commit 30bf90ccdec1da9c8198b161ecbff39ce4e5a9ba upstream.
Found using DEBUG_ATOMIC_SLEEP while submitting an AIO read operation:
[ 100.853642] BUG: sleeping function called from invalid context at mm/slab.h:421
[ 100.861148] in_atomic(): 1, irqs_disabled(): 1, pid: 1880, name: python
[ 100.867954] 2 locks held by python/1880:
[ 100.867961] #0: (&epfile->mutex){....}, at: [<f8188627>] ffs_mutex_lock+0x27/0x30 [usb_f_fs]
[ 100.868020] #1: (&(&ffs->eps_lock)->rlock){....}, at: [<f818ad4b>] ffs_epfile_io.isra.17+0x24b/0x590 [usb_f_fs]
[ 100.868076] CPU: 1 PID: 1880 Comm: python Not tainted 4.14.0-edison+ #118
[ 100.868085] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 542 2015.01.21:18.19.48
[ 100.868093] Call Trace:
[ 100.868122] dump_stack+0x47/0x62
[ 100.868156] ___might_sleep+0xfd/0x110
[ 100.868182] __might_sleep+0x68/0x70
[ 100.868217] kmem_cache_alloc_trace+0x4b/0x200
[ 100.868248] ? dwc3_gadget_ep_alloc_request+0x24/0xe0 [dwc3]
[ 100.868302] dwc3_gadget_ep_alloc_request+0x24/0xe0 [dwc3]
[ 100.868343] usb_ep_alloc_request+0x16/0xc0 [udc_core]
[ 100.868386] ffs_epfile_io.isra.17+0x444/0x590 [usb_f_fs]
[ 100.868424] ? _raw_spin_unlock_irqrestore+0x27/0x40
[ 100.868457] ? kiocb_set_cancel_fn+0x57/0x60
[ 100.868477] ? ffs_ep0_poll+0xc0/0xc0 [usb_f_fs]
[ 100.868512] ffs_epfile_read_iter+0xfe/0x157 [usb_f_fs]
[ 100.868551] ? security_file_permission+0x9c/0xd0
[ 100.868587] ? rw_verify_area+0xac/0x120
[ 100.868633] aio_read+0x9d/0x100
[ 100.868692] ? __fget+0xa2/0xd0
[ 100.868727] ? __might_sleep+0x68/0x70
[ 100.868763] SyS_io_submit+0x471/0x680
[ 100.868878] do_int80_syscall_32+0x4e/0xd0
[ 100.868921] entry_INT80_32+0x2a/0x2a
[ 100.868932] EIP: 0xb7fbb676
[ 100.868941] EFLAGS: 00000292 CPU: 1
[ 100.868951] EAX: ffffffda EBX: b7aa2000 ECX: 00000002 EDX: b7af8368
[ 100.868961] ESI: b7fbb660 EDI: b7aab000 EBP: bfb6c658 ESP: bfb6c638
[ 100.868973] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 007b
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Signed-off-by: Siqi Lin <siqilin@google.com>
commit 5553b142be11e794ebc0805950b2e8313f93d718 upstream.
VTTBR_BADDR_MASK is used to sanity check the size and alignment of the
VTTBR address. It seems to currently be off by one, thereby only
allowing up to 39-bit addresses (instead of 40-bit) and also
insufficiently checking the alignment. This patch fixes it.
This patch is the 32bit pendent of Kristina's arm64 fix, and
she deserves the actual kudos for pinpointing that one.
Fixes: f7ed45be3ba52 ("KVM: ARM: World-switch implementation")
Cc: <stable@vger.kernel.org> # 3.9
Reported-by: Kristina Martsenko <kristina.martsenko@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
This reverts commit 87e2bd898d3a79a8c609f183180adac47879a2a4 which is
commit edc3b9129cecd0f0857112136f5b8b1bc1d45918 upstream.
Turns there was too many other issues with this patch to make it viable
for the stable tree.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Borislav Petkov <bp@suse.de>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Sai Praneeth Prakhya <sai.praneeth.prakhya@intel.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-efi@vger.kernel.org
Cc: "Ghannam, Yazen" <Yazen.Ghannam@amd.com>
This reverts commit b73adb60852034d84092d123b323196ca42529cd which is
commit c9f2a9a65e4855b74d92cdad688f6ee4a1a323ff upstream.
This reverts commit 36e0f05afd4e1d09fd47936761a502aedbc50649 which is
commit 67a9108ed4313b85a9c53406d80dc1ae3f8c3e36 upstream.
[ Upstream commit 15fe076edea787807a7cdc168df832544b58eba6 ]
syzbot reported crashes [1] and provided a C repro easing bug hunting.
When/if packet_do_bind() calls __unregister_prot_hook() and releases
po->bind_lock, another thread can run packet_notifier() and process an
NETDEV_UP event.
This calls register_prot_hook() and hooks again the socket right before
first thread is able to grab again po->bind_lock.
Fixes this issue by temporarily setting po->num to 0, as suggested by
David Miller.
