Pull NTFS update from Anton Altaparmakov:
"Here is a small NTFS update notably implementing FIBMAP ioctl for NTFS
by adding the bmap address space operation. People seem to still want
FIBMAP"
* git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfs:
NTFS: Bump version to 2.1.31.
NTFS: Add bmap address space operation needed for FIBMAP ioctl.
NTFS: Remove changelog from Documentation/filesystems/ntfs.txt.
NTFS: Split ntfs_aops into ntfs_normal_aops and ntfs_compressed_aops in preparation for them diverging.
Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable fixes:
- fix an uninitialised pointer Oops in the writeback error path
- fix a bogus warning (and early exit from the loop) in nfs_generic_pgio()
Features:
- Add NFSv4.2 SEEK feature and client support for lseek(SEEK_HOLE/SEEK_DATA)
Other fixes:
- pnfs: replace broken pnfs_put_lseg_async
- Remove dead prototype for nfs4_insert_deviceid_node"
* tag 'nfs-for-3.18-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFS: Fix a bogus warning in nfs_generic_pgio
NFS: Fix an uninitialised pointer Oops in the writeback error path
NFSv4.1/pnfs: replace broken pnfs_put_lseg_async
NFSv4: Remove dead prototype for nfs4_insert_deviceid_node()
NFS: Implement SEEK
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device-mapper updates from Mike Snitzer:
"I rebased the DM tree ontop of linux-block.git's 'for-3.18/core' at
the beginning of October because DM core now depends on the newly
introduced bioset_create_nobvec() interface.
Summary:
- fix DM's long-standing excessive use of memory by leveraging the
new bioset_create_nobvec() interface when creating the DM's bioset
- fix a few bugs in dm-bufio and dm-log-userspace
- add DM core support for a DM multipath use-case that requires
loading DM tables that contain devices that have failed (by
allowing active and inactive DM tables to share dm_devs)
- add discard support to the DM raid target; like MD raid456 the user
must opt-in to raid456 discard support be specifying the
devices_handle_discard_safely=Y module param"
* tag 'dm-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm log userspace: fix memory leak in dm_ulog_tfr_init failure path
dm bufio: when done scanning return from __scan immediately
dm bufio: update last_accessed when relinking a buffer
dm raid: add discard support for RAID levels 4, 5 and 6
dm raid: add discard support for RAID levels 1 and 10
dm: allow active and inactive tables to share dm_devs
dm mpath: stop queueing IO when no valid paths exist
dm: use bioset_create_nobvec()
dm: remove nr_iovecs parameter from alloc_tio()
Pull block layer driver update from Jens Axboe:
"This is the block driver pull request for 3.18. Not a lot in there
this round, and nothing earth shattering.
- A round of drbd fixes from the linbit team, and an improvement in
asender performance.
- Removal of deprecated (and unused) IRQF_DISABLED flag in rsxx and
hd from Michael Opdenacker.
- Disable entropy collection from flash devices by default, from Mike
Snitzer.
- A small collection of xen blkfront/back fixes from Roger Pau Monné
and Vitaly Kuznetsov"
* 'for-3.18/drivers' of git://git.kernel.dk/linux-block:
block: disable entropy contributions for nonrot devices
xen, blkfront: factor out flush-related checks from do_blkif_request()
xen-blkback: fix leak on grant map error path
xen/blkback: unmap all persistent grants when frontend gets disconnected
rsxx: Remove deprecated IRQF_DISABLED
block: hd: remove deprecated IRQF_DISABLED
drbd: use RB_DECLARE_CALLBACKS() to define augment callbacks
drbd: compute the end before rb_insert_augmented()
drbd: Add missing newline in resync progress display in /proc/drbd
drbd: reduce lock contention in drbd_worker
drbd: Improve asender performance
drbd: Get rid of the WORK_PENDING macro
drbd: Get rid of the __no_warn and __cond_lock macros
drbd: Avoid inconsistent locking warning
drbd: Remove superfluous newline from "resync_extents" debugfs entry.
drbd: Use consistent names for all the bi_end_io callbacks
drbd: Use better variable names
Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
Pull MTD update from Brian Norris:
"Sorry for delaying this a bit later than usual. There's one mild
regression from 3.16 that was noticed during the 3.17 cycle, and I
meant to send a fix for it along with this pull request. I'll
probably try to queue it up for a later pull request once I've had a
better look at it, hopefully by -rc2 at the latest.
