* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: authenc - Add EINPROGRESS check
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon: Fix sparc regression in r300_scratch()
drm: make sure vblank interrupts are disabled at DPMS time
drm/radeon/kms/evergreen: No EnableYUV table
drm/radeon: 9800 SE has only one quadpipe
drm/radeon/kms: don't print error for legal crtcs.
drm/radeon/kms/evergreen: fix LUT setup
Commit b4fe945405e477cded91772b4fec854705443dd5 ("drm/radeon: Fix
memory allocation failures in the preKMS command stream checking.")
added a regression in that it completely tossed the get_unaligned()
done by r300_scratch() which we added in commit
958a6f8ccb1964adc3eec84cf401c5baeb4fbca0 ("drm: radeon: Fix unaligned
access in r300_scratch().").
Put it back.
Acked-by: Matt Turner <mattst88@gmail.com>
When we call drm_vblank_off() at DPMS off time (to wake any clients so
they don't hang) we need to make sure interrupts are actually disabled.
If drm_vblank_off() gets called before the vblank usage timer expires,
it'll prevent the timer from disabling interrupts since it also clears
the vblank_enabled flag for the pipe.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
When Steffen originally wrote the authenc async hash patch, he
correctly had EINPROGRESS checks in place so that we did not invoke
the original completion handler with it.
Unfortuantely I told him to remove it before the patch was applied.
As only MAY_BACKLOG request completion handlers are required to
handle EINPROGRESS completions, those checks are really needed.
This patch restores them.
Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
ipv6: Fix inet6_csk_bind_conflict()
e100: Fix the TX workqueue race
Commit fda48a0d7a84 (tcp: bind() fix when many ports are bound)
introduced a bug on IPV6 part.
We should not call ipv6_addr_any(inet6_rcv_saddr(sk2)) but
ipv6_addr_any(inet6_rcv_saddr(sk)) because sk2 can be IPV4, while sk is
IPV6.
Reported-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Michael S. Tsirkin <mst@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Issue the discard operation *before* releasing the blocks to be reused
ext4: Fix buffer head leaks after calls to ext4_get_inode_loc()
ext4: Fix possible lost inode write in no journal mode
Nothing stops the workqueue being left to run in parallel with close or a
few other operations. This causes double unmaps and the like.
See kerneloops.org #1041230 for an example
Signed-off-by: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] use max load in conservative governor
[CPUFREQ] fix a lockdep warning
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits)
gianfar: Fix potential oops during OF address translation
fsl_pq_mdio: Fix kernel oops during OF address translation
rdma: potential ERR_PTR dereference
rtnetlink: potential ERR_PTR dereference
net: ipv6 bind to device issue
ipv6: allow to send packet after receiving ICMPv6 Too Big message with MTU field less than IPV6_MIN_MTU
drivers/net/usb: Add new driver ipheth
cxgb3: fix linkup issue
X25 fix dead unaccepted sockets
KS8851: NULL pointer dereference if list is empty
net: 3c574_cs fix stats.tx_bytes counter
xfrm6: ensure to use the same dev when building a bundle
can: Fix possible NULL pointer dereference in ems_usb.c
net: Fix an RCU warning in dev_pick_tx()
ipv6: Fix tcp_v6_send_response transport header setting.
bridge: add a missing ntohs()
8139too: Fix a typo in the function name.
mac80211: pass HT changes to driver when off channel
mac80211: remove bogus TX agg state assignment
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: Ensure we re-enable devices on resume
x86/PCI: parse additional host bridge window resource types
PCI: revert broken device warning
PCI aerdrv: use correct bit defines and add 2ms delay to aer_root_reset
x86/PCI: ignore Consumer/Producer bit in ACPI window descriptions
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86:
eeepc-laptop: add missing sparse_keymap_free
eeepc-wmi: Build fix
asus: don't modify bluetooth/wlan on boot
dell-wmi: Fix memory leak
eeepc-wmi: add backlight support
eeepc-wmi: use a platform device as parent device of all sub-devices
eeepc-wmi: add an eeepc_wmi context structure
The unpack routine fails to handle the decompress_method() returning
unrecognised decompressor (compress_name == NULL). This results in the
routine looping eventually oopsing on an out of bounds memory access.
