2008-03-04Kprobes: move kprobe examples to samples/Ananth N Mavinakayanahalli
Move kprobes examples from Documentation/kprobes.txt to under samples/. Patch originally by Randy Dunlap. o Updated the patch to apply on 2.6.25-rc3 o Modified examples code to build on multiple architectures. Currently, the kprobe and jprobe examples code works for x86 and powerpc o Cleaned up unneeded #includes o Cleaned up Kconfig per Sam Ravnborg's suggestions to fix build break on archs that don't have kretprobes o Implemented suggestions by Mathieu Desnoyers on CONFIG_KRETPROBES o Included Andrew Morton's cleanup based on x86-git o Modified kretprobe_example to act as a arch-agnostic module to determine routine execution times: Use 'modprobe kretprobe_example func=<func_name>' to determine execution time of func_name in nanoseconds. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Kprobes: indicate kretprobe support in KconfigAnanth N Mavinakayanahalli
Add CONFIG_HAVE_KRETPROBES to the arch/<arch>/Kconfig file for relevant architectures with kprobes support. This facilitates easy handling of in-kernel modules (like samples/kprobes/kretprobe_example.c) that depend on kretprobes being present in the kernel. Thanks to Sam Ravnborg for helping make the patch more lean. Per Mathieu's suggestion, added CONFIG_KRETPROBES and fixed up dependencies. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04VT notifier fix for VT switchSamuel Thibault
VT notifier callbacks need to be aware of console switches. This is already partially done from console_callback(), but at that time fg_console, cursor positions, etc. are not yet updated and hence screen readers fetch the old values. This adds an update notify after all of the values are updated in redraw_screen(vc, 1). Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04alloc_percpu() fails to allocate percpu dataEric Dumazet
Some oprofile results obtained while using tbench on a 2x2 cpu machine were very surprising. For example, loopback_xmit() function was using high number of cpu cycles to perform the statistic updates, supposed to be real cheap since they use percpu data pcpu_lstats = netdev_priv(dev); lb_stats = per_cpu_ptr(pcpu_lstats, smp_processor_id()); lb_stats->packets++; /* HERE : serious contention */ lb_stats->bytes += skb->len; struct pcpu_lstats is a small structure containing two longs. It appears that on my 32bits platform, alloc_percpu(8) allocates a single cache line, instead of giving to each cpu a separate cache line. Using the following patch gave me impressive boost in various benchmarks ( 6 % in tbench) (all percpu_counters hit this bug too) Long term fix (ie >= 2.6.26) would be to let each CPU allocate their own block of memory, so that we dont need to roudup sizes to L1_CACHE_BYTES, or merging the SGI stuff of course... Note : SLUB vs SLAB is important here to *show* the improvement, since they dont have the same minimum allocation sizes (8 bytes vs 32 bytes). This could very well explain regressions some guys reported when they switched to SLUB. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04vfs: fix NULL pointer dereference in fsync_buffers_list()Jan Kara
Fix NULL pointer dereference in fsync_buffers_list() introduced by recent fix of races in private_list handling. Since bh->b_assoc_map has been cleared in __remove_assoc_queue() we should really use original value stored in the 'mapping' variable. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04zlc_setup(): handle jiffies wraparoundKOSAKI Motohiro
jiffies subtraction may cause an overflow problem. It should be using time_after(). [akpm@linux-foundation.org: include jiffies.h] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Paul Jackson <pj@sgi.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Fix "Malformed early option 'loglevel'"Alex Riesen
Keith Mannthey said: The parameter hotadd_percent is setup right but there is a "Malformed early option 'numa'" message. Rusty Russell said: This happens when the function registered with early_param() returns non-zero. __setup() functions return 1 if OK, module_param() and early_param() return 0 or a -ve error code. For instance: Linux version 2.6.25-rc3-t (raa@steel) (gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)) #22 SMP PREEMPT Tue Feb 26 BIOS-provided physical RAM map: BIOS-e820: 0000000000000000 - 00000000000a0000 (usable) BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) BIOS-e820: 0000000000100000 - 000000003fff0000 (usable) BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS) BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data) BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved) Malformed early option 'loglevel' 127MB HIGHMEM available. 896MB LOWMEM available. Command line: BOOT_IMAGE=2.6.25-t ro root=809 ro console=ttyS0,57600n8 console=tty0 loglevel=5 Acked-by: Yinghai Lu <yhlu.kernel@gmai.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Keith Mannthey <kmannth@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04core dump: user_regset writebackRoland McGrath
