[ Upstream commit 9d53caec84c7c5700e7c1ed744ea584fff55f9ac ]
A large sun4v SPARC system may have moments of intensive xcall activities,
usually caused by unmapping many pages on many CPUs concurrently. This can
flood receivers with CPU mondo interrupts for an extended period, causing
some unlucky senders to hit send-mondo timeout. This problem gets worse
as cpu count increases because sometimes mappings must be invalidated on
all CPUs, and sometimes all CPUs may gang up on a single CPU.
But a busy system is not a broken system. In the above scenario, as long
as the receiver is making forward progress processing mondo interrupts,
the sender should continue to retry.
This patch implements the receiver's forward progress meter by introducing
a per cpu counter 'cpu_mondo_counter[cpu]' where 'cpu' is in the range
of 0..NR_CPUS. The receiver increments its counter as soon as it receives
a mondo and the sender tracks the receiver's counter. If the receiver has
stopped making forward progress when the retry limit is reached, the sender
declares send-mondo-timeout and panic; otherwise, the receiver is allowed
to keep making forward progress.
In addition, it's been observed that PCIe hotplug events generate Correctable
Errors that are handled by hypervisor and then OS. Hypervisor 'borrows'
a guest cpu strand briefly to provide the service. If the cpu strand is
simultaneously the only cpu targeted by a mondo, it may not be available
for the mondo in 20msec, causing SUN4V mondo timeout. It appears that 1 second
is the agreed wait time between hypervisor and guest OS, this patch makes
the adjustment.
Orabug: 25476541
Orabug: 26417466
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Steve Sistare <steven.sistare@oracle.com>
Reviewed-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Reviewed-by: Thomas Tai <thomas.tai@oracle.com>
[ Upstream commit dfa523ae9f2542bee4cddaea37b3be3e157f6e6b ]
Add a flag to indicate if a queue is rate-limited. Test the flag in
NAPI poll handler and avoid rescheduling the queue if true, otherwise
we risk locking up the host. The rescheduling will be done in the
timer callback function.
Reported-by: Jean-Louis Dupond <jean-louis@dupond.be>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Tested-by: Jean-Louis Dupond <jean-louis@dupond.be>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
[ Upstream commit 7b9a88a390dacb37b051a7b09b9a08f546edf5eb ]
The PHY library does not deal very well with bind and unbind events. The first
thing we would see is that we were not properly canceling the PHY state machine
workqueue, so we would be crashing while dereferencing phydev->drv since there
is no driver attached anymore.
Suggested-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 7ad813f208533cebfcc32d3d7474dc1677d1b09a ]
Marc reported that he was not getting the PHY library adjust_link()
callback function to run when calling phy_stop() + phy_disconnect()
which does not indeed happen because we set the state machine to
PHY_HALTED but we don't get to run it to process this state past that
point.
Fix this with a synchronous call to phy_state_machine() in order to have
the state machine actually act on PHY_HALTED, set the PHY device's link
down, turn the network device's carrier off and finally call the
adjust_link() function.
Reported-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Fixes: a390d1f379cf ("phylib: convert state_queue work to delayed_work")
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
[ Upstream commit 6b84202c946cd3da3a8daa92c682510e9ed80321 ]
Commit b1f5bfc27a19 ("sctp: don't dereference ptr before leaving
_sctp_walk_{params, errors}()") tried to fix the issue that it
may overstep the chunk end for _sctp_walk_{params, errors} with
'chunk_end > offset(length) + sizeof(length)'.
But it introduced a side effect: When processing INIT, it verifies
the chunks with 'param.v == chunk_end' after iterating all params
by sctp_walk_params(). With the check 'chunk_end > offset(length)
+ sizeof(length)', it would return when the last param is not yet
accessed. Because the last param usually is fwdtsn supported param
whose size is 4 and 'chunk_end == offset(length) + sizeof(length)'
This is a badly issue even causing sctp couldn't process 4-shakes.
Client would always get abort when connecting to server, due to
the failure of INIT chunk verification on server.
The patch is to use 'chunk_end <= offset(length) + sizeof(length)'
instead of 'chunk_end < offset(length) + sizeof(length)' for both
_sctp_walk_params and _sctp_walk_errors.
Fixes: b1f5bfc27a19 ("sctp: don't dereference ptr before leaving _sctp_walk_{params, errors}()")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit b1f5bfc27a19f214006b9b4db7b9126df2dfdf5a ]
If the length field of the iterator (|pos.p| or |err|) is past the end
of the chunk, we shouldn't access it.