Note this bug is usually hidden, only triggering on trailing junk after
one or more correct compressed blocks. The case of the compressed archive
being complete junk is (by accident?) caught by the if (state != Reset)
check because state is initialised to Start, but not updated due to the
decompressor not having been called. Obviously if the junk is trailing a
correctly decompressed buffer, state == Reset from the previous call to
the decompressor.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
The follow_page() function can potentially return -EFAULT so I added
checks for this.
Also I silenced an uninitialized variable warning on my version of gcc
(version 4.3.2).
Acked-by: Izik Eidus <ieidus@redhat.com>
This is a standalone version of VMware Balloon driver. Ballooning is a
technique that allows hypervisor dynamically limit the amount of memory
available to the guest (with guest cooperation). In the overcommit
scenario, when hypervisor set detects that it needs to shuffle some
memory, it instructs the driver to allocate certain number of pages, and
the underlying memory gets returned to the hypervisor. Later hypervisor
may return memory to the guest by reattaching memory to the pageframes and
instructing the driver to "deflate" balloon.
We are submitting a standalone driver because KVM maintainer (Avi Kivity)
expressed opinion (rightly) that our transport does not fit well into
virtqueue paradigm and thus it does not make much sense to integrate with
virtio.
There were also some concerns whether current ballooning technique is the
right thing. If there appears a better framework to achieve this we are
prepared to evaluate and switch to using it, but in the meantime we'd like
to get this driver upstream.
We want to get the driver accepted in distributions so that users do not
have to deal with an out-of-tree module and many distributions have
"upstream first" requirement.
The driver has been shipping for a number of years and users running on
VMware platform will have it installed as part of VMware Tools even if it
will not come from a distribution, thus there should not be additional
risk in pulling the driver into mainline. The driver will only activate
if host is VMware so everyone else should not be affected at all.
Signed-off-by: Dmitry Torokhov <dtor@vmware.com>
Cc: Avi Kivity <avi@redhat.com>
block devices
We are seeing a large regression in database performance on recent
kernels. The database opens a block device with O_DIRECT|O_SYNC and a
number of threads write to different regions of the file at the same time.
A simple test case is below. I haven't defined DEVICE since getting it
wrong will destroy your data :) On an 3 disk LVM with a 64k chunk size we
see about 17MB/sec and only a few threads in IO wait:
procs -----io---- -system-- -----cpu------
r b bi bo in cs us sy id wa st
0 3 0 16170 656 2259 0 0 86 14 0
0 2 0 16704 695 2408 0 0 92 8 0
0 2 0 17308 744 2653 0 0 86 14 0
0 2 0 17933 759 2777 0 0 89 10 0
Most threads are blocking in vfs_fsync_range, which has:
mutex_lock(&mapping->host->i_mutex);
err = fop->fsync(file, dentry, datasync);
if (!ret)
ret = err;
mutex_unlock(&mapping->host->i_mutex);
commit 148f948ba877f4d3cdef036b1ff6d9f68986706a (vfs: Introduce new
helpers for syncing after writing to O_SYNC file or IS_SYNC inode) offers
some explanation of what is going on:
Use these new helpers for syncing from generic VFS functions. This makes
O_SYNC writes to block devices acquire i_mutex for syncing. If we really
care about this, we can make block_fsync() drop the i_mutex and reacquire
it before it returns.