This makes the user_regset-based core dump code call user_regset writeback hooks when available. This is necessary groundwork to allow IA64 to set CORE_DUMP_USE_REGSET. Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Roland McGrath <roland@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Add memory resource controller maintainersakpm@linux-foundation.org
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Control Groups: add Paul Menage as maintainerPaul Menage
Control Groups: Add Paul Menage as maintainer Signed-off-by: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04gpio: <linux/gpio.h> and "no GPIO support here" stubsDavid Brownell
Add a <linux/gpio.h> defining fail/warn stubs for GPIO calls on platforms that don't support the GPIO programming interface. That includes the arch-specific implementation glue otherwise. This facilitates a new model for GPIO usage: drivers that can use GPIOs if they're available, but don't require them. One example of such a driver is NAND driver for various FreeScale chips. On platforms update with GPIO support, they can be used instead of a worst-case delay to verify that the BUSY signal is off. (Also includes a couple minor unrelated doc updates.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04specialix.c: fix possible double-unlockHarvey Harrison
Noticed by sparse, trivial to see: drivers/char/specialix.c:2112:3: warning: context imbalance in 'sx_throttle' - unexpected unlock Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04rtc: add support for the S-35390A RTC chipByron Bradley
This adds basic get/set time support for the Seiko Instruments S-35390A. This chip communicates using I2C and is used on the QNAP TS-109/TS-209 NAS devices. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Byron Bradley <byron.bbradley@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: David Brownell <david-b@pacbell.net> Tested-by: Tim Ellis <tim@ngndg.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Memory Resource Controller use strstrip while parsing argumentsBalbir Singh
The memory controller has a requirement that while writing values, we need to use echo -n. This patch fixes the problem and makes the UI more consistent. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04CRIS v10: Include mm.h instead of vmstat.h in kernel/time.cJesper Nilsson
Commit 2f569afd9ced9ebec9a6eb3dbf6f83429be0a7b4 (CONFIG_HIGHPTE vs. sub-page page tables) introduced use of inc_zone_page_state and dec_zone_page_state in include/linux/mm.h. Those are defined in include/linux/vmstat.h, but after it includes mm.h, making it impossible to include vmstat.h since inc_zone_page_state and dec_zone_page_state then would be undefined. arch/cris/arch-v10/kernel/time.c does just this, which makes the CRIS v10 build break with the following error: ... CC arch/cris/arch-v10/kernel/time.o In file included from include/linux/vmstat.h:7, from arch/cris/arch-v10/kernel/time.c:17: include/linux/mm.h: In function 'pgtable_page_ctor': include/linux/mm.h:902: error: implicit declaration of function 'inc_zone_page_state' include/linux/mm.h: In function 'pgtable_page_dtor': include/linux/mm.h:908: error: implicit declaration of function 'dec_zone_page_state' make[2]: *** [arch/cris/arch-v10/kernel/time.o] Error 1 make[1]: *** [arch/cris/arch-v10/kernel] Error 2 make: *** [sub-make] Error 2 ... By changing kernel/time.c to include linux/mm.h, the build succeeds. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04serial: add PNP ID GVC0303 for Archtek 3334BRV ISA modemBjorn Helgaas
Thomas Lehmann <thomas.lehmann@alumni.tu-berlin.de> verified that this entry works. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04update checkpatch.pl to version 0.15Andy Whitcroft
This version brings a number of minor fixes updating the type detector and the unary tracker. It also brings a few small fixes for false positives. It also reverts the --file warning. Of note: - limit CVS checks to added lines - improved type detections - fixes to the unary tracker Andy Whitcroft (13): Version: 0.15 EXPORT_SYMBOL checks need to accept array variables export checks must match DECLARE_foo and LIST_HEAD possible types: cleanup debugging missing line values: track values through preprocessor conditional paths typeof is actually a type possible types: detect definitions which cross lines values: include line numbers on value debug information values: ensure we find correctly record pending brackets values: simplify the brace history stack CVS keyword checks should only apply to added lines loosen spacing for comments allow braces for single statement blocks with multiline conditionals Harvey Harrison (1): checkpatch: remove fastcall Ingo Molnar (1): checkpatch.pl: revert wrong --file message Uwe Kleine-Koenig (1): fix typo "goot" -> "good" Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04cgroup: fix default notify_on_release settingLi Zefan
