50 40 b8 01 00 00 00 48 89 93 d0 1a 00 00 <f0> 0f c1 02 83 c0 01 83 f8 01 0f 8e 53 02 00 00 49 8b 44 24 38
[13108726.363769] RIP [<ffffffffc01f79eb>] svcauth_unix_set_client+0x2ab/0x520 [sunrpc]
[13108726.365530] RSP <ffffa0c2a74bfd80>
[13108726.367179] CR2: 0000000000000074
Fixes: d58431eacb22 ("sunrpc: don't mark uninitialised items as VALID.")
Signed-off-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Acked-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 8efe1223d73c218ce7e8b2e0e9aadb974b582d7f upstream.
Reported-by: Qian Cai <cai@lca.pw>
Fixes: def98c84b6cd ("workqueue: Fix spurious sanity check failures in destroy_workqueue()")
Cc: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp>
commit d2c9be89f8ebe7ebcc97676ac40f8dec1cf9b43a upstream.
8962842ca5ab ("blk-mq: avoid sysfs buffer overflow with too many CPU cores")
avoids sysfs buffer overflow, and reserves one character for line break.
However, the last snprintf() doesn't get correct 'size' parameter passed
in, so fixed it.
Fixes: 8962842ca5ab ("blk-mq: avoid sysfs buffer overflow with too many CPU cores")
Signed-off-by: Ming Lei <ming.lei@redhat.com>
[ Upstream commit 37ef8c2c15bdc1322b160e38986c187de2b877b2 ]
The Rockchip PMIC driver can automatically detect connected component
versions by reading the ID_MSB and ID_LSB registers. The probe function
will always fail with RK818 PMICs because the ID_MSK is 0xFFF0 and the
RK818 template ID is 0x8181.
This patch changes this value to 0x8180.
Fixes: 9d6105e19f61 ("mfd: rk808: Fix up the chip id get failed")
Cc: Elaine Zhang <zhangqing@rock-chips.com>
Cc: Joseph Chen <chenjh@rock-chips.com>
Signed-off-by: Daniel Schultz <d.schultz@phytec.de>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 565333a1554d704789e74205989305c811fd9c7a upstream.
No need to wait for any commit once the page is fully truncated.
Besides, it may confuse e.g. concurrent ext4_writepage() with the page
still be dirty (will be cleared by truncate_pagecache() in
ext4_setattr()) but buffers has been freed; and then trigger a bug
show as below:
[ 26.057508] ------------[ cut here ]------------
[ 26.058531] kernel BUG at fs/ext4/inode.c:2134!
[ 26.088130] Call trace:
[ 26.088695] ext4_writepage+0x914/0xb28
[ 26.089541] writeout.isra.4+0x1b4/0x2b8
[ 26.090409] move_to_new_page+0x3b0/0x568
[ 26.091338] __unmap_and_move+0x648/0x988
[ 26.092241] unmap_and_move+0x48c/0xbb8
[ 26.093096] migrate_pages+0x220/0xb28
[ 26.093945] kernel_mbind+0x828/0xa18
[ 26.094791] __arm64_sys_mbind+0xc8/0x138
[ 26.095716] el0_svc_common+0x190/0x490
[ 26.096571] el0_svc_handler+0x60/0xd0
[ 26.097423] el0_svc+0x8/0xc
Run the procedure (generate by syzkaller) parallel with ext3.
void main()
int fd, fd1, ret;
void *addr;
size_t length = 4096;
int flags;
off_t offset = 0;
char *str = "12345";
fd = open("a", O_RDWR | O_CREAT);
assert(fd >= 0);
/* Truncate to 4k */
ret = ftruncate(fd, length);
assert(ret == 0);
/* Journal data mode */
flags = 0xc00f;
ret = ioctl(fd, _IOW('f', 2, long), &flags);
assert(ret == 0);
/* Truncate to 0 */
fd1 = open("a", O_TRUNC | O_NOATIME);
assert(fd1 >= 0);
addr = mmap(NULL, length, PROT_WRITE | PROT_READ,
MAP_SHARED, fd, offset);
assert(addr != (void *)-1);
memcpy(addr, str, 5);
mbind(addr, length, 0, 0, 0, MPOL_MF_MOVE);
And the bug will be triggered once we seen the below order.
reproduce1 reproduce2
truncate to 4k |
change to journal data mode |
| memcpy(set page dirty)
truncate to 0: |
ext4_setattr: |
ext4_wait_for_tail_page_commit |
| mbind(trigger bug)
truncate_pagecache(clean dirty)| ...
mbind will call ext4_writepage() since the page still be dirty, and then
report the bug since the buffers has been free. Fix it by return
directly once offset equals to 0 which means the page has been fully
truncated.
