git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull IMA fixes from James Morris:
"Here are two more fixes for IMA"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
ima: properly free ima_template_entry structures
ima: Do not free 'entry' before it is initialized
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree fixes from Rob Herring:
- Various DT binding documentation updates
- Add Kumar Gala and remove Stephen Warren as DT binding maintainers
* tag 'dt-fixes-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
dt: binding: reword PowerPC 8xxx GPIO documentation
ARM: tegra: delete nvidia,tegra20-spi.txt binding
hwmon: ntc_thermistor: Fix typo (pullup-uV -> pullup-uv)
of: add vendor prefix for GMT
clk: exynos: Fix typos in DT bindings documentation
of: Add vendor prefix for LG Corporation
Documentation: net: fsl-fec.txt: Add phy-supply entry
ARM: dts: doc: Document missing binding for omap5-mpu
dt-bindings: add ARMv8 PMU binding
MAINTAINERS: remove swarren from DT bindings
MAINTAINERS: Add Kumar to Device Tree Binding maintainers group
Clean up the aio ring file in the fail path of aio_setup_ring
and ioctx_alloc. And maybe it can fix the GPF issue reported by
Dave Jones:
https://lkml.org/lkml/2013/11/25/898
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
Pull power management fixes from Rafael Wysocki:
- cpufreq regression fix from Bjørn Mork restoring the pre-3.12
behavior of the framework during system suspend/hibernation to avoid
garbage sysfs files from being left behind in case of a suspend error
- PNP regression fix to restore the correct states of devices after
resume from hibernation broken in 3.12. From Dmitry Torokhov.
- cpuidle fix to prevent cpuidle device unregistration from crashing
due to a NULL pointer dereference if cpuidle has been disabled from
the kernel command line. From Konrad Rzeszutek Wilk.
- intel_idle fix for the C6 state definition on Intel Avoton/Rangeley
processors from Arne Bockholdt.
- Power capping framework fix to make the energy_uj sysfs attribute
work in accordance with the documentation. From Srinivas Pandruvada.
- epoll fix to make it ignore the EPOLLWAKEUP flag if the kernel has
been compiled with CONFIG_PM_SLEEP unset (in which case that flag
should not have any effect). From Amit Pundir.
- cpufreq fix to prevent governor sysfs files from being lost over
system suspend/resume in some (arguably unusual) situations. From
Viresh Kumar.
* tag 'pm-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PowerCap: Fix mode for energy counter
PNP: fix restoring devices after hibernation
cpuidle: Check for dev before deregistering it.
epoll: drop EPOLLWAKEUP if PM_SLEEP is disabled
cpufreq: fix garbage kobjects on errors during suspend/resume
cpufreq: suspend governors on system suspend/hibernate
intel_idle: Fixed C6 state on Avoton/Rangeley processors
* pm-epoll:
* pnp:
* powercap:
* pm-cpuidle:
* pm-cpufreq:
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull arch/tile ftrace bug fix from Chris Metcalf:
"This fixes a build failure with allyesconfig reported by Fengguang Wu
and fixed by Tony Lu"
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
ftrace: default to tilegx if ARCH=tile is specified
Pull block layer fixes from Jens Axboe:
"A small collection of fixes for the current series. It contains:
- A fix for a use-after-free of a request in blk-mq. From Ming Lei
- A fix for a blk-mq bug that could attempt to dereference a NULL rq
if allocation failed
- Two xen-blkfront small fixes
- Cleanup of submit_bio_wait() type uses in the kernel, unifying
that. From Kent
- A fix for 32-bit blkg_rwstat reading. I apologize for this one
looking mangled in the shortlog, it's entirely my fault for missing
an empty line between the description and body of the text"
* 'for-linus' of git://git.kernel.dk/linux-block:
blk-mq: fix use-after-free of request
blk-mq: fix dereference of rq->mq_ctx if allocation fails
block: xen-blkfront: Fix possible NULL ptr dereference
xen-blkfront: Silence pfn maybe-uninitialized warning
block: submit_bio_wait() conversions
Update of blkg_stat and blkg_rwstat may happen in bh context
Pull NFS client bugfixes from Trond Myklebust:
- Stable fix for a NFSv4.1 delegation and state recovery deadlock
- Stable fix for a loop on irrecoverable errors when returning
delegations
- Fix a 3-way deadlock between layoutreturn, open, and state recovery
- Update the MAINTAINERS file with contact information for Trond
Myklebust
- Close needs to handle NFS4ERR_ADMIN_REVOKED
- Enabling v4.2 should not recompile nfsd and lockd
- Fix a couple of compile warnings
* tag 'nfs-for-3.13-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
nfs: fix do_div() warning by instead using sector_div()
MAINTAINERS: Update contact information for Trond Myklebust
NFSv4.1: Prevent a 3-way deadlock between layoutreturn, open and state recovery
SUNRPC: do not fail gss proc NULL calls with EACCES
NFSv4: close needs to handle NFS4ERR_ADMIN_REVOKED
NFSv4: Update list of irrecoverable errors on DELEGRETURN
NFSv4 wait on recovery for async session errors
NFS: Fix a warning in nfs_setsecurity
NFS: Enabling v4.2 should not recompile nfsd and lockd
This matches the existing behavior in arch/tile/Makefile for defconfig.
