2019-01-29apalis/colibri t20/t30: defconfig: Add nf_filterColibri-T30_LXDE-Image_2.8b6.184-20190401Colibri-T20_LXDE-Image_2.8b6.184-20190401Apalis-T30_LXDE-Image_2.8b6.184-20190401Philippe Schenker
For iptables filtering to work we need the NF_FILTER kernel module. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2018-12-27colibri_t20: nand: fix trp timing to be trea + 6ns for edo modeColibri-T30_LXDE-Image_2.8b5.156-20181228Colibri-T20_LXDE-Image_2.8b5.156-20181228Apalis-T30_LXDE-Image_2.8b5.156-20181228Marcel Ziswiler
This fixes TC58NYG2S0HBAI4 and TH58NYG3S0HBAI4 which got added in commit 2a1eb198705c ("colibri_t20: nand: add new v1.2b flashes") Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
2018-11-29apalis/colibri_t20/t30: avoid spurious over-temperature shutdownMarcel Ziswiler
To avoid spurious shutdowns on over-temperature make sure we read the temperature 3 times in a row. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-11-29net: usb: asix: add testmode supportDominik Sliwa
Using module parameter, Etherent compliance testing can be run. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-11-29Input: atmel_mxt_ts - fix reset-gpio for level based irqsSebastian Reichel
The current reset-gpio support triggers an interrupt storm on platforms using the maxtouch with level based interrupt. The Motorola Droid 4, which I used for some of the tests is not affected, since it uses a edge based interrupt. This change avoids the interrupt storm by enabling the device while its interrupt is disabled. Afterwards we wait 100ms. This is important for two reasons: The device is unresponsive for some time (~22ms for mxt224E) and the CHG (interrupt) line is not working properly for 100ms. We don't need to wait for any following interrupts, since the following mxt_initialize() checks for bootloader mode anyways. This fixes a boot issue on GE PPD (watchdog kills device due to interrupt storm) and does not cause regression on Motorola Droid 4. Fixes: f657b00df22e ("Input: atmel_mxt_ts - add support for reset line") Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit ca1cd36cef00260db6b35b32d863e0c580c0488d) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> (cherry picked from commit 40af4dba5fe9c14bd254fde06b1f64f8c0348974)
2018-11-29Input: atmel_mxt_ts - add support for reset lineSebastian Reichel
Provide support for controlling reset pin. If this is not driven correctly the device will be held in reset and will not respond. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> (cherry picked from commit 51a32466a0ca40843039b6d1f1e719bc93db8a21)
2018-11-29Input: atmel_mxt_ts - use more managed resourcesSebastian Reichel
Switch mxt_data and interrupt to resource managed allocation methods, which cleans up the driver slightly and prepares for adding reset GPIO support. Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit 8cc8446b9b62ef954b630ed30e53bd1553e916a6)
2018-11-29Input: atmel_mxt_ts - add T100 as a readable objectMaxime Roussin-Bélanger
When using the 'object' sysfs attribute, T100 is not displayed in the output. Signed-off-by: Maxime Roussin-Bélanger <maxime.roussinbelanger@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit 089b50d95948f691589cca4d81f1f8761747dbaa)
2018-11-29Input: touchscreen - use local variables consistentlyGuenter Roeck
If a function declares a variable to access a structure element, use it consistently. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (cherry picked from commit d7ddf15414dd598b9b875664e6b7aebe6c988f5d)
2018-11-29Revert "input: atmel_mxt_ts: support reset gpio line"Dominik Sliwa
This reverts commit 28531a1ff5ca27c0ab7e2f99bbb0058858b72aa5.
