Colibri-iMX6ULL WB version includes the on-module WiFi/Bluetooth device
AW-CM276NF. Enable driver support for Bluetooth part of this device.
Related-to: ELB-2767
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
toradex_4.9-2.3.x-imx-next
sound/soc/codecs/sgtl5000.c
sound/soc/fsl/imx-sgtl5000.c
4.9 2.3.x imx
This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
Enable WIRELESS_EXT, WEXT_PRIV and MODULE_SIG options that
are needed for the backports-5.4.
Related-to: ELB-2724
Disable wireless drivers and cfg80211 module to avoid conflicts
with backported drivers.
Disabling all wireless drivers and cfg80211 module to avoid conflicts
Enable WIRELESS_EXT, WEXT_PRIV and MODULE_SIG options as needed for
the backports-5.4.
The config option WIRELESS_EXT and WEXT_PRIV use to build external
drivers, such as backports. Make these options storable in config file
to be able to set them independently.
Related-to: ELB-2388
As suggested by the reference manual in a note in chapter 13.2
this commit disables the keeper and enables a 100k pull-down on the
adc pins.
Related-to: ELB-2690
(cherry picked from commit d5a3675860d03d783689de3ed7cb3dec27e6a155)
commit e78e5a91456fcecaa2efbb3706572fe043766f4d upstream.
In the __getcpu function, lsl is using the wrong target and destination
registers. Luckily, the compiler tends to choose %eax for both variables,
so it has been working so far.
Fixes: a582c540ac1b ("x86/vdso: Use RDPID in preference to LSL when available")
Signed-off-by: Samuel Neves <sneves@dei.uc.pt>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180901201452.27828-1-sneves@dei.uc.pt
Signed-off-by: Nobuhiro Iwamatsu (CIP) <nobuhiro1.iwamatsu@toshiba.co.jp>
On Intel it is required to do CPUID(1) before reading the microcode
revision MSR. Current code in 4.4 an 4.9 relies on sync_core() to call
CPUID, unfortunately on 32 bit machines code inside sync_core() always
jumps past CPUID instruction as it depends on data structure boot_cpu_data
witch are not populated correctly so early in boot sequence.
It depends on:
commit 5dedade6dfa2 ("x86/CPU: Add native CPUID variants returning a single
datum")
This patch is for 4.4 but also should apply to 4.9
Signed-off-by: Evalds Iodzevics <evalds.iodzevics@gmail.com>
commit 5dedade6dfa243c130b85d1e4daba6f027805033 upstream.
... similarly to the cpuid_<reg>() variants.
Link: http://lkml.kernel.org/r/20170109114147.5082-2-bp@alien8.de
Cc: Evalds Iodzevics <evalds.iodzevics@gmail.com>
commit 49c64df880570034308e4a9a49c4bc95cf8cdb33 upstream.
The variable 'name' is released multiple times in the error path,
which may cause double free issues.
This problem is avoided by adding a goto label to release the memory
uniformly. And this change also makes the code a bit more cleaner.
Fixes: 4f678a58d335 ("mtd: fix memory leaks in phram_setup")
Signed-off-by: Wen Yang <wenyang@linux.alibaba.com>
Cc: Joern Engel <joern@lazybastard.org>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Vignesh Raghavendra <vigneshr@ti.com>
Cc: linux-mtd@lists.infradead.org
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Link: https://lore.kernel.org/linux-mtd/20200318153156.25612-1-wenyang@linux.alibaba.com
commit 4da0ea71ea934af18db4c63396ba2af1a679ef02 upstream.
This function is only called from lpddr_probe(). We free "lpddr" both
here and in the caller, so it's a double free. The best place to free
"lpddr" is in lpddr_probe() so let's delete this one.
Fixes: 8dc004395d5e ("[MTD] LPDDR qinfo probing.")
Link: https://lore.kernel.org/linux-mtd/20200228092554.o57igp3nqhyvf66t@kili.mountain
commit 80c503e0e68fbe271680ab48f0fe29bc034b01b7 upstream.