[1]
dev_remove_pack: ffff8801bf16fa80 not found
kernel BUG at net/core/dev.c:7945! ( BUG_ON(!list_empty(&dev->ptype_all)); )
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
device syz0 entered promiscuous mode
CPU: 0 PID: 3161 Comm: syzkaller404108 Not tainted 4.14.0+ #190
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
task: ffff8801cc57a500 task.stack: ffff8801cc588000
RIP: 0010:netdev_run_todo+0x772/0xae0 net/core/dev.c:7945
RSP: 0018:ffff8801cc58f598 EFLAGS: 00010293
RAX: ffff8801cc57a500 RBX: dffffc0000000000 RCX: ffffffff841f75b2
RDX: 0000000000000000 RSI: 1ffff100398b1ede RDI: ffff8801bf1f8810
RBP: ffff8801cc58f898 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801bf1f8cd8
R13: ffff8801cc58f870 R14: ffff8801bf1f8780 R15: ffff8801cc58f7f0
FS: 0000000001716880(0000) GS:ffff8801db400000(0000) knlGS:0000000000000000
CR2: 0000000020b13000 CR3: 0000000005e25000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
rtnl_unlock+0xe/0x10 net/core/rtnetlink.c:106
tun_detach drivers/net/tun.c:670 [inline]
tun_chr_close+0x49/0x60 drivers/net/tun.c:2845
__fput+0x333/0x7f0 fs/file_table.c:210
____fput+0x15/0x20 fs/file_table.c:244
task_work_run+0x199/0x270 kernel/task_work.c:113
exit_task_work include/linux/task_work.h:22 [inline]
do_exit+0x9bb/0x1ae0 kernel/exit.c:865
do_group_exit+0x149/0x400 kernel/exit.c:968
SYSC_exit_group kernel/exit.c:979 [inline]
SyS_exit_group+0x1d/0x20 kernel/exit.c:977
entry_SYSCALL_64_fastpath+0x1f/0x96
RIP: 0033:0x44ad19
Fixes: 30f7ea1c2b5f ("packet: race condition in packet_bind")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Francesco Ruggeri <fruggeri@aristanetworks.com>
syzkaller found a race condition fanout_demux_rollover() while removing
a packet socket from a fanout group.
po->rollover is read and operated on during packet_rcv_fanout(), via
fanout_demux_rollover(), but the pointer is currently cleared before the
synchronization in packet_release(). It is safer to delay the cleanup
until after synchronize_net() has been called, ensuring all calls to
packet_rcv_fanout() for this socket have finished.
To further simplify synchronization around the rollover structure, set
po->rollover in fanout_add() only if there are no errors. This removes
the need for rcu in the struct and in the call to
packet_getsockopt(..., PACKET_ROLLOVER_STATS, ...).
Crashing stack trace:
fanout_demux_rollover+0xb6/0x4d0 net/packet/af_packet.c:1392
packet_rcv_fanout+0x649/0x7c8 net/packet/af_packet.c:1487
dev_queue_xmit_nit+0x835/0xc10 net/core/dev.c:1953
xmit_one net/core/dev.c:2975 [inline]
dev_hard_start_xmit+0x16b/0xac0 net/core/dev.c:2995
__dev_queue_xmit+0x17a4/0x2050 net/core/dev.c:3476
dev_queue_xmit+0x17/0x20 net/core/dev.c:3509
neigh_connected_output+0x489/0x720 net/core/neighbour.c:1379
neigh_output include/net/neighbour.h:482 [inline]
ip6_finish_output2+0xad1/0x22a0 net/ipv6/ip6_output.c:120
ip6_finish_output+0x2f9/0x920 net/ipv6/ip6_output.c:146
NF_HOOK_COND include/linux/netfilter.h:239 [inline]
ip6_output+0x1f4/0x850 net/ipv6/ip6_output.c:163
dst_output include/net/dst.h:459 [inline]
NF_HOOK.constprop.35+0xff/0x630 include/linux/netfilter.h:250
mld_sendpack+0x6a8/0xcc0 net/ipv6/mcast.c:1660
mld_send_initial_cr.part.24+0x103/0x150 net/ipv6/mcast.c:2072
mld_send_initial_cr net/ipv6/mcast.c:2056 [inline]
ipv6_mc_dad_complete+0x99/0x130 net/ipv6/mcast.c:2079
addrconf_dad_completed+0x595/0x970 net/ipv6/addrconf.c:4039
addrconf_dad_work+0xac9/0x1160 net/ipv6/addrconf.c:3971
process_one_work+0xbf0/0x1bc0 kernel/workqueue.c:2113
worker_thread+0x223/0x1990 kernel/workqueue.c:2247
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:432
Fixes: 0648ab70afe6 ("packet: rollover prepare: per-socket state")
Fixes: 509c7a1ecc860 ("packet: avoid panic in packet_getsockopt()")
Signed-off-by: Mike Maloney <maloney@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit f859b4af1c52493ec21173ccc73d0b60029b5b88 ]
After parsing the sit netlink change info, we forget to update frag_off in
ipip6_tunnel_update(). Fix it by assigning frag_off with new value.
