Usually the active scan mask is freed in __iio_update_buffers() when the buffer
is disabled. But when the device is still sampling when it is removed we'll end
up disabling the buffers in iio_disable_all_buffers(). So we also need to free
the active scan mask here, otherwise it will be leaked.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
adf4350_probe()
Add the missing clk_disable_unprepare() before return
from adf4350_probe() in the error handling case.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Reviewed-by: Lars-Peter CLausen <lars@metafoo.de>
Modify the code to use current_euid(), and in_egroup_p, as in done
in fs/proc/proc_sysctl.c:test_perm()
Cc: stable@vger.kernel.org
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
Reported-by: Eric Sandeen <sandeen@redhat.com>
Pull SCSI target fixes from Nicholas Bellinger:
"Here are the outstanding target fixes queued up for v3.12-rc4 code.
The highlights include:
- Make vhost/scsi tag percpu_ida_alloc() use GFP_ATOMIC
- Allow sess_cmd_map allocation failure fallback to use vzalloc
- Fix COMPARE_AND_WRITE se_cmd->data_length bug with FILEIO backends
- Fixes for COMPARE_AND_WRITE callback recursive failure OOPs + non
zero scsi_status bug
- Make iscsi-target do acknowledgement tag release from RX context
- Setup iscsi-target with extra (cmdsn_depth / 2) percpu_ida tags
Also included is a iscsi-target patch CC'ed for v3.10+ that avoids
legacy wait_for_task=true release during fast-past StatSN
acknowledgement, and two other SRP target related patches that address
long-standing issues that are CC'ed for v3.3+.
Extra thanks to Thomas Glanzmann for his testing feedback with
COMPARE_AND_WRITE + EXTENDED_COPY VAAI logic"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iscsi-target; Allow an extra tag_num / 2 number of percpu_ida tags
iscsi-target: Perform release of acknowledged tags from RX context
iscsi-target: Only perform wait_for_tasks when performing shutdown
target: Fail on non zero scsi_status in compare_and_write_callback
target: Fix recursive COMPARE_AND_WRITE callback failure
target: Reset data_length for COMPARE_AND_WRITE to NoLB * block_size
ib_srpt: always set response for task management
target: Fall back to vzalloc upon ->sess_cmd_map kzalloc failure
vhost/scsi: Use GFP_ATOMIC with percpu_ida_alloc for obtaining tag
ib_srpt: Destroy cm_id before destroying QP.
target: Fix xop->dbl assignment in target_xcopy_parse_segdesc_02
Pull slave-dmaengine fixes from Vinod Koul:
"Here is the slave dmanegine fixes. We have the fix for deadlock issue
on imx-dma by Michael and Josh's edma config fix along with author
change"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: imx-dma: fix callback path in tasklet
dmaengine: imx-dma: fix lockdep issue between irqhandler and tasklet
dmaengine: imx-dma: fix slow path issue in prep_dma_cyclic
dma/Kconfig: Make TI_EDMA select TI_PRIV_EDMA
edma: Update author email address
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"This is a small collection of fixes, including a regression fix from
Liu Bo that solves rare crashes with compression on.
I've merged my for-linus up to 3.12-rc3 because the top commit is only
meant for 3.12. The rest of the fixes are also available in my master
branch on top of my last 3.11 based pull"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
btrfs: Fix crash due to not allocating integrity data for a bioset
Btrfs: fix a use-after-free bug in btrfs_dev_replace_finishing
Btrfs: eliminate races in worker stopping code
Btrfs: fix crash of compressed writes
Btrfs: fix transid verify errors when recovering log tree
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Two patches for the OMAP driver, dealing with setting up IRQs properly
on the device tree boot path"
* tag 'gpio-v3.12-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio/omap: auto-setup a GPIO when used as an IRQ
gpio/omap: maintain GPIO and IRQ usage separately
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are none fixes for various USB driver problems. The majority are
gadget/musb fixes, but there are some new device ids in here as well"
* tag 'usb-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usb: chipidea: add Intel Clovertrail pci id
usb: gadget: s3c-hsotg: fix can_write limit for non-periodic endpoints
usb: gadget: f_fs: fix error handling
usb: musb: dsps: do not bind to "musb-hdrc"
USB: serial: option: Ignore card reader interface on Huawei E1750
usb: musb: gadget: fix otg active status flag
usb: phy: gpio-vbus: fix deferred probe from __init
usb: gadget: pxa25x_udc: fix deferred probe from __init
usb: musb: fix otg default state
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty fixes from Greg KH:
"Here are two tty driver fixes for 3.12-rc4.
One fixes the reported regression in the n_tty code that a number of
people found recently, and the other one fixes an issue with xen
consoles that broke in 3.10"
* tag 'tty-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
xen/hvc: allow xenboot console to be used again
tty: Fix pty master read() after slave closes
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging fixes from Greg KH:
"Here are 4 tiny staging and iio driver fixes for 3.12-rc4. Nothing
major, just some small fixes for reported issues"
* tag 'staging-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: comedi: ni_65xx: (bug fix) confine insn_bits to one subdevice
iio:magnetometer: Bugfix magnetometer default output registers
iio: Remove debugfs entries in iio_device_unregister()
iio: amplifiers: ad8366: Remove regulator_put
When btrfs creates a bioset, we must also allocate the integrity data pool.