Thanks Jan for such a good commit message! As well as dropping i_mutex,
Christoph suggests we should remove the call to sync_blockdev():
> sync_blockdev is an overcomplicated alias for filemap_write_and_wait on
> the block device inode, which is exactly what we did just before calling
> into ->fsync
The patch below incorporates both suggestions. With it the testcase improves
from 17MB/s to 68M/sec:
0 7 0 65536 1000 3878 0 0 70 30 0
0 34 0 69632 1016 3921 0 1 46 53 0
0 57 0 69632 1000 3921 0 0 55 45 0
0 53 0 69640 754 4111 0 0 81 19 0
Testcase:
#define _GNU_SOURCE
#include <stdio.h>
#include <pthread.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#define NR_THREADS 64
#define BUFSIZE (64 * 1024)
#define DEVICE "/dev/mapper/XXXXXX"
#define ALIGN(VAL, SIZE) (((VAL)+(SIZE)-1) & ~((SIZE)-1))
static int fd;
static void *doit(void *arg)
unsigned long offset = (long)arg;
char *b, *buf;
b = malloc(BUFSIZE + 1024);
buf = (char *)ALIGN((unsigned long)b, 1024);
memset(buf, 0, BUFSIZE);
while (1)
pwrite(fd, buf, BUFSIZE, offset);
int main(int argc, char *argv[])
int flags = O_RDWR|O_DIRECT;
int i;
unsigned long offset = 0;
if (argc > 1 && !strcmp(argv[1], "O_SYNC"))
flags |= O_SYNC;
fd = open(DEVICE, flags);
if (fd == -1) {
perror("open");
exit(1);
for (i = 0; i < NR_THREADS-1; i++) {
pthread_t tid;
pthread_create(&tid, NULL, doit, (void *)offset);
offset += BUFSIZE;
doit((void *)offset);
return 0;
Acked-by: Jan Kara <jack@suse.cz>
Cc: Jens Axboe <jens.axboe@oracle.com>
Add a missing EXPORT_SYMBOL.
I must be the first person that wants to use this function :-)
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Fixes the following error:
drivers/w1/masters/omap_hdq.c: In function 'hdq_wait_for_flag':
drivers/w1/masters/omap_hdq.c:137: error: implicit declaration of function 'schedule_timeout_uninterruptible'
drivers/w1/masters/omap_hdq.c: In function 'hdq_write_byte':
drivers/w1/masters/omap_hdq.c:177: error: 'TASK_UNINTERRUPTIBLE' undeclared (first use in this function)
drivers/w1/masters/omap_hdq.c:177: error: (Each undeclared identifier is reported only once
drivers/w1/masters/omap_hdq.c:177: error: for each function it appears in.)
drivers/w1/masters/omap_hdq.c:177: error: implicit declaration of function 'schedule_timeout'
drivers/w1/masters/omap_hdq.c: In function 'hdq_isr':
drivers/w1/masters/omap_hdq.c:221: error: 'TASK_NORMAL' undeclared (first use in this function)
drivers/w1/masters/omap_hdq.c: In function 'omap_hdq_break':
drivers/w1/masters/omap_hdq.c:316: error: 'TASK_UNINTERRUPTIBLE' undeclared (first use in this function)
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
If find_mergeable_anon_vma() succeeds but another thread installs
->anon_vma before we take ptl, then allocated == NULL but avc should be
freed. Change the code to check avc != NULL to detect this case.
Also, a couple of whitespace changes to make the critical section more
visible.
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Fix the following RCU warning:
[ INFO: suspicious rcu_dereference_check() usage. ]
security/keys/request_key.c:116 invoked rcu_dereference_check() without protection!
This was caused by doing:
[root@andromeda ~]# keyctl newring fred @s
539196288
[root@andromeda ~]# keyctl request2 user a a 539196288
request_key: Required key not available
This patch fixes 2 issues with the LZO decompressor:
- It doesn't handle the case where a block isn't compressed at all. In
this case, calling lzo1x_decompress_safe will fail, so we need to just
use memcpy() instead (the upstream LZO code does something similar)
- Since commit 54291362d2a5738e1b0495df2abcb9e6b0563a3f ("initramfs: add
missing decompressor error check") , the decompressor return code is
checked in the init/initramfs.c The LZO decompressor didn't return the
expected value, causing the initramfs code to falsely believe a
decompression error occured
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Tested-by: bert schulze <spambemyguest@googlemail.com>
If a futex key happens to be located within a huge page mapped
MAP_PRIVATE, get_futex_key() can go into an infinite loop waiting for a
page->mapping that will never exist.