Signed-off-by: yangerkun <yangerkun@huawei.com>
Link: https://lore.kernel.org/r/20190919063508.1045-1-yangerkun@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit aa71ecd8d86500da6081a72da6b0b524007e0627 upstream.
In 64bit system. sb->s_maxbytes of shmem filesystem is MAX_LFS_FILESIZE,
which equal LLONG_MAX.
If offset > LLONG_MAX - PAGE_SIZE, offset + len < LLONG_MAX in
shmem_fallocate, which will pass the checking in vfs_fallocate.
/* Check for wrap through zero too */
if (((offset + len) > inode->i_sb->s_maxbytes) || ((offset + len) < 0))
return -EFBIG;
loff_t unmap_start = round_up(offset, PAGE_SIZE) in shmem_fallocate
causes a overflow.
Syzkaller reports a overflow problem in mm/shmem:
UBSAN: Undefined behaviour in mm/shmem.c:2014:10
signed integer overflow: '9223372036854775807 + 1' cannot be represented in type 'long long int'
CPU: 0 PID:17076 Comm: syz-executor0 Not tainted 4.1.46+ #1
Hardware name: linux, dummy-virt (DT)
Call trace:
dump_backtrace+0x0/0x2c8 arch/arm64/kernel/traps.c:100
show_stack+0x20/0x30 arch/arm64/kernel/traps.c:238
__dump_stack lib/dump_stack.c:15 [inline]
ubsan_epilogue+0x18/0x70 lib/ubsan.c:164
handle_overflow+0x158/0x1b0 lib/ubsan.c:195
shmem_fallocate+0x6d0/0x820 mm/shmem.c:2104
vfs_fallocate+0x238/0x428 fs/open.c:312
SYSC_fallocate fs/open.c:335 [inline]
SyS_fallocate+0x54/0xc8 fs/open.c:239
The highest bit of unmap_start will be appended with sign bit 1
(overflow) when calculate shmem_falloc.start:
shmem_falloc.start = unmap_start >> PAGE_SHIFT.
Fix it by casting the type of unmap_start to u64, when right shifted.
This bug is found in LTS Linux 4.1. It also seems to exist in mainline.
Link: http://lkml.kernel.org/r/1573867464-5107-1-git-send-email-chenjun102@huawei.com
Signed-off-by: Chen Jun <chenjun102@huawei.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Qian Cai <cai@lca.pw>
Cc: Kefeng Wang <wangkefeng.wang@huawei.com>
commit ff34f3cce278a0982a7b66b1afaed6295141b1fc upstream.
The 'a0' member of 'struct arm_smccc_res' is declared as 'unsigned long',
however the Qualcomm SCM firmware interface driver expects to receive
negative error codes via this field, so ensure that it's cast to 'long'
before comparing to see if it is less than 0.
Cc: <stable@vger.kernel.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Will Deacon <will@kernel.org>
commit c7df4a1ecb8579838ec8c56b2bb6a6716e974f37 upstream.
If the file system is corrupted such that a file's i_links_count is
too small, then it's possible that when unlinking that file, i_nlink
will already be zero. Previously we were working around this kind of
corruption by forcing i_nlink to one; but we were doing this before
trying to delete the directory entry --- and if the file system is
corrupted enough that ext4_delete_entry() fails, then we exit with
i_nlink elevated, and this causes the orphan inode list handling to be
FUBAR'ed, such that when we unmount the file system, the orphan inode
list can get corrupted.
A better way to fix this is to simply skip trying to call drop_nlink()
if i_nlink is already zero, thus moving the check to the place where
it makes the most sense.
https://bugzilla.kernel.org/show_bug.cgi?id=205433
Link: https://lore.kernel.org/r/20191112032903.8828-1-tytso@mit.edu
Cc: stable@kernel.org
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
[ Upstream commit 552263456215ada7ee8700ce022d12b0cffe4802 ]
clock_getres in the vDSO library has to preserve the same behaviour
of posix_get_hrtimer_res().
In particular, posix_get_hrtimer_res() does:
sec = 0;
ns = hrtimer_resolution;
and hrtimer_resolution depends on the enablement of the high
resolution timers that can happen either at compile or at run time.
Fix the powerpc vdso implementation of clock_getres keeping a copy of
hrtimer_resolution in vdso data and using that directly.