Otherwise btrfs will crash when it tries to submit a bio to a checksumming
disk:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150
PGD 2305e4067 PUD 23063d067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: btrfs scsi_debug xfs ext4 jbd2 ext3 jbd mbcache
sch_fq_codel eeprom lpc_ich mfd_core nfsd exportfs auth_rpcgss af_packet
raid6_pq xor zlib_deflate libcrc32c [last unloaded: scsi_debug]
CPU: 1 PID: 4486 Comm: mount Not tainted 3.12.0-rc1-mcsum #2
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff8802451c9720 ti: ffff880230698000 task.ti: ffff880230698000
RIP: 0010:[<ffffffff8111e28a>] [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150
RSP: 0018:ffff880230699688 EFLAGS: 00010286
RAX: 0000000000000001 RBX: 0000000000000000 RCX: 00000000005f8445
RDX: 0000000000000001 RSI: 0000000000000010 RDI: 0000000000000000
RBP: ffff8802306996f8 R08: 0000000000011200 R09: 0000000000000008
R10: 0000000000000020 R11: ffff88009d6e8000 R12: 0000000000011210
R13: 0000000000000030 R14: ffff8802306996b8 R15: ffff8802451c9720
FS: 00007f25b8a16800(0000) GS:ffff88024fc80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000018 CR3: 0000000230576000 CR4: 00000000000007e0
Stack:
ffff8802451c9720 0000000000000002 ffffffff81a97100 0000000000281250
ffffffff81a96480 ffff88024fc99150 ffff880228d18200 0000000000000000
0000000000000000 0000000000000040 ffff880230e8c2e8 ffff8802459dc900
Call Trace:
[<ffffffff811b2208>] bio_integrity_alloc+0x48/0x1b0
[<ffffffff811b26fc>] bio_integrity_prep+0xac/0x360
[<ffffffff8111e298>] ? mempool_alloc+0x58/0x150
[<ffffffffa03e8041>] ? alloc_extent_state+0x31/0x110 [btrfs]
[<ffffffff81241579>] blk_queue_bio+0x1c9/0x460
[<ffffffff8123e58a>] generic_make_request+0xca/0x100
[<ffffffff8123e639>] submit_bio+0x79/0x160
[<ffffffffa03f865e>] btrfs_map_bio+0x48e/0x5b0 [btrfs]
[<ffffffffa03c821a>] btree_submit_bio_hook+0xda/0x110 [btrfs]
[<ffffffffa03e7eba>] submit_one_bio+0x6a/0xa0 [btrfs]
[<ffffffffa03ef450>] read_extent_buffer_pages+0x250/0x310 [btrfs]
[<ffffffff8125eef6>] ? __radix_tree_preload+0x66/0xf0
[<ffffffff8125f1c5>] ? radix_tree_insert+0x95/0x260
[<ffffffffa03c66f6>] btree_read_extent_buffer_pages.constprop.128+0xb6/0x120
[btrfs]
[<ffffffffa03c8c1a>] read_tree_block+0x3a/0x60 [btrfs]
[<ffffffffa03caefd>] open_ctree+0x139d/0x2030 [btrfs]
[<ffffffffa03a282a>] btrfs_mount+0x53a/0x7d0 [btrfs]
[<ffffffff8113ab0b>] ? pcpu_alloc+0x8eb/0x9f0
[<ffffffff81167305>] ? __kmalloc_track_caller+0x35/0x1e0
[<ffffffff81176ba0>] mount_fs+0x20/0xd0
[<ffffffff81191096>] vfs_kern_mount+0x76/0x120
[<ffffffff81193320>] do_mount+0x200/0xa40
[<ffffffff81135cdb>] ? strndup_user+0x5b/0x80
[<ffffffff81193bf0>] SyS_mount+0x90/0xe0
[<ffffffff8156d31d>] system_call_fastpath+0x1a/0x1f
Code: 4c 8d 75 a8 4c 89 6d e8 45 89 e0 4c 8d 6f 30 48 89 5d d8 41 83 e0 af 48
89 fb 49 83 c6 18 4c 89 7d f8 65 4c 8b 3c 25 c0 b8 00 00 <48> 8b 73 18 44 89 c7
44 89 45 98 ff 53 20 48 85 c0 48 89 c2 74
RIP [<ffffffff8111e28a>] mempool_alloc+0x4a/0x150
RSP <ffff880230699688>
---[ end trace 7a96042017ed21e2 ]---
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
Pull CIFS fixes from Steve French:
"Small set of cifs fixes. Most important is Jeff's fix that works
around disconnection problems which can be caused by simultaneous use
of user space tools (starting a long running smbclient backup then
doing a cifs kernel mount) or multiple cifs mounts through a NAT, and
Jim's fix to deal with reexport of cifs share.
I expect to send two more cifs fixes next week (being tested now) -
fixes to address an SMB2 unmount hang when server dies and a fix for
cifs symlink handling of Windows "NFS" symlinks"
* 'for-linus' of git://git.samba.org/sfrench/cifs-2.6:
[CIFS] update cifs.ko version
[CIFS] Remove ext2 flags that have been moved to fs.h
[CIFS] Provide sane values for nlink
cifs: stop trying to use virtual circuits
CIFS: FS-Cache: Uncache unread pages in cifs_readpages() before freeing them
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fix from Bjorn Helgaas:
"We merged what was intended to be an MMCONFIG cleanup, but in fact,
for systems without _CBA (which is almost everything), it broke
extended config space for domain 0 and it broke all config space for
other domains.