2018-10-04colibri_t30: corrects reset and irq pins for capacitive touch on T30Colibri-T30_LXDE-Image_2.8b4.129-20181005Colibri-T20_LXDE-Image_2.8b4.129-20181005Apalis-T30_LXDE-Image_2.8b4.129-20181005Philippe Schenker
Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-10-04colibri_t20: corrected reset-pin for capacitive touch on T20Philippe Schenker
2018-09-27colibri_t20: nand: add new v1.2b flashesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-09-27mtd: nand: add missing nand manufacturers idsMarcel Ziswiler
2018-09-12ARM: fix put_user() for gcc-8Arnd Bergmann
Building kernels before linux-4.7 with gcc-8 results in many build failures when gcc triggers a check that was meant to catch broken compilers: /tmp/ccCGMQmS.s:648: Error: .err encountered According to the discussion in the gcc bugzilla, a local "register asm()" variable is still supposed to be the correct way to force an inline assembly to use a particular register, but marking it 'const' lets the compiler do optimizations that break that, i.e the compiler is free to treat the variable as either 'const' or 'register' in that case. Upstream commit 9f73bd8bb445 ("ARM: uaccess: remove put_user() code duplication") fixed this problem in linux-4.8 as part of a larger change, but seems a little too big to be backported to 4.4. Let's take the simplest fix and change only the one broken line in the same way as newer kernels. Suggested-by: Bernd Edlinger <bernd.edlinger@hotmail.de> Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=85745 Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=86673 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> (cherry picked from commit 0ca85fc310e8c24cba10ed241a0188795e177683) /tmp/ccmcXtfu.s: Assembler messages: /tmp/ccmcXtfu.s:1441: Error: .err encountered Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Conflicts: arch/arm/include/asm/uaccess.h
2018-09-12give up on gcc ilog2() constant optimizationsLinus Torvalds
gcc-7 has an "optimization" pass that completely screws up, and generates the code expansion for the (impossible) case of calling ilog2() with a zero constant, even when the code gcc compiles does not actually have a zero constant. And we try to generate a compile-time error for anybody doing ilog2() on a constant where that doesn't make sense (be it zero or negative). So now gcc7 will fail the build due to our sanity checking, because it created that constant-zero case that didn't actually exist in the source code. There's a whole long discussion on the kernel mailing about how to work around this gcc bug. The gcc people themselevs have discussed their "feature" in https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785 but it's all water under the bridge, because while it looked at one point like it would be solved by the time gcc7 was released, that was not to be. So now we have to deal with this compiler braindamage. And the only simple approach seems to be to just delete the code that tries to warn about bad uses of ilog2(). So now "ilog2()" will just return 0 not just for the value 1, but for any non-positive value too. It's not like I can recall anybody having ever actually tried to use this function on any invalid value, but maybe the sanity check just meant that such code never made it out in public. Reported-by: Laura Abbott <labbott@redhat.com> Cc: John Stultz <john.stultz@linaro.org>, Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c) Conflicts: tools/include/linux/log2.h File does not exist in the 3.1 kernel, change dropped. This helps with the move to GCC 8. | include/linux/log2.h:22:1: error: ignoring attribute 'noreturn' because it conflicts with attribute 'const' [-Werror=attributes] | int ____ilog2_NaN(void); Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-06-19perf tools: Fix getrusage() related build failure on glibc trunkColibri-T30_LXDE-Image_2.8b3.111-20180627Colibri-T20_LXDE-Image_2.8b3.111-20180626Apalis-T30_LXDE-Image_2.8b3.111-20180626Markus Trippelsdorf
On a system running glibc trunk perf doesn't build: CC builtin-sched.o builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration] [...] Fix it by including sys/resource.h. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120404084527.GA294@x4 Signed-off-by: Ingo Molnar <mingo@kernel.org> (cherry picked from commit 7b78f13603c6fcb64e020a0bbe31a651ea2b657b) Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-06-19apalis_t30: colibri_t30: colibri_t20: do not configure touchscreen reset lineDominik Sliwa
Leave reset line setup to the capacitive touch drivers. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-19apalis_t30: support 2nd ov5640 with sccb_id of 0x3d on csi_2Marcel Ziswiler
This commit adds support for the 2nd CSI Camera Module 5MP OV5640 with SCCB_ID of 0x3d connected to Apalis T30 Mezzanine V2.0A on X4 aka CSI_2_CSI-2/2x. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-06-19apalis/colibri_t20/t30: configure 7in capacitive touch reset lineDominik Sliwa
2018-06-19input: atmel_mxt_ts: support reset gpio lineDominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466) Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-06-19apalis/colibri_t20/t30: pull-up sd card detect pinsMarcel Ziswiler
In order to avoid any floating SD card detect pins as may e.g. happen on Ixora V1.1A pull them all up. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2018-03-28crypto, tegra: fix build without pm runtimeColibri-T30_LXDE-Image_2.8b2.97-20180331Colibri-T20_LXDE-Image_2.8b2.97-20180331Apalis-T30_LXDE-Image_2.8b2.97-20180331Marcel Ziswiler
2017-12-22tegra: colibri_t30: colibri_t20: capacitive touch adapter supportColibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Dominik Sliwa
Adds compile time option to enable support for Toradex Capacitive Touch Adapter. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22tegra: colibri_t30: colibri_t20: fix touch panel pins and resetDominik Sliwa
2017-12-21apalis/colibri_t20/t30_defconfig: enable user debugStefan Agner
Let the kernel print some debug messages when a user program crashes due to an exception. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21vfs: make O_PATH file descriptors usable for 'fchdir()'Linus Torvalds