The documentation says the default value of notify_on_release of a child cgroup is inherited from its parent, which is reasonable, but the implementation just sets the flag disabled. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04x86: a P4 is a P6 not an i486Hugh Dickins
P4 has been coming out as CPU_FAMILY=4 instead of 6: fix MPENTIUM4 typo. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: scsi: missing add of padded bytes to io completion byte count
2008-03-04Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: [PATCH] fs/ocfs2/aops.c: Correct use of ! and & [2.6 patch] ocfs2: make dlm_do_assert_master() static [2.6 patch] make ocfs2_downconvert_thread() static [2.6 patch] fs/ocfs2/: possible cleanups [PATCH] ocfs2: le*_add_cpu conversion ocfs2: Fix writeout in ocfs2_data_convert_worker() ocfs2: Enable localalloc for local mounts
2008-03-04Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: ioat: fix 'ack' handling, driver must ensure that 'ack' is zero dmaengine: fix sparse warning fsldma: do not cleanup descriptors in hardirq context dmaengine: add driver for Freescale MPC85xx DMA controller
2008-03-04scsi: missing add of padded bytes to io completion byte countJens Axboe
Original patch from Tejun Heo <htejun@gmail.com> but should use ->extra_len and not ->data_len, as we would then overshoot the original request size. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-devel * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched-devel: sched: revert load_balance_monitor() changes
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86/xen: fix DomU boot problem x86: not set node to cpu_to_node if the node is not online x86, i387: fix ptrace leakage using init_fpu()
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: x86: disable KVM for Voyager and friends KVM: VMX: Avoid rearranging switched guest msrs while they are loaded KVM: MMU: Fix race when instantiating a shadow pte KVM: Route irq 0 to vcpu 0 exclusively KVM: Avoid infinite-frequency local apic timer KVM: make MMU_DEBUG compile again KVM: move alloc_apic_access_page() outside of non-preemptable region KVM: SVM: fix Windows XP 64 bit installation crash KVM: remove the usage of the mmap_sem for the protection of the memory slots. KVM: emulate access to MSR_IA32_MCG_CTL KVM: Make the supported cpuid list a host property rather than a vm property KVM: Fix kvm_arch_vcpu_ioctl_set_sregs so that set_cr0 works properly KVM: SVM: set NM intercept when enabling CR0.TS in the guest KVM: SVM: Fix lazy FPU switching
2008-03-04ioat: fix 'ack' handling, driver must ensure that 'ack' is zeroDan Williams
Initialize 'ack' to zero in case the descriptor has been recycled. Prevents "kernel BUG at crypto/async_tx/async_xor.c:185!" Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Shannon Nelson <shannon.nelson@intel.com> Cc: stable@kernel.org
2008-03-04dmaengine: fix sparse warningDan Williams
include/linux/dmaengine.h:364:2: warning: returning void-valued expression Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-03-04fsldma: do not cleanup descriptors in hardirq contextDan Williams
"Cleaning" descriptors involves calling pending callbacks and clients assume that their callback will only ever happen in softirq context. Delay cleanup to the tasklet. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Zhang Wei <wei.zhang@freescale.com>
2008-03-04dmaengine: add driver for Freescale MPC85xx DMA controllerZhang Wei
The driver implements DMA engine API for Freescale MPC85xx DMA controller, which could be used by devices in the silicon. The driver supports the Basic mode of Freescale MPC85xx DMA controller. The MPC85xx processors supported include MPC8540/60, MPC8555, MPC8548, MPC8641 and so on. The MPC83xx(MPC8349, MPC8360) are also supported. [kamalesh@linux.vnet.ibm.com: build fix] [dan.j.williams@intel.com: merge mm fixes, rebase on async_tx-2.6.25] Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com> Acked-by: Kumar Gala <galak@gate.crashing.org> Cc: Shannon Nelson <shannon.nelson@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-03-04sched: revert load_balance_monitor() changesPeter Zijlstra
The following commits cause a number of regressions: commit 58e2d4ca581167c2a079f4ee02be2f0bc52e8729 Author: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Date: Fri Jan 25 21:08:00 2008 +0100 sched: group scheduling, change how cpu load is calculated commit 6b2d7700266b9402e12824e11e0099ae6a4a6a79 Author: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Date: Fri Jan 25 21:08:00 2008 +0100 sched: group scheduler, fix fairness of cpu bandwidth allocation for task groups Namely: - very frequent wakeups on SMP, reported by PowerTop users. - cacheline trashing on (large) SMP - some latencies larger than 500ms While there is a mergeable patch to fix the latter, the former issues are not fixable in a manner suitable for .25 (we're at -rc3 now). Hence we revert them and try again in v2.6.26. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-04x86/xen: fix DomU boot problemIan Campbell