This reverts the change"
* tag 'pci-v3.12-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
Revert "x86/PCI: MMCONFIG: Check earlier for MMCONFIG region at address zero"
This reverts commit 07f9b61c3915e8eb156cb4461b3946736356ad02.
07f9b61c was intended to be a cleanup that didn't change anything, but in
fact, for systems without _CBA (which is almost everything), it broke
extended config space for domain 0 and all config space for other domains.
Reference: http://lkml.kernel.org/r/20131004011806.GE20450@dangermouse.emea.sgi.com
Reported-by: Hedi Berriche <hedi@sgi.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Pull ACPI and power management fixes from Rafael Wysocki:
- The resume part of user space driven hibernation (s2disk) is now
broken after the change that moved the creation of memory bitmaps to
after the freezing of tasks, because I forgot that the resume utility
loaded the image before freezing tasks and needed the bitmaps for
that. The fix adds special handling for that case.
- One of recent commits changed the export of acpi_bus_get_device() to
EXPORT_SYMBOL_GPL(), which was technically correct but broke existing
binary modules using that function including one in particularly
widespread use. Change it back to EXPORT_SYMBOL().
- The intel_pstate driver sometimes fails to disable turbo if its
no_turbo sysfs attribute is set. Fix from Srinivas Pandruvada.
- One of recent cpufreq fixes forgot to update a check in cpufreq-cpu0
which still (incorrectly) treats non-NULL as non-error. Fix from
Philipp Zabel.
- The SPEAr cpufreq driver uses a wrong variable type in one place
preventing it from catching errors returned by one of the functions
called by it. Fix from Sachin Kamat.
* tag 'pm+acpi-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI: Use EXPORT_SYMBOL() for acpi_bus_get_device()
intel_pstate: fix no_turbo
cpufreq: cpufreq-cpu0: NULL is a valid regulator, part 2
cpufreq: SPEAr: Fix incorrect variable type
PM / hibernate: Fix user space driven resume regression
Pull xfs bugfixes from Ben Myers:
"There are lockdep annotations for project quotas, a fix for dirent
dtype support on v4 filesystems, a fix for a memory leak in recovery,
and a fix for the build error that resulted from it. D'oh"
* tag 'xfs-for-linus-v3.12-rc4' of git://oss.sgi.com/xfs/xfs:
xfs: Use kmem_free() instead of free()
xfs: fix memory leak in xlog_recover_add_to_trans
xfs: dirent dtype presence is dependent on directory magic numbers
xfs: lockdep needs to know about 3 dquot-deep nesting
Now avc_audit() has no more users with that parameter. Remove it.
.. so get rid of it. The only indirect users were all the
avc_has_perm() callers which just expanded to have a zero flags
argument.
free_device rcu callback, scheduled from btrfs_rm_dev_replace_srcdev,
can be processed before btrfs_scratch_superblock is called, which would
result in a use-after-free on btrfs_device contents. Fix this by
zeroing the superblock before the rcu callback is registered.
Cc: Stefan Behrens <sbehrens@giantdisaster.de>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
The current implementation of worker threads in Btrfs has races in
worker stopping code, which cause all kinds of panics and lockups when
running btrfs/011 xfstest in a loop. The problem is that
btrfs_stop_workers is unsynchronized with respect to check_idle_worker,
check_busy_worker and __btrfs_start_workers.
E.g., check_idle_worker race flow:
btrfs_stop_workers(): check_idle_worker(aworker):
- grabs the lock
- splices the idle list into the
working list
- removes the first worker from the
working list
- releases the lock to wait for
its kthread's completion
- grabs the lock
- if aworker is on the working list,
moves aworker from the working list
to the idle list
- releases the lock
- grabs the lock
- puts the worker
- removes the second worker from the
working list
btrfs_stop_workers returns, aworker is on the idle list
FS is umounted, memory is freed
aworker is waken up, fireworks ensue
With this applied, I wasn't able to trigger the problem in 48 hours,
whereas previously I could reliably reproduce at least one of these
races within an hour.
Reported-by: David Sterba <dsterba@suse.cz>
The crash[1] is found by xfstests/generic/208 with "-o compress",
it's not reproduced everytime, but it does panic.
The bug is quite interesting, it's actually introduced by a recent commit
(573aecafca1cf7a974231b759197a1aebcf39c2a,
Btrfs: actually limit the size of delalloc range).
Btrfs implements delay allocation, so during writeback, we
(1) get a page A and lock it
(2) search the state tree for delalloc bytes and lock all pages within the range
(3) process the delalloc range, including find disk space and create
ordered extent and so on.
(4) submit the page A.
It runs well in normal cases, but if we're in a racy case, eg.
buffered compressed writes and aio-dio writes,
sometimes we may fail to lock all pages in the 'delalloc' range,
in which case, we need to fall back to search the state tree again with
a smaller range limit(max_bytes = PAGE_CACHE_SIZE - offset).
The mentioned commit has a side effect, that is, in the fallback case,
we can find delalloc bytes before the index of the page we already have locked,
so we're in the case of (delalloc_end <= *start) and return with (found > 0).
This ends with not locking delalloc pages but making ->writepage still
process them, and the crash happens.
This fixes it by just thinking that we find nothing and returning to caller
as the caller knows how to deal with it properly.
[1]:
kernel BUG at mm/page-writeback.c:2170!
