Partly a case of removing unused headers and partly a case
of ifdefing out the iio_trigger_ops structures. This has
come about because of an 'unusual' separation of code in this
driver.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Denis Ciocca <denis.ciocca@st.com>
Also include a couple of forward defs of struct iio_trigger and struct
iio_trigger_ops to avoid doing this in each driver.
Use the new spi_sync_transfer() helper function instead of open-coding it.
Quite often the pattern used for setting up and transferring a synchronous SPI
transaction looks very much like the following:
struct spi_message msg;
struct spi_transfer xfers[] = {
spi_message_init(&msg);
spi_message_add_tail(&xfers[0], &msg);
spi_message_add_tail(&xfers[ARRAY_SIZE(xfers) - 1], &msg);
ret = spi_sync(&msg);
This patch adds two new helper functions for handling this case. The first
helper function spi_message_init_with_transfers() takes a spi_message and an
array of spi_transfers. It will initialize the message and then call
spi_message_add_tail() for each transfer in the array. E.g. the following
can be rewritten as
spi_message_init_with_transfers(&msg, xfers, ARRAY_SIZE(xfers));
The second function spi_sync_transfer() takes a SPI device and an array of
spi_transfers. It will allocate a new spi_message (on the stack) and add all
transfers in the array to the message. Finally it will call spi_sync() on the
message.
E.g. the follwing
ret = spi_sync(spi, &msg);
can be rewritten as
ret = spi_sync_transfer(spi, xfers, ARRAY_SIZE(xfers));
A coccinelle script to find such instances will follow.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The following warning is generated by sparse:
drivers/staging/iio/adc/mxs-lradc.c:118:47: warning: duplicate const
Remove the duplicate const.
disabled.
This patch resolve a bugfix when driver is compiled without trigger.
Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
For iio_channel_get to work with OF based configurations, it needs the
consumer device pointer instead of the consumer device name as argument.
Acked-by: Anton Vorontsov <anton@enomsg.org>
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Implement external reference voltage as regulator named "vref".
Use pcmcia_request_irq() instead of request_irq() to request the
shared irq for the PCMCIA device. This allows the PCMCIA core to
clean up the registration in pcmcia_disable_device().
Cc: Ian Abbott <abbotti@mev.co.uk>
Use the comedi_pcmcia_{enable,disable} helpers to enable/disable
the PCMCIA device.
This driver uses a local (*conf_check) to check the pcmcia_device
configuration.
Allow comedi pcmcia drivers to use a custom conf_check() when calling
comedi_pcmcia_enable() to enable the pcmcia device. If a conf_check()
is not passed the internal comedi_pcmcia_conf_check() will be used.
the PCMCIA device.
This driver is not an audio device, remove CONF_AUTO_AUDIO from
the link->config_flags.
the PCMCIA device.
This driver does not use interrupts and is not an audio device, remove
CONF_ENABLE_IRQ and CONF_AUTO_AUDIO from the link->config_flags.
In comedi drivers typically *_attach_common() is used as the 'common'
part of the comedi_driver attach code for drivers that support various
bus types (ISA, PCI, etc.). This driver is specific to a USB device.
To avoid confusion when grepping, rename this function to something
more appropriate.
git history provides a better Changelog for the driver.
The vmk8055_range table is a duplicate of the comedi core provided
range_unipolar5 table. Use that instead.
For aesthetic reasons, clean up the formating of the vmk8061_range
table.
If CONFIG_COMEDI_DEBUG is defined a macro is enabled to output some
printk(KERN_REBUG ...) messages. These are just added noise. Remove
it.
This define is no longer used by the driver. Remove it.
The comedi core can use the (*insn_bits) function to emulate the
(*insn_read) function. Remove the unnecessary (*insn_read) function.
(*insn_write) function. Remove the unnecessary (*insn_read)
function.
The digital output (*insn_bits) function properly handles the
VMK8061_MODEL to read the digital output states before returning.
Remove the unnecessary (*insn_read) function. It's also not
necessary to set the SDF_READABLE flag so remove the entire
conditional in the attach.
Change the 'pwm_bits' in the boardinfo to 'pwm_maxdata' so that the
calculation of s->maxdata can be removed. Also, change the type to
match the comedi_subdevice type. For aesthetic reasons, rename the
'pwm_chans' boardinfo and change its type also.
Remove the '0' values in the boardinfo.
Rename the (*insn_read) and (*insn_write) functions for the pwm
subdevice to make grepping easier.
For aesthetic reasons, add some whitespace to the subdevice init.
Change the 'cnt_bits' in the boardinfo to 'cnt_maxdata' so that the
match the comedi_subdevice type. Add a comment about the '0' value
for DEVICE_VMK8061.
The s->maxdata should always be set for the subdevice. Move it out
of the conditional.
Rename the (*insn_read), (*insn_config_, and (*insn_write) functions
for the counter subdevice to make grepping easier.
Remove the SDF_GROUND flag from s->subdev_flags. This flag only has
meaning for analog subdevices.
Add the missing s->range_table for the subdevice.
Rename the (*insn_write), (*insn_bits), and (*insn_read) functions
for the digital input subdevice to make grepping easier.
Change the type for the digital input 'di_chans' boardinfo to match
the comedi_subdevice type it is set to. For aesthetic reasons, rename
the variable also.
Rename the (*insn_read) and (*insn_bits) functions for the digital
Change the type for the analog output 'ao_chans' boardinfo to match
the variable also.
Rename the (*insn_write) and (*insn_read) functions for the analog
output subdevice to make grepping easier.
Change the 'ai_bits' in the boardinfo to 'ai_maxdata' so that the
Change the types for the analog input boardinfo to match the
comedi_subdevice types they are set to.