See https://bugzilla.redhat.com/show_bug.cgi?id=552257 for more details
about the problem.
This patch makes page->mapping a poisoned value that includes
PAGE_MAPPING_ANON mapped MAP_PRIVATE. This is enough for futex to
continue but because of PAGE_MAPPING_ANON, the poisoned value is not
dereferenced or used by futex. No other part of the VM should be
dereferencing the page->mapping of a hugetlbfs page as its page cache is
not on the LRU.
This patch fixes the problem with the test case described in the bugzilla.
[akpm@linux-foundation.org: mel cant spel]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Darren Hart <darren@dvhart.com>
Cc: <stable@kernel.org>
Fix regression caused by commit 507e2fbaaacb6f164b4125b87c5002f95143174b
("w1: w1 temp calculation overflow fix") whereby negative temperatures for
the DS18B20 are not converted properly.
When the temperature exceeds 32767 milli-degrees the temperature overflows
to -32768 millidegrees. These are both well within the -55 - +125 degree
range for the sensor.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=12646
Signed-of-by: Ian Dall <ian@beware.dropbear.id.au>
Tested-by: Karsten Elfenbein <kelfe@gmx.de>
Writing to cgroup.procs is not supported now.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Ben Blum <bblum@andrew.cmu.edu>
Cc: Paul Menage <menage@google.com>
Description of patch:
This is a patch for the EFI framebuffer driver to enable the framebuffer
of the NVIDIA 9400M as found in MacBook Pro (MBP) 5,1 and up. The
framebuffer of the NVIDIA graphic cards are located at the following
addresses in memory:
9400M: 0xC0010000
9600M GT: 0xB0030000
The patch delivered right here only provides the memory location of the
framebuffer of the 9400M device. The 9600M GT is not covered. It is
assumed that the 9400M is used when powered up the MBP.
The information which device is currently powered and in use is stored in
the 64 bytes large EFI variable "gpu-power-prefs". More specifically,
byte 0x3B indicates whether 9600M GT (0x00) or 9400M (0x01) is online.
The PCI bus IDs are the following:
9400M: PCI 03:00:00
9600M GT: PCI 02:00:00
The EFI variables can be easily read-out and manipulated with "rEFIt", an
MBP specific bootloader tool. For more information on how handle rEFIt
and EFI variables please consult "http://refit.sourceforge.net" and
"http://ubuntuforums.org/archive/index.php/t-1076879.html".
IMPORTANT NOTE: The information on how to activate the 9400M device given
at "ubuntuforums.org" is not correct, since it states
gpu-power-prefs[0x3B] = 0x00 -> 9400M (PCI 02:00:00)
gpu-power-prefs[0x3B] = 0x01 -> 9600M GT (PCI 03:00:00)
Actually, the assignment of the values and the PCI bus IDs are swapped.
Suggestions:
To cover framebuffers of both 9400M and 9600M GT, I would suggest to
implement a conditional on "gpu-power-prefs". Depending on the value of
byte 0x3B, the according framebuffer is selected. However, this requires
kernel access to the EFI variables.
[akpm@linux-foundation.org: rename optname, per Peter Jones]
Signed-off-by: Thomas Gerlach <t.m.gerlach@freenet.de>
Acked-by: Peter Jones <pjones@redhat.com>
Correct axis-mappings for new HP ProBook laptops.
Acked-by: Eric Piel <eric.piel@tremplin-utc.net>
We must tell GCC to use even register for variable passed to ldrd
instruction. Without this patch GCC 4.2.1 puts this variable to r2/r3 on
EABI and r3/r4 on OABI, so force it to r2/r3. This does not change
anything when EABI and OABI compilation works OK.