CPU: 2 PID: 11755 Comm: btrfs-delalloc- Tainted: G O 3.11.0+ #8
RIP: 0010:[<ffffffff810f5093>] [<ffffffff810f5093>] clear_page_dirty_for_io+0x1e/0x83
[ 4934.248731] Stack:
[ 4934.248731] ffff8801477e5dc8 ffffea00049b9f00 ffff8801869f9ce8 ffffffffa02b841a
[ 4934.248731] 0000000000000000 0000000000000000 0000000000000fff 0000000000000620
[ 4934.248731] ffff88018db59c78 ffffea0005da8d40 ffffffffa02ff860 00000001810016c0
[ 4934.248731] Call Trace:
[ 4934.248731] [<ffffffffa02b841a>] extent_range_clear_dirty_for_io+0xcf/0xf5 [btrfs]
[ 4934.248731] [<ffffffffa02a8889>] compress_file_range+0x1dc/0x4cb [btrfs]
[ 4934.248731] [<ffffffff8104f7af>] ? detach_if_pending+0x22/0x4b
[ 4934.248731] [<ffffffffa02a8bad>] async_cow_start+0x35/0x53 [btrfs]
[ 4934.248731] [<ffffffffa02c694b>] worker_loop+0x14b/0x48c [btrfs]
[ 4934.248731] [<ffffffffa02c6800>] ? btrfs_queue_worker+0x25c/0x25c [btrfs]
[ 4934.248731] [<ffffffff810608f5>] kthread+0x8d/0x95
[ 4934.248731] [<ffffffff81060868>] ? kthread_freezable_should_stop+0x43/0x43
[ 4934.248731] [<ffffffff814fe09c>] ret_from_fork+0x7c/0xb0
[ 4934.248731] Code: ff 85 c0 0f 94 c0 0f b6 c0 59 5b 5d c3 0f 1f 44 00 00 55 48 89 e5 41 54 53 48 89 fb e8 2c de 00 00 49 89 c4 48 8b 03 a8 01 75 02 <0f> 0b 4d 85 e4 74 52 49 8b 84 24 80 00 00 00 f6 40 20 01 75 44
[ 4934.248731] RIP [<ffffffff810f5093>] clear_page_dirty_for_io+0x1e/0x83
[ 4934.248731] RSP <ffff8801869f9c48>
[ 4934.280307] ---[ end trace 36f06d3f8750236a ]---
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
If we crash with a log, remount and recover that log, and then crash before we
can commit another transaction we will get transid verify errors on the next
mount. This is because we were not zero'ing out the log when we committed the
transaction after recovery. This is ok as long as we commit another transaction
at some point in the future, but if you abort or something else goes wrong you
can end up in this weird state because the recovery stuff says that the tree log
should have a generation+1 of the super generation, which won't be the case of
the transaction that was started for recovery. Fix this by removing the check
and _always_ zero out the log portion of the super when we commit a transaction.
This fixes the transid verify issues I was seeing with my force errors tests.
Thanks,
Every single user passes in '0'. I think we had non-zero users back in
some stone age when selinux_inode_permission() was implemented in terms
of inode_has_perm(), but that complicated case got split up into a
totally separate code-path so that we could optimize the much simpler
special cases.
See commit 2e33405785d3 ("SELinux: delay initialization of audit data in
selinux_inode_permission") for example.
This fixes a build failure caused by calling the free() function which
does not exist in the Linux kernel.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit aaaae98022efa4f3c31042f1fdf9e7a0c5f04663)
Free the memory in error path of xlog_recover_add_to_trans().
Normally this memory is freed in recovery pass2, but is leaked
in the error path.
Signed-off-by: Mark Tinguely <tinguely@sgi.com>
(cherry picked from commit 519ccb81ac1c8e3e4eed294acf93be00b43dcad6)
The determination of whether a directory entry contains a dtype
field originally was dependent on the filesystem having CRCs
enabled. This meant that the format for dtype beign enabled could be
determined by checking the directory block magic number rather than
doing a feature bit check. This was useful in that it meant that we
didn't need to pass a struct xfs_mount around to functions that
were already supplied with a directory block header.
Unfortunately, the introduction of dtype fields into the v4
structure via a feature bit meant this "use the directory block
magic number" method of discriminating the dirent entry sizes is
broken. Hence we need to convert the places that use magic number
checks to use feature bit checks so that they work correctly and not
by chance.
The current code works on v4 filesystems only because the dirent
size roundup covers the extra byte needed by the dtype field in the
places where this problem occurs.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Ben Myers <bpm@sgi.com>
(cherry picked from commit 367993e7c6428cb7617ab7653d61dca54e2fdede)
Michael Semon reported that xfs/299 generated this lockdep warning:
[ INFO: possible recursive locking detected ]
3.12.0-rc2+ #2 Not tainted
touch/21072 is trying to acquire lock:
(&xfs_dquot_other_class){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64
but task is already holding lock:
Possible unsafe locking scenario:
CPU0
lock(&xfs_dquot_other_class);
*** DEADLOCK ***
May be due to missing lock nesting notation
7 locks held by touch/21072:
#0: (sb_writers#10){++++.+}, at: [<c11185b6>] mnt_want_write+0x1e/0x3e
#1: (&type->i_mutex_dir_key#4){+.+.+.}, at: [<c11078ee>] do_last+0x245/0xe40
#2: (sb_internal#2){++++.+}, at: [<c122c9e0>] xfs_trans_alloc+0x1f/0x35
#3: (&(&ip->i_lock)->mr_lock/1){+.+...}, at: [<c126cd1b>] xfs_ilock+0x100/0x1f1
#4: (&(&ip->i_lock)->mr_lock){++++-.}, at: [<c126cf52>] xfs_ilock_nowait+0x105/0x22f
#5: (&dqp->q_qlock){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64
#6: (&xfs_dquot_other_class){+.+...}, at: [<c12902fb>] xfs_trans_dqlockedjoin+0x57/0x64
The lockdep annotation for dquot lock nesting only understands
locking for user and "other" dquots, not user, group and quota
dquots. Fix the annotations to match the locking heirarchy we now
have.