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit f3069c6d33f6ae63a1668737bc78aaaa51bff7ca ]
This is a fix for syzkaller719569, where memory registration was
attempted without any underlying transport being loaded.
Analysis of the case reveals that it is the setsockopt() RDS_GET_MR
(2) and RDS_GET_MR_FOR_DEST (7) that are vulnerable.
Here is an example stack trace when the bug is hit:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000c0
IP: __rds_rdma_map+0x36/0x440 [rds]
PGD 2f93d03067 P4D 2f93d03067 PUD 2f93d02067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: bridge stp llc tun rpcsec_gss_krb5 nfsv4
dns_resolver nfs fscache rds binfmt_misc sb_edac intel_powerclamp
coretemp kvm_intel kvm irqbypass crct10dif_pclmul c rc32_pclmul
ghash_clmulni_intel pcbc aesni_intel crypto_simd glue_helper cryptd
iTCO_wdt mei_me sg iTCO_vendor_support ipmi_si mei ipmi_devintf nfsd
shpchp pcspkr i2c_i801 ioatd ma ipmi_msghandler wmi lpc_ich mfd_core
auth_rpcgss nfs_acl lockd grace sunrpc ip_tables ext4 mbcache jbd2
mgag200 i2c_algo_bit drm_kms_helper ixgbe syscopyarea ahci sysfillrect
sysimgblt libahci mdio fb_sys_fops ttm ptp libata sd_mod mlx4_core drm
crc32c_intel pps_core megaraid_sas i2c_core dca dm_mirror
dm_region_hash dm_log dm_mod
CPU: 48 PID: 45787 Comm: repro_set2 Not tainted 4.14.2-3.el7uek.x86_64 #2
Hardware name: Oracle Corporation ORACLE SERVER X5-2L/ASM,MOBO TRAY,2U, BIOS 31110000 03/03/2017
task: ffff882f9190db00 task.stack: ffffc9002b994000
RIP: 0010:__rds_rdma_map+0x36/0x440 [rds]
RSP: 0018:ffffc9002b997df0 EFLAGS: 00010202
RAX: 0000000000000000 RBX: ffff882fa2182580 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffc9002b997e40 RDI: ffff882fa2182580
RBP: ffffc9002b997e30 R08: 0000000000000000 R09: 0000000000000002
R10: ffff885fb29e3838 R11: 0000000000000000 R12: ffff882fa2182580
R13: ffff882fa2182580 R14: 0000000000000002 R15: 0000000020000ffc
FS: 00007fbffa20b700(0000) GS:ffff882fbfb80000(0000) knlGS:0000000000000000
CR2: 00000000000000c0 CR3: 0000002f98a66006 CR4: 00000000001606e0
Call Trace:
rds_get_mr+0x56/0x80 [rds]
rds_setsockopt+0x172/0x340 [rds]
? __fget_light+0x25/0x60
? __fdget+0x13/0x20
SyS_setsockopt+0x80/0xe0
do_syscall_64+0x67/0x1b0
entry_SYSCALL64_slow_path+0x25/0x25
RIP: 0033:0x7fbff9b117f9
RSP: 002b:00007fbffa20aed8 EFLAGS: 00000293 ORIG_RAX: 0000000000000036
RAX: ffffffffffffffda RBX: 00000000000c84a4 RCX: 00007fbff9b117f9
RDX: 0000000000000002 RSI: 0000400000000114 RDI: 000000000000109b
RBP: 00007fbffa20af10 R08: 0000000000000020 R09: 00007fbff9dd7860
R10: 0000000020000ffc R11: 0000000000000293 R12: 0000000000000000
R13: 00007fbffa20b9c0 R14: 00007fbffa20b700 R15: 0000000000000021
Code: 41 56 41 55 49 89 fd 41 54 53 48 83 ec 18 8b 87 f0 02 00 00 48
89 55 d0 48 89 4d c8 85 c0 0f 84 2d 03 00 00 48 8b 87 00 03 00 00 <48>
83 b8 c0 00 00 00 00 0f 84 25 03 00 0 0 48 8b 06 48 8b 56 08
The fix is to check the existence of an underlying transport in
__rds_rdma_map().
Signed-off-by: Håkon Bugge <haakon.bugge@oracle.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit a7d5f107b4978e08eeab599ee7449af34d034053 ]
When the function tipc_accept_from_sock() fails to create an instance of
struct tipc_subscriber it omits to free the already created instance of
struct tipc_conn instance before it returns.
We fix that with this commit.
Reported-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
commit 2b04e8f6bbb196cab4b232af0f8d48ff2c7a8058 upstream.
we need to take care of failure exit as well - pages already
in bio should be dropped by analogue of bio_unmap_pages(),
since their refcounts had been bumped only once per reference
in bio.
Cc: stable@vger.kernel.org
commit fbbd7f1a51965b50dd12924841da0d478f3da71b upstream.
The switch_to() macro has an optimization to avoid saving and
restoring register contents that aren't needed for kernel threads.
There is however the possibility that a kernel thread execve's a user
space program. In such a case the execve'd process can partially see
the contents of the previous process, which shouldn't be allowed.
To avoid this, simply always save and restore register contents on
context switch.