This bug has been detected by KMSAN. For the following pair of system
calls:
socket(PF_INET6, SOCK_STREAM, 0x84 /* IPPROTO_??? */) = 3
sendto(3, "A", 1, MSG_OOB, {sa_family=AF_INET6, sin6_port=htons(0),
inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0,
sin6_scope_id=0}, 28) = 1
the tool has reported a use of uninitialized memory:
BUG: KMSAN: use of uninitialized memory in sctp_rcv+0x17b8/0x43b0
CPU: 1 PID: 2940 Comm: probe Not tainted 4.11.0-rc5+ #2926
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x172/0x1c0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:927
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:469
__sctp_rcv_init_lookup net/sctp/input.c:1074
__sctp_rcv_lookup_harder net/sctp/input.c:1233
__sctp_rcv_lookup net/sctp/input.c:1255
sctp_rcv+0x17b8/0x43b0 net/sctp/input.c:170
sctp6_rcv+0x32/0x70 net/sctp/ipv6.c:984
ip6_input_finish+0x82f/0x1ee0 net/ipv6/ip6_input.c:279
NF_HOOK ./include/linux/netfilter.h:257
ip6_input+0x239/0x290 net/ipv6/ip6_input.c:322
dst_input ./include/net/dst.h:492
ip6_rcv_finish net/ipv6/ip6_input.c:69
ipv6_rcv+0x1dbd/0x22e0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x2f6f/0x3a20 net/core/dev.c:4208
__netif_receive_skb net/core/dev.c:4246
process_backlog+0x667/0xba0 net/core/dev.c:4866
napi_poll net/core/dev.c:5268
net_rx_action+0xc95/0x1590 net/core/dev.c:5333
__do_softirq+0x485/0x942 kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902
</IRQ>
do_softirq kernel/softirq.c:328
__local_bh_enable_ip+0x25b/0x290 kernel/softirq.c:181
local_bh_enable+0x37/0x40 ./include/linux/bottom_half.h:31
rcu_read_unlock_bh ./include/linux/rcupdate.h:931
ip6_finish_output2+0x19b2/0x1cf0 net/ipv6/ip6_output.c:124
ip6_finish_output+0x764/0x970 net/ipv6/ip6_output.c:149
NF_HOOK_COND ./include/linux/netfilter.h:246
ip6_output+0x456/0x520 net/ipv6/ip6_output.c:163
dst_output ./include/net/dst.h:486
ip6_xmit+0x1841/0x1c00 net/ipv6/ip6_output.c:261
sctp_v6_xmit+0x3b7/0x470 net/sctp/ipv6.c:225
sctp_packet_transmit+0x38cb/0x3a20 net/sctp/output.c:632
sctp_outq_flush+0xeb3/0x46e0 net/sctp/outqueue.c:885
sctp_outq_uncork+0xb2/0xd0 net/sctp/outqueue.c:750
sctp_side_effects net/sctp/sm_sideeffect.c:1773
sctp_do_sm+0x6962/0x6ec0 net/sctp/sm_sideeffect.c:1147
sctp_primitive_ASSOCIATE+0x12c/0x160 net/sctp/primitive.c:88
sctp_sendmsg+0x43e5/0x4f90 net/sctp/socket.c:1954
inet_sendmsg+0x498/0x670 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633
sock_sendmsg net/socket.c:643
SYSC_sendto+0x608/0x710 net/socket.c:1696
SyS_sendto+0x8a/0xb0 net/socket.c:1664
do_syscall_64+0xe6/0x130 arch/x86/entry/common.c:285
entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246
RIP: 0033:0x401133
RSP: 002b:00007fff6d99cd38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000401133
RDX: 0000000000000001 RSI: 0000000000494088 RDI: 0000000000000003
RBP: 00007fff6d99cd90 R08: 00007fff6d99cd50 R09: 000000000000001c
R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000000
R13: 00000000004063d0 R14: 0000000000406460 R15: 0000000000000000
origin:
save_stack_trace+0x37/0x40 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:302
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:198
kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:211
slab_alloc_node mm/slub.c:2743
__kmalloc_node_track_caller+0x200/0x360 mm/slub.c:4351
__kmalloc_reserve net/core/skbuff.c:138
__alloc_skb+0x26b/0x840 net/core/skbuff.c:231
alloc_skb ./include/linux/skbuff.h:933
sctp_packet_transmit+0x31e/0x3a20 net/sctp/output.c:570
return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit e90ce2fc27cad7e7b1e72b9e66201a7a4c124c2b ]
In dccp_feat_init, when ccid_get_builtin_ccids failsto alloc
memory for rx.val, it should free tx.val before returning an
error.