Reported-by: Michael L. Semon <mlsemon35@gmail.com>
(cherry picked from commit f112a049712a5c07de25d511c3c6587a2b1a015e)
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse bugfixes from Miklos Szeredi:
"This contains two more fixes by Maxim for writeback/truncate races and
fixes for RCU walk in fuse_dentry_revalidate()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: no RCU mode in fuse_access()
fuse: readdirplus: fix RCU walk
fuse: don't check_submounts_and_drop() in RCU walk
fuse: fix fallocate vs. ftruncate race
fuse: wait for writeback in fuse_file_fallocate()
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu fixes from Joerg Roedel:
"A couple of fixes from the IOMMU side:
- some small fixes for the new ARM-SMMU driver
- a register offset correction for VT-d
- add MAINTAINERS entry for drivers/iommu
Overall no really big or intrusive changes"
* tag 'iommu-fixes-v3.12-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
x86/iommu: correct ICS register offset
MAINTAINERS: add overall IOMMU section
iommu/arm-smmu: don't enable SMMU device until probing has completed
iommu/arm-smmu: fix iommu_present() test in init
iommu/arm-smmu: fix a signedness bug
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull ARM64 fixes/updates from Catalin Marinas:
- Bug-fixes (get_user/put_user, incorrect register width for ASID,
FPSIMD initialisation)
- Kconfig clean-up
- defconfig update
* tag 'arm64-stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
arm64: Remove duplicate DEBUG_STACK_USAGE config
arm64: include VIRTIO_{MMIO,BLK} in defconfig
arm64: include EXT4 in defconfig
arm64: fix possible invalid FPSIMD initialization state
arm64: use correct register width when retrieving ASID
arm64: avoid multiple evaluation of ptr in get_user/put_user()
Pull MIPS fixes from Ralf Baechle:
"Two small fixes for 3.12 only this week. I have a few more fixes
pending but those are conceptually more complex so will have to wait
for a bit longer"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: Fix forgotten preempt_enable() when CPU has inclusive pcaches
MIPS: Alchemy: MTX-1: fix incorrect placement of __initdata tag
Pull x86 fixes from Ingo Molnar:
"Two simplefb fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/simplefb: Mark framebuffer mem-resources as IORESOURCE_BUSY to avoid bootup warning
x86/simplefb: Fix overflow causing bogus fall-back
Pull irq fix from Ingo Molnar:
"Frederic's minimal fix for hardirq/softirq nesting crashes"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irq: Force hardirq exit's softirq processing on its own stack
We need to free the ld_active list head before jumping into the callback
routine. Otherwise the callback could run into issue_pending and change
our ld_active list head we just going to free. This will run the channel
list into an currupted and undefined state.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
The tasklet and irqhandler are using spin_lock while other routines are
using spin_lock_irqsave/restore. This leads to lockdep issues as
described bellow. This patch is changing the code to use
spinlock_irq_save/restore in both code pathes.
As imxdma_xfer_desc always gets called with spin_lock_irqsave lock held,
this patch also removes the spare call inside the routine to avoid
double locking.
[ 403.358162] =================================
[ 403.362549] [ INFO: inconsistent lock state ]
[ 403.366945] 3.10.0-20130823+ #904 Not tainted
[ 403.371331] ---------------------------------
[ 403.375721] inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage.
[ 403.381769] swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 403.386762] (&(&imxdma->lock)->rlock){?.-...}, at: [<c019d77c>] imxdma_tasklet+0x20/0x134
[ 403.395201] {IN-HARDIRQ-W} state was registered at:
[ 403.400108] [<c004b264>] mark_lock+0x2a0/0x6b4
[ 403.404798] [<c004d7c8>] __lock_acquire+0x650/0x1a64
[ 403.410004] [<c004f15c>] lock_acquire+0x94/0xa8
[ 403.414773] [<c02f74e4>] _raw_spin_lock+0x54/0x8c
[ 403.419720] [<c019d094>] dma_irq_handler+0x78/0x254
[ 403.424845] [<c0061124>] handle_irq_event_percpu+0x38/0x1b4
[ 403.430670] [<c00612e4>] handle_irq_event+0x44/0x64
[ 403.435789] [<c0063a70>] handle_level_irq+0xd8/0xf0
[ 403.440903] [<c0060a20>] generic_handle_irq+0x28/0x38
[ 403.446194] [<c0009cc4>] handle_IRQ+0x68/0x8c
[ 403.450789] [<c0008714>] avic_handle_irq+0x3c/0x48
[ 403.455811] [<c0008f84>] __irq_svc+0x44/0x74
[ 403.460314] [<c0040b04>] cpu_startup_entry+0x88/0xf4
[ 403.465525] [<c02f00d0>] rest_init+0xb8/0xe0
[ 403.470045] [<c03e07dc>] start_kernel+0x28c/0x2d4
[ 403.474986] [<a0008040>] 0xa0008040
[ 403.478709] irq event stamp: 50854
[ 403.482140] hardirqs last enabled at (50854): [<c001c6b8>] tasklet_action+0x38/0xdc
[ 403.489954] hardirqs last disabled at (50853): [<c001c6a0>] tasklet_action+0x20/0xdc
[ 403.497761] softirqs last enabled at (50850): [<c001bc64>] _local_bh_enable+0x14/0x18
[ 403.505741] softirqs last disabled at (50851): [<c001c268>] irq_exit+0x88/0xdc
[ 403.513026]
[ 403.513026] other info that might help us debug this:
[ 403.519593] Possible unsafe locking scenario:
[ 403.519593]
[ 403.525548] CPU0
[ 403.528020] ----
[ 403.530491] lock(&(&imxdma->lock)->rlock);
[ 403.534828] <Interrupt>
[ 403.537474] lock(&(&imxdma->lock)->rlock);
[ 403.541983]
[ 403.541983] *** DEADLOCK ***
[ 403.541983]
[ 403.547951] no locks held by swapper/0.