Cc: <stable@vger.kernel.org> # v2.6.37+
Fixes: fdb6d070effba ("switch_to: dont restore/save access & fpu regs for kernel threads")
commit 4f7f5551a760eb0124267be65763008169db7087 upstream.
System may crash after unloading ipmi_si.ko module
because a timer may remain and fire after the module cleaned up resources.
cleanup_one_si() contains the following processing.
* Make sure that interrupts, the timer and the thread are
* stopped and will not run again.
if (to_clean->irq_cleanup)
to_clean->irq_cleanup(to_clean);
wait_for_timer_and_thread(to_clean);
* Timeouts are stopped, now make sure the interrupts are off
* in the BMC. Note that timers and CPU interrupts are off,
* so no need for locks.
while (to_clean->curr_msg || (to_clean->si_state != SI_NORMAL)) {
poll(to_clean);
schedule_timeout_uninterruptible(1);
si_state changes as following in the while loop calling poll(to_clean).
SI_GETTING_MESSAGES
=> SI_CHECKING_ENABLES
=> SI_SETTING_ENABLES
=> SI_GETTING_EVENTS
=> SI_NORMAL
As written in the code comments above,
timers are expected to stop before the polling loop and not to run again.
But the timer is set again in the following process
when si_state becomes SI_SETTING_ENABLES.
=> poll
=> smi_event_handler
=> handle_transaction_done
// smi_info->si_state == SI_SETTING_ENABLES
=> start_getting_events
=> start_new_msg
=> smi_mod_timer
=> mod_timer
As a result, before the timer set in start_new_msg() expires,
the polling loop may see si_state becoming SI_NORMAL
and the module clean-up finishes.
For example, hard LOCKUP and panic occurred as following.
smi_timeout was called after smi_event_handler,
kcs_event and hangs at port_inb()
trying to access I/O port after release.
[exception RIP: port_inb+19]
RIP: ffffffffc0473053 RSP: ffff88069fdc3d80 RFLAGS: 00000006
RAX: ffff8806800f8e00 RBX: ffff880682bd9400 RCX: 0000000000000000
RDX: 0000000000000ca3 RSI: 0000000000000ca3 RDI: ffff8806800f8e40
RBP: ffff88069fdc3d80 R8: ffffffff81d86dfc R9: ffffffff81e36426
R10: 00000000000509f0 R11: 0000000000100000 R12: 0000000000]:000000
R13: 0000000000000000 R14: 0000000000000246 R15: ffff8806800f8e00
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
--- <NMI exception stack> ---
To fix the problem I defined a flag, timer_can_start,
as member of struct smi_info.
The flag is enabled immediately after initializing the timer
and disabled immediately before waiting for timer deletion.
Fixes: 0cfec916e86d ("ipmi: Start the timer and thread on internal msgs")
Signed-off-by: Yamazaki Masamitsu <m-yamazaki@ah.jp.nec.com>
[Adjusted for recent changes in the driver.]
[Some fairly major changes went into the IPMI driver in 4.15, so this
required a backport as the code had changed and moved to a different
file. The 4.14 version of this patch moved some code under an
if statement and there was an API change causing it to not apply to
4.4-4.6.]
Signed-off-by: Corey Minyard <cminyard@mvista.com>
[ Upstream commit 173743dd99a49c956b124a74c8aacb0384739a4c ]
Prior to this patch we enabled audit in audit_init(), which is too
late for PID 1 as the standard initcalls are run after the PID 1 task
is forked. This means that we never allocate an audit_context (see
audit_alloc()) for PID 1 and therefore miss a lot of audit events
generated by PID 1.
This patch enables audit as early as possible to help ensure that when
PID 1 is forked it can allocate an audit_context if required.
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit ca29fd7cce5a6444d57fb86517589a1a31c759e1 ]
When process the outbound packet of ipv6, we should assign the master
device to output device other than input device.
Signed-off-by: Keefe Liu <liuqifa@huawei.com>
Acked-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit f4b3526d83c40dd8bf5948b9d7a1b2c340f0dcc8 ]
The handler for the CB.ProbeUuid operation in the cache manager is
implemented, but isn't listed in the switch-statement of operation
selection, so won't be used. Fix this by adding it.
[ Upstream commit 31fde034a8bd964a5c7c1a5663fc87a913158db2 ]
The UMR's QP is created by calling mlx5_ib_create_qp directly, and
therefore the send CQ and the recv CQ on the ibqp weren't assigned.
Assign them right after calling the mlx5_ib_create_qp to assure
that any access to those pointers will work as expected and won't
crash the system as might happen as part of reset flow.
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
Signed-off-by: Majd Dibbiny <majd@mellanox.com>
Reviewed-by: Yishai Hadas <yishaih@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 5f22a1d87c5315a98981ecf93cd8de226cffe6ca ]
Maximal message should be used as a limit to the max message payload allowed,
without the headers. The ConnectX-3 check is done against this value includes
the headers. When the payload is 4K this will cause the NIC to drop packets.
Increase maximal message to 8K as workaround, this shouldn't change current
behaviour because we continue to set the MTU to 4k.