[ Upstream commit b7953d3c0e30a5fc944f6b7bd0bcceb0794bcd85 ]
The patch "dccp: fix a memleak that dccp_ipv6 doesn't put reqsk
properly" fixed reqsk refcnt leak for dccp_ipv6. The same issue
exists on dccp_ipv4.
This patch is to fix it for dccp_ipv4.
[ Upstream commit c800aaf8d869f2b9b47b10c5c312fe19f0a94042 ]
There are multiple reports showing we have a use-after-free in
the timer prb_retire_rx_blk_timer_expired(), where we use struct
tpacket_kbdq_core::pkbdq, a pg_vec, after it gets freed by
free_pg_vec().
The interesting part is it is not freed via packet_release() but
via packet_setsockopt(), which means we are not closing the socket.
Looking into the big and fat function packet_set_ring(), this could
happen if we satisfy the following conditions:
1. closing == 0, not on packet_release() path
2. req->tp_block_nr == 0, we don't allocate a new pg_vec
3. rx_ring->pg_vec is already set as V3, which means we already called
packet_set_ring() wtih req->tp_block_nr > 0 previously
4. req->tp_frame_nr == 0, pass sanity check
5. po->mapped == 0, never called mmap()
In this scenario we are clearing the old rx_ring->pg_vec, so we need
to free this pg_vec, but we don't stop the timer on this path because
of closing==0.
The timer has to be stopped as long as we need to free pg_vec, therefore
the check on closing!=0 is wrong, we should check pg_vec!=NULL instead.
Thanks to liujian for testing different fixes.
Reported-by: alexander.levin@verizon.com
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: liujian (CE) <liujian56@huawei.com>
Tested-by: liujian (CE) <liujian56@huawei.com>
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: Willem de Bruijn <willemdebruijn.kernel@gmail.com>
[ Upstream commit 9476d393667968b4a02afbe9d35a3558482b943e ]
DMA transfers are not allowed to buffers that are on the stack.
Therefore allocate a buffer to store the result of usb_control_message().
Fixes these bugreports:
https://bugzilla.kernel.org/show_bug.cgi?id=195217
https://bugzilla.redhat.com/show_bug.cgi?id=1421387
https://bugzilla.redhat.com/show_bug.cgi?id=1427398
Shortened kernel backtrace from 4.11.9-200.fc25.x86_64:
kernel: ------------[ cut here ]------------
kernel: WARNING: CPU: 3 PID: 2957 at drivers/usb/core/hcd.c:1587
kernel: transfer buffer not dma capable
kernel: Call Trace:
kernel: dump_stack+0x63/0x86
kernel: __warn+0xcb/0xf0
kernel: warn_slowpath_fmt+0x5a/0x80
kernel: usb_hcd_map_urb_for_dma+0x37f/0x570
kernel: ? try_to_del_timer_sync+0x53/0x80
kernel: usb_hcd_submit_urb+0x34e/0xb90
kernel: ? schedule_timeout+0x17e/0x300
kernel: ? del_timer_sync+0x50/0x50
kernel: ? __slab_free+0xa9/0x300
kernel: usb_submit_urb+0x2f4/0x560
kernel: ? urb_destroy+0x24/0x30
kernel: usb_start_wait_urb+0x6e/0x170
kernel: usb_control_msg+0xdc/0x120
kernel: mcs_get_reg+0x36/0x40 [mcs7780]
kernel: mcs_net_open+0xb5/0x5c0 [mcs7780]
Regression goes back to 4.9, so it's a good candidate for -stable.
Though it's the decision of the maintainer.
Thanks to Dan Williams for adding the "transfer buffer not dma capable"
warning in the first place. It instantly pointed me in the right direction.
Patch has been tested with transferring data from a Polar watch.
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
[ Upstream commit 153711f9421be5dbc973dc57a4109dc9d54c89b1 ]
virtnet_set_mac_address() interprets mac address as struct
sockaddr, but upper layer only allocates dev->addr_len
which is ETH_ALEN + sizeof(sa_family_t) in this case.
We lack a unified definition for mac address, so just fix
the upper layer, this also allows drivers to interpret it
to struct sockaddr freely.
Reported-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 8799a221f5944a7d74516ecf46d58c28ec1d1f75 ]
Net stack initialization currently initializes fib-trie after the
first call to netdevice_notifier() call. In fact fib_trie initialization
needs to happen before first rtnl_register(). It does not cause any problem
since there are no devices UP at this moment, but trying to bring 'lo'
UP at initialization would make this assumption wrong and exposes the issue.