Reported-by: fengguang.wu@intel.com
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Tony Lu <zlu@tilera.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
It has been reported that boot up with FTRACE_SELFTEST enabled can take a
very long time. There can be stalls of over a minute.
This was tracked down to the synchronize_sched() called when a system call
event is disabled. As the self tests enable and disable thousands of events,
this makes the synchronize_sched() get called thousands of times.
The synchornize_sched() was added with d562aff93bfb53 "tracing: Add support
for SOFT_DISABLE to syscall events" which caused this regression (added
in 3.13-rc1).
The synchronize_sched() is to protect against the events being accessed
when a tracer instance is being deleted. When an instance is being deleted
all the events associated to it are unregistered. The synchronize_sched()
makes sure that no more users are running when it finishes.
Instead of calling synchronize_sched() for all syscall events, we only
need to call it once, after the events are unregistered and before the
instance is deleted. The event_mutex is held during this action to
prevent new users from enabling events.
Link: http://lkml.kernel.org/r/20131203124120.427b9661@gandalf.local.home
Reported-by: Petr Mladek <pmladek@suse.cz>
Acked-by: Tom Zanussi <tom.zanussi@linux.intel.com>
Acked-by: Petr Mladek <pmladek@suse.cz>
Tested-by: Petr Mladek <pmladek@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs MAINTAINERS file update:
"I'm still getting settled into new devel hardware etc, but I do have
one commit for the next rc.
This changes my email over to fb.com, and adds a MAINTAINERS entry for
Josef as well"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: update the MAINTAINERS file
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull minor fbdev fixes from Tomi Valkeinen.
* tag 'fbdev-fixes-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
video: vt8500: fix error handling in probe()
atmel_lcdfb: fix module autoload
fbdev: sh_mobile_meram: Fix defined but not used compiler warnings
video: kyro: fix incorrect sizes when copying to userspace
ARM: OMAPFB: panel-sony-acx565akm: fix bad unlock balance
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"A usual pattern of half ASoC and half HD-audio fixes, although
HD-audio fixups have more volumes, in addition to a couple of trivial
fixes. Nothing to worry much is found here.
For ASoC side: a few fixes for PCM rate constraints calculations,
regmap byte-order fix, the rest driver specific fixes (atmel, fsl,
omap, kirkwood, wm codecs).
For HD-audio: Dell headset and mono out fix, ELD update in polling
mode, ALC283 Chromebook fixes, a few fixes for old AD codecs and
MBA2, one regression fix"
* tag 'sound-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (30 commits)
ALSA: hda - Fix silent output on MacBook Air 2,1
ALSA: hda - Fix missing ELD info when using jackpoll_ms parameter
ALSA: hda/realtek - remove hp_automute_hook from alc283_fixup_chromebook
ASoC: wm8731: fix dsp mode configuration
ALSA: hda/realtek - Independent of model for HP
ALSA: hda - Fix headset mic input after muted internal mic (Dell/Realtek)
ALSA: hda - Use always amps for auto-mute on AD1986A codec
ALSA: hda/analog - Handle inverted EAPD properly in vmaster hook
ALSA: hda - Another fixup for ASUS laptop with ALC660 codec
ALSA: atmel: Fix possible array overflow
ALSA: hda - Fix complete_all() timing in deferred probes
ALSA: hda - Fix bad EAPD setup for HP machines with AD1984A
ASoC: core: fix devres parameter in devm_snd_soc_register_card()
ASoC: omap: n810: Convert to clk_prepare_enable/clk_disable_unprepare
ASoC: fsl: set correct platform drvdata in pcm030_fabric_probe()
ASoC: fsl: imx-pcm-fiq: Remove unused 'runtime' variable
ASoC: fsl: imx-pcm-fiq: remove bogus period delta calculation
ALSA: hda - Fix silent output on ASUS W7J laptop
ASoC: core: Use consistent byte ordering in snd_soc_bytes_get
ALSA: dice: fix array limits in dice_proc_read()
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
- Minor bug fixes for the Rockchip, ST-Ericsson abx500, Renesas PFC
r8a7740 and sh7372.