Rename the (*insn_read) function for the analog input subdevice from
vmk80xx_ai_rinsn to vmk80xx_ai_insn_read to make grepping easier.
The only information in the boardinfo that is used outside of the
attach of the driver is the 'model' of the device.
Remove the 'board' pointer from the private data and replace it with
the 'model' enum and just copy that information over during the attach.
Make the usb_driver (*probe) simply call comedi_usb_auto_config()
and move all the (*probe) code into the (*auto_attach) function.
This allows getting rid of the static private data array since we
no longer do part of the initialization in the (*probe) and then
finish it in the (*auto_attach). We can simply kzalloc the private
data instead. The comedi core will then handle the kfree of the
data when the driver is detached.
We can also get rid of the static 'glb_mutex' since this mutex was
only used to protect the static private data array.
Change the parameters for a couple of the helper functions used
during the auto attach. Now that the comedi_device is available
we can simply pass that pointer and get the specific pointers
needed by the helper functions from it.
Allow the comedi usb drivers to pass a 'context' from their (*probe)
functions to the comedi core's comedi_usb_auto_config(). This 'context'
is then passed to comedi_auto_config() and then to the comedi_driver's
(*auto_attach).
The 'attached' flag in the private data is set after the comedi_driver
(*auto_attach) function has completed successfully.
The only places it's checked are in rudimentary_check(), which does
some basic sanity checks before doing any of the subdevice operations,
and vmk80xx_auto_attach(), which is the comedi_driver (*auto_attach)
function.
The (*auto_attach) function can only be called as the result of a
successfull usb_driver (*probe). Part of the probe is to locate a
free slot in the static private data array. All free slots are
initialized to '0' so the 'attached' flag will always be cleared.
Remove the unneccessary 'attached' flag in the private data.
The 'probed' variable is used in the usb driver (*probe) to detect an
unused element in the static private data arry. This variable is then
set after the usb driver has completed its (*probe) before calling
comedi_usb_auto_config(). When the comedi core does the auto config
it will call the (*auto_attach) function, vmk80xx_auto_attach(), which
then locates the correct private data in the static array by checking
to see if it has been 'probed' and that the 'intf' variable matches
the usb_interface pointer for the usb device.
Now that the private data is clean after failed usb probes and disconnects
we don't have to worry about have a garbage 'intf' value in the private
data that might match.
Remove the 'probed' flag from the private data and just use the 'intf'
pointer to detect the match.
Currently the private data used in this driver is stored in a static
array. During the usb (*probe) and empty location is found in this
array for use by the usb device. Some initialization of the private
data is then done before comedi_usb_auto_config() is called to allow
the comedi core to attach its comedi_device to the usb device.
The (*probe) can fail for various reasons. If it does, make sure that
the private data is clean before returning an error.
The usb (*disconnect) simply calls comedi_usb_auto_unconfig() to
allow the comedi core to disconnect its comedi_device from the usb
device. Since the private data points to the static array it cannot
be kfree'ed during the detach. Instead make sure it clean before
leaving the detach.
The 'count' in the private data is only used in a couple dev_info()
kernel messages. These messages are just added noise.
Remove the 'count' variable in the private data as well as the
dev_info() messages.
Factor the code that allocates the usb buffers out of vmk80xx_usb_probe().
Factor the code that detects the usb endpoints out of vmk80xx_usb_probe().
Cleanup the detection code in the new function,
Rename some of the local variables used in this driver to make the
code easier to maintain and understand.
s/udev/usb the usb_device that the comedi_driver is attached to
s/dev/devpriv the private data of the comedi_device
s/cdev/dev the comedi_device
Also, use some local variables in a couple of the functions to tidy
up the code a bit.
The struct vmk80xx_usb is actually the private data for the
comedi_device. For aesthetic reasons, rename the struct to
vmk80xx_private.
These enum values are only used in the initialization of the
comedi_subdevices. They don't help make the code any clearer
so just remove them.
Some of the information in the boardinfo is common for both boards
supported by this driver. Remove that information from the boardinfo
and just initialize the subdevice values directly.
Also, remove any information in the boardinfo that is not used in
the driver.
Save a copy of the boardinfo pointer in the comedi_device 'board_ptr'.
The subdevice functions can then simply get it using the comedi_board()
helper.
The normal way of presenting the board specific information in comedi
drivers is store the data in a static const array. This data is then
accessed using a pointer, normally the comedi_device 'board_ptr',
Move the boardinfo for the two boards supported by this driver from
the vmk80xx_usb_probe() function into a static const array.
Change the access of this information so a pointer is used.
The usb_driver (*disconnect) in this driver is simply a wrapper around
comedi_auto_unconfig(). Just use comedi_auto_unconfig() directly for
the (*disconnect).
The usb_driver (*disconnect) in this driver calls the comedi core
comedi_usb_auto_unconfig() which calls the comedi_driver (*detach).
Move the code in the (*disconnect) to the (*detach) to get all the
disconnect/detach in one place.
This comedi USB driver supports attaching with the auto config
mechanism. Remove the manual attaching support using the
COMEDI_DEVCONFIG ioctl.
Lockdep complains about recursive deadlock of zram->init_lock.
[1] made it false positive because we can't request IO to zram
before setting disksize. Anyway, we should shut lockdep up to
avoid many reporting from user.
[1] : zram: force disksize setting before using zram
Acked-by: Jerome Marchand <jmarchan@redhat.com>
Acked-by: Nitin Gupta <ngupta@vflare.org>
Signed-off-by: Minchan Kim <minchan@kernel.org>
kbuild bot whinges due to print format mistmatch caused by
zram: force disksize setting before using zram.
This patch fixes it.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