Without this patch and with OABI I get:
CC drivers/mtd/nand/orion_nand.o
/tmp/ccMkwOCs.s: Assembler messages:
/tmp/ccMkwOCs.s:63: Error: first destination register must be even -- `ldrd r3,[ip]'
make[5]: *** [drivers/mtd/nand/orion_nand.o] Error 1
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com>
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Acked-by: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Jamie Lokier <jamie@shareable.org>
memset() is called with the wrong address and the kernel panics.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Cc: Patrick McHardy <kaber@trash.net>
Acked-by: David Rientjes <rientjes@google.com>
On ppc64 you get this error:
$ setarch ppc -R true
setarch: ppc: Unrecognized architecture
because uname still reports ppc64 as the machine.
So mask off the personality flags when checking for PER_LINUX32.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Commit 48b32a3553a54740d236b79a90f20147a25875e3 ("reiserfs: use generic
xattr handlers") introduced a problem that causes corruption when extended
attributes are replaced with a smaller value.
The issue is that the reiserfs_setattr to shrink the xattr file was moved
from before the write to after the write.
The root issue has always been in the reiserfs xattr code, but was papered
over by the fact that in the shrink case, the file would just be expanded
again while the xattr was written.
The end result is that the last 8 bytes of xattr data are lost.
This patch fixes it to use new_size.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=14826
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reported-by: Christian Kujau <lists@nerdbynature.de>
Tested-by: Christian Kujau <lists@nerdbynature.de>
Cc: Edward Shishkin <edward.shishkin@gmail.com>
Cc: Jethro Beekman <kernel@jbeekman.nl>
Cc: Greg Surbey <gregsurbey@hotmail.com>
Cc: Marco Gatti <marco.gatti@gmail.com>
If a signal is pending (task being killed by sigkill)
__mem_cgroup_try_charge will write NULL into &mem, and css_put will oops
on null pointer dereference.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff810fc6cc>] mem_cgroup_prepare_migration+0x7c/0xc0
PGD a5d89067 PUD a5d8a067 PMD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/platform/microcode/firmware/microcode/loading
CPU 0
Modules linked in: nfs lockd nfs_acl auth_rpcgss sunrpc acpi_cpufreq pcspkr sg [last unloaded: microcode]
Pid: 5299, comm: largepages Tainted: G W 2.6.34-rc3 #3 Penryn1600SLI-110dB/To Be Filled By O.E.M.
RIP: 0010:[<ffffffff810fc6cc>] [<ffffffff810fc6cc>] mem_cgroup_prepare_migration+0x7c/0xc0
[nishimura@mxp.nes.nec.co.jp: fix merge issues]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Commit 677c9b2e393a0cd203bd54e9c18b012b2c73305a ("reiserfs: remove
privroot hiding in lookup") removed the magic from the lookup code to hide
the .reiserfs_priv directory since it was getting loaded at mount-time
instead. The intent was that the entry would be hidden from the user via
a poisoned d_compare, but this was faulty.
This introduced a security issue where unprivileged users could access and
modify extended attributes or ACLs belonging to other users, including
root.
This patch resolves the issue by properly hiding .reiserfs_priv. This was
the intent of the xattr poisoning code, but it appears to have never
worked as expected. This is fixed by using d_revalidate instead of
d_compare.
This patch makes -oexpose_privroot a no-op. I'm fine leaving it this way.
The effort involved in working out the corner cases wrt permissions and
caching outweigh the benefit of the feature.
Acked-by: Edward Shishkin <edward.shishkin@gmail.com>
Reported-by: Matt McCutchen <matt@mattmccutchen.net>
Tested-by: Matt McCutchen <matt@mattmccutchen.net>
gianfar driver may pass NULL pointer to the of_translate_address(),
which may lead to a kernel oops. Fix this by using of_iomap(), which
is also much simpler and shorter.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
Old P1020RDB device trees were not specifing tbipa address for
MDIO nodes, which is now causing this kernel oops:
eth2: TX BD ring size for Q[6]: 256
eth2: TX BD ring size for Q[7]: 256
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xc0015504
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c0015504] memcpy+0x3c/0x9c
LR [c000a9f8] __of_translate_address+0xfc/0x21c
Call Trace:
[df839e00] [c000a94c] __of_translate_address+0x50/0x21c (unreliable)
[df839e50] [c01a33e8] get_gfar_tbipa+0xb0/0xe0
The old device trees are buggy, though having a dead ethernet is
better than a dead kernel, so fix the issue by using of_iomap().