The __torture_print_stats() function in locktorture.c carefully
initializes local variable "min" to statp[0].n_lock_acquired, but
then compares it to statp[i].n_lock_fail. Given that the .n_lock_fail
field should normally be zero, and given the initialization, it seems
reasonable to display the maximum and minimum number acquisitions
instead of miscomputing the maximum and minimum number of failures.
This commit therefore switches from failures to acquisitions.
And this turns out to be not only a day-zero bug, but entirely my
own fault. I hate it when that happens!
Fixes: 0af3fe1efa53 ("locktorture: Add a lock-torture kernel module")
Reported-by: Will Deacon <will@kernel.org>
Signed-off-by: Paul E. McKenney <paulmck@kernel.org>
Acked-by: Will Deacon <will@kernel.org>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Josh Triplett <josh@joshtriplett.org>
commit 3670664b5da555a2a481449b3baafff113b0ac35 upstream.
ev_byte_channel_send() assumes that its third argument is a 16 byte
array. Some places where it is called it may not be (or we can't
easily tell if it is). Newer compilers have started producing warnings
about this, so make sure we actually pass a 16 byte array.
There may be more elegant solutions to this, but the driver is quite
old and hasn't been updated in many years.
The warnings (from a powerpc allyesconfig build) are:
In file included from include/linux/byteorder/big_endian.h:5,
from arch/powerpc/include/uapi/asm/byteorder.h:14,
from include/asm-generic/bitops/le.h:6,
from arch/powerpc/include/asm/bitops.h:250,
from include/linux/bitops.h:29,
from include/linux/kernel.h:12,
from include/asm-generic/bug.h:19,
from arch/powerpc/include/asm/bug.h:109,
from include/linux/bug.h:5,
from include/linux/mmdebug.h:5,
from include/linux/gfp.h:5,
from include/linux/slab.h:15,
from drivers/tty/ehv_bytechan.c:24:
drivers/tty/ehv_bytechan.c: In function ‘ehv_bc_udbg_putc’:
arch/powerpc/include/asm/epapr_hcalls.h:298:20: warning: array subscript 1 is outside array bounds of ‘const char[1]’ [-Warray-bounds]
298 | r6 = be32_to_cpu(p[1]);
include/uapi/linux/byteorder/big_endian.h:40:51: note: in definition of macro ‘__be32_to_cpu’
40 | #define __be32_to_cpu(x) ((__force __u32)(__be32)(x))
arch/powerpc/include/asm/epapr_hcalls.h:298:7: note: in expansion of macro ‘be32_to_cpu’
drivers/tty/ehv_bytechan.c:166:13: note: while referencing ‘data’
166 | static void ehv_bc_udbg_putc(char c)
Fixes: dcd83aaff1c8 ("tty/powerpc: introduce the ePAPR embedded hypervisor byte channel driver")
Tested-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
[mpe: Trim warnings from change log]
Link: https://lore.kernel.org/r/20200109183912.5fcb52aa@canb.auug.org.au
commit d3d19d6fc5736a798b118971935ce274f7deaa82 upstream.
The "fix" struct has a 2 byte hole after ->ywrapstep and the
"fix = info->fix;" assignment doesn't necessarily clear it. It depends
on the compiler. The solution is just to replace the assignment with an
memcpy().
Fixes: 1f5e31d7e55a ("fbmem: don't call copy_from/to_user() with mutex held")
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Andrea Righi <righi.andrea@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Peter Rosin <peda@axentia.se>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: Gerd Hoffmann <kraxel@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200113100132.ixpaymordi24n3av@kili.mountain
[ Upstream commit c20f36534666e37858a14e591114d93cc1be0d34 ]
The SPA of the GCR3 table root pointer[51:31] masks 20 bits. However,
this requires 21 bits (Please see the AMD IOMMU specification).
This leads to the potential failure when the bit 51 of SPA of
the GCR3 table root pointer is 1'.