Fixes following crash
Call Trace:
? alternate_node_alloc+0x76/0xa0
fib_table_insert+0x1b7/0x4b0
fib_magic.isra.17+0xea/0x120
fib_add_ifaddr+0x7b/0x190
fib_netdev_event+0xc0/0x130
register_netdevice_notifier+0x1c1/0x1d0
ip_fib_init+0x72/0x85
ip_rt_init+0x187/0x1e9
ip_init+0xe/0x1a
inet_init+0x171/0x26c
? ipv4_offload_init+0x66/0x66
do_one_initcall+0x43/0x160
kernel_init_freeable+0x191/0x219
? rest_init+0x80/0x80
kernel_init+0xe/0x150
ret_from_fork+0x22/0x30
Code: f6 46 23 04 74 86 4c 89 f7 e8 ae 45 01 00 49 89 c7 4d 85 ff 0f 85 7b ff ff ff 31 db eb 08 4c 89 ff e8 16 47 01 00 48 8b 44 24 38 <45> 8b 6e 14 4d 63 76 74 48 89 04 24 0f 1f 44 00 00 48 83 c4 08
RIP: kmem_cache_alloc+0xcf/0x1c0 RSP: ffff9b1500017c28
CR2: 0000000000000014
Fixes: 7b1a74fdbb9e ("[NETNS]: Refactor fib initialization so it can handle multiple namespaces.")
Fixes: 7f9b80529b8a ("[IPV4]: fib hash|trie initialization")
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit 6399f1fae4ec29fab5ec76070435555e256ca3a6 ]
In some cases, offset can overflow and can cause an infinite loop in
ip6_find_1stfragopt(). Make it unsigned int to prevent the overflow, and
cap it at IPV6_MAXPLEN, since packets larger than that should be invalid.
This problem has been here since before the beginning of git history.
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 63679112c536289826fec61c917621de95ba2ade ]
The ifr.ifr_name is passed around and assumed to be NULL terminated.
[ Upstream commit 6fb05e0dd32e566facb96ea61a48c7488daa5ac3 ]
Avoid a double fetch by reusing the values from the prior transfer.
Originally reported via https://bugzilla.kernel.org/show_bug.cgi?id=195559
Thanks to Pengfei Wang <wpengfeinudt@gmail.com> for reporting.
Signed-off-by: Steven Toth <stoth@kernellabs.com>
Reported-by: Pengfei Wang <wpengfeinudt@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 15d3042a937c13f5d9244241c7a9c8416ff6e82a ]
Make sure segno and blkoff read from raw image are valid.
Cc: stable@vger.kernel.org
Signed-off-by: Jin Qian <jinqian@google.com>
[Jaegeuk Kim: adjust minor coding style]
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 9f5039ba440e499d85c29b1ddbc3cbc9dc90e44b ]
Since commit e8f4818895b3 ("[media] lirc: advertise
LIRC_CAN_GET_REC_RESOLUTION and improve") lircd uses the ioctl
LIRC_GET_REC_RESOLUTION to determine the shortest pulse or space that
the hardware can detect. This breaks decoding in lirc because lircd
expects the answer in microseconds, but nanoseconds is returned.
Cc: <stable@vger.kernel.org> # v2.6.36+
Reported-by: Derek <user.vdr@gmail.com>
Tested-by: Derek <user.vdr@gmail.com>
Signed-off-by: Sean Young <sean@mess.org>
[ Upstream commit fce50a2fa4e9c6e103915c351b6d4a98661341d6 ]
This patch fixes a NULL pointer dereference in isert_login_recv_done()
of isert_conn->cm_id due to isert_cma_handler() -> isert_connect_error()
resetting isert_conn->cm_id = NULL during a failed login attempt.
As per Sagi, we will always see the completion of all recv wrs posted
on the qp (given that we assigned a ->done handler), this is a FLUSH
error completion, we just don't get to verify that because we deref
NULL before.
The issue here, was the assumption that dereferencing the connection
cm_id is always safe, which is not true since:
commit 4a579da2586bd3b79b025947ea24ede2bbfede62
Author: Sagi Grimberg <sagig@mellanox.com>
Date: Sun Mar 29 15:52:04 2015 +0300
iser-target: Fix possible deadlock in RDMA_CM connection error
As I see it, we have a direct reference to the isert_device from
isert_conn which is the one-liner fix that we actually need like
we do in isert_rdma_read_done() and isert_rdma_write_done().
Reported-by: Andrea Righi <righi.andrea@gmail.com>
Tested-by: Andrea Righi <righi.andrea@gmail.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Cc: <stable@vger.kernel.org> # 3.10+
[ Upstream commit 105fa2f44e504c830697b0c794822112d79808dc ]
This patch fixes a BUG() in iscsit_close_session() that could be
triggered when iscsit_logout_post_handler() execution from within
tx thread context was not run for more than SECONDS_FOR_LOGOUT_COMP
(15 seconds), and the TCP connection didn't already close before
then forcing tx thread context to automatically exit.