Construct Xen guest e820 map with a hole between 640K-1M. It's pure luck that Xen kernels have gotten away with it in the past. The patch below seems like the right thing to do. It certainly boots in a domU without the DMI problem (without any of the other related patches such as Alexander's). Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Tested-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-04x86: not set node to cpu_to_node if the node is not onlineYinghai Lu
resolve boot problem reported by Mel Gorman: http://lkml.org/lkml/2008/2/13/404 init_cpu_to_node will use cpu->apic (from MADT or mptable) and apic->node(from SRAT or AMD config space with k8_bus_64.c) to have cpu->node mapping, and later identify_cpu will overwrite them again...(with nearby_node...) this patch checks if the node is online, otherwise it will not update cpu_node map. so keep cpu_node map to online node before identify_cpu..., to prevent possible error. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-04x86, i387: fix ptrace leakage using init_fpu()Suresh Siddha
This bug got introduced by the recent i387 merge: commit 4421011120b2304e5c248ae4165a2704588aedf1 Author: Roland McGrath <roland@redhat.com> Date: Wed Jan 30 13:31:50 2008 +0100 x86: x86 i387 user_regset Current usage of unlazy_fpu() in ptrace specific routines is wrong. unlazy_fpu() will not init fpu if the task never used math. So the ptrace calls can expose the parent tasks FPU data in some cases. Replace it with the init_fpu() which will init the math state, if the task never used math before. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: fix blkdev_issue_flush() not detecting and passing EOPNOTSUPP back block: fix shadowed variable warning in blk-map.c block: remove extern on function definition cciss: remove READ_AHEAD define and use block layer defaults make cdrom.c:check_for_audio_disc() static block/genhd.c: proper externs unexport blk_rq_map_user_iov unexport blk_{get,put}_queue block/genhd.c: cleanups proper prototype for blk_dev_init() block/blk-tag.c should #include "blk.h" Fix DMA access of block device in 64-bit kernel on some non-x86 systems with 4GB or upper 4GB memory block: separate out padding from alignment block: restore the meaning of rq->data_len to the true data length resubmit: cciss: procfs updates to display info about many splice: only return -EAGAIN if there's hope of more data block: fix kernel-docbook parameters and files
2008-03-04m68k{,nommu}: Wire up new timerfd syscallsGeert Uytterhoeven
m68k{,nommu}: Wire up the new timerfd syscalls, which were introduced in commit 4d672e7ac79b5ec5cdc90e450823441e20464691 ("timerfd: new timerfd API"). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: fix fec driver interrupt racesGreg Ungerer
The FEC driver has a common interrupt handler for all interrupt event types. It is raised on a number of distinct interrupt vectors. This handler can't be re-entered while processing an interrupt, so make sure all requested vectors are flagged as IRQF_DISABLED. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: declare do_IRQ()Greg Ungerer
Need a declaration of do_IRQ for the 68328 interrupt handling code. It is common to all m68knommu targets, so a common declaration makes sense. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: remove duplicate hw_tick() codeGreg Ungerer
Remove duplicate hw_tick() function from 68328 timers code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04m68knommu: update defconfigGreg Ungerer
Update the m68knommu defconfig. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Build fix for drivers/s390/char/defkeymap.cTony Breeds
Commit 5ce2087ed0eb424e0889bdc9102727f65d2ecdde (Fix default compose table initialization) left a trailing quote. CC drivers/s390/char/defkeymap.o drivers/s390/char/defkeymap.c:155: error: missing terminating ' character drivers/s390/char/defkeymap.c:156: error: syntax error before ';' token make[3]: *** [drivers/s390/char/defkeymap.o] Error 1 Fix that. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] remove unused variable [CIFS] consolidate duplicate code in posix/unix inode handling [CIFS] fix build break when proc disabled [CIFS] factoring out common code in get_inode_info functions [CIFS] fix prepath conversion when server supports posix paths [CIFS] Only convert / when server does not support posix paths [CIFS] Fix mixed case name in structure dfs_info3_param [CIFS] fixup prefixpaths which contain multiple path components [CIFS] fix typo [CIFS] patch to fix incorrect encoding of number of aces on set mode [CIFS] Fix typo in quota operations [CIFS] clean up some hard to read ifdefs [CIFS] reduce checkpatch warnings [CIFS] fix warning in cifs_spnego.c