Signed-off-by: Adrian Huang <ahuang12@lenovo.com>
Fixes: 52815b75682e2 ("iommu/amd: Add support for IOMMUv2 domain mode")
Signed-off-by: Joerg Roedel <jroedel@suse.de>
[ Upstream commit f84afbdd3a9e5e10633695677b95422572f920dc ]
The "cmd" comes from the user and it can be up to 255. It it's more
than the number of bits in long, it results out of bounds read when we
check test_bit(cmd, &cmd_mask). The highest valid value for "cmd" is
ND_CMD_CALL (10) so I added a compare against that.
Fixes: 62232e45f4a2 ("libnvdimm: control (ioctl) messages for nvdimm_bus and nvdimm devices")
Link: https://lore.kernel.org/r/20200225162055.amtosfy7m35aivxg@kili.mountain
[ Upstream commit 32302085a8d90859c40cf1a5e8313f575d06ec75 ]
Fix a debug-only build error in ext2/xattr.c:
When building without extra debugging, (and with another patch that uses
no_printk() instead of <empty> for the ext2-xattr debug-print macros,
this build error happens:
../fs/ext2/xattr.c: In function ‘ext2_xattr_cache_insert’:
../fs/ext2/xattr.c:869:18: error: ‘ext2_xattr_cache’ undeclared (first use in
this function); did you mean ‘ext2_xattr_list’?
atomic_read(&ext2_xattr_cache->c_entry_count));
Fix the problem by removing cached entry count from the debug message
since otherwise we'd have to export the mbcache structure just for that.
Fixes: be0726d33cb8 ("ext2: convert to mbcache2")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
[ Upstream commit 44a52022e7f15cbaab957df1c14f7a4f527ef7cf ]
When EXT2_ATTR_DEBUG is not defined, modify the 2 debug macros
to use the no_printk() macro instead of <nothing>.
This fixes gcc warnings when -Wextra is used:
../fs/ext2/xattr.c:252:42: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../fs/ext2/xattr.c:258:42: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../fs/ext2/xattr.c:330:42: warning: suggest braces around empty body in an ‘if’ statement [-Wempty-body]
../fs/ext2/xattr.c:872:45: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
I have verified that the only object code change (with gcc 7.5.0) is
the reversal of some instructions from 'cmp a,b' to 'cmp b,a'.
Link: https://lore.kernel.org/r/e18a7395-61fb-2093-18e8-ed4f8cf56248@infradead.org
Cc: Jan Kara <jack@suse.com>
Cc: linux-ext4@vger.kernel.org
[ Upstream commit 862f35c94730c9270833f3ad05bd758a29f204ed ]
If we just set the mirror count to 1 without first clearing out
the mirrors, we can leak queued up requests.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit 1493e0f944f3c319d11e067c185c904d01c17ae5 ]
We have to properly retry again by returning -EINVAL immediately in case
somebody else instantiated the table concurrently. We missed to add the
goto in this function only. The code now matches the other, similar
shadowing functions.
We are overwriting an existing region 2 table entry. All allocated pages
are added to the crst_list to be freed later, so they are not lost
forever. However, when unshadowing the region 2 table, we wouldn't trigger
unshadowing of the original shadowed region 3 table that we replaced. It
would get unshadowed when the original region 3 table is modified. As it's
not connected to the page table hierarchy anymore, it's not going to get
used anymore. However, for a limited time, this page table will stick
around, so it's in some sense a temporary memory leak.
Identified by manual code inspection. I don't think this classifies as
stable material.
Fixes: 998f637cc4b9 ("s390/mm: avoid races on region/segment/page table shadowing")
Signed-off-by: David Hildenbrand <david@redhat.com>
Link: https://lore.kernel.org/r/20200403153050.20569-4-david@redhat.com
Reviewed-by: Claudio Imbrenda <imbrenda@linux.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit af9c5d2e3b355854ff0e4acfbfbfadcd5198a349 ]
compiletime_assert() uses __LINE__ to create a unique function name. This
means that if you have more than one BUILD_BUG_ON() in the same source
line (which can happen if they appear e.g. in a macro), then the error
message from the compiler might output the wrong condition.