- Compilation warning fixes.
* tag 'pinctrl-v3.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
sh-pfc: sh7372: Fix pin bias setup
sh-pfc: r8a7740: Fix pin bias setup
pinctrl: abx500: Fix header file include guard
pinctrl: rockchip: missing unlock on error in rockchip_set_pull()
pinctrl: abx500: fix some more bitwise AND tests
pinctrl: rockchip: testing the wrong variable
If accounting is on, we will do the IO completion accounting after
we have freed the request. Fix that by moving it sooner instead.
Pull x86 and EFI fixes from Peter Anvin:
"Half of these are EFI-related:
The by far biggest change is the change to hold off the deletion of a
sysfs entry while a backend scan is in progress. This is to avoid
calling kmemdup() while under a spinlock.
The other major change is for each entry in the EFI pstore backend to
get a unique identifier, as required by the pstore filesystem proper.
The other changes are:
A fix to the recent consolidation and optimization of using "asm goto"
with read-modify-write operation, which broke the bitops; specifically
in such a way that we could end up generating invalid code.
A build hack to make sure we compile with -mno-sse. icc, and most
likely future versions of gcc, can generate SSE instructions unless we
tell it not to.
A comment-only patch to a change the was due in part to an unpublished
erratum; now when the erratum is published we want to add a comment
explaining why"
* 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/apic, doc: Justification for disabling IO APIC before Local APIC
x86, bitops: Correct the assembly constraints to testing bitops
x86-64, build: Always pass in -mno-sse
efi-pstore: Make efi-pstore return a unique id
x86/efi: Fix earlyprintk off-by-one bug
efivars, efi-pstore: Hold off deletion of sysfs entry until the scan is completed
Since erratum AVR31 in "Intel Atom Processor C2000 Product Family
Specification Update" is now published, I added a justification
comment for disabling IO APIC before Local APIC, as changed in commit:
522e66464467 x86/apic: Disable I/O APIC before shutdown of the local APIC
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Link: http://lkml.kernel.org/r/1386202069-51515-1-git-send-email-fenghua.yu@intel.com
As per the documentation of powercap sysfs, energy_uj field is read only,
if it can't be reset. Currently it always allows write but will fail,
if there is no reset callback.
Changing mode field, to read only if there is no reset callback.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Reported-by: Dirk Brandewie <dirk.j.brandewie@intel.com>
On returning from hibernation 'restore' callback is called,
not 'resume'. Fix it.
Fixes: eaf140b60ec9 (PNP: convert PNP driver bus legacy pm_ops to dev_pm_ops)
Cc: 3.12+ <stable@vger.kernel.org> # 3.12+
In checkin:
0c44c2d0f459 x86: Use asm goto to implement better modify_and_test() functions
the various functions which do modify and test were unified and
optimized using "asm goto". However, this change missed the detail
that the bitops require an "Ir" constraint rather than an "er"
constraint ("I" = integer constant from 0-31, "e" = signed 32-bit
integer constant). This would cause code to miscompile if these
functions were used on constant bit positions 32-255 and the build to
fail if used on constant bit positions above 255.
Add the constraints as a parameter to the GEN_BINARY_RMWcc() macro to
avoid this problem.
