The MCP2515 on the Colibri EvalBoard V3.1a actually uses regular system
reset aka RESET_OUT# on SODIMM 87 to reset the MCP2515.
Therefore clean-up resp. remove any MECS Tellurium legacy in that
respect.
While at it adjust copyright year, re-order some include, clean-up some
struct spacing, re-order clocks and improve some comments.
Don't initialize the whole display controller (dc) when framebuffer
mode is set to off.
This avoids creation of the /dev/tegra_dc_x device. The tegra X
driver requires for each tegra_dc_x device an framebuffer device
with the same id. This patch avoids creation of both, which makes
the tegra X driver load correctly.
Note: Turning off tegrafb0 still leads to kernel crash due to
hard coded device enumeration.
Symptoms:
The interface stops receiving CAN frames when reception of CAN frame
and call to the introduced get_berr_counter function coincide.
Reproduction:
Ip requests, among others, the berr field for the can interfaces. NOTE
that it does so even if called as 'ip link show lo', as interface-based
filtering is only done after the system calls to receive interface
information.
Run candump on a MCP-based can interface that has a lot of traffic (via
'cangen -g1' on another can node).
On the system with the MCP chip, run
while /bin/true; do ip link > /dev/null ; done;
Reception of CAN-frames (as shown by candump) will cease within
seconds.
This issue got introduced by commit
1b59090a47101b4bf379d2c35986ad3f0bcb2aa1 as access to the SPI registers
of the MCP251x were not locked.
Issue report and patch courtesy David R. Piegdon of Indurad GmbH.
Driver features:
1. Supported formats:
- Full HD, 1920x1080, 8.5 FPS, YUYV
- VGA, 640x480, 30 FPS, YUYV
2. Available controls with enabled AE (auto exposure):
- brightness [0...255],
- contrast [16...64],
- saturation [0...256],
- hue [-2200...2200],
- gamma [100...280].
3. Works only in parallell interface mode (CSI in progress).
4. No external tools needed (for i2c).
This commit restores the full framerate (25 FPS), after a drop to
16 FPS caused by a l4t-r16-r4 merge.
This commit adds settings such as:
- values of horizontal/vertical active start,
- enabling/disabling internal sync,
to the private data of decoders: MAX9526, ADV7180, TVP5150,
OV7670 and AS0260.
The feature is available through *_tegra_camera_platform_data
struct initialised in board-*.c files.
This commit fixes the crash that occures while loading tegra_v4l2_camera
module caused by its new features (private data per sensor).
updated files:
arch/arm/mach-tegra/board-apalis_t30.c
arch/arm/mach-tegra/board-colibri_t20.c
arch/arm/mach-tegra/board-colibri_t30.c
This commit fixes the kernel compilation error with the lack
of the export of tegra_powergate_partition symbol in
arch/arm/mach-tegra/powergate.c
Bug 1369083
Change-Id: I1a81bcb62e8f6bb654ffbebba09661187ab4b512
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/309536
Tested-by: Vikram Fugro <vfugro@nvidia.com>
Reviewed-by: Kaustubh Purandare <kpurandare@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Add support for dual cameras from both CSI-A and CSI-B:
- move all the CSI settings into video buffer struct
- queue the video buffer struct to a dedicated queue
- process one video buffer struct from the queue at one time
Bug 1369083
Change-Id: Ie64d69282ab991b66e97327e288a2bacde088bd6
Reviewed-on: http://git-master/r/246269
(cherry picked from commit 228b0c2d9ae3fa1121f88836626d654ae0fc4ff0)
Reviewed-on: http://git-master/r/279987
Tested-by: Matthew Pedro <mapedro@nvidia.com>
drivers/media/video/tegra_v4l2_camera.c
soc_camera_link supports passing power on/off control callback to
soc_camera stack. So the power control can be handled by soc_camera
stack instead of our Tegra V4L2 host driver.
Also pass other platform_data fields via soc_camera_link instead of
a hacking nvhost_device_data struct.
Bug 1240806
Bug 1369083
Change-Id: I443a7d28196cc8292805da70d2d5ff1c3cd50a5d
Reviewed-on: http://git-master/r/246267
(cherry picked from commit 9083d270bf93b583cd5bf5151a52ea250f8541a3)
Reviewed-on: http://git-master/r/279986
CSI host controller of Tegra can support Bayer Raw8 and Raw 10 data
input, it also output data as extended 16-bit data format in memory
directly.
Raw data output should be handled by the second output channel.
This patch add supporting for Raw data input/output and the second
output channel.
All were tested on Cardhu board.
Change-Id: Ifd1d8c94671a1d4571dcf176774e2d3cffafc399
Reviewed-on: http://git-master/r/200225
GVS: Gerrit_Virtual_Submit
Enable IEEE 1588 precision time protocol (PTP) support.
Springville/i211 with a blank Flash/iNVM use different PCI IDs. Extend
the driver to load despite i210/i211 data sheets claiming tools only,
not for driver.
Only warn rather than fail on NVM validation failures on Apalis T30.
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
Use the Toradex OUI as default MAC address if no valid one is
encountered.
Tested on samples of Apalis T30 2GB V1.0B, V1.0C and Apalis T30 1GB
V1.0A both with blank NVMs as well as iNVMs programmed with Intel's
defaults.
Springville/i211 with a blank Flash/iNVM use a different PCI ID (tools
only, not for driver) than properly programmed ones.
Integrate latest igb driver version 5.1.2
(igb-5.1.2.tar.gz from e1000.sf.net).