For this source file:
#include <linux/build_bug.h>
#define macro() \
BUILD_BUG_ON(1); \
BUILD_BUG_ON(0);
void foo()
macro();
gcc would output:
./include/linux/compiler.h:350:38: error: call to `__compiletime_assert_9' declared with attribute error: BUILD_BUG_ON failed: 0
_compiletime_assert(condition, msg, __compiletime_assert_, __LINE__)
However, it was not the BUILD_BUG_ON(0) that failed, so it should say 1
instead of 0. With this patch, we use __COUNTER__ instead of __LINE__, so
each BUILD_BUG_ON() gets a different function name and the correct
condition is printed:
./include/linux/compiler.h:350:38: error: call to `__compiletime_assert_0' declared with attribute error: BUILD_BUG_ON failed: 1
_compiletime_assert(condition, msg, __compiletime_assert_, __COUNTER__)
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Reviewed-by: Daniel Santos <daniel.santos@pobox.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Ian Abbott <abbotti@mev.co.uk>
Cc: Joe Perches <joe@perches.com>
Link: http://lkml.kernel.org/r/20200331112637.25047-1-vegard.nossum@oracle.com
[ Upstream commit 7e2345200262e4a6056580f0231cccdaffc825f3 ]
"vm_committed_as.count" could be accessed concurrently as reported by
KCSAN,
BUG: KCSAN: data-race in __vm_enough_memory / percpu_counter_add_batch
write to 0xffffffff9451c538 of 8 bytes by task 65879 on cpu 35:
percpu_counter_add_batch+0x83/0xd0
percpu_counter_add_batch at lib/percpu_counter.c:91
__vm_enough_memory+0xb9/0x260
dup_mm+0x3a4/0x8f0
copy_process+0x2458/0x3240
_do_fork+0xaa/0x9f0
__do_sys_clone+0x125/0x160
__x64_sys_clone+0x70/0x90
do_syscall_64+0x91/0xb05
entry_SYSCALL_64_after_hwframe+0x49/0xbe
read to 0xffffffff9451c538 of 8 bytes by task 66773 on cpu 19:
__vm_enough_memory+0x199/0x260
percpu_counter_read_positive at include/linux/percpu_counter.h:81
(inlined by) __vm_enough_memory at mm/util.c:839
mmap_region+0x1b2/0xa10
do_mmap+0x45c/0x700
vm_mmap_pgoff+0xc0/0x130
ksys_mmap_pgoff+0x6e/0x300
__x64_sys_mmap+0x33/0x40
The read is outside percpu_counter::lock critical section which results in
a data race. Fix it by adding a READ_ONCE() in
percpu_counter_read_positive() which could also service as the existing
compiler memory barrier.
Signed-off-by: Qian Cai <cai@lca.pw>
Acked-by: Marco Elver <elver@google.com>
Link: http://lkml.kernel.org/r/1582302724-2804-1-git-send-email-cai@lca.pw
[ Upstream commit c96e2b8564adfb8ac14469ebc51ddc1bfecb3ae2 ]
Under some circumstances we may encounter a filesystem error on a
read-only block device, and if we try to save the error info to the
superblock and commit it, we'll wind up with a noisy error and
backtrace, i.e.:
[ 3337.146838] EXT4-fs error (device pmem1p2): ext4_get_journal_inode:4634: comm mount: inode #0: comm mount: iget: illegal inode #
generic_make_request: Trying to write to read-only block-device pmem1p2 (partno 2)
WARNING: CPU: 107 PID: 115347 at block/blk-core.c:788 generic_make_request_checks+0x6b4/0x7d0
To avoid this, commit the error info in the superblock only if the
block device is writable.