Summary for this pull:
NAND
- Cleanup for Denali driver
- Atmel: add support for new page sizes
- Atmel: fix up 'raw' mode support
- Atmel: miscellaneous cleanups
- New timing mode helpers for non-ONFI NAND
- OMAP: allow driver to be (properly) built as a module
- bcm47xx: RESET support and other cleanups
SPI NOR
- Miscellaneous cleanups, to prepare framework for wider use (some
further work still pending)
- Compile-time configuration to select 4K vs. 64K support for flash
that support both (necessary for using UBIFS on some SPI NOR)
A few scattered code quality fixes, detected by Coverity
See the changesets for more"
* tag 'for-linus-20141015' of git://git.infradead.org/linux-mtd: (59 commits)
mtd: nand: omap: Correct CONFIG_MTD_NAND_OMAP_BCH help message
mtd: nand: Force omap_elm to be built as a module if omap2_nand is a module
mtd: move support for struct flash_platform_data into m25p80
mtd: spi-nor: add Kconfig option to disable 4K sectors
mtd: nand: Move ELM driver and rename as omap_elm
nand: omap2: Replace pr_err with dev_err
nand: omap2: Remove horrible ifdefs to fix module probe
mtd: nand: add Hynix's H27UCG8T2ATR-BC to nand_ids table
mtd: nand: support ONFI timing mode retrieval for non-ONFI NANDs
mtd: physmap_of: Add non-obsolete map_rom probe
mtd: physmap_of: Fix ROM support via OF
MAINTAINERS: add l2-mtd.git, 'next' tree for MTD
mtd: denali: fix indents and other trivial things
mtd: denali: remove unnecessary parentheses
mtd: denali: remove another set-but-unused variable
mtd: denali: fix include guard and license block of denali.h
mtd: nand: don't break long print messages
mtd: bcm47xxnflash: replace some magic numbers
mtd: bcm47xxnflash: NAND_CMD_RESET support
mtd: bcm47xxnflash: add cmd_ctrl handler
Pull md updates from Neil Brown:
- a few minor bug fixes
- quite a lot of code tidy-up and simplification
- remove PRINT_RAID_DEBUG ioctl. I'm fairly sure it is unused, and it
isn't particularly useful.
* tag 'md/3.18' of git://neil.brown.name/md: (21 commits)
lib/raid6: Add log level to printks
md: move EXPORT_SYMBOL to after function in md.c
md: discard PRINT_RAID_DEBUG ioctl
md: remove MD_BUG()
md: clean up 'exit' labels in md_ioctl().
md: remove unnecessary test for MD_MAJOR in md_ioctl()
md: don't allow "-sync" to be set for device in an active array.
md: remove unwanted white space from md.c
md: don't start resync thread directly from md thread.
md: Just use RCU when checking for overlap between arrays.
md: avoid potential long delay under pers_lock
md: simplify export_array()
md: discard find_rdev_nr in favour of find_rdev_nr_rcu
md: use wait_event() to simplify md_super_wait()
md: be more relaxed about stopping an array which isn't started.
md/raid1: process_checks doesn't use its return value.
md/raid5: fix init_stripe() inconsistencies
md/raid10: another memory leak due to reshape.
md: use set_bit/clear_bit instead of shift/mask for bi_flags changes.