Reported-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Link: http://lkml.kernel.org/r/529E8719.4070202@zytor.com
When compiling a 32bit kernel with CONFIG_LBDAF=n the compiler complains like
shown below. Fix this warning by instead using sector_div() which is provided
by the kernel.h header file.
fs/nfs/blocklayout/extents.c: In function ‘normalize’:
include/asm-generic/div64.h:43:28: warning: comparison of distinct pointer types lacks a cast [enabled by default]
fs/nfs/blocklayout/extents.c:47:13: note: in expansion of macro ‘do_div’
nfs/blocklayout/extents.c:47:2: warning: right shift count >= width of type [enabled by default]
fs/nfs/blocklayout/extents.c:47:2: warning: passing argument 1 of ‘__div64_32’ from incompatible pointer type [enabled by default]
include/asm-generic/div64.h:35:17: note: expected ‘uint64_t *’ but argument is of type ‘sector_t *’
extern uint32_t __div64_32(uint64_t *dividend, uint32_t divisor);
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Andy Adamson reports:
The state manager is recovering expired state and recovery OPENs are being
processed. If kswapd is pruning inodes at the same time, a deadlock can occur
when kswapd calls evict_inode on an NFSv4.1 inode with a layout, and the
resultant layoutreturn gets an error that the state mangager is to handle,
causing the layoutreturn to wait on the (NFS client) cl_rpcwaitq.
At the same time an open is waiting for the inode deletion to complete in
__wait_on_freeing_inode.
If the open is either the open called by the state manager, or an open from
the same open owner that is holding the NFSv4 sequence id which causes the
OPEN from the state manager to wait for the sequence id on the Seqid_waitqueue,
then the state is deadlocked with kswapd.
The fix is simply to have layoutreturn ignore all errors except NFS4ERR_DELAY.
We already know that layouts are dropped on all server reboots, and that
it has to be coded to deal with the "forgetful client model" that doesn't
send layoutreturns.
Reported-by: Andy Adamson <andros@netapp.com>
Link: http://lkml.kernel.org/r/1385402270-14284-1-git-send-email-andros@netapp.com
Signed-off-by: Trond Myklebust <Trond.Myklebust@primarydata.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Here are a few more GPIO patches, we're a bit noisy for being the GPIO
subsystem, mostly due to the new descriptor API, but all is getting
into shape.
- Fix compile warnings
- Fix overly talkative diagnostic messages from usual use cases wrt
GPIO descriptors
- Add a documentation 00-INDEX
- Use platform GPIOs as fallback when ACPI or device tree is used as
the primary means to get GPIO lines
- A bug fix for the MPC8572/MPC8536 fixing erroneous input data"
* tag 'gpio-v3.13-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpiolib: change a warning to debug message when failing to get gpio
powerpc/gpio: Fix the wrong GPIO input data on MPC8572/MPC8536
gpiolib: use platform GPIO mappings as fallback
Documentation: gpiolib: add 00-INDEX file
gpiolib: fix lookup of platform-mapped GPIOs
gpiolib: add missing declarations
Pull ARM SoC fixes from Olof Johansson:
"Another batch of fixes for ARM SoCs for 3.13. The diffstat is large,
mostly because of:
- Another set of fixes to fix regressions caused by moving OMAP from
board files to DT. Tony thinks this was the last major set of
fixes, with maybe just a few small patches to follow.
- More fixes for Marvell platforms, most dealing with misdescribed
PCIe hardware, i.e. incorrect number of busses on some SoCs, etc.
The line delta adds up due to various ranges moving around when
this is fixed.
But there's also:
- Some smaller tweaks to defconfigs to make more boards bootable in
my test setup for better coverage.