Reported-by: Ritesh Harjani <riteshh@linux.ibm.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Link: https://lore.kernel.org/r/4b6e774d-cc00-3469-7abb-108eb151071a@sandeen.net
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit af6cf95c4d003fccd6c2ecc99a598fb854b537e7 ]
When building ppc64 defconfig, Clang errors (trimmed for brevity):
arch/powerpc/platforms/maple/setup.c:365:1: error: attribute declaration
must precede definition [-Werror,-Wignored-attributes]
machine_device_initcall(maple, maple_cpc925_edac_setup);
machine_device_initcall expands to __define_machine_initcall, which in
turn has the macro machine_is used in it, which declares mach_##name
with an __attribute__((weak)). define_machine actually defines
mach_##name, which in this file happens before the declaration, hence
the warning.
To fix this, move define_machine after machine_device_initcall so that
the declaration occurs before the definition, which matches how
machine_device_initcall and define_machine work throughout
arch/powerpc.
While we're here, remove some spaces before tabs.
Fixes: 8f101a051ef0 ("edac: cpc925 MC platform device setup")
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
Suggested-by: Ilie Halip <ilie.halip@gmail.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Link: https://lore.kernel.org/r/20200323222729.15365-1-natechancellor@gmail.com
[ Upstream commit 872f27103874a73783aeff2aac2b41a489f67d7c ]
/proc/cpuinfo should not print information about CPU 0 when it is offline.
Fixes: 281eaa8cb67c ("s390/cpuinfo: simplify locking and skip offline cpus early")
Signed-off-by: Alexander Gordeev <agordeev@linux.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
[heiko.carstens@de.ibm.com: shortened commit message]
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
[ Upstream commit 8605cf0e852af3b2c771c18417499dc4ceed03d5 ]
When dreq is allocated by nfs_direct_req_alloc(), dreq->kref is
initialized to 2. Therefore we need to call nfs_direct_req_release()
twice to release the allocated dreq. Usually it is called in
nfs_file_direct_{read, write}() and nfs_direct_complete().
However, current code only calls nfs_direct_req_relese() once if
nfs_get_lock_context() fails in nfs_file_direct_{read, write}().
So, that case would result in memory leak.
Fix this by adding the missing call.
Signed-off-by: Misono Tomohiro <misono.tomohiro@jp.fujitsu.com>
[ Upstream commit 6fe38aa8cac3a5db38154331742835a4d9740788 ]
Tegra PMC clocks clk_out_1, clk_out_2, and clk_out_3 supported parents
are osc, osc_div2, osc_div4 and extern clock.
Clock driver is using incorrect parents clk_m, clk_m_div2, clk_m_div4
for PMC clocks.
This patch fixes this.
Tested-by: Dmitry Osipenko <digetx@gmail.com>
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Sowjanya Komatineni <skomatineni@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit 583b53ece0b0268c542a1eafadb62e3d4b0aab8c ]
The driver fails to probe with -EPROBE_DEFER if battery's power supply
(charger driver) isn't ready yet and this results in a bit noisy error
message in KMSG during kernel's boot up. Let's silence the harmless
error message.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Pali Rohár <pali@kernel.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
[ Upstream commit b0ecf1c6c6e82da4847900fad0272abfd014666d ]
clk_hw_round_rate() may call round rate function of its parents. In case
of SAM9X60 two of USB parrents are PLLA and UPLL. These clocks are
controlled by clk-sam9x60-pll.c driver. The round rate function for this
driver is sam9x60_pll_round_rate() which call in turn
sam9x60_pll_get_best_div_mul(). In case the requested rate is not in the
proper range (rate < characteristics->output[0].min &&
rate > characteristics->output[0].max) the sam9x60_pll_round_rate() will
return a negative number to its caller (called by
clk_core_round_rate_nolock()). clk_hw_round_rate() will return zero in
case a negative number is returned by clk_core_round_rate_nolock(). With
this, the USB clock will continue its rate computation even caller of
clk_hw_round_rate() returned an error. With this, the USB clock on SAM9X60
may not chose the best parent. I detected this after a suspend/resume
cycle on SAM9X60.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Link: https://lkml.kernel.org/r/1579261009-4573-2-git-send-email-claudiu.beznea@microchip.com
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
[ Upstream commit 216830d2413cc61be3f76bc02ffd905e47d2439e ]
kmemleak reports several memory leaks from devicetree unittest.