Fixes: a7f290dad32e ("[PATCH] powerpc: Merge vdso's and add vdso support to 32 bits kernel")
Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
Reviewed-by: Christophe Leroy <christophe.leroy@c-s.fr>
Acked-by: Shuah Khan <skhan@linuxfoundation.org>
[chleroy: changed CLOCK_REALTIME_RES to CLOCK_HRTIMER_RES]
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Link: https://lore.kernel.org/r/a55eca3a5e85233838c2349783bcb5164dae1d09.1575273217.git.christophe.leroy@c-s.fr
[ Upstream commit c9029ef9c95765e7b63c4d9aa780674447db1ec0 ]
Commit aea447141c7e ("powerpc: Disable -Wbuiltin-requires-header when
setjmp is used") disabled -Wbuiltin-requires-header because of a
warning about the setjmp and longjmp declarations.
r367387 in clang added another diagnostic around this, complaining
that there is no jmp_buf declaration.
In file included from ../arch/powerpc/xmon/xmon.c:47:
../arch/powerpc/include/asm/setjmp.h:10:13: error: declaration of
built-in function 'setjmp' requires the declaration of the 'jmp_buf'
type, commonly provided in the header <setjmp.h>.
[-Werror,-Wincomplete-setjmp-declaration]
extern long setjmp(long *);
../arch/powerpc/include/asm/setjmp.h:11:13: error: declaration of
built-in function 'longjmp' requires the declaration of the 'jmp_buf'
extern void longjmp(long *, long);
2 errors generated.
We are not using the standard library's longjmp/setjmp implementations
for obvious reasons; make this clear to clang by using -ffreestanding
on these files.
Cc: stable@vger.kernel.org # 4.14+
Suggested-by: Segher Boessenkool <segher@kernel.crashing.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Link: https://lore.kernel.org/r/20191119045712.39633-3-natechancellor@gmail.com
[ Upstream commit 08d80e4cd27ba19f9bee9e5f788f9a9fc440a22f ]
On SMP platform, when continuously running wifi up/down, the napi
poll can be scheduled during chip reset, which will call
ath10k_pci_has_fw_crashed() to check the fw status. But in the reset
period, the value from FW_INDICATOR_ADDRESS register will return
0xdeadbeef, which also be treated as fw crash. Fix the issue by
moving chip reset after napi disabled.
ath10k_pci 0000:01:00.0: firmware crashed! (guid 73b30611-5b1e-4bdd-90b4-64c81eb947b6)
ath10k_pci 0000:01:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
ath10k_pci 0000:01:00.0: htt-ver 2.2 wmi-op 6 htt-op 4 cal otp max-sta 512 raw 0 hwcrypto 1
ath10k_pci 0000:01:00.0: failed to get memcpy hi address for firmware address 4: -16
ath10k_pci 0000:01:00.0: failed to read firmware dump area: -16
ath10k_pci 0000:01:00.0: Copy Engine register dump:
ath10k_pci 0000:01:00.0: [00]: 0x0004a000 0 0 0 0
ath10k_pci 0000:01:00.0: [01]: 0x0004a400 0 0 0 0
ath10k_pci 0000:01:00.0: [02]: 0x0004a800 0 0 0 0
ath10k_pci 0000:01:00.0: [03]: 0x0004ac00 0 0 0 0
ath10k_pci 0000:01:00.0: [04]: 0x0004b000 0 0 0 0
ath10k_pci 0000:01:00.0: [05]: 0x0004b400 0 0 0 0
ath10k_pci 0000:01:00.0: [06]: 0x0004b800 0 0 0 0
ath10k_pci 0000:01:00.0: [07]: 0x0004bc00 1 0 1 0
ath10k_pci 0000:01:00.0: [08]: 0x0004c000 0 0 0 0
ath10k_pci 0000:01:00.0: [09]: 0x0004c400 0 0 0 0
ath10k_pci 0000:01:00.0: [10]: 0x0004c800 0 0 0 0
ath10k_pci 0000:01:00.0: [11]: 0x0004cc00 0 0 0 0
Tested HW: QCA9984,QCA9887,WCN3990
Signed-off-by: Miaoqing Pan <miaoqing@codeaurora.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit ee1c71a8e1456ab53fe667281d855849edf26a4d ]
If the system has other devices being registered in the component
framework, the compare function will be called with a device that
doesn't belong to vimc.
This device is not necessarily a platform_device, nor have a
platform_data (which causes a NULL pointer dereference error) and if it
does have a pdata, it is not necessarily type of struct vimc_platform_data.
So casting to any of these types is wrong.
Instead of expecting a given pdev with a given pdata, just expect for
the device it self. vimc-core is the one who creates them, we know in
advance exactly which object to expect in the match.