This commit adds a method that MAC drivers may call in order to find out
the device number of their associated PTP Hardware Clock.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
This commit adds a new ethtool ioctl that exposes the SO_TIMESTAMPING
capabilities of a network interface. In addition, user space programs
can use this ioctl to discover the PTP Hardware Clock (PHC) device
associated with the interface.
Since software receive time stamps are handled by the stack, the generic
ethtool code can answer the query correctly in case the MAC or PHY
drivers lack special time stamping features.
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
Add a new ethtool operation (get_rxfh_indir_size) to get the
indirectional table size. Use this to validate the user buffer size
before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get
the number of RX rings, and validate the contents of the new
indirection table before calling set_rxfh_indir. Remove this
validation from drivers.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Dimitris Michailidis <dm@chelsio.com>
Tegra20 and Tegra30 do not support gen2 PCIe, so correct the
register setting to disable it.
Signed-off-by: Eric Brower <ebrower@nvidia.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Thierry Reding <treding@nvidia.com>
reverted to current driver supporting ACM rather than CSI2
drivers/media/video/videobuf2-dma-nvmap.c
drivers/video/tegra/host/Makefile
While setup, there is a time the serial port is running on a
predefined speed (115200). When data arrived during this phase at
a lower baudrate (e.g. 9600), a lot of overrun and break error
messages were shown. Due to those messages, the terminal setup
never finished, and thus never reached the selected baudrate (e.g.
9600). By choosing a lower baudrate at the startup (9600), a lot
less (if any at all) messages are shown and those initialization
always succeeds.
Another solution would be to disable those messages completely.
However, while normal mode its good to have those UART error
messages.
Hack to avoid 24 Hz mode in X resulting in no display at all. This has
been encountered using e.g. a Samsung SyncMaster F2380 if connected by
HDMI.
root@colibri-t20:~# xrandr
Screen 0: minimum 256 x 128, current 1920 x 1080, maximum 2048 x 2048
LVDS-1 connected 1920x1080+0+0 (normal left inverted right x axis y
axis) 0mm x 0mm
1920x1080 60.0*+
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y
axis) 160mm x 90mm
1920x1080 60.0 + 24.0*
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
1024x768 75.0 70.1 60.0
832x624 74.6
800x600 72.2 75.0 60.3 56.2
720x576 50.0
720x480 59.9
640x480 75.0 72.8 66.7 59.9
720x400 70.1
This is really just enabling the same hack from Apalis/Colibri T30
which is now relevant on the Colibri T20 as well due to the modedb
changes:
3a6fc5303b9e798295caa01d2cfe75b05fdccf55
Before updating modes on HDMI hotplug, check if framebuffer is
registered at all. This allows to disable framebuffers completely.
Use platform independent description for requested GPIOs.
Activate Fusion touchscreen driver. Use GPIO 5/6 as pen down/reset
GPIO and provide a helper function to free the GPIO before the
driver requests them.
Fusion touchscreen driver now uses platform data to do GPIO
initialization by itself. Make use of this by providing GPIO numbers
instead of doing initialization in the board initialization.
Fix chip reset by sleeping long enought after reset. Do proper error
handling (free GPIO on failure). Use dev_* for message logging to get
similar messages for all fusion driver related errors and warnings.
To avoid warnings use the new I2C power management function for
suspend and resume.
Added platform data struct to define interrupt and reset GPIO. This
allows to initialize the touchscreen controller inside the driver
rather then in each platform and use the driver as a module.
When the next interrupt request apeares between the confirmation of
the previous (a write via I2C, fusion_F0710A_write_complete) and
the reenable of the GPIO interrupt, the driver hangs and no more
touch inputs are reported.
This patch moves the confirmation after the reenabling of the GPIO
interrupt.
Recent evdev X-Server input driver implementation complain when
only multitouch axes have been reported ("found only multitouch-axes.
That shouldn't happen."). Therefor also report the primary touch
detection with default axis.
Allow to change clock polarity for RGB display output using the
keywords outputen/pixclockpol/vsync and hsync. Add them right
after the driver specification, use 0/1 to specifiy high/low
polarity, e.g. video=tegrafb0:pixclockpol:1,800x480
Remove special clocks for Tegra 2, but use backup clock source
instead. This allows to run all common used resolution within
the drivers -1/+9% allowed band for pixelclock exactness.
Add some more modes e.g. for full HD panel.
Also add tweaked pixel clock for Tegra 2 because the clock is always
a child of the peripherial clock and only some divisors are available.
HDMI.
root@apalis-t30:~# xrandr
axis) 0mm x 0mm
1920x1080 58.6*+
axis) 160mm x 90mm
1920x1080 60.0*+
1680x1050 59.9
1280x1024 75.0 60.0
1440x900 75.0 59.9
1280x960 60.0
1280x800 59.9
1152x864 75.0
1280x720 60.0 50.0
832x624 74.6
720x576 50.0
720x480 59.9
720x400 70.1
This is basically a revamp of the following commit which got scrapped
by the modedb changes:
8174d21e5fe0d086cb5824161c58eb065f412281
When grepping through sysfs, grep tries to read all sysfs files
which are available. Some of them lead to error due to null pointers.
Therefor check for null pointers before using them.
Remove TEGRA_FB_VGA defines and use VGA as default. Since initial
mode is now configureable through kernel cmd line parameter, we
don't need those compile time helpers.
Updated several comments to make code easier to read and understand.
Also use the front_porch workaround in any case, for HDMI output
too.
Use modedb to set mode on framebuffer/display controller for
Tegra 20 based module Colibri T20 too.
In order to find a viable resolution we not only parse VESA mode,
we also parse CEA (multimedia) modes and our own small modedb (for
specific touch screens).