This would manifest itself during explicit logout as:
[33206.974254] 1 connection(s) still exist for iSCSI session to iqn.1993-08.org.debian:01:3f5523242179
[33206.980184] INFO: NMI handler (kgdb_nmi_handler) took too long to run: 2100.772 msecs
[33209.078643] ------------[ cut here ]------------
[33209.078646] kernel BUG at drivers/target/iscsi/iscsi_target.c:4346!
Normally when explicit logout attempt fails, the tx thread context
exits and iscsit_close_connection() from rx thread context does the
extra cleanup once it detects conn->conn_logout_remove has not been
cleared by the logout type specific post handlers.
To address this special case, if the logout post handler in tx thread
context detects conn->tx_thread_active has already been cleared, simply
return and exit in order for existing iscsit_close_connection()
logic from rx thread context do failed logout cleanup.
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
Tested-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Mike Christie <mchristi@redhat.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: stable@vger.kernel.org # 3.14+
Tested-by: Gary Guo <ghg@datera.io>
Tested-by: Chu Yuan Lin <cyl@datera.io>
[ Upstream commit da05d52d2f0f6bd61094a0cd045fed94bf7d673a ]
this patch makes sure VPFE_CMD_S_CCDC_RAW_PARAMS ioctl no longer works
for vpfe_capture driver with a minimal patch suitable for backporting.
- This ioctl was never in public api and was only defined in kernel header.
- The function set_params constantly mixes up pointers and phys_addr_t
numbers.
- This is part of a 'VPFE_CMD_S_CCDC_RAW_PARAMS' ioctl command that is
described as an 'experimental ioctl that will change in future kernels'.
- The code to allocate the table never gets called after we copy_from_user
the user input over the kernel settings, and then compare them
for inequality.
- We then go on to use an address provided by user space as both the
__user pointer for input and pass it through phys_to_virt to come up
with a kernel pointer to copy the data to. This looks like a trivially
exploitable root hole.
Due to these reasons we make sure this ioctl now returns -EINVAL and backport
this patch as far as possible.
Fixes: 5f15fbb68fd7 ("V4L/DVB (12251): v4l: dm644x ccdc module for vpfe capture driver")
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Cc: <stable@vger.kernel.org> # for v3.7 and up
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[ Upstream commit 8d4514173211586c6238629b1ef1e071927735f5 ]
As written in the datasheet the PCA955 can only handle low level irq and
not edge irq.
Without this fix the interrupt is not usable for pca955: the gpio-pca953x
driver already set the irq type as low level which is incompatible with
edge type, then the kernel prevents using the interrupt:
"irq: type mismatch, failed to map hwirq-18 for
/soc/internal-regs/gpio@18100!"
Fixes: 928413bd859c ("ARM: mvebu: Add Armada 388 General Purpose
Development Board support")
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
[ Upstream commit aec51758ce10a9c847a62a48a168f8c804c6e053 ]
On a 32-bit platform, the value of n_blcoks_count may be wrong during
the file system is resized to size larger than 2^32 blocks. This may
caused the superblock being corrupted with zero blocks count.
Fixes: 1c6bd7173d66
Signed-off-by: Jerry Lee <jerrylee@qnap.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org # 3.7+
[ Upstream commit fcf5ea10992fbac3c7473a1db33d56a139333cd1 ]
ext4_find_unwritten_pgoff() does not properly handle a situation when
starting index is in the middle of a page and blocksize < pagesize. The
following command shows the bug on filesystem with 1k blocksize:
xfs_io -f -c "falloc 0 4k" \
-c "pwrite 1k 1k" \
-c "pwrite 3k 1k" \
-c "seek -a -r 0" foo
In this example, neither lseek(fd, 1024, SEEK_HOLE) nor lseek(fd, 2048,
SEEK_DATA) will return the correct result.
Fix the problem by neglecting buffers in a page before starting offset.
Reported-by: Andreas Gruenbacher <agruenba@redhat.com>
CC: stable@vger.kernel.org # 3.8+
[ Upstream commit adb1fe9ae2ee6ef6bc10f3d5a588020e7664dfa7 ]
Linus suggested we try to remove some of the low-hanging fruit related
to kernel address exposure in dmesg. The only leaks I see on my local
system are:
Freeing SMP alternatives memory: 32K (ffffffff9e309000 - ffffffff9e311000)
Freeing initrd memory: 10588K (ffffa0b736b42000 - ffffa0b737599000)
Freeing unused kernel memory: 3592K (ffffffff9df87000 - ffffffff9e309000)
Freeing unused kernel memory: 1352K (ffffa0b7288ae000 - ffffa0b728a00000)
Freeing unused kernel memory: 632K (ffffa0b728d62000 - ffffa0b728e00000)
Linus says:
"I suspect we should just remove [the addresses in the 'Freeing'
messages]. I'm sure they are useful in theory, but I suspect they
were more useful back when the whole "free init memory" was
originally done.