Fixes: 4a29b7090749 ("[media] vimc: Subdevices as modules")
Signed-off-by: Helen Koike <helen.koike@collabora.com>
Reviewed-by: Boris Brezillon <boris.brezillon@collabora.com>
Tested-by: Boris Brezillon <boris.brezillon@collabora.com>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit 83d5782681cc12b3d485a83cb34c46b2445f510c ]
The driver tries to periodically refresh neighbours that are used to
reach nexthops. This is done by periodically calling neigh_event_send().
However, if the neighbour becomes dead, there is nothing we can do to
return it to a connected state and the above function call is basically
a NOP.
This results in the nexthop never being written to the device's
adjacency table and therefore never used to forward packets.
Fix this by dropping our reference from the dead neighbour and
associating the nexthop with a new neigbhour which we will try to
refresh.
Fixes: a7ff87acd995 ("mlxsw: spectrum_router: Implement next-hop routing")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Alex Veber <alexve@mellanox.com>
Tested-by: Alex Veber <alexve@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit c68b901ac4fa969db8917b6a9f9b40524a690d20 ]
The accumulator sample register is signed 32-bits wide register on
droid 4. And only the earlier version of cpcap has a signed 24-bits
wide register. We're currently passing it around as unsigned, so
let's fix that and use sign_extend32() for the earlier revision.
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
[ Upstream commit 30aa3d26edb0f3d7992757287eec0ca588a5c259 ]
The MC4_MISC thresholding quirk needs to be applied during S5 -> S0 and
S3 -> S0 state transitions, which follow different code paths. Carve it
out into a separate function and call it mce_amd_feature_init() where
the two code paths of the state transitions converge.
[ bp: massage commit message and the carved out function. ]
Signed-off-by: Shirish S <shirish.s@amd.com>
Cc: Vishal Verma <vishal.l.verma@intel.com>
Cc: Yazen Ghannam <yazen.ghannam@amd.com>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/1547651417-23583-3-git-send-email-shirish.s@amd.com
[ Upstream commit c95b323dcd3598dd7ef5005d6723c1ba3b801093 ]
MC4_MISC thresholding is not supported on all family 0x15 processors,
hence skip the x86_model check when applying the quirk.
[ bp: massage commit message. ]
Link: https://lkml.kernel.org/r/1547106849-3476-2-git-send-email-shirish.s@amd.com
[ Upstream commit cd0d465bb697a9c7bf66a9fe940f7981232f1676 ]
Fix a static code checker warning:
drivers/net/ethernet/intel/e100.c:1349
e100_load_ucode_wait() warn: passing zero to 'PTR_ERR'
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
[ Upstream commit 5816a0932b4fd74257b8cc5785bc8067186a8723 ]
Clang warns when an implicit conversion is done between enumerated
types:
drivers/block/drbd/drbd_state.c:708:8: warning: implicit conversion from
enumeration type 'enum drbd_ret_code' to different enumeration type
'enum drbd_state_rv' [-Wenum-conversion]
rv = ERR_INTR;
drbd_request_detach_interruptible's only call site is in the return
statement of adm_detach, which returns an int. Change the return type of
drbd_request_detach_interruptible to match, silencing Clang's warning.
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit 1c36833d82ff24d0d54215fd956e7cc30fffce54 ]
Driver is setting bits in word 10 of the SLI4 ABORT WQE (the wqid). The
field was a carry over from a prior SLI revision. The field does not exist
in SLI4, and the action may result in an overlap with future definition of
the WQE.
Remove the setting of WQID in the ABORT WQE.
Also cleaned up WQE field settings - initialize to zero, don't bother to
set fields to zero.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <jsmart2021@gmail.com>
[ Upstream commit 8b47ae69e049ae0b3373859d901f0334322f9fe9 ]
Depending on the chipset, the number of NPIV vports may vary and be in
excess of what most switches support (256). To avoid confusion with the
users, limit the reported NPIV vports to 256.
Additionally correct the 16G adapter which is reporting a bogus NPIV vport
number if the link is down.
[ Upstream commit 2398c41d64321e62af54424fd399964f3d48cdc2 ]
With a wl1251 child node of mmc3 in the device tree decoded
in omap_hsmmc.c to handle special wl1251 initialization, we do
no longer need to instantiate the mmc3 through pdata quirks.
We also can remove the wlan regulator and reset/interrupt definitions
and do them through device tree.
Fixes: 81eef6ca9201 ("mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Cc: <stable@vger.kernel.org> # v4.7+
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 4bd5ead82d4b877ebe41daf95f28cda53205b039 ]
Since the role_store() uses strncmp(), it's possible to refer
out-of-memory if the sysfs data size is smaller than strlen("host").
This patch fixes it by using sysfs_streq() instead of strncmp().