[ 403.551813]
[ 403.551813] stack backtrace:
[ 403.556222] CPU: 0 PID: 0 Comm: swapper Not tainted 3.10.0-20130823+ #904
[ 403.563039] Backtrace:
[ 403.565581] [<c000b98c>] (dump_backtrace+0x0/0x10c) from [<c000bb28>] (show_stack+0x18/0x1c)
[ 403.574054] r6:00000000 r5:c05c51d8 r4:c040bd58 r3:00200000
[ 403.579872] [<c000bb10>] (show_stack+0x0/0x1c) from [<c02f398c>] (dump_stack+0x20/0x28)
[ 403.587955] [<c02f396c>] (dump_stack+0x0/0x28) from [<c02f29c8>] (print_usage_bug.part.28+0x224/0x28c)
[ 403.597340] [<c02f27a4>] (print_usage_bug.part.28+0x0/0x28c) from [<c004b404>] (mark_lock+0x440/0x6b4)
[ 403.606682] r8:c004a41c r7:00000000 r6:c040bd58 r5:c040c040 r4:00000002
[ 403.613566] [<c004afc4>] (mark_lock+0x0/0x6b4) from [<c004d844>] (__lock_acquire+0x6cc/0x1a64)
[ 403.622244] [<c004d178>] (__lock_acquire+0x0/0x1a64) from [<c004f15c>] (lock_acquire+0x94/0xa8)
[ 403.631010] [<c004f0c8>] (lock_acquire+0x0/0xa8) from [<c02f74e4>] (_raw_spin_lock+0x54/0x8c)
[ 403.639614] [<c02f7490>] (_raw_spin_lock+0x0/0x8c) from [<c019d77c>] (imxdma_tasklet+0x20/0x134)
[ 403.648434] r6:c3847010 r5:c040e890 r4:c38470d4
[ 403.653194] [<c019d75c>] (imxdma_tasklet+0x0/0x134) from [<c001c70c>] (tasklet_action+0x8c/0xdc)
[ 403.662013] r8:c0599160 r7:00000000 r6:00000000 r5:c040e890 r4:c3847114 r3:c019d75c
[ 403.670042] [<c001c680>] (tasklet_action+0x0/0xdc) from [<c001bd4c>] (__do_softirq+0xe4/0x1f0)
[ 403.678687] r7:00000101 r6:c0402000 r5:c059919c r4:00000001
[ 403.684498] [<c001bc68>] (__do_softirq+0x0/0x1f0) from [<c001c268>] (irq_exit+0x88/0xdc)
[ 403.692652] [<c001c1e0>] (irq_exit+0x0/0xdc) from [<c0009cc8>] (handle_IRQ+0x6c/0x8c)
[ 403.700514] r4:00000030 r3:00000110
[ 403.704192] [<c0009c5c>] (handle_IRQ+0x0/0x8c) from [<c0008714>] (avic_handle_irq+0x3c/0x48)
[ 403.712664] r5:c0403f28 r4:c0593ebc
[ 403.716343] [<c00086d8>] (avic_handle_irq+0x0/0x48) from [<c0008f84>] (__irq_svc+0x44/0x74)
[ 403.724733] Exception stack(0xc0403f28 to 0xc0403f70)
[ 403.729841] 3f20: 00000001 00000004 00000000 20000013 c0402000 c04104a8
[ 403.738078] 3f40: 00000002 c0b69620 a0004000 41069264 a03fb5f4 c0403f7c c0403f40 c0403f70
[ 403.746301] 3f60: c004b92c c0009e74 20000013 ffffffff
[ 403.751383] r6:ffffffff r5:20000013 r4:c0009e74 r3:c004b92c
[ 403.757210] [<c0009e30>] (arch_cpu_idle+0x0/0x4c) from [<c0040b04>] (cpu_startup_entry+0x88/0xf4)
[ 403.766161] [<c0040a7c>] (cpu_startup_entry+0x0/0xf4) from [<c02f00d0>] (rest_init+0xb8/0xe0)
[ 403.774753] [<c02f0018>] (rest_init+0x0/0xe0) from [<c03e07dc>] (start_kernel+0x28c/0x2d4)
[ 403.783051] r6:c03fc484 r5:ffffffff r4:c040a0e0
[ 403.787797] [<c03e0550>] (start_kernel+0x0/0x2d4) from [<a0008040>] (0xa0008040)
When perparing cyclic_dma buffers by the sound layer, it will dump the
following lockdep trace. The leading snd_pcm_action_single get called
with read_lock_irq called. To fix this, we change the kcalloc call from
GFP_KERNEL to GFP_ATOMIC.