These days, if we have a use-after-free, I suspect the init-mem
situation is the easiest situation by far. Compared to all the dynamic
allocations which are much more likely to show it anyway. So having
debug output for that case is likely not all that productive."
With this patch the freeing messages now look like this:
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/6836ff90c45b71d38e5d4405aec56fa9e5d1d4b2.1477405374.git.jpoimboe@redhat.com
[ Upstream commit 337c017ccdf2653d0040099433fc1a2b1beb5926 ]
WARNING: CPU: 5 PID: 1242 at kernel/rcu/tree_plugin.h:323 rcu_note_context_switch+0x207/0x6b0
CPU: 5 PID: 1242 Comm: unity-settings- Not tainted 4.13.0-rc2+ #1
RIP: 0010:rcu_note_context_switch+0x207/0x6b0
Call Trace:
__schedule+0xda/0xba0
? kvm_async_pf_task_wait+0x1b2/0x270
schedule+0x40/0x90
kvm_async_pf_task_wait+0x1cc/0x270
? prepare_to_swait+0x22/0x70
do_async_page_fault+0x77/0xb0
? do_async_page_fault+0x77/0xb0
async_page_fault+0x28/0x30
RIP: 0010:__d_lookup_rcu+0x90/0x1e0
I encounter this when trying to stress the async page fault in L1 guest w/
L2 guests running.
Commit 9b132fbe5419 (Add rcu user eqs exception hooks for async page
fault) adds rcu_irq_enter/exit() to kvm_async_pf_task_wait() to exit cpu
idle eqs when needed, to protect the code that needs use rcu. However,
we need to call the pair even if the function calls schedule(), as seen
from the above backtrace.
This patch fixes it by informing the RCU subsystem exit/enter the irq
towards/away from idle for both n.halted and !n.halted.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit b1cd2e34c69a2f3988786af451b6e17967c293a0 ]
Multiple frontend dailinks may be connected to a backend
dailink at the same time. When one of frontend dailinks is
closed, the associated backend dailink should not be closed
if it is connected to other active frontend dailinks. Change
ensures that backend dailink is closed only after all
connected frontend dailinks are closed.
Signed-off-by: Gopikrishnaiah Anandan <agopik@codeaurora.org>
Signed-off-by: Banajit Goswami <bgoswami@codeaurora.org>
Signed-off-by: Patrick Lai <plai@codeaurora.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 3f3c371421e601fa93b6cb7fb52da9ad59ec90b4 ]
Sony VAIO VPCL14M1R needs the quirk to make the speaker working properly.
Tested-by: Dmitriy <mexx400@yandex.ru>
Signed-off-by: Sergei A. Trusov <sergei.a.trusov@ya.ru>
[ Upstream commit 5c0338c68706be53b3dc472e4308961c36e4ece1 ]
The combination of WQ_UNBOUND and max_active == 1 used to imply
ordered execution. After NUMA affinity 4c16bd327c74 ("workqueue:
implement NUMA affinity for unbound workqueues"), this is no longer
true due to per-node worker pools.
While the right way to create an ordered workqueue is
alloc_ordered_workqueue(), the documentation has been misleading for a
long time and people do use WQ_UNBOUND and max_active == 1 for ordered
workqueues which can lead to subtle bugs which are very difficult to
trigger.
It's unlikely that we'd see noticeable performance impact by enforcing
ordering on WQ_UNBOUND / max_active == 1 workqueues. Let's
automatically set __WQ_ORDERED for those workqueues.
Reported-by: Christoph Hellwig <hch@infradead.org>
Reported-by: Alexei Potashnik <alexei@purestorage.com>
Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues")
Cc: stable@vger.kernel.org # v3.10+
[ Upstream commit 59a5e266c3f5c1567508888dd61a45b86daed0fa ]
My static checker complains that "devno" can be negative, meaning that
we read before the start of the loop. I've looked at the code, and I
think the warning is right. This come from /proc so it's root only or
it would be quite a quite a serious bug. The call tree looks like this:
proc_scsi_write() <- gets id and channel from simple_strtoul()
-> scsi_add_single_device() <- calls shost->transportt->user_scan()
-> ata_scsi_user_scan()
-> ata_find_dev()
Cc: stable@vger.kernel.org # all versions at this point
[ Upstream commit 9f169b9f52a4afccdab7a7d2311b0c53a78a1e6b ]
When multiple front-ends are using the same back-end, putting state of a
front-end to STOP state upon receiving pause command will result in backend
stream getting released by DPCM framework unintentionally. In order to
avoid backend to be released when another active front-end stream is
present, put the stream state to PAUSED state instead of STOP state.