md/raid1: minor typos and reformatting.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull selinux fix from James Morris:
"Fix for a list corruption bug in the SELinux code"
* 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
selinux: fix inode security list corruption
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"One cc: stable commit, the rest are a series of minor cleanups which
have been sitting in MST's tree during my vacation. I changed a
function name and made one trivial change, then they spent two days in
linux-next"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
virtio-rng: refactor probe error handling
virtio_scsi: drop scan callback
virtio_balloon: enable VQs early on restore
virtio_scsi: fix race on device removal
virito_scsi: use freezable WQ for events
virtio_net: enable VQs early on restore
virtio_console: enable VQs early on restore
virtio_scsi: enable VQs early on restore
virtio_blk: enable VQs early on restore
virtio_scsi: move kick event out from virtscsi_init
virtio_net: fix use after free on allocation failure
9p/trans_virtio: enable VQs early
virtio: add API to enable VQs early
virtio_net: minor cleanup
virtio-net: drop config_mutex
virtio_net: drop config_enable
virtio-blk: drop config_mutex
Pull module fix from Rusty Russell:
"A single panic fix for a rare race, stable CC'd"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modules, lock around setting of MODULE_STATE_UNFORMED
It seems it's my turn to be the documentation maintainer for a bit. My
plan is to work to ensure that docs patches don't fall through the cracks;
I assume most changes will continue to flow through subsystem-specific
trees.
Acked-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
CR4 isn't constant; at least the TSD and PCE bits can vary.
TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks
like it's correct.
This adds a branch and a read from cr4 to each vm entry. Because it is
extremely likely that consecutive entries into the same vcpu will have
the same host cr4 value, this fixes up the vmcs instead of restoring cr4
after the fact. A subsequent patch will add a kernel-wide cr4 shadow,
reducing the overhead in the common case to just two memory reads and a
branch.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: stable@vger.kernel.org
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
pskb_may_pull() maybe change skb->data and make iph pointer oboslete,
fix it by geting ip header length directly.
Fixes: ca15a078 (sit: generate icmpv6 error when receiving icmpv4 error)
Cc: Oussama Ghorbel <ghorbel@pivasoftware.com>
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
pskb_may_pull() maybe change skb->data and make opth pointer oboslete,
so set the opth again
pskb_may_pull() may change skb->data and make greh pointer oboslete;
so need to reassign greh;
but since first calling pskb_may_pull already ensured that skb->data
has enough space for greh, so move the reference of greh before second
calling pskb_may_pull(), to avoid reassign greh.
Fixes: 7a7ffbabf9("ipv4: fix tunneled VM traffic over hw VXLAN/GRE GSO NIC")
Cc: Wei-Chun Chao <weichunc@plumgrid.com>
$ make M=net/ipv4
CC net/ipv4/route.o
In file included from net/ipv4/route.c:102:0:
include/net/tcp.h: In function ‘tcp_v6_iif’:
include/net/tcp.h:738:32: error: ‘union <anonymous>’ has no member named ‘h6’
return TCP_SKB_CB(skb)->header.h6.iif;
Fixes: 870c3151382c ("ipv6: introduce tcp_v6_iif()")
Pull networking fixes from David Miller:
1) Include fixes for netrom and dsa (Fabian Frederick and Florian
Fainelli)
2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO.
3) Several SKB use after free fixes (vxlan, openvswitch, vxlan,
ip_tunnel, fou), from Li ROngQing.
4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy.
5) Use after free in virtio_net, from Michael S Tsirkin.
6) Fix flow mask handling for megaflows in openvswitch, from Pravin B
Shelar.
7) ISDN gigaset and capi bug fixes from Tilman Schmidt.
8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin.
9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov.
10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong
Wang and Eric Dumazet.
11) Don't overwrite end of SKB when parsing malformed sctp ASCONF
chunks, from Daniel Borkmann.