We already use them for openat() and friends, but fchdir() also wants to be able to use O_PATH file descriptors. This should make it comparable to the O_SEARCH of Solaris. In particular, O_PATH allows you to access (not-quite-open) a directory you don't have read persmission to, only execute permission. Noticed during development of multithread support for ksh93. Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org # O_PATH introduced in 3.0+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 332a2e1244bd08b9e3ecd378028513396a004a24) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21vfs: make O_PATH file descriptors usable for 'fstat()'Linus Torvalds
We already use them for openat() and friends, but fstat() also wants to be able to use O_PATH file descriptors. This should make it more directly comparable to the O_SEARCH of Solaris. Note that you could already do the same thing with "fstatat()" and an empty path, but just doing "fstat()" directly is simpler and faster, so there is no reason not to just allow it directly. See also commit 332a2e1244bd, which did the same thing for fchdir, for the same reasons. Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org # O_PATH introduced in 3.0+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 55815f70147dcfa3ead5738fd56d3574e2e3c1c2) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21VFS: make vfs_fstat() use f[get|put]_light()Linus Torvalds
Use the *_light() versions that properly avoid doing the file user count updates when they are unnecessary. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit e994defb7b6813ba6fa7a2a36e86d2455ad1dc35) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21tegra: apalis_t30: colibri_t30: colibri_t20: user crypto in defconfigDominik Sliwa
Add user crypto to defconfigs. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add a flag to identify crypto instancesSteffen Klassert
The upcomming crypto user configuration api needs to identify crypto instances. This patch adds a flag that is set if the algorithm is an instance that is build from templates. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 64a947b1337b93061da7c7af1f6ce6b2431b70ae) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Export crypto_remove_finalSteffen Klassert
The upcomming crypto usrerspace configuration api needs to remove the spawns on top on an algorithm, so export crypto_remove_final. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 22e5b20be72e2e166c3ba915b01a59a8eb2dc71f) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: user - Fix rwsem leak in crypto_userJonathan Corbet
The list_empty case in crypto_alg_match() will return without calling up_read() on crypto_alg_sem. We could do the "goto out" routine, but the function will clearly do the right thing with that test simply removed. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit fb223c32b4d3ee593c8dce07e983680d06abe387) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: user - Initialise match in crypto_alg_matchHerbert Xu
We need to default match to 0 as otherwise it may lead to a false positive. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit e6ea64ece7f4c14294b2fce5403b1e71eab87f1e) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for compress type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 540b97c1dd9ee68112269be322d901f1edc1a282) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for cipher type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 07a5fa4abd8b6965d4585d3b110f89bdf5612aff) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for rng type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 792608e9c215141fa4b870b7b2a23767a1ef12f4) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for pcompress type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit a55465dca7befd31f4ffa54508d4e2d1e701b8dc) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for nivaead type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit b735d0a91556fd9fd5bbeeebd7d327c2d92c36c8) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for aead type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 6ad414fe710d4fd3a8c8c6c2ad8fefcfcc207968) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for givcipher type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 3e29c1095a091f606a26c04a6542061c9e5f1d6b) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for ablkcipher type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 29ffc87640e2a5bf0ab98bfeed8d6fc78b2d848e) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for blkcipher type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for ahash type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 6238cbaec429c98d1a280014839c934107c7c8f6) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for shash type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit f4d663ce6357e533f107ce3789bd8848c94bea81) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace report for larval type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 6c5a86f529a9e9ca4c9aca5fa477e9557d4a3d3d) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add a report function pointer to crypto_typeSteffen Klassert
We add a report function pointer to struct crypto_type. This function pointer is used from the crypto userspace configuration API to report crypto algorithms to userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit b6aa63c09ba3b150a1030f9c95c7647361e7910e) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Export crypto_remove_spawnsSteffen Klassert
The upcomming crypto usrerspace configuration api needs to remove the spawns on top on an algorithm, so export crypto_remove_spawns. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit 89b596ba22d79dd5616616a9975192e1c2bea0fe) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21crypto: Add userspace configuration APISteffen Klassert
This patch adds a basic userspace configuration API for the crypto layer. With this it is possible to instantiate, remove and to show crypto algorithms from userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit a38f7907b926e4c6c7d389ad96cc38cec2e5a9e9) Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-21tegra: apalis_t30: colibri_t30: increase pwm clockDominik Sliwa
Incresed PWM base clock to 25.5MHz. This results in maximum 99.6Khz PWM out frequency which can be further divided by an integer divider. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
