2006-05-30[MTD] NAND Expose the new raw mode function and status info to userspaceThomas Gleixner
The raw read/write access to NAND (without ECC) has been changed in the NAND rework. Expose the new way - setting the file mode via ioctl - to userspace. Also allow to read out the ecc statistics information so userspace tools can see that bitflips happened and whether errors where correctable or not. Also expose the number of bad blocks for the partition, so nandwrite can check if the data fits into the parition before writing to it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Signal that a bitflip was corrected by ECCThomas Gleixner
Return -EUCLEAN on read when a bitflip was detected and corrected, so the clients can react and eventually copy the affected block to a spare one. Make all in kernel users aware of the change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Rework the out of band handling completelyThomas Gleixner
Hopefully the last iteration on this! The handling of out of band data on NAND was accompanied by tons of fruitless discussions and halfarsed patches to make it work for a particular problem. Sufficiently annoyed by I all those "I know it better" mails and the resonable amount of discarded "it solves my problem" patches, I finally decided to go for the big rework. After removing the _ecc variants of mtd read/write functions the solution to satisfy the various requirements was to refactor the read/write _oob functions in mtd. The major change is that read/write_oob now takes a pointer to an operation descriptor structure "struct mtd_oob_ops".instead of having a function with at least seven arguments. read/write_oob which should probably renamed to a more descriptive name, can do the following tasks: - read/write out of band data - read/write data content and out of band data - read/write raw data content and out of band data (ecc disabled) struct mtd_oob_ops has a mode field, which determines the oob handling mode. Aside of the MTD_OOB_RAW mode, which is intended to be especially for diagnostic purposes and some internal functions e.g. bad block table creation, the other two modes are for mtd clients: MTD_OOB_PLACE puts/gets the given oob data exactly to/from the place which is described by the ooboffs and ooblen fields of the mtd_oob_ops strcuture. It's up to the caller to make sure that the byte positions are not used by the ECC placement algorithms. MTD_OOB_AUTO puts/gets the given oob data automaticaly to/from the places in the out of band area which are described by the oobfree tuples in the ecclayout data structre which is associated to the devicee. The decision whether data plus oob or oob only handling is done depends on the setting of the datbuf member of the data structure. When datbuf == NULL then the internal read/write_oob functions are selected, otherwise the read/write data routines are invoked. Tested on a few platforms with all variants. Please be aware of possible regressions for your particular device / application scenario Disclaimer: Any whining will be ignored from those who just contributed "hot air blurb" and never sat down to tackle the underlying problem of the mess in the NAND driver grown over time and the big chunk of work to fix up the existing users. The problem was not the holiness of the existing MTD interfaces. The problems was the lack of time to go for the big overhaul. It's easy to add more mess to the existing one, but it takes alot of effort to go for a real solution. Improvements and bugfixes are welcome! Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Remove silly MTD_WRITE/READ macrosThomas Gleixner
Most of those macros are unused and the used ones just obfuscate the code. Remove them and fixup all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Replace oobinfo by ecclayoutThomas Gleixner
The nand_oobinfo structure is not fitting the newer error correction demands anymore. Replace it by struct nand_ecclayout and fixup the users all over the place. Keep the nand_oobinfo based ioctl for user space compability reasons. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Consolidate oobinfo handlingThomas Gleixner
The info structure for out of band data was copied into the mtd structure. Make it a pointer and remove the ability to set it from userspace. The position of ecc bytes is defined by the hardware and should not be changed by software. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Fix platform structure and NDFC driverThomas Gleixner
The platform structure was lacking an oobinfo field. The NDFC driver had some remains from another tree. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] Fix debug printk format warning in m25p80 SPI chip driver, again.Andrew Morton
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-29[MTD] AMD Geode NAND support can depend on X86_32; we won't see it on x86_64David Woodhouse
2006-05-29[JFFS2] Preallocate raw_node_refs in a couple of missing places in scanDavid Woodhouse
2006-05-28[JFFS2] Fix oops when marking space dirty in scan, but no previous node exists.David Woodhouse
2006-05-27[JFFS2] Fix wbuf recovery of f->metadata->raw node.David Woodhouse
A data node might not be in the fraglist; it could be f->metadata. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-27[MTD] NAND Consolidate references and add back default name settingThomas Gleixner
We have a type pointer. Make use of it instead of the error prone nand_ids[i] reference. The NAND driver used to set default name settings from the chip ID string for the device. The feature got lost during the rework. Add it back. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-27[MTD] NAND simplify nand_chip_selectThomas Gleixner
nCE setting can be done when the first command is issued to the device. We keep the deselect functionality as it makes sense to deassert nCE when the device becomes idle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-26[MTD] Fix thinko in nand_write_page_hwecc()David Woodhouse
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-26[JFFS2] Switch to using an array of jffs2_raw_node_refs instead of a list.David Woodhouse
This allows us to drop another pointer from the struct jffs2_raw_node_ref, shrinking it to 8 bytes on 32-bit machines (if the TEST_TOTLEN) paranoia check is turned off, which will be committed soon). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-26[MTD] NAND modularize write functionThomas Gleixner
Modularize the write function and reorganaize the internal buffer management. Remove obsolete chip options and fixup all affected users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-26[MTD] Remove PCI dependency for Geode CS553[56] NAND controller.David Woodhouse
PCI is faked on these devices by SMM traps. Don't depend on that -- check for the chipset directly instead. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[JFFS2] Fix 64-bit size_t problems in XATTR code.David Woodhouse
2006-05-25[MTD] Fix NAND_VERIFY_WRITE case to build with tglx's recent changesDavid Woodhouse
Bad tglx. No biscuit. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[MTD] Remove the only useless readv implementationThomas Gleixner