To reproduce;
set MTU to 4296 on the corresponding interface, for example:
ifconfig eth0 mtu 4296 (both server and client)
On server:
ib_send_bw -c UD -d mlx4_0 -s 4096 -n 1000000 -i1 -m 4096
On client:
ib_send_bw -d mlx4_0 -c UD <server_ip> -s 4096 -n 1000000 -i 1 -m 4096
Fixes: 6e0d733d9215 ("IB/mlx4: Allow 4K messages for UD QPs")
Signed-off-by: Mark Bloch <markb@mellanox.com>
Reviewed-by: Majd Dibbiny <majd@mellanox.com>
[ Upstream commit 0e74aa1d79a5bbc663e03a2804399cae418a0321 ]
The syzbot found an ancient bug in the IPsec code. When we cloned
a socket policy (for example, for a child TCP socket derived from a
listening socket), we did not copy the family field. This results
in a live policy with a zero family field. This triggers a BUG_ON
check in the af_key code when the cloned policy is retrieved.
This patch fixes it by copying the family field over.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 92ee46efeb505ead3ab06d3c5ce695637ed5f152 ]
Fengguang Wu reported that running the rcuperf test during boot can cause
the jump_label_test() to hit a WARN_ON(). The issue is that the core jump
label code relies on kernel_text_address() to detect when it can no longer
update branches that may be contained in __init sections. The
kernel_text_address() in turn assumes that if the system_state variable is
greter than or equal to SYSTEM_RUNNING then __init sections are no longer
valid (since the assumption is that they have been freed). However, when
rcuperf is setup to run in early boot it can call kernel_power_off() which
sets the system_state to SYSTEM_POWER_OFF.
Since rcuperf initialization is invoked via a module_init(), we can make
the dependency of jump_label_test() needing to complete before rcuperf
explicit by calling it via early_initcall().
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Jason Baron <jbaron@akamai.com>
Link: http://lkml.kernel.org/r/1510609727-2238-1-git-send-email-jbaron@akamai.com
[ Upstream commit bde533f2ea607cbbbe76ef8738b36243939a7bc2 ]
atm_dev_register() can fail here and passed parameters to free irq
which is not initialised. Initialization of 'dev->irq' happened after
the 'goto out_free_irq'. So using 'irq' insted of 'dev->irq' in
free_irq().
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
[ Upstream commit cea0cc80a6777beb6eb643d4ad53690e1ad1d4ff ]
Commit dfcb9f4f99f1 ("sctp: deny peeloff operation on asocs with threads
sleeping on it") fixed the race between peeloff and wait sndbuf by
checking waitqueue_active(&asoc->wait) in sctp_do_peeloff().
But it actually doesn't work, as even if waitqueue_active returns false
the waiting sndbuf thread may still not yet hold sk lock. After asoc is
peeled off, sk is not asoc->base.sk any more, then to hold the old sk
lock couldn't make assoc safe to access.
This patch is to fix this by changing to hold the new sk lock if sk is
not asoc->base.sk, meanwhile, also set the sk in sctp_sendmsg with the
new sk.
With this fix, there is no more race between peeloff and waitbuf, the
check 'waitqueue_active' in sctp_do_peeloff can be removed.
Thanks Marcelo and Neil for making this clear.
v1->v2:
fix it by changing to lock the new sock instead of adding a flag in asoc.
Suggested-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit ca3af4dd28cff4e7216e213ba3b671fbf9f84758 ]
Now in sctp_sendmsg sctp_wait_for_sndbuf could schedule out without
holding sock sk. It means the current asoc can be freed elsewhere,
like when receiving an abort packet.
If the asoc is just created in sctp_sendmsg and sctp_wait_for_sndbuf
returns err, the asoc will be freed again due to new_asoc is not nil.
An use-after-free issue would be triggered by this.
This patch is to fix it by setting new_asoc with nil if the asoc is
already dead when cpu schedules back, so that it will not be freed
again in sctp_sendmsg.
v1->v2:
set new_asoc as nil in sctp_sendmsg instead of sctp_wait_for_sndbuf.
[ Upstream commit 2a20aa171071a334d80c4e5d5af719d8374702fc ]
Without deferred struct page feature (CONFIG_DEFERRED_STRUCT_PAGE_INIT),
flags and other fields in "struct page"es are never changed prior to
first initializing struct pages by going through __init_single_page().
With deferred struct page feature enabled there is a case where we set
some fields prior to initializing:
mem_init() {
register_page_bootmem_info();
free_all_bootmem();
When register_page_bootmem_info() is called only non-deferred struct
pages are initialized. But, this function goes through some reserved
pages which might be part of the deferred, and thus are not yet
initialized.
mem_init
register_page_bootmem_info_node
get_page_bootmem
.. setting fields here ..
such as: page->freelist = (void *)type;
free_all_bootmem()
free_low_memory_core_early()
for_each_reserved_mem_region()
reserve_bootmem_region()
init_reserved_page() <- Only if this is deferred reserved page
__init_single_pfn()
memset(0) <-- Loose the set fields here
We end up with similar issue as in the previous patch, where currently
we do not observe problem as memory is zeroed. But, if flag asserts are
changed we can start hitting issues.