- There are also a few other smaller fixes, a short series for at91,
a couple of reverts for ux500, etc"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits)
arm: dts: socfpga: Change some clocks of gate-clk type to perip-clk
arm: socfpga: Enable ARM_TWD for socfpga
ARM: multi_v7_defconfig: enable SDHCI_BCM_KONA and MMC_BLOCK_MINORS=16
ARM: sunxi_defconfig: enable NFS, TMPFS, PRINTK_TIME and nfsroot support
ARM: multi_v7_defconfig: enable network for BeagleBone Black
ARM: dts: Fix the name of supplies for smsc911x shared by OMAP
ARM: OMAP2+: Powerdomain: Fix unchecked dereference of arch_pwrdm
ARM: dts: omap3-beagle: Add omap-twl4030 audio support
ARM: dts: omap4-sdp: Fix pin muxing for wl12xx
ARM: dts: omap4-panda-common: Fix pin muxing for wl12xx
ARM: at91: fixed unresolved symbol "at91_pm_set_standby" when built without CONFIG_PM
ARM: at91: add usart3 alias to dtsi
ARM: at91: sama5d3: reduce TWI internal clock frequency
mmc: omap: Fix I2C dependency and make driver usable with device tree
mmc: omap: Fix DMA configuration to not rely on device id
ARM: dts: omap3-beagle: Fix USB host on beagle boards (for 3.13)
ARM: dts: omap3-igep0020: name twl4030 VPLL2 regulator as vdds_dsi
ARM: dts: AM33XX IGEP0033: add USB support
ARM: dts: AM33XX BASE0033: add 32KBit EEPROM support
ARM: dts: AM33XX BASE0033: add pinmux and user led support
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parsic updates from Helge Deller:
- a fix for the mmap(MAP_FIXED|MAP_SHARED) syscall to the same address
which was already given in a previous call (fixes locale-gen on
debian)
- change the memory layout of the kernel to avoid the need for the
-mlong-calls compiler option (depends on commit 5ecbe3c3c690 -
"kernel/extable: fix address-checks for core_kernel and init areas")
- defconfig updates, e.g. use the SIL680 driver instead of the SIIMAGE
driver
- add more parisc machine names to the machine database
* 'parisc-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: update 64bit defconfigs and use SIL680 instead of SIIMAGE driver
parisc: remove CONFIG_MLONGCALLS=y from defconfigs
parisc: fix kernel memory layout in vmlinux.ld.S
parisc: use kernel_text_address() in unwind functions
parisc: remove empty SERIAL_PORT_DFNS in serial.h
parisc: add some more machine names to hardware database
parisc: fix mmap(MAP_FIXED|MAP_SHARED) to already mmapped address
git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next
Pull squashfs bugfix from Phillip Lougher:
"Just a single bug fix to the new "directly decompress into the page
cache" code"
* tag 'squashfs-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next:
Squashfs: fix failure to unlock pages on decompress error
Pull crypto fixes from Herbert Xu:
"This push fixes a number of crashes triggered by a previous crypto
self-test update. It also fixes a build problem in the caam driver,
as well as a concurrency issue in s390.
Finally there is a pair of fixes to bugs in the crypto scatterwalk
code and authenc that may lead to crashes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: testmgr - fix sglen in test_aead for case 'dst != src'
crypto: talitos - fix aead sglen for case 'dst != src'
crypto: caam - fix aead sglen for case 'dst != src'
crypto: ccm - Fix handling of zero plaintext when computing mac
crypto: s390 - Fix aes-xts parameter corruption
crypto: talitos - corrrectly handle zero-length assoc data
crypto: scatterwalk - Set the chain pointer indication bit
crypto: authenc - Find proper IV address in ablkcipher callback
crypto: caam - Add missing Job Ring include
Pull timer fixes from Thomas Gleixner:
- timekeeping: Cure a subtle drift issue on GENERIC_TIME_VSYSCALL_OLD
- nohz: Make CONFIG_NO_HZ=n and nohz=off command line option behave the
same way. Fixes a long standing load accounting wreckage.
- clocksource/ARM: Kconfig update to avoid ARM=n wreckage
- clocksource/ARM: Fixlets for the AT91 and SH clocksource/clockevents
- Trivial documentation update and kzalloc conversion from akpms pile
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: Fix another inconsistency between CONFIG_NO_HZ=n and nohz=off
time: Fix 1ns/tick drift w/ GENERIC_TIME_VSYSCALL_OLD
clocksource: arm_arch_timer: Hide eventstream Kconfig on non-ARM
clocksource: sh_tmu: Add clk_prepare/unprepare support
clocksource: sh_tmu: Release clock when sh_tmu_register() fails
clocksource: sh_mtu2: Add clk_prepare/unprepare support
clocksource: sh_mtu2: Release clock when sh_mtu2_register() fails
ARM: at91: rm9200: switch back to clockevents_config_and_register
tick: Document tick_do_timer_cpu
timer: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node(...)