Removing readv from struct mtd_info broke block2mtd. Remove the reference and the useless default implementation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[MTD] NAND Modularize read functionThomas Gleixner
Split the core of the read function out and implement seperate handling functions for software and hardware ECC. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[MTD] NAND Add read/write function pointers to struct nand_ecc_ctrlThomas Gleixner
Add read/write function pointers to struct nand_ecc_ctrl to prepare the modulaization of nand_read/write functions. The current implementation handles every type of ecc mode software/hardware and all kinds of strange ecc placement schemes in one switch/if construct. Thats too complex to maintain and too inflexible to expand. Modularization will also shorten the code pathes of the read/write functions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[MTD] Add ECC statistics to struct mtd_infoThomas Gleixner
FLASH - especially NAND FLASH - will become less reliable and bit flips more likely. Add an ECC statistics struct to struct mtd_info to keep track of this. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[MTD] NAND Cleanup oob functionsThomas Gleixner
Cleanup the code in the oob related functions and make use of the new NO_READRDY flag. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[MTD] NAND Introduce NAND_NO_READRDY optionThomas Gleixner
The nand driver has a superflous read ready / command delay in the read functions. This was added to handle chips which have an automatic read forward. Newer chips do not have this functionality anymore. Add this option to avoid the delay / I/O operation. Mark all large page chips with the new option flag. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[MTD] NAND Initialize controller lock and wq only onceThomas Gleixner
The lock simplifying patch did not move the lock and waitqueue initialization into the controller allocation patch. This reinitializes waitqueue and spinlocks also for driver supplied controller stuctures. Move it into the allocation path. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-25[JFFS2] Fix and improve debugging output during scan.David Woodhouse
Print wasted_size in scanned eraseblocks, print range correctly for summary dirent and inode entries. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[JFFS2] Add 'jeb' argument to jffs2_prealloc_raw_node_refs()David Woodhouse
Preallocation of refs is shortly going to be a per-eraseblock thing, rather than per-filesystem. Add the required argument to the function. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[JFFS2] Correctly handle wasted space before summary node.David Woodhouse
2006-05-25[JFFS2] jffs2_free_all_node_refs() doesn't free them all. Rename it.David Woodhouse
... to jffs2_free_jeb_node_refs() since that's what it does. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[JFFS2] Allocate node_ref for wasted space when skipping to page boundaryDavid Woodhouse
One more place where we were changing the accounting info without actually allocating a ref for the lost space... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24[MTD] NAND fix cmd_ctrl breakageThomas Gleixner
The cmd_ctrl rework lacks some state transition flags. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-24[MTD] NAND coding style and namespace cleanupThomas Gleixner
Cleanup the functions which are not going to change in the next steps. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-24[JFFS2] Revert Artem's Bunkage in debug messages.David Woodhouse
Random unthinking 'cleanup' caused debug messages like this: Obsoleting node at 0x0006daf4 of len 0x3a4: <7>Dirtying If messages are continuation of an existing line, they don't need to be prefixed with KERN_DEBUG. THINK. Or you will be replaced by a small shell script. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24Merge branch 'master' of git://git.infradead.org/~gleixner/mtd-nand-2.6.gitDavid Woodhouse
2006-05-24[JFFS2] Introduce ref_next() macro for finding next physical nodeDavid Woodhouse
Another part of the preparation for switching to an array... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24[JFFS2] Reduce visibility of raw_node_ref to upper layers of JFFS2 code.David Woodhouse
As the first step towards eliminating the ref->next_phys member and saving memory by using an _array_ of struct jffs2_raw_node_ref per eraseblock, stop the write functions from allocating their own refs; have them just _reserve_ the appropriate number instead. Then jffs2_link_node_ref() can just fill them in. Use a linked list of pre-allocated refs in the superblock, for now. Once we switch to an array, it'll just be a case of extending that array. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-23[MTD] NAND LED support cleanupThomas Gleixner
Move the define out of the middle of the code and add an appropriate comment. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] NAND remove write_byte/word function from nand_chipThomas Gleixner
The previous change of the command / hardware control allows to remove the write_byte/word functions completely, as their only user were nand_command and nand_command_lp. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Refactor NAND hwcontrol to cmd_ctrlThomas Gleixner
The hwcontrol function enforced a step by step state machine for any kind of hardware chip access. Let the hardware driver know which control bits are set and inform it about a change of the control lines. Let the hardware driver write out the command and address bytes directly. This gives a peformance advantage for address bus controlled chips and simplifies the quirks in the hardware drivers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Export nand_write_rawThomas Gleixner
The previous _ecc removal / cleanup broke (i)nftl module usage. Export the missing symbol. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Mark NAND drivers TOTO and PPChameleon brokenThomas Gleixner
Both drivers can not be fixed and compiled due to missing header files. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove read/write _ecc variantsThomas Gleixner
MTD clients are agnostic of FLASH which needs ECC suppport. Remove the functions and fixup the callers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove readv/readv_eccThomas Gleixner
These functions were never implemented and added only bloat to partition and concat code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] Remove nand writev supportThomas Gleixner
NAND writev(_ecc) support is not longer necessary. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] ECC rework broke diskonchipThomas Gleixner
Fix the diskonchip ecc setup. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23[MTD] NAND ECC hwctl function has no return valueThomas Gleixner
Fix the broken prototype Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-23Merge branch 'master' of /home/tglx/work/kernel/git/mtd-2.6/Thomas Gleixner
2006-05-23[MTD] NAND modularize ECCThomas Gleixner
First step of modularizing ECC support. - Move ECC related functionality into a seperate embedded data structure - Get rid of the hardware dependend constants to simplify new ECC models Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