Also, because in this patch series we will stop zeroing struct page
memory during allocation, we must make sure that struct pages are
properly initialized prior to using them.
The deferred-reserved pages are initialized in free_all_bootmem().
Therefore, the fix is to switch the above calls.
Link: http://lkml.kernel.org/r/20171013173214.27300-4-pasha.tatashin@oracle.com
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
Reviewed-by: Daniel Jordan <daniel.m.jordan@oracle.com>
Reviewed-by: Bob Picco <bob.picco@oracle.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Michal Hocko <mhocko@kernel.org>
[ Upstream commit 34d9715ac1edd50285168dd8d80c972739a4f6a4 ]
Once blk_set_queue_dying() is done in blk_cleanup_queue(), we call
blk_freeze_queue() and wait for q->q_usage_counter becoming zero. But
if there are tasks blocked in get_request(), q->q_usage_counter can
never become zero. So we have to wake up all these tasks in
blk_set_queue_dying() first.
Fixes: 3ef28e83ab157997 ("block: generic request_queue reference counting")
Signed-off-by: Ming Lei <ming.lei@redhat.com>
[ Upstream commit b2bfe5915d5fe7577221031a39ac722a0a2a1199 ]
The rpc_task_begin trace point always display a task ID of zero.
Move the trace point call site so that it picks up the new task ID.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit d803224c84be067754db7fa58a93f36f61566493 ]
On successful rename, the "old_dentry" is retained and is attached to
the "new_dir", so we need to call nfs_set_verifier() accordingly.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
instead of 0
[ Upstream commit 1f3c790bd5989fcfec9e53ad8fa09f5b740c958f ]
line-range is supposed to treat "1-" as "1-endoffile", so
handle the special case by setting last_lineno to UINT_MAX.
Fixes this error:
dynamic_debug:ddebug_parse_query: last-line:0 < 1st-line:1
dynamic_debug:ddebug_exec_query: query parse failed
Link: http://lkml.kernel.org/r/10a6a101-e2be-209f-1f41-54637824788e@infradead.org
Acked-by: Jason Baron <jbaron@akamai.com>
[ Upstream commit 36a3d1dd4e16bcd0d2ddfb4a2ec7092f0ae0d931 ]
If the amount of resources allocated to a gen_pool exceeds 2^32 then the
avail atomic overflows and this causes problems when clients try and
borrow resources from the pool. This is only expected to be an issue on
64 bit systems.
Add the <linux/atomic.h> header to pull in atomic_long* operations. So
that 32 bit systems continue to use atomic32_t but 64 bit systems can
use atomic64_t.
Link: http://lkml.kernel.org/r/1509033843-25667-1-git-send-email-sbates@raithlin.com
Signed-off-by: Stephen Bates <sbates@raithlin.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Daniel Mentz <danielmentz@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
[ Upstream commit e39d5246111399dbc6e11cd39fd8580191b86c47 ]
Now when creating fnhe for redirect, it sets fnhe_expires for this
new route cache. But when updating the exist one, it doesn't do it.
It will cause this fnhe never to be expired.
Paolo already noticed it before, in Jianlin's test case, it became
even worse:
When ip route flush cache, the old fnhe is not to be removed, but
only clean it's members. When redirect comes again, this fnhe will
be found and updated, but never be expired due to fnhe_expires not
being set.
So fix it by simply updating fnhe_expires even it's for redirect.
Fixes: aee06da6726d ("ipv4: use seqlock for nh_exceptions")
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit cebe84c6190d741045a322f5343f717139993c08 ]
Now when ip route flush cache and it turn out all fnhe_genid != genid.
If a redirect/pmtu icmp packet comes and the old fnhe is found and all
it's members but fnhe_genid will be updated.
Then next time when it looks up route and tries to rebind this fnhe to
the new dst, the fnhe will be flushed due to fnhe_genid != genid. It
causes this redirect/pmtu icmp packet acutally not to be applied.
This patch is to also reset fnhe_genid when updating a route cache.
Fixes: 5aad1de5ea2c ("ipv4: use separate genid for next hop exceptions")
[ Upstream commit 67bd52386125ce1159c0581cbcd2740addf33cd4 ]
hwsim_new_radio_nl() now copies the name attribute in order to add a
null-terminator. mac80211_hwsim_new_radio() (indirectly) copies it
again into the net_device structure, so the first copy is not used or
freed later. Free the first copy before returning.
Fixes: ff4dd73dd2b4 ("mac80211_hwsim: check HWSIM_ATTR_RADIO_NAME length")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 2dbc644ac62bbcb9ee78e84719953f611be0413d ]
For rpm-pkg and deb-pkg, a source tar file is created. All paths in
the archive must be prefixed with the base name of the tar so that
everything is contained in the directory when you extract it.
Currently, scripts/package/Makefile uses a symlink for that, and
removes it after the tar is created.