12) Don't call sock_kfree_s() with NULL pointers, this function also has
the side effect of adjusting the socket memory usage. From Cong Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
bna: fix skb->truesize underestimation
net: dsa: add includes for ethtool and phy_fixed definitions
openvswitch: Set flow-key members.
netrom: use linux/uaccess.h
dsa: Fix conversion from host device to mii bus
tipc: fix bug in bundled buffer reception
sfc: add support for skb->xmit_more
r8152: return -EBUSY for runtime suspend
ipv4: fix a potential use after free in fou.c
ipv4: fix a potential use after free in ip_tunnel_core.c
hyperv: Add handling of IP header with option field in netvsc_set_hash()
openvswitch: Create right mask with disabled megaflows
vxlan: fix a free after use
openvswitch: fix a use after free
ipv4: dst_entry leak in ip_send_unicast_reply()
ipv4: clean up cookie_v4_check()
ipv4: share tcp_v4_save_options() with cookie_v4_check()
ipv4: call __ip_options_echo() in cookie_v4_check()
atm: simplify lanai.c by using module_pci_driver
Pull Sparc bugfix from David Miller:
"Sparc64 AES ctr mode bug fix"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc64: Fix FPU register corruption with AES crypto offload.
Pull IDE cleanup from David Miller:
"One IDE driver cleanup"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide:
Drivers: ide: Remove typedef atiixp_ide_timing
Commit b0c29f79ecea (futexes: Avoid taking the hb->lock if there's
nothing to wake up) changes the futex code to avoid taking a lock when
there are no waiters. This code has been subsequently fixed in commit
11d4616bd07f (futex: revert back to the explicit waiter counting code).
Both the original commit and the fix-up rely on get_futex_key_refs() to
always imply a barrier.
However, for private futexes, none of the cases in the switch statement
of get_futex_key_refs() would be hit and the function completes without
a memory barrier as required before checking the "waiters" in
futex_wake() -> hb_waiters_pending(). The consequence is a race with a
thread waiting on a futex on another CPU, allowing the waker thread to
read "waiters == 0" while the waiter thread to have read "futex_val ==
locked" (in kernel).
Without this fix, the problem (user space deadlocks) can be seen with
Android bionic's mutex implementation on an arm64 multi-cluster system.
Reported-by: Matteo Franchin <Matteo.Franchin@arm.com>
Fixes: b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up)
Acked-by: Davidlohr Bueso <dave@stgolabs.net>
Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: <stable@vger.kernel.org>
Cc: Darren Hart <dvhart@linux.intel.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo:
User visible changes:
* Add period data column and make it default in 'perf script' (Jiri Olsa)
Infrastructure changes:
* Move exit stuff from perf_evsel__delete to perf_evsel__exit, delete
should be just a front end for exit + free (Arnaldo Carvalho de Melo)
* Add missing 'struct option' forward declaration (Arnaldo Carvalho de Melo)
* No need to drag util/cgroup.h into evsel.h (Arnaldo Carvalho de Melo)
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
skb->truesize is not meant to be tracking amount of used bytes
in an skb, but amount of reserved/consumed bytes in memory.
For instance, if we use a single byte in last page fragment,
we have to account the full size of the fragment.
skb->truesize can be very different from skb->len, that has
a very specific safety purpose.
Cc: Rasesh Mody <rasesh.mody@qlogic.com>
net/dsa/slave.c uses functions and structures declared in phy_fixed.h
but does not explicitely include it, while dsa.h needs structure
declarations for 'struct ethtool_wolinfo' and 'struct ethtool_eee', fix
those by including the correct header files.
Fixes: ec9436baedb6 ("net: dsa: allow drivers to do link adjustment")
Fixes: ce31b31c68e7 ("net: dsa: allow updating fixed PHY link information")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
This patch adds missing memset which are required to initialize
flow key member. For example for IP flow we need to initialize
ip.frag for all cases.
Found by inspection.
This bug is introduced by commit 0714812134d7dcadeb7ecfbfeb18788aa7e1eaac
("openvswitch: Eliminate memset() from flow_extract").
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
replace asm/uaccess.h by linux/uaccess.h
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Commit b4d2394d01bc ("dsa: Replace mii_bus with a generic host device")
replaces mii_bus with a generic host_dev, and introduces
dsa_host_dev_to_mii_bus() to support conversion from host_dev to mii_bus.