2008-03-04freezer vs stopped or tracedRoland McGrath
This changes the "freezer" code used by suspend/hibernate in its treatment of tasks in TASK_STOPPED (job control stop) and TASK_TRACED (ptrace) states. As I understand it, the intent of the "freezer" is to hold all tasks from doing anything significant. For this purpose, TASK_STOPPED and TASK_TRACED are "frozen enough". It's possible the tasks might resume from ptrace calls (if the tracer were unfrozen) or from signals (including ones that could come via timer interrupts, etc). But this doesn't matter as long as they quickly block again while "freezing" is in effect. Some minor adjustments to the signal.c code make sure that try_to_freeze() very shortly follows all wakeups from both kinds of stop. This lets the freezer code safely leave stopped tasks unmolested. Changing this fixes the longstanding bug of seeing after resuming from suspend/hibernate your shell report "[1] Stopped" and the like for all your jobs stopped by ^Z et al, as if you had freshly fg'd and ^Z'd them. It also removes from the freezer the arcane special case treatment for ptrace'd tasks, which relied on intimate knowledge of ptrace internals. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04x86: disable KVM for Voyager and friendsRandy Dunlap
Most classic Pentiums don't have hardware virtualization extension, and building kvm with Voyager, Visual Workstation, or NUMAQ generates spurious failures. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2008-03-04KVM: VMX: Avoid rearranging switched guest msrs while they are loadedAvi Kivity
KVM tries to run as much as possible with the guest msrs loaded instead of host msrs, since switching msrs is very expensive. It also tries to minimize the number of msrs switched according to the guest mode; for example, MSR_LSTAR is needed only by long mode guests. This optimization is done by setup_msrs(). However, we must not change which msrs are switched while we are running with guest msr state: - switch to guest msr state - call setup_msrs(), removing some msrs from the list - switch to host msr state, leaving a few guest msrs loaded An easy way to trigger this is to kexec an x86_64 linux guest. Early during setup, the guest will switch EFER to not include SCE. KVM will stop saving MSR_LSTAR, and on the next msr switch it will leave the guest LSTAR loaded. The next host syscall will end up in a random location in the kernel. Fix by reloading the host msrs before changing the msr list. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04KVM: MMU: Fix race when instantiating a shadow pteAvi Kivity
For improved concurrency, the guest walk is performed concurrently with other vcpus. This means that we need to revalidate the guest ptes once we have write-protected the guest page tables, at which point they can no longer be modified. The current code attempts to avoid this check if the shadow page table is not new, on the assumption that if it has existed before, the guest could not have modified the pte without the shadow lock. However the assumption is incorrect, as the racing vcpu could have modified the pte, then instantiated the shadow page, before our vcpu regains control: vcpu0 vcpu1 fault walk pte modify pte fault in same pagetable instantiate shadow page lookup shadow page conclude it is old instantiate spte based on stale guest pte We could do something clever with generation counters, but a test run by Marcelo suggests this is unnecessary and we can just do the revalidation unconditionally. The pte will be in the processor cache and the check can be quite fast. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04KVM: Route irq 0 to vcpu 0 exclusivelyAvi Kivity
Some Linux versions allow the timer interrupt to be processed by more than one cpu, leading to hangs due to tsc instability. Work around the issue by only disaptching the interrupt to vcpu 0. Problem analyzed (and patch tested) by Sheng Yang. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04KVM: Avoid infinite-frequency local apic timerAvi Kivity
If the local apic initial count is zero, don't start a an hrtimer with infinite frequency, locking up the host. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04KVM: make MMU_DEBUG compile againMarcelo Tosatti
the cr3 variable is now inside the vcpu->arch structure. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-03-04KVM: move alloc_apic_access_page() outside of non-preemptable regionMarcelo Tosatti
alloc_apic_access_page() can sleep, while vmx_vcpu_setup is called inside a non preemptable region. Move it after put_cpu(). Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