If you terminate the build during the tar creation, the symlink is
left over. Then, at the next package build, you will see a warning
like follows:
ln: '.' and 'kernel-4.14.0+/.' are the same file
It is possible to fix it by adding -n (--no-dereference) option to
the "ln" command, but a cleaner way is to use --transform option
of "tar" command. This option is GNU extension, but it should not
hurt to use it in the Linux build system.
The 'S' flag is needed to exclude symlinks from the path fixup.
Without it, symlinks in the kernel are broken.
[ Upstream commit a8c8261425649da58bdf08221570e5335ad33a31 ]
In the i5000 and i5400 drivers, the NRECMEMB register is defined as a
16-bit value, which results in wrong shifts in the code, as reported by
sparse.
In the datasheets ([1], section 3.9.22.20 and [2], section 3.9.22.21),
this register is a 32-bit register. A u32 value for the register fixes
the wrong shifts warnings and matches the datasheet.
Also fix the mask to access to the CAS bits [27:16] in the i5000 driver.
[1]: https://www.intel.com/content/dam/doc/datasheet/5000p-5000v-5000z-chipset-memory-controller-hub-datasheet.pdf
[2]: https://www.intel.se/content/dam/doc/datasheet/5400-chipset-memory-controller-hub-datasheet.pdf
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/20170629005729.8478-1-jeremy.lefaure@lse.epita.fr
[ Upstream commit e61555c29c28a4a3b6ba6207f4a0883ee236004d ]
The MTR_DRAM_WIDTH macro returns the data width. It is sometimes used
as if it returned a boolean true if the width if 8. Fix the tests where
MTR_DRAM_WIDTH is misused.
Link: http://lkml.kernel.org/r/20170309011809.8340-1-jeremy.lefaure@lse.epita.fr
[ Upstream commit 7aafac11e308d37ed3c509829bb43d80c1811ac3 ]
The IODA2 specification says that a 64 DMA address cannot use top 4 bits
(3 are reserved and one is a "TVE select"); bottom page_shift bits
cannot be used for multilevel table addressing either.
The existing IODA2 table allocation code aligns the minimum TCE table
size to PAGE_SIZE so in the case of 64K system pages and 4K IOMMU pages,
we have 64-4-12=48 bits. Since 64K page stores 8192 TCEs, i.e. needs
13 bits, the maximum number of levels is 48/13 = 3 so we physically
cannot address more and EEH happens on DMA accesses.
This adds a check that too many levels were requested.
It is still possible to have 5 levels in the case of 4K system page size.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
[ Upstream commit c085bd5119d5d0bdf3ef591a5563566be7dedced ]
Signed-off-by: Jim Qu <Jim.Qu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit 672a2c87c83649fb0167202342ce85af9a3b4f1c ]
It is invalid to call del_gendisk() when disk->queue is NULL. Fix error
handling in axon_ram_probe() to avoid doing that.
Also del_gendisk() does not drop a reference to gendisk allocated by
alloc_disk(). That has to be done by put_disk(). Add that call where
needed.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit 7b4fdf77a450ec0fdcb2f677b080ddbf2c186544 ]
Andrey reports syzkaller splat caused by
NF_CT_ASSERT(!ip_is_fragment(ip_hdr(skb)));
in ipv4 nat. But this assertion (and the comment) are wrong, this function
does see fragments when IP_NODEFRAG setsockopt is used.
As conntrack doesn't track packets without complete l4 header, only the
first fragment is tracked.
Because applying nat to first packet but not the rest makes no sense this
also turns off tracking of all fragments.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 0bc315381fe9ed9fb91db8b0e82171b645ac008f ]
zram can handle at most SECTORS_PER_PAGE sectors in a bio's bvec. When using
the NVMe over Fabrics loopback target which potentially sends a huge bulk of
pages attached to the bio's bvec this results in a kernel panic because of
array out of bounds accesses in zram_decompress_page().
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
[ Upstream commit 2501c1bb054290679baad0ff7f4f07c714251f4c ]
While modifying the driver to use the STOP interrupt, the completion of the
intermediate transfers need to wake the driver back up in order to initiate
the next transfer (restart condition). Otherwise you get never ending
interrupts and only the first transfer sent.