[ Upstream commit 9698b6f473555a722bf81a3371998427d5d27bde ]
This fix is to avoid calling fnic_fw_reset_handler through
fnic_host_reset when a finc reset is alreay in progress.
Signed-off-by: Satish Kharat <satishkh@cisco.com>
Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com>
[ Upstream commit 08f9572671c8047e7234cbf150869aa3c3d59a97 ]
This headlamp contains a dummy HID descriptor which pretends to be
a mouse-like device, but can't be used as a mouse at all.
Reported-by: Lukas Ocilka <lukas.ocilka@suse.com>
[ Upstream commit 13a6c8328e6056932dc680e447d4c5e8ad9add17 ]
Testing EP_FLAG_RUNNING in snd_complete_urb() before running the completion
logic allows us to save a few cpu cycles by returning early, skipping the
pending urb in case the stream was stopped; the stop logic handles the urb
and sets the completion callbacks to NULL.
Signed-off-by: Ioan-Adrian Ratiu <adi@adirat.com>
[ Upstream commit 71eae1ca77fd6be218d8a952d97bba827e56516d ]
The RX descriptor word 0 on SH7734 has the RFS[9:0] field in bits 16-25
(bits 0-15 usually used for that are occupied by the packet checksum).
Thus we need to set the 'shift_rd0' field in the SH7734 SoC data...
Fixes: f0e81fecd4f8 ("net: sh_eth: Add support SH7734")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 6ef4fb387d50fa8f3bffdffc868b57e981cdd709 ]
Recent changes made KERN_CONT mandatory for continued lines. In the
absence of KERN_CONT, a newline may be implicit inserted by the core
printk code.
In show_pte, we (erroneously) use printk without KERN_CONT for continued
prints, resulting in output being split across a number of lines, and
not matching the intended output, e.g.
[ff000000000000] *pgd=00000009f511b003
, *pud=00000009f4a80003
, *pmd=0000000000000000
Fix this by using pr_cont() for all the continuations.
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit e19f32da5ded958238eac1bbe001192acef191a2 ]
Here, pci_iomap can fail, handle this case release selected
pci regions and return -ENOMEM.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 4dcd19bfabaee8f9f4bcf203afba09b98ccbaf76 ]
Here, If devm_ioremap will fail. It will return NULL.
Kernel can run into a NULL-pointer dereference.
This error check will avoid NULL pointer dereference.
Acked-by: Yoichi Yuasa <yuasa@linux-mips.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ]
Currently, the sched:sched_switch tracepoint reports deadline tasks with
priority -1. But when reading the trace via perf script I've got the
following output:
# ./d & # (d is a deadline task, see [1])
# perf record -e sched:sched_switch -a sleep 1
# perf script
swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295]
d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295]
The task d reports the wrong priority [4294967295]. This happens because
the "int prio" is stored in an unsigned long long val. Although it is
set as a %lld, as int is shorter than unsigned long long,
trace_seq_printf prints it as a positive number.
The fix is just to cast the val as an int, and print it as a %d,
as in the sched:sched_switch tracepoint's "format".
The output with the fix is:
# ./d &
# perf script
swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1]
d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120]
[1] d.c
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <linux/types.h>
#include <linux/sched.h>
struct sched_attr {
__u32 size, sched_policy;
__u64 sched_flags;
__s32 sched_nice;
__u32 sched_priority;
__u64 sched_runtime, sched_deadline, sched_period;
int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags)
return syscall(__NR_sched_setattr, pid, attr, flags);
int main(void)
struct sched_attr attr = {
.size = sizeof(attr),
.sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */
.sched_runtime = 10 * 1000 * 1000,
.sched_period = attr.sched_deadline = 30 * 1000 * 1000,
if (sched_setattr(0, &attr, 0) < 0) {
perror("sched_setattr");
return -1;
for(;;);
Committer notes:
Got the program from the provided URL, http://bristot.me/lkml/d.c,
trimmed it and included in the cset log above, so that we have
everything needed to test it in one place.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com
[ Upstream commit 43aef5c2ca90535b3227e97e71604291875444ed ]
This fixes an error message that was probably copied and pasted. The same
message is used for both the in and out endpoints, so it makes it impossible
to know which one actually failed because both cases say "IN".
Make the out endpoint error message say "OUT".