This is the fix for problem 2 of 5.
of_unittest_platform_populate() left an elevated reference count for
grandchild nodes (which are platform devices). Fix the platform
device reference counts so that the memory will be freed.
Fixes: fb2caa50fbac ("of/selftest: add testcase for nodes with same name and address")
Reported-by: Erhard F. <erhard_f@mailbox.org>
Signed-off-by: Frank Rowand <frank.rowand@sony.com>
Signed-off-by: Rob Herring <robh@kernel.org>
commit 94a5d8790e79ab78f499d2d9f1ff2cab63849d9f upstream.
Without including psci.h and arm-smccc.h, we now get a build failure in
some configurations:
arch/arm64/kernel/cpu_errata.c: In function 'arm64_update_smccc_conduit':
arch/arm64/kernel/cpu_errata.c:278:10: error: 'psci_ops' undeclared (first use in this function); did you mean 'sysfs_ops'?
arch/arm64/kernel/cpu_errata.c: In function 'arm64_set_ssbd_mitigation':
arch/arm64/kernel/cpu_errata.c:311:3: error: implicit declaration of function 'arm_smccc_1_1_hvc' [-Werror=implicit-function-declaration]
arm_smccc_1_1_hvc(ARM_SMCCC_ARCH_WORKAROUND_2, state, NULL);
[ Upstream commit bd82bbf38cbe27f2c65660da801900d71bcc5cc8 ]
The ref counting is broken for OF_DYNAMIC when sysfs is disabled because
the kobject initialization is skipped. Only the properties
add/remove/update should be skipped for !SYSFS config.
Tested-by: Nicolas Pitre <nico@linaro.org>
Reviewed-by: Frank Rowand <frowand.list@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
[ Upstream commit a216000f0140f415cec96129f777b5234c9d142f ]
Endianness can vary in the system, add le32_to_cpu when comparing
partition sizes from smem.
Signed-off-by: Chris Lew <clew@codeaurora.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
[ Upstream commit 26a6d5274865532502c682ff378ac8ebe2886238 ]
The current length check:
sizeof(cmd) + len > r->entry_size
will allow very large values of len (> U16_MAX - sizeof(cmd))
and can cause a buffer overflow. Fix the check to cover this case.
In addition, ensure the mailbox entry_size is not too small,
since this can also bypass the above check.
Signed-off-by: Lior David <qca_liord@qca.qualcomm.com>
Signed-off-by: Maya Erez <qca_merez@qca.qualcomm.com>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
[ Upstream commit 83220bf38b77a830f8e62ab1a0d0408304f9b966 ]
In order to set time in rtc, need to disable
rtc hw before writing into rtc registers.
Also fixes disabling of alarm while setting
rtc time.
Signed-off-by: Mohit Aggarwal <maggarwa@codeaurora.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
[ Upstream commit 3d6b72729cc2933906de8d2c602ae05e920b2122 ]
wil_err inside wil_rx_refill can flood the log buffer.
Replace it with wil_err_ratelimited.
Signed-off-by: Dedy Lansky <dlansky@codeaurora.org>
Signed-off-by: Maya Erez <merez@codeaurora.org>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
[ Upstream commit 69a6fff068567469c0ef1156ae5ac8d3d71701f0 ]
UFSHCD_QUIRK_BROKEN_UFS_HCI_VERSION is only applicable for QCOM UFS host
controller version 2.x.y and this has been fixed from version 3.x.y
onwards, hence this change removes this quirk for version 3.x.y onwards.