Reported-by: Pavel Machek <pavel@denx.de>
Fixes: 9bb86777fb71 ("phy: rcar-gen3-usb2: add sysfs for usb role swap")
Cc: <stable@vger.kernel.org> # v4.10+
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Pavel Machek <pavel@denx.de>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
[ Upstream commit 4c35b7a51e2f291471f7221d112c6a45c63e83bc ]
The driver is defining debugfs entries by calling
`adis16480_debugfs_init()`. However, those entries are attached to the
iio_dev debugfs entry which won't exist if no debugfs_reg_access
callback is provided.
Fixes: 2f3abe6cbb6c ("iio:imu: Add support for the ADIS16480 and similar IMUs")
Signed-off-by: Nuno Sá <nuno.sa@analog.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit bd82873f23c9a6ad834348f8b83f3b6a5bca2c65 ]
spin_unlock_irqrestore() might be called with stale flags after
reading port status, possibly restoring interrupts to a incorrect
state.
If a usb2 port just finished resuming while the port status is read
the spin lock will be temporary released and re-acquired in a separate
function. The flags parameter is passed as value instead of a pointer,
not updating flags properly before the final spin_unlock_irqrestore()
is called.
Cc: <stable@vger.kernel.org> # v3.12+
Fixes: 8b3d45705e54 ("usb: Fix xHCI host issues on remote wakeup.")
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Link: https://lore.kernel.org/r/20191211142007.8847-7-mathias.nyman@linux.intel.com
[ Upstream commit ce91f1a43b37463f517155bdfbd525eb43adbd1a ]
When xHCI is part of Alpine or Titan Ridge Thunderbolt controller and
the xHCI device is hot-removed as a result of unplugging a dock for
example, the driver leaks memory it allocates for xhci->usb3_rhub.psi
and xhci->usb2_rhub.psi in xhci_add_in_port() as reported by kmemleak:
unreferenced object 0xffff922c24ef42f0 (size 16):
comm "kworker/u16:2", pid 178, jiffies 4294711640 (age 956.620s)
hex dump (first 16 bytes):
21 00 0c 00 12 00 dc 05 23 00 e0 01 00 00 00 00 !.......#.......
backtrace:
[<000000007ac80914>] xhci_mem_init+0xcf8/0xeb7
[<0000000001b6d775>] xhci_init+0x7c/0x160
[<00000000db443fe3>] xhci_gen_setup+0x214/0x340
[<00000000fdffd320>] xhci_pci_setup+0x48/0x110
[<00000000541e1e03>] usb_add_hcd.cold+0x265/0x747
[<00000000ca47a56b>] usb_hcd_pci_probe+0x219/0x3b4
[<0000000021043861>] xhci_pci_probe+0x24/0x1c0
[<00000000b9231f25>] local_pci_probe+0x3d/0x70
[<000000006385c9d7>] pci_device_probe+0xd0/0x150
[<0000000070241068>] really_probe+0xf5/0x3c0
[<0000000061f35c0a>] driver_probe_device+0x58/0x100
[<000000009da11198>] bus_for_each_drv+0x79/0xc0
[<000000009ce45f69>] __device_attach+0xda/0x160
[<00000000df201aaf>] pci_bus_add_device+0x46/0x70
[<0000000088a1bc48>] pci_bus_add_devices+0x27/0x60
[<00000000ad9ee708>] pci_bus_add_devices+0x52/0x60
unreferenced object 0xffff922c24ef3318 (size 8):
hex dump (first 8 bytes):
34 01 05 00 35 41 0a 00 4...5A..
backtrace:
Fix this by calling kfree() for the both psi objects in
xhci_mem_cleanup().
Cc: <stable@vger.kernel.org> # 4.4+
Fixes: 47189098f8be ("xhci: parse xhci protocol speed ID list for usb 3.1 usage")
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: https://lore.kernel.org/r/20191211142007.8847-2-mathias.nyman@linux.intel.com
[ Upstream commit da48b82425b8bf999fb9f7c220e967c4d661b5f8 ]
This patch updates log message which indicates number of vectors used by
the driver instead of displaying failure to get maximum requested
vectors. Driver will always request maximum vectors during
initialization. In the event driver is not able to get maximum requested
vectors, it will adjust the allocated vectors. This is normal and does not
imply failure in driver.
Signed-off-by: Himanshu Madhani <hmadhani@marvell.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
Reviewed-by: Lee Duncan <lduncan@suse.com>
Link: https://lore.kernel.org/r/20190830222402.23688-2-hmadhani@marvell.com
[ Upstream commit e6803efae5acd109fad9f2f07dab674563441a53 ]
This patch fixes several Coverity complaints about not always checking
the qla2x00_wait_for_hba_online() return value.