NOHZ: Check for nohz active instead of nohz enabled
drivers/gpio/gpio-em.c
This uses the new API for tagging GPIO lines as in use by
IRQs. This enforces a few semantic checks on how the underlying
GPIO line is used.
Cc: Mathias Nyman <mathias.nyman@linux.intel.com>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
GPIO line is used.
ChangeLog v1->v2:
- Explicitly call the - empty - mask/unmask functions from the
startup/shutdown hooks. These are currently empty, but maybe
they will not be that forever, so better be safe than sorry.
Acked-by: David Cohen <david.a.cohen@linux.intel.com>
GPIO line is used.
Also assign the gpio_chip.dev pointer to be used for error
messages.
ChangeLog v1->v2:
- Satisfy implicit semantics by calling .enable and .disable
callbacks in the startup/shutdown callbacks.
Cc: Ian Molton <ian.molton@codethink.co.uk>
Cc: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Magnus Damm <damm@opensource.se>
GPIO line is used.
Cc: Christian Daudt <csd@broadcom.com>
Cc: Grygorii Strashko <grygorii.strashko@ti.com>
Reviewed-by: Markus Mayer <markus.mayer@linaro.org>
Tested-by: Markus Mayer <markus.mayer@linaro.org>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
GPIO line is used.
Only compile tested on the lpc32xx.
ChangeLog v2->v3:
- Switch to using the startup()/shutdown() callbacks again.
Still satisfy the mask/unmask semantics.
ChangeLog v1->v2:
- Use the .enable() callback from the irq_chip
- Call .unmask() from the .enable() callback to satisfy semantics.
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
This switches the two members of struct gpio_chip that were
defined as unsigned foo:1 to bool, because that is indeed what
they are. Switch all users in the gpio and pinctrl subsystems
to assign these values with true/false instead of 0/1. The
users outside these subsystems will survive since true/false
is 1/0, atleast we set some kind of more strict typing example.
MacBook Air 2,1 has a fairly different pin assignment from its brother
MBA 1,1, and yet another quirks are needed for pin 0x18 and 0x19,
similarly like what iMac 9,1 requires, in order to make the sound
working on it.
Reported-and-tested-by: Bruno Prémont <bonbons@linux-vserver.org>
Cc: <stable@vger.kernel.org>
gpiochip_offset_to_desc() was using gpio_to_desc(), which directly
addresses the global GPIO array we are hoping to get rid of someday.
Reimplement it using the descriptor array of the chip itself, after
checking the requested offset is within the valid bounds of the chip.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Renaming "moxart_gpio_base" to "base" allows better fit,
remove line breaks in moxart_gpio_get().
While doing trivial cleanup, also remove fields initialized
with zero in moxart_template_chip.
Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v3.13
A smattering of fixes here, some core ones for the rate combination
issues for things other than simple bitmasks, for readback of byte
controls and for updating the power of value muxes plus a bunch of
driver fixes of varying severity.
The warning fix in the i.MX FIQ driver is fixing a warning introduced
by a previous fix.
We shouldn't kfree(fbi) because that was allocated with devm_kzalloc().
There were several error paths which returned directly instead of
releasing resources.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Add missing module device table which is needed for module autoloading.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
In the case of using jackpoll_ms instead of unsol events, the jack
was correctly detected, but ELD info was not refreshed on plug-in.
And without ELD info, no proper restriction of pcm, which can in turn
break sound output on some devices.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
I forgot to remove the hp_automute_hook from alc283_fixup_chromebook.
It doesn't need this for other chrome os machine.
Signed-off-by: Kailang Yang <kailang@realtek.com>
Josef and I have new email addresses
Signed-off-by: Chris Mason <clm@fb.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
Always pass in the -mno-sse argument, regardless if
-preferred-stack-boundary is supported. We never want to generate SSE
instructions in the kernel unless we *really* know what we're doing.
According to H. J. Lu, any version of gcc new enough that we support
it at all should handle the -mno-sse option, so just add it
unconditionally.
Reported-by: Kevin B. Smith <kevin.b.smith@intel.com>
Cc: H. J. Lu <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/n/tip-j21wzqv790q834n7yc6g80j1@git.kernel.org
Cc: <stable@vger.kernel.org> # build fix only
Some of the clocks that were designated gate-clk do not have a gate, so
change those clocks to be of periph-clk type.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