WARNING: at kernel/lockdep.c:2740 lockdep_trace_alloc+0xcc/0x114()
DEBUG_LOCKS_WARN_ON(irqs_disabled_flags(flags))
Modules linked in:
CPU: 0 PID: 832 Comm: aplay Not tainted 3.11.0-20130823+ #903
Backtrace:
r6:c004c090 r5:00000009 r4:c2e0bd18 r3:00404000
[<c000bb10>] (show_stack+0x0/0x1c) from [<c02f397c>] (dump_stack+0x20/0x28)
[<c02f395c>] (dump_stack+0x0/0x28) from [<c001531c>] (warn_slowpath_common+0x54/0x70)
[<c00152c8>] (warn_slowpath_common+0x0/0x70) from [<c00153dc>] (warn_slowpath_fmt+0x38/0x40)
r8:00004000 r7:a3b90000 r6:000080d0 r5:60000093 r4:c2e0a000 r3:00000009
[<c00153a4>] (warn_slowpath_fmt+0x0/0x40) from [<c004c090>] (lockdep_trace_alloc+0xcc/0x114)
r3:c03955d8 r2:c03907db
[<c004bfc4>] (lockdep_trace_alloc+0x0/0x114) from [<c008f16c>] (__kmalloc+0x34/0x118)
r6:000080d0 r5:c3800120 r4:000080d0 r3:c040a0f8
[<c008f138>] (__kmalloc+0x0/0x118) from [<c019c95c>] (imxdma_prep_dma_cyclic+0x64/0x168)
r7:a3b90000 r6:00000004 r5:c39d8420 r4:c3847150
[<c019c8f8>] (imxdma_prep_dma_cyclic+0x0/0x168) from [<c024618c>] (snd_dmaengine_pcm_trigger+0xa8/0x160)
[<c02460e4>] (snd_dmaengine_pcm_trigger+0x0/0x160) from [<c0241fa8>] (soc_pcm_trigger+0x90/0xb4)
r8:c058c7b0 r7:c3b8140c r6:c39da560 r5:00000001 r4:c3b81000
[<c0241f18>] (soc_pcm_trigger+0x0/0xb4) from [<c022ece4>] (snd_pcm_do_start+0x2c/0x38)
r7:00000000 r6:00000003 r5:c058c7b0 r4:c3b81000
[<c022ecb8>] (snd_pcm_do_start+0x0/0x38) from [<c022e958>] (snd_pcm_action_single+0x40/0x6c)
[<c022e918>] (snd_pcm_action_single+0x0/0x6c) from [<c022ea64>] (snd_pcm_action_lock_irq+0x7c/0x9c)
r7:00000003 r6:c3b810f0 r5:c3b810f0 r4:c3b81000
[<c022e9e8>] (snd_pcm_action_lock_irq+0x0/0x9c) from [<c023009c>] (snd_pcm_common_ioctl1+0x7f8/0xfd0)
r8:c3b7f888 r7:005407b8 r6:c2c991c0 r5:c3b81000 r4:c3b81000 r3:00004142
[<c022f8a4>] (snd_pcm_common_ioctl1+0x0/0xfd0) from [<c023117c>] (snd_pcm_playback_ioctl1+0x464/0x488)
[<c0230d18>] (snd_pcm_playback_ioctl1+0x0/0x488) from [<c02311d4>] (snd_pcm_playback_ioctl+0x34/0x40)
r8:c3b7f888 r7:00004142 r6:00000004 r5:c2c991c0 r4:005407b8
[<c02311a0>] (snd_pcm_playback_ioctl+0x0/0x40) from [<c00a14a4>] (vfs_ioctl+0x30/0x44)
[<c00a1474>] (vfs_ioctl+0x0/0x44) from [<c00a1fe8>] (do_vfs_ioctl+0x55c/0x5c0)
[<c00a1a8c>] (do_vfs_ioctl+0x0/0x5c0) from [<c00a208c>] (SyS_ioctl+0x40/0x68)
[<c00a204c>] (SyS_ioctl+0x0/0x68) from [<c0009380>] (ret_fast_syscall+0x0/0x44)
r8:c0009544 r7:00000036 r6:bedeaa58 r5:00000000 r4:000000c0
Commit d0380e6c3c0f6edb986d8798a23acfaf33d5df23 (early_printk:
consolidate random copies of identical code) added in 3.10 introduced
a check for con->index == -1 in early_console_register().
Initialize index to -1 for the xenboot console so earlyprintk=xen
works again.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Also clean up the last item of the pci id list to be "cleaner".
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Cc: stable <stable@vger.kernel.org>
The `insn_bits` handler `ni_65xx_dio_insn_bits()` has a `for` loop that
currently writes (optionally) and reads back up to 5 "ports" consisting
of 8 channels each. It reads up to 32 1-bit channels but can only read
and write a whole port at once - it needs to handle up to 5 ports as the
first channel it reads might not be aligned on a port boundary. It
breaks out of the loop early if the next port it handles is beyond the
final port on the card. It also breaks out early on the 5th port in the
loop if the first channel was aligned. Unfortunately, it doesn't check
that the current port it is dealing with belongs to the comedi subdevice
the `insn_bits` handler is acting on. That's a bug.