Fixes: 71ccea095ea1 ("i2c: riic: correctly finish transfers")
Reported-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 07de4bc88ce6a4d898cad9aa4c99c1df7e87702d ]
In a regular interrupt handler driver was finishing the crypt/decrypt
request by calling complete on crypto request. This is disallowed since
converting to skcipher in commit b286d8b1a690 ("crypto: skcipher - Add
skcipher walk interface") and causes a warning:
WARNING: CPU: 0 PID: 0 at crypto/skcipher.c:430 skcipher_walk_first+0x13c/0x14c
The interrupt is marked shared but in fact there are no other users
sharing it. Thus the simplest solution seems to be to just use a
threaded interrupt handler, after converting it to oneshot.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 15e668070a64bb97f102ad9cf3bccbca0545cda8 ]
Andrey reported the following kernel crash:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 0 PID: 14446 Comm: syz-executor6 Not tainted 4.10.0+ #82
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff88001f311700 task.stack: ffff88001f6e8000
RIP: 0010:ip6mr_sk_done+0x15a/0x3d0 net/ipv6/ip6mr.c:1618
RSP: 0018:ffff88001f6ef418 EFLAGS: 00010202
RAX: dffffc0000000000 RBX: 1ffff10003edde8c RCX: ffffc900043ee000
RDX: 0000000000000004 RSI: ffffffff83e3b3f8 RDI: 0000000000000020
RBP: ffff88001f6ef508 R08: fffffbfff0dcc5d8 R09: 0000000000000000
R10: ffffffff86e62ec0 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: ffff88001f6ef4e0 R15: ffff8800380a0040
FS: 00007f7a52cec700(0000) GS:ffff88003ec00000(0000) knlGS:0000000000000000
CR2: 000000000061c500 CR3: 000000001f1ae000 CR4: 00000000000006f0
DR0: 0000000020000000 DR1: 0000000020000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000600
Call Trace:
rawv6_close+0x4c/0x80 net/ipv6/raw.c:1217
inet_release+0xed/0x1c0 net/ipv4/af_inet.c:425
inet6_release+0x50/0x70 net/ipv6/af_inet6.c:432
sock_release+0x8d/0x1e0 net/socket.c:597
__sock_create+0x39d/0x880 net/socket.c:1226
sock_create_kern+0x3f/0x50 net/socket.c:1243
inet_ctl_sock_create+0xbb/0x280 net/ipv4/af_inet.c:1526
icmpv6_sk_init+0x163/0x500 net/ipv6/icmp.c:954
ops_init+0x10a/0x550 net/core/net_namespace.c:115
setup_net+0x261/0x660 net/core/net_namespace.c:291
copy_net_ns+0x27e/0x540 net/core/net_namespace.c:396
9pnet_virtio: no channels available for device ./file1
create_new_namespaces+0x437/0x9b0 kernel/nsproxy.c:106
unshare_nsproxy_namespaces+0xae/0x1e0 kernel/nsproxy.c:205
SYSC_unshare kernel/fork.c:2281 [inline]
SyS_unshare+0x64e/0x1000 kernel/fork.c:2231
entry_SYSCALL_64_fastpath+0x1f/0xc2
This is because net->ipv6.mr6_tables is not initialized at that point,
ip6mr_rules_init() is not called yet, therefore on the error path when
we iterator the list, we trigger this oops. Fix this by reordering
ip6mr_rules_init() before icmpv6_sk_init().
[ Upstream commit 78d5505432436516456c12abbe705ec8dee7ee2b ]
On failure to configure a VF MAC/VLAN filter we should not attempt to
rollback filters that we failed to configure with -EEXIST.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
[ Upstream commit 22118d861cec5da6ed525aaf12a3de9bfeffc58f ]
It is too late to check for the limit of the number of VF multicast
addresses after they have already been copied to the req->multicast[]
array, possibly overflowing it.
Do the check before copying.
Also fix the error path to not skip unlocking vf2pf_mutex.
[ Upstream commit 466e8bf10ac104d96e1ea813e8126e11cb72ea20 ]
It is possible to crash the kernel by accessing a PTP device while its
associated bnx2x interface is down. Before the interface is brought up,
the timecounter is not initialized, so accessing it results in NULL
dereference.
Fix it by checking if the interface is up.
Use -ENETDOWN as the error code when the interface is down.
-EFAULT in bnx2x_ptp_adjfreq() did not seem right.
Tested using phc_ctl get/set/adj/freq commands.
[ Upstream commit 4342696df764ec65dcdfbd0c10d90ea52505f8ba ]
Signed-off-by: Maarten Blomme <Maarten.Blomme@flir.com>
[ Upstream commit ba4dd156eabdca93501d92a980ba27fa5f4bbd27 ]
Currently we BUG() if we see an ESR_EL2.EC value we don't recognise. As
configurable disables/enables are added to the architecture (controlled
by RES1/RES0 bits respectively), with associated synchronous exceptions,
it may be possible for a guest to trigger exceptions with classes that
we don't recognise.
While we can't service these exceptions in a manner useful to the guest,
we can avoid bringing down the host. Per ARM DDI 0487A.k_iss10775, page
D7-1937, EC values within the range 0x00 - 0x2c are reserved for future
use with synchronous exceptions, and EC values within the range 0x2d -
0x3f may be used for either synchronous or asynchronous exceptions.
The patch makes KVM handle any unknown EC by injecting an UNDEFINED
exception into the guest, with a corresponding (ratelimited) warning in
the host dmesg. We could later improve on this with with a new (opt-in)
exit to the host userspace.
Cc: Dave Martin <dave.martin@arm.com>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit f050fe7a9164945dd1c28be05bf00e8cfb082ccf ]
Currently we BUG() if we see a HSR.EC value we don't recognise. As
we don't recognise.
we can avoid bringing down the host. Per ARM DDI 0406C.c, all currently
unallocated HSR EC encodings are reserved, and per ARM DDI
0487A.k_iss10775, page G6-4395, EC values within the range 0x00 - 0x2c
are reserved for future use with synchronous exceptions, and EC values
within the range 0x2d - 0x3f may be used for either synchronous or