However, in some cases it uses to_mii_bus to perform that conversion.
Since host_dev is not the phy bus device but typically a platform device,
this fails and results in a crash with the affected drivers.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81781d35>] __mutex_lock_slowpath+0x75/0x100
PGD 406783067 PUD 406784067 PMD 0
Oops: 0002 [#1] SMP
Call Trace:
[<ffffffff810a538b>] ? pick_next_task_fair+0x61b/0x880
[<ffffffff81781de3>] mutex_lock+0x23/0x37
[<ffffffff81533244>] mdiobus_read+0x34/0x60
[<ffffffff8153b95a>] __mv88e6xxx_reg_read+0x8a/0xa0
[<ffffffff8153b9bc>] mv88e6xxx_reg_read+0x4c/0xa0
Fixes: b4d2394d01bc ("dsa: Replace mii_bus with a generic host device")
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
In commit ec8a2e5621db2da24badb3969eda7fd359e1869f ("tipc: same receive
code path for connection protocol and data messages") we omitted the
the possiblilty that an arriving message extracted from a bundle buffer
may be a multicast message. Such messages need to be to be delivered to
the socket via a separate function, tipc_sk_mcast_rcv(). As a result,
small multicast messages arriving as members of a bundle buffer will be
silently dropped.
This commit corrects the error by considering this case in the function
tipc_link_bundle_rcv().
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
Commit 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line
misses") added a regression for SO_BINDTODEVICE on IPv6.
This is because we still use inet6_iif() which expects that IP6 control
block is still at the beginning of skb->cb[]
This patch adds tcp_v6_iif() helper and uses it where necessary.
Because __inet6_lookup_skb() is used by TCP and DCCP, we add an iif
parameter to it.
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Acked-by: Cong Wang <cwang@twopensource.com>
Don't ring the doorbell, and don't do PIO. This will also prevent
TX Push, because there will be more than one buffer waiting when
the doorbell is rung.
Signed-off-by: Edward Cree <ecree@solarflare.com>
Remove calling cancel_delayed_work_sync() for runtime suspend,
because it would cause dead lock. Instead, return -EBUSY to
avoid the device enters suspending if the net is running and
the delayed work is pending or running. The delayed work would
try to wake up the device later, so the suspending is not
necessary.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
pskb_may_pull() maybe change skb->data and make uh pointer oboslete,
so reload uh and guehdr
Fixes: 37dd0247 ("gue: Receive side for Generic UDP Encapsulation")
Cc: Tom Herbert <therbert@google.com>
pskb_may_pull() maybe change skb->data and make eth pointer oboslete,
so set eth after pskb_may_pull()
Fixes:3d7b46cd("ip_tunnel: push generic protocol handling to ip_tunnel module")
Cc: Pravin B Shelar <pshelar@nicira.com>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
In case that the IP header has optional field at the end, this patch will
get the port numbers after that field, and compute the hash. The general
parser skb_flow_dissect() is used here.
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
Signed-off-by: Steven French <smfrench@gmail.com>
If megaflows are disabled, the userspace does not send the netlink attribute
OVS_FLOW_ATTR_MASK, and the kernel must create an exact match mask.
sw_flow_mask_set() sets every bytes (in 'range') of the mask to 0xff, even the
bytes that represent padding for struct sw_flow, or the bytes that represent
fields that may not be set during ovs_flow_extract().
This is a problem, because when we extract a flow from a packet,
we do not memset() anymore the struct sw_flow to 0.
This commit gets rid of sw_flow_mask_set() and introduces mask_set_nlattr(),
which operates on the netlink attributes rather than on the mask key. Using
this approach we are sure that only the bytes that the user provided in the
flow are matched.
Also, if the parse_flow_mask_nlattrs() for the mask ENCAP attribute fails, we
now return with an error.