Signed-off-by: David Lechner <david@lechnology.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit c2a6bbaf0c5f90463a7011a295bbdb7e33c80b51 ]
The way acpi_find_child_device() works currently is that, if there
are two (or more) devices with the same _ADR value in the same
namespace scope (which is not specifically allowed by the spec and
the OS behavior in that case is not defined), the first one of them
found to be present (with the help of _STA) will be returned.
This covers the majority of cases, but is not sufficient if some of
the devices in question have a _HID (or _CID) returning some valid
ACPI/PNP device IDs (which is disallowed by the spec) and the
ASL writers' expectation appears to be that the OS will match
devices without a valid ACPI/PNP device ID against a given bus
address first.
To cover this special case as well, modify find_child_checks()
to prefer devices without ACPI/PNP device IDs over devices that
have them.
Suggested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
[ Upstream commit 3ef01c968fbfb21c2f16281445d30a865ee4412c ]
NF_CT_PROTO_DCCP/SCTP/UDPLITE were switched from tristate to boolean so
defconfig needs to be adjusted to silence warnings:
warning: symbol value 'm' invalid for NF_CT_PROTO_DCCP
warning: symbol value 'm' invalid for NF_CT_PROTO_SCTP
warning: symbol value 'm' invalid for NF_CT_PROTO_UDPLITE
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit c415f9e8304a1d235ef118d912f374ee2e46c45d ]
The Zynq Ultrascale MP uses version 1.4 of the Cadence IP core
which fixes some silicon bugs that needed software workarounds
in Version 1.0 that was used on Zynq systems.
Signed-off-by: Moritz Fischer <mdf@kernel.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Sören Brinkmann <soren.brinkmann@xilinx.com>
Cc: Rob Herring <robh+dt@kernel.org>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
[ Upstream commit 4ea2a6be9565455f152c12f80222af1582ede0c7 ]
The patch removes these warnings reported by dtc 1.4:
Warning (unit_address_vs_reg): Node /amba_apu has a reg or ranges
property, but no unit name
Warning (unit_address_vs_reg): Node /memory has a reg or ranges
[ Upstream commit 086cc1c31a0ec075dac02425367c871bb65bc2c9 ]
The build robot reports:
.tmp_kallsyms1.o: In function `kallsyms_relative_base':
>> (.rodata+0x8a18): undefined reference to `_text'
This is when using 'make alldefconfig'. Adding this _text symbol to mark
the start of the kernel as in other architecture fixes this.
Signed-off-by: Stafford Horne <shorne@gmail.com>
Acked-by: Jonas Bonn <jonas@southpole.se>
[ Upstream commit 13288bdf4adbaa6bd1267f10044c1bc25d90ce7f ]
Some system have multiple dw devices. Currently the driver uses a
fixed name for the debugfs dir. Append dev name to the debugfs dir
name to make it unique.
Signed-off-by: Phil Reid <preid@electromag.com.au>
[ Upstream commit 63c3194b82530bd71fd49db84eb7ab656b8d404a ]
The RESET register only have one self clearing bit and it should not be
cached. If it is cached, when we sync the registers back to the chip we
will initiate a software reset as well, which is not desirable.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reviewed-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
[ Upstream commit 45e869714489431625c569d21fc952428d761476 ]
Using ancient compilers (gcc-4.5 or older) on ARM, we get a link
failure with the vfio-pci driver:
ERROR: "__aeabi_lcmp" [drivers/vfio/pci/vfio-pci.ko] undefined!
The reason is that the compiler tries to do a comparison of
a 64-bit range. This changes it to convert to a 32-bit number
explicitly first, as newer compilers do for themselves.
[ Upstream commit a6cb3b864b21b7345f824a4faa12b723c8aaf099 ]
For every submission buffer object one of MSM_SUBMIT_BO_WRITE
and MSM_SUBMIT_BO_READ must be set (and nothing else). If we
allowed zero then the buffer object would never get queued to
be unreferenced.
Signed-off-by: Jordan Crouse <jcrouse@codeaurora.org>
Signed-off-by: Rob Clark <robdclark@gmail.com>
[ Upstream commit 88b333b0ed790f9433ff542b163bf972953b74d3 ]
Currently the value written to CP_RB_WPTR is calculated on the fly as
(rb->next - rb->start). But as the code is designed rb->next is wrapped
before writing the commands so if a series of commands happened to
fit perfectly in the ringbuffer, rb->next would end up being equal to
rb->size / 4 and thus result in an out of bounds address to CP_RB_WPTR.
The easiest way to fix this is to mask WPTR when writing it to the
hardware; it makes the hardware happy and the rest of the ringbuffer
math appears to work and there isn't any point in upsetting anything.
[squash in is_power_of_2() check]