Cc: Himanshu Madhani <hmadhani@marvell.com>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Tested-by: Himanshu Madhani <hmadhani@marvell.com>
Reviewed-by: Himanshu Madhani <hmadhani@marvell.com>
[ Upstream commit c29282c65d1cf54daeea63be46243d7f69d72f4d ]
Set the r??_data_len variables before using these instead of after.
This patch fixes the following Coverity complaint:
const: At condition req_data_len != rsp_data_len, the value of req_data_len
must be equal to 0.
const: At condition req_data_len != rsp_data_len, the value of rsp_data_len
must be equal to 0.
dead_error_condition: The condition req_data_len != rsp_data_len cannot be
true.
Fixes: a9b6f722f62d ("[SCSI] qla2xxx: Implementation of bidirectional.") # v3.7.
[ Upstream commit ac452b8e79320c9e90c78edf32ba2d42431e4daf ]
Pass the correct session ID to find_sess_by_s_id() instead of passing an
uninitialized variable.
Fixes: 2d70c103fd2a ("[SCSI] qla2xxx: Add LLD target-mode infrastructure for >= 24xx series") # v3.5.
[ Upstream commit 5d328de64d89400dcf9911125844d8adc0db697f ]
With debug kernel we see following wanings indicating memory leak.
[28809.523959] WARNING: CPU: 3 PID: 6790 at lib/dma-debug.c:978
dma_debug_device_change+0x166/0x1d0
[28809.523964] pci 0000:0c:00.6: DMA-API: device driver has pending DMA
allocations while released from device [count=5]
[28809.523964] One of leaked entries details: [device
address=0x00000002aefe4000] [size=8208 bytes] [mapped with DMA_BIDIRECTIONAL]
[mapped as coherent]
Fix this by unmapping DMA memory.
Signed-off-by: Quinn Tran <qutran@marvell.com>
[ Upstream commit 100843f176109af94600e500da0428e21030ca7f ]
While v2.6.26 commit b75db73159cc ("[SCSI] zfcp: Add qtcb dump to hba debug
trace") is right that we don't want to flood the (payload) trace ring
buffer, we don't trace successful FCP command responses by default. So we
can include the channel log for problem determination with failed responses
of any FSF request type.
Fixes: b75db73159cc ("[SCSI] zfcp: Add qtcb dump to hba debug trace")
Fixes: a54ca0f62f95 ("[SCSI] zfcp: Redesign of the debug tracing for HBA records.")
Cc: <stable@vger.kernel.org> #2.6.38+
Link: https://lore.kernel.org/r/e37597b5c4ae123aaa85fd86c23a9f71e994e4a9.1572018132.git.bblock@linux.ibm.com
Reviewed-by: Benjamin Block <bblock@linux.ibm.com>
Signed-off-by: Steffen Maier <maier@linux.ibm.com>
Signed-off-by: Benjamin Block <bblock@linux.ibm.com>
commit 2a5cf35cd6c56b2924bce103413ad3381bdc31fa upstream.
There are actually two kinds of discard merge:
- one is the normal discard merge, just like normal read/write request,
and call it single-range discard
- another is the multi-range discard, queue_max_discard_segments(rq->q) > 1
For the former case, queue_max_discard_segments(rq->q) is 1, and we
should handle this kind of discard merge like the normal read/write
request.
This patch fixes the following kernel panic issue[1], which is caused by
not removing the single-range discard request from elevator queue.
Guangwu has one raid discard test case, in which this issue is a bit
easier to trigger, and I verified that this patch can fix the kernel
panic issue in Guangwu's test case.
[1] kernel panic log from Jens's report
BUG: unable to handle kernel NULL pointer dereference at 0000000000000148
PGD 0 P4D 0.