Redo the `for` loop to terminate after the final port belonging to the
subdevice, changing the loop variable in the process to simplify things
a bit. The `for` loop could now try and handle more than 5 ports if the
subdevice has more than 40 channels, but the test `if (bitshift >= 32)`
ensures it will break out early after 4 or 5 ports (depending on whether
the first channel is aligned on a port boundary). (`bitshift` will be
between -7 and 7 inclusive on the first iteration, increasing by 8 for
each subsequent operation.)
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Cc: <stable@vger.kernel.org> # 3.10.y 3.11.y 3.12.y
This patch bumps the default number of tags allocated per session by
iscsi-target via transport_alloc_session_tags() -> percpu_ida_init()
by another (tag_num / 2).
This is done to take into account the tags waiting to be acknowledged
and released in iscsit_ack_from_expstatsn(), but who's number are not
directly limited by the CmdSN Window queue_depth being enforced by
the target.
Using a larger value here is also useful to prevent percpu_ida_alloc()
from having to steal tags from other CPUs when no tags are available
on the local CPU, while waiting for unacknowledged tags to be released.
This patch converts iscsit_ack_from_expstatsn() to populate a local
ack_list of commands, and call iscsit_free_cmd() directly from RX
thread context, instead of using iscsit_add_cmd_to_immediate_queue()
to queue the acknowledged commands to be released from TX thread
context.
It is helpful to release the acknowledge commands as quickly as
possible, along with the associated percpu_ida tags, in order to
prevent percpu_ida_alloc() from having to steal tags from other
CPUs while waiting for iscsit_free_cmd() to happen from TX thread
context.
This patch changes transport_generic_free_cmd() to only wait_for_tasks
when shutdown=true is passed to iscsit_free_cmd().
With the advent of >= v3.10 iscsi-target code using se_cmd->cmd_kref,
the extra wait_for_tasks with shutdown=false is unnecessary, and may
end up causing an extra context switch when releasing WRITEs.
Cc: stable@vger.kernel.org # 3.10+
Pull kvm NULL deref fix from Gleb Natapov.
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
Fix NULL dereference in gfn_to_hva_prot()
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC fix from Vineet Gupta:
"Chrisitian found/fixed issue with SA_SIGINFO based signal handler
corrupting the user space registers post after signal handling"
* 'for-curr' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: Fix signal frame management for SA_SIGINFO
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Ben Herrenschmidt:
"Here are a few powerpc fixes, all aimed at -stable, found in part
thanks to the ramping up of a major distro testing and in part thanks
to the LE guys hitting all sort interesting corner cases.
The most scary are probably the register clobber issues in
csum_partial_copy_generic(), especially since Anton even had a test
case for that thing, which didn't manage to hit the bugs :-)
Another highlight is that memory hotplug should work again with these
fixes.
Oh and the vio modalias one is worse than the cset implies as it
upsets distro installers, so I've been told at least, which is why I'm
shooting it to stable"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/tm: Switch out userspace PPR and DSCR sooner
powerpc/tm: Turn interrupts hard off in tm_reclaim()
powerpc/perf: Fix handling of FAB events
powerpc/vio: Fix modalias_show return values
powerpc/iommu: Use GFP_KERNEL instead of GFP_ATOMIC in iommu_init_table()
powerpc/sysfs: Disable writing to PURR in guest mode
powerpc: Restore registers on error exit from csum_partial_copy_generic()
powerpc: Fix parameter clobber in csum_partial_copy_generic()
powerpc: Fix memory hotplug with sparse vmemmap
This patch addresses a bug for backends such as IBLOCK that perform
asynchronous completion via transport_complete_cmd(), that will call
target_complete_failure_work() -> transport_generic_request_failure(),
upon exception status and invoke cmd->transport_complete_callback()
-> compare_and_write_callback() incorrectly during the failure case.
It adds a check for a non zero se_cmd->scsi_status within the first
invocation of compare_and_write_callback(), and will jump to out plus
up se_device->caw_sem before exiting the callback.
Reported-by: Thomas Glanzmann <thomas@glanzmann.de>
Tested-by: Thomas Glanzmann <thomas@glanzmann.de>
This patch addresses a bug when compare_and_write_callback() invoked from
target_complete_ok_work() hits an failure from __target_execute_cmd() ->
cmd->execute_cmd(), that ends up calling transport_generic_request_failure()
-> compare_and_write_post(), thus causing SCF_COMPARE_AND_WRITE_POST to
incorrectly be set.
The result of this bug is that target_complete_ok_work() no longer hits
the if (!rc && !(cmd->se_cmd_flags & SCF_COMPARE_AND_WRITE_POST) check
that forces an immediate return, and instead double completes the se_cmd
in question, triggering an OOPs in the process.
This patch changes compare_and_write_post() to only set this bit when a
failure has not already occured to ensure the immediate return from within
target_complete_ok_work(), and thus allow transport_generic_request_failure()
to handle the sending of the CHECK_CONDITION exception status.
This patch resets se_cmd->data_length for COMPARE_AND_WRITE emulation
within sbc_compare_and_write() to NoLB * block_size in order to address
a bug with FILEIO backends where a I/O failure will occur when data_length
does not match the I/O size being actually dispatched for the individual
per block READs + WRITEs.
This is done late enough in sbc_compare_and_write() after the memory
allocations have occured in transport_generic_new_cmd() to not cause
any unwanted side-effects.