[mkp: applied by hand]
Signed-off-by: Subhash Jadavani <subhashj@codeaurora.org>
Signed-off-by: Asutosh Das <asutoshd@codeaurora.org>
[ Upstream commit 7f6ba4f12e6cbfdefbb95cfd8fc67ece6c15d799 ]
As multiple requests are submitted to the ufs host controller in
parallel there could be instances where the command completion interrupt
arrives later for a request that is already processed earlier as the
corresponding doorbell was cleared when handling the previous
interrupt. Read the interrupt status in a loop after processing the
received interrupt to catch such interrupts and handle it.
Signed-off-by: Venkat Gopalakrishnan <venkatg@codeaurora.org>
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
[ Upstream commit 6d9eb7ebae3d7e951bc0999235ae7028eb4cae4f ]
For negative temperatures, "temp" debugfs is showing wrong values.
Use signed types so proper calculations is done for sub zero
temperatures.
[ Upstream commit 6ccae584014ef7074359eb4151086beef66ecfa9 ]
Firmware ready event may take longer than
current timeout in some scenarios, for example
with multiple RFs connected where each
requires an initial calibration.
Increase the timeout to support these scenarios.
Signed-off-by: Hamad Kadmany <hkadmany@codeaurora.org>
[ Upstream commit 1ca2a92b2a99323f666f1b669b7484df4bda05e4 ]
This reverts commit 72d3200061776264941be1b5a9bb8e926b3b30a5.
We cannot blindly query the direction of all GPIOs when the pins are
first registered. The get_direction callback normally triggers a
read/write to hardware, but we shouldn't be touching the hardware for
an individual GPIO until after it's been properly claimed.
Signed-off-by: Timur Tabi <timur@codeaurora.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
commit 22a07038c0eaf4d1315a493ce66dcd255accba19 upstream.
The Parfait (version 2.1.0) static code analysis tool found the
following NULL pointer derefernce problem.
- drivers/gpu/drm/drm_dp_mst_topology.c
The call to drm_dp_calculate_rad() in function drm_dp_port_setup_pdt()
could result in a NULL pointer being returned to port->mstb due to a
failure to allocate memory for port->mstb.
Signed-off-by: Joe Moriarty <joe.moriarty@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20180212195144.98323-3-joe.moriarty@oracle.com
commit 864eb1afc60cb43e7df879b97f8ca0d719bbb735 upstream.
Clang warns when multiple pairs of parentheses are used for a single
conditional statement.
drivers/video/fbdev/sis/init301.c:851:42: warning: equality comparison
with extraneous parentheses [-Wparentheses-equality]
} else if((SiS_Pr->SiS_IF_DEF_LVDS == 1) /* ||
drivers/video/fbdev/sis/init301.c:851:42: note: remove extraneous
parentheses around the comparison to silence this warning
drivers/video/fbdev/sis/init301.c:851:42: note: use '=' to turn this
equality comparison into an assignment
1 warning generated.
Remove the parentheses and while we're at it, clean up the commented
code, which has been here since the beginning of git history.
Link: https://github.com/ClangBuiltLinux/linux/issues/118
Cc: Thomas Winischhofer <thomas@winischhofer.net>
commit 25faa4bd37c10f19e4b848b9032a17a3d44c6f09 upstream.
At the error path of the firmware loading error, the driver tries to
release the card object and set NULL to drvdata. This may be referred
badly at the possible PM action, as the driver itself is still bound
and the PM callbacks read the card object.
Instead, we continue the probing as if it were no option set. This is
often a better choice than the forced abort, too.
Fixes: 5cb543dba986 ("ALSA: hda - Deferred probing with request_firmware_nowait()")
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=207043
Link: https://lore.kernel.org/r/20200413082034.25166-2-tiwai@suse.de
commit 849f8583e955dbe3a1806e03ecacd5e71cce0a08 upstream.
If the dxfer_len is greater than 256M then the request is invalid and we
need to call sg_remove_request in sg_common_write.
Link: https://lore.kernel.org/r/1586777361-17339-1-git-send-email-huawei.libin@huawei.com
Fixes: f930c7043663 ("scsi: sg: only check for dxfer_len greater than 256M")
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Signed-off-by: Li Bin <huawei.libin@huawei.com>