Oops: 0000 [#1] SMP PTI
CPU: 37 PID: 763 Comm: kworker/37:1H Not tainted \
4.20.0-rc3-00649-ge64d9a554a91-dirty #14 Hardware name: Wiwynn \
Leopard-Orv2/Leopard-DDR BW, BIOS LBM08 03/03/2017 Workqueue: kblockd \
blk_mq_run_work_fn RIP: \
0010:blk_mq_get_driver_tag+0x81/0x120 Code: 24 \
10 48 89 7c 24 20 74 21 83 fa ff 0f 95 c0 48 8b 4c 24 28 65 48 33 0c 25 28 00 00 00 \
0f 85 96 00 00 00 48 83 c4 30 5b 5d c3 <48> 8b 87 48 01 00 00 8b 40 04 39 43 20 72 37 \
f6 87 b0 00 00 00 02 RSP: 0018:ffffc90004aabd30 EFLAGS: 00010246 \
RAX: 0000000000000003 RBX: ffff888465ea1300 RCX: ffffc90004aabde8
RDX: 00000000ffffffff RSI: ffffc90004aabde8 RDI: 0000000000000000
RBP: 0000000000000000 R08: ffff888465ea1348 R09: 0000000000000000
R10: 0000000000001000 R11: 00000000ffffffff R12: ffff888465ea1300
R13: 0000000000000000 R14: ffff888465ea1348 R15: ffff888465d10000
FS: 0000000000000000(0000) GS:ffff88846f9c0000(0000) knlGS:0000000000000000
CR2: 0000000000000148 CR3: 000000000220a003 CR4: 00000000003606e0
Call Trace:
blk_mq_dispatch_rq_list+0xec/0x480
? elv_rb_del+0x11/0x30
blk_mq_do_dispatch_sched+0x6e/0xf0
blk_mq_sched_dispatch_requests+0xfa/0x170
__blk_mq_run_hw_queue+0x5f/0xe0
process_one_work+0x154/0x350
worker_thread+0x46/0x3c0
kthread+0xf5/0x130
? process_one_work+0x350/0x350
? kthread_destroy_worker+0x50/0x50
ret_from_fork+0x1f/0x30
Modules linked in: sb_edac x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel \
kvm switchtec irqbypass iTCO_wdt iTCO_vendor_support efivars cdc_ether usbnet mii \
cdc_acm i2c_i801 lpc_ich mfd_core ipmi_si ipmi_devintf ipmi_msghandler acpi_cpufreq \
button sch_fq_codel nfsd nfs_acl lockd grace auth_rpcgss oid_registry sunrpc nvme \
nvme_core fuse sg loop efivarfs autofs4 CR2: 0000000000000148 \
---[ end trace 340a1fb996df1b9b ]---
RIP: 0010:blk_mq_get_driver_tag+0x81/0x120
Code: 24 10 48 89 7c 24 20 74 21 83 fa ff 0f 95 c0 48 8b 4c 24 28 65 48 33 0c 25 28 \
00 00 00 0f 85 96 00 00 00 48 83 c4 30 5b 5d c3 <48> 8b 87 48 01 00 00 8b 40 04 39 43 \
20 72 37 f6 87 b0 00 00 00 02
Fixes: 445251d0f4d329a ("blk-mq: fix discard merge with scheduler attached")
Reported-by: Jens Axboe <axboe@kernel.dk>
Cc: Guangwu Zhang <guazhang@redhat.com>
Cc: Jianchao Wang <jianchao.w.wang@oracle.com>
Cc: Andre Tomt <andre@tomt.net>
Cc: Jack Wang <jack.wang.usish@gmail.com>
commit 60e4cf67a582d64f07713eda5fcc8ccdaf7833e6 upstream.
Since commit d0a5b995a308 (vfs: Add IOP_XATTR inode operations flag)
extended attributes haven't worked on the root directory in reiserfs.
This is due to reiserfs conditionally setting the sb->s_xattrs handler
array depending on whether it located or create the internal privroot
directory. It necessarily does this after the root inode is already
read in. The IOP_XATTR flag is set during inode initialization, so
it never gets set on the root directory.
This commit unconditionally assigns sb->s_xattrs and clears IOP_XATTR on
internal inodes. The old return values due to the conditional assignment
are handled via open_xa_root, which now returns EOPNOTSUPP as the VFS
would have done.
Link: https://lore.kernel.org/r/20191024143127.17509-1-jeffm@suse.com
CC: stable@vger.kernel.org
Fixes: d0a5b995a308 ("vfs: Add IOP_XATTR inode operations flag")
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 65db869c754e7c271691dd5feabf884347e694f5 upstream.
Estimate for the number of credits needed for final freeing of inode in
ext4_evict_inode() was to small. We may modify 4 blocks (inode & sb for
orphan deletion, bitmap & group descriptor for inode freeing) and not
just 3.
[ Fixed minor whitespace nit. -- TYT ]
Fixes: e50e5129f384 ("ext4: xattr-in-inode support")
Link: https://lore.kernel.org/r/20191105164437.32602-6-jack@suse.cz
commit 6ff33d99fc5c96797103b48b7b0902c296f09c05 upstream.
Write only quotas which are dirty at entry.
XFSTEST: https://github.com/dmonakhov/xfstests/commit/b10ad23566a5bf75832a6f500e1236084083cddc
Link: https://lore.kernel.org/r/20191031103920.3919-1-dmonakhov@openvz.org
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Signed-off-by: Dmitry Monakhov <dmtrmonakhov@yandex-team.ru>
commit e705f4b8aa27a59f8933e8f384e9752f052c469c upstream.