Also, a somewhat similar issue exist in the probe() routine, though
there the oops is only a possibility. Nonetheless, fix it too.
Also remove legacy keymap which was not used since
we use sparse_keymap.
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda: Use STAC_DELL_M6_BOTH quirk for Dell Studio 1558
ALSA: hda: Use LPIB quirk for DG965OT board version AAD63733-203
ALSA: snd-meastro3: Ignore spurious HV interrupts during suspend / resume
ALSA: snd-meastro3: Add amp_gpio quirk for Compaq EVO N600C
ALSA: hda: Use ALC880_F1734 quirk for Fujitsu Siemens AMILO Xi 1526
ALSA: hda: Use STAC_DELL_M6_BOTH quirk for Dell Studio XPS 1645
ALSA: hda - Fix resume from StR of HP 2510p with docking-station
This cleans up a few of the complaints of __generic_block_fiemap. I've
fixed all the typing stuff, used inline functions instead of macros,
gotten rid of a couple of variables, and made sure the size and block
requests are all block aligned. It also fixes a problem where sometimes
FIEMAP_EXTENT_LAST wasn't being set properly.
Signed-off-by: Josef Bacik <josef@redhat.com>
My PIPE_CONTROL fix (just sent via Eric's tree) was buggy; I was
testing a whole set of patches together and missed a conversion to the
new HAS_PIPE_CONTROL macro, which will cause breakage on non-Ironlake
965 class chips. Fortunately, the fix is trivial and has been tested.
Be sure to use the HAS_PIPE_CONTROL macro in i915_get_gem_seqno, or
we'll end up reading the wrong graphics memory, likely causing hangs,
crashes, or worse.
Reported-by: Zdenek Kabelac <zdenek.kabelac@gmail.com>
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
DCE4 cards don't have an EnableYUV table.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
BugLink: https://launchpad.net/bugs/568600
The OR has verified that the dell-m6 model quirk is necessary for audio
to be audible by default on the Dell Studio XPS 1645.
This change is necessary for 2.6.32.11 and 2.6.33.2 alike.
Reported-by: Andy Ross <andy@plausible.org>
Tested-by: Andy Ross <andy@plausible.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
BugLink: https://launchpad.net/bugs/459083
The OR has verified with 2.6.32.11 and the latest alsa-driver stable
daily snapshot that position_fix=1 is necessary for the external mic
to work and for PulseAudio not to crash constantly.
This patch is necessary also for 2.6.32.11 and 2.6.33.2.
Reported-by: <imwithid@yahoo.com>
Tested-by: <imwithid@yahoo.com>
Although these cards have 2 pipelines on the silicon only
the first passed the QA and the other should be disabled.
http://www.digital-daily.com/video/ati-radeon9800se/
http://www.rojakpot.com/showarticle.aspx?artno=101&pgno=1
agd5f: add some other SE cards as well; fix up kms
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
With evergreen this is bounded by num_crtc not by 0,1.
Must have gotten broken during an earlier rebase.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: ensure NCQ error result taskfile is fully initialized before returning it via qc->result_tf.
libata: fix docs, RE port and device of libata.force ID separated by point
pata_pcmcia/ide-cs: add IDs for transcend and kingston cards
libata: fix locking around blk_abort_request()
Port autoselection done by kernel only works when number of bound
sockets is under a threshold (typically 30000).
When this threshold is over, we must check if there is a conflict before
exiting first loop in inet_csk_get_port()
Change inet_csk_bind_conflict() to forbid two reuse-enabled sockets to
bind on same (address,port) tuple (with a non ANY address)
Same change for inet6_csk_bind_conflict()
Reported-by: Gaspar Chilingarov <gasparch@gmail.com>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Cc: stable@kernel.org