Check err when partial == NULL is meaningless because
partial == NULL means getting branch successfully without
error.
Link: https://lore.kernel.org/r/20191105045100.7104-1-cgxu519@mykernel.net
Signed-off-by: Chengguang Xu <cgxu519@mykernel.net>
commit df4bb5d128e2c44848aeb36b7ceceba3ac85080d upstream.
There is a race window where quota was redirted once we drop dq_list_lock inside dqput(),
but before we grab dquot->dq_lock inside dquot_release()
TASK1 TASK2 (chowner)
->dqput()
we_slept:
spin_lock(&dq_list_lock)
if (dquot_dirty(dquot)) {
spin_unlock(&dq_list_lock);
dquot->dq_sb->dq_op->write_dquot(dquot);
goto we_slept
if (test_bit(DQ_ACTIVE_B, &dquot->dq_flags)) {
dquot->dq_sb->dq_op->release_dquot(dquot);
dqget()
mark_dquot_dirty()
dqput()
goto we_slept;
So dquot dirty quota will be released by TASK1, but on next we_sleept loop
we detect this and call ->write_dquot() for it.
XFSTEST: https://github.com/dmonakhov/xfstests/commit/440a80d4cbb39e9234df4d7240aee1d551c36107
Link: https://lore.kernel.org/r/20191031103920.3919-2-dmonakhov@openvz.org
commit 6039f37dd6b76641198e290f26b31c475248f567 upstream.
The bar values are little endian, not big endian. The pack
function did it right but the unpack got it wrong. Fix it.
Cc: linux-media@vger.kernel.org
Cc: Martin Bugge <marbugge@cisco.com>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Fixes: 2c676f378edb ("[media] hdmi: added unpack and logging functions for InfoFrames")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190919132853.30954-1-ville.syrjala@linux.intel.com
Reviewed-by: Thierry Reding <treding@nvidia.com>
commit b67a95f2abff0c34e5667c15ab8900de73d8d087 upstream.
The PCI INTx interrupts and other LSI interrupts are handled differently
under a sPAPR platform. When the interrupt source characteristics are
queried, the hypervisor returns an H_INT_ESB flag to inform the OS
that it should be using the H_INT_ESB hcall for interrupt management
and not loads and stores on the interrupt ESB pages.
A default -1 value is returned for the addresses of the ESB pages. The
driver ignores this condition today and performs a bogus IO mapping.
Recent changes and the DEBUG_VM configuration option make the bug
visible with :
kernel BUG at arch/powerpc/include/asm/book3s/64/pgtable.h:612!
Oops: Exception in kernel mode, sig: 5 [#1]
LE PAGE_SIZE=64K MMU=Radix MMU=Hash SMP NR_CPUS=1024 NUMA pSeries
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.0-0.rc6.git0.1.fc32.ppc64le #1
NIP: c000000000f63294 LR: c000000000f62e44 CTR: 0000000000000000
REGS: c0000000fa45f0d0 TRAP: 0700 Not tainted (5.4.0-0.rc6.git0.1.fc32.ppc64le)
NIP ioremap_page_range+0x4c4/0x6e0
LR ioremap_page_range+0x74/0x6e0
Call Trace:
ioremap_page_range+0x74/0x6e0 (unreliable)
do_ioremap+0x8c/0x120
__ioremap_caller+0x128/0x140
ioremap+0x30/0x50
xive_spapr_populate_irq_data+0x170/0x260
xive_irq_domain_map+0x8c/0x170
irq_domain_associate+0xb4/0x2d0
irq_create_mapping+0x1e0/0x3b0
irq_create_fwspec_mapping+0x27c/0x3e0
irq_create_of_mapping+0x98/0xb0
of_irq_parse_and_map_pci+0x168/0x230
pcibios_setup_device+0x88/0x250
pcibios_setup_bus_devices+0x54/0x100
__of_scan_bus+0x160/0x310
pcibios_scan_phb+0x330/0x390
pcibios_init+0x8c/0x128
do_one_initcall+0x60/0x2c0
kernel_init_freeable+0x290/0x378
kernel_init+0x2c/0x148
ret_from_kernel_thread+0x5c/0x80
Fixes: bed81ee181dd ("powerpc/xive: introduce H_INT_ESB hcall")
Cc: stable@vger.kernel.org # v4.14+
Signed-off-by: Cédric Le Goater <clg@kaod.org>
Tested-by: Daniel Axtens <dja@axtens.net>
Link: https://lore.kernel.org/r/20191203163642.2428-1-clg@kaod.org