Reported-by: Alex Wang <alexw@nicira.com>
Signed-off-by: Daniele Di Proietto <ddiproietto@vmware.com>
Signed-off-by: Andy Zhou <azhou@nicira.com>
pskb_may_pull maybe change skb->data and make eth pointer oboslete,
so eth needs to reload
Fixes: 91269e390d062 ("vxlan: using pskb_may_pull as early as possible")
Cc: Eric Dumazet <edumazet@google.com>
pskb_may_pull() called by arphdr_ok can change skb->data, so put the arp
setting after arphdr_ok to avoid the use the freed memory
Fixes: 0714812134d7d ("openvswitch: Eliminate memset() from flow_extract.")
Cc: Jesse Gross <jesse@nicira.com>
Acked-by: Jesse Gross <jesse@nicira.com>
ip_setup_cork() called inside ip_append_data() steals dst entry from rt to cork
and in case errors in __ip_append_data() nobody frees stolen dst entry
Fixes: 2e77d89b2fa8 ("net: avoid a pair of dst_hold()/dst_release() in ip_append_data()")
Signed-off-by: Vasily Averin <vvs@parallels.com>
Adding period as a default output column in script command fo hardware,
software and raw events.
If PERF_SAMPLE_PERIOD sample type is defined in perf.data, following
will be displayed in perf script output:
$ perf script
ls 8034 57477.887209: 250000 task-clock: ffffffff81361d72 memset ([kernel.kallsyms])
ls 8034 57477.887464: 250000 task-clock: ffffffff816f6d92 _raw_spin_unlock_irqrestore ([kernel.kallsyms])
ls 8034 57477.887708: 250000 task-clock: ffffffff811a94f0 do_munmap ([kernel.kallsyms])
ls 8034 57477.887959: 250000 task-clock: 34080916c6 get_next_seq (/usr/lib64/libc-2.17.so)
ls 8034 57477.888208: 250000 task-clock: 3408079230 _IO_doallocbuf (/usr/lib64/libc-2.17.so)
ls 8034 57477.888717: 250000 task-clock: ffffffff814242c8 n_tty_write ([kernel.kallsyms])
ls 8034 57477.889285: 250000 task-clock: 3408076402 fwrite_unlocked (/usr/lib64/libc-2.17.so)
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: David Ahern <dsahern@gmail.com>
Cc: "Jen-Cheng(Tommy) Huang" <tommy24@gatech.edu>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Jen-Cheng(Tommy) Huang <tommy24@gatech.edu>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1408977943-16594-10-git-send-email-jolsa@kernel.org
Adding period data column to be displayed in perf script. It's possible
to get period values using -f option, like:
$ perf script -f comm,tid,time,period,ip,sym,dso
:26019 26019 52414.329088: 3707 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms])
:26019 26019 52414.329088: 44 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms])
:26019 26019 52414.329093: 1987 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms])
:26019 26019 52414.329093: 6 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms])
ls 26019 52414.329442: 537558 3407c0639c _dl_map_object_from_fd (/usr/lib64/ld-2.17.so)
ls 26019 52414.329442: 2099 3407c0639c _dl_map_object_from_fd (/usr/lib64/ld-2.17.so)
ls 26019 52414.330181: 1242100 34080917bb get_next_seq (/usr/lib64/libc-2.17.so)
ls 26019 52414.330181: 3774 34080917bb get_next_seq (/usr/lib64/libc-2.17.so)
ls 26019 52414.331427: 1083662 ffffffff810c7dc2 update_curr ([kernel.kallsyms])
ls 26019 52414.331427: 360 ffffffff810c7dc2 update_curr ([kernel.kallsyms])
Acked-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1408977943-16594-9-git-send-email-jolsa@kernel.org
We can retrieve opt from skb, no need to pass it as a parameter.
And opt should always be non-NULL, no need to check.
Cc: Krzysztof Kolasa <kkolasa@winsoft.pl>
Tested-by: Krzysztof Kolasa <kkolasa@winsoft.pl>
Signed-off-by: Cong Wang <cwang@twopensource.com>
cookie_v4_check() allocates ip_options_rcu in the same way
with tcp_v4_save_options(), we can just make it a helper function.
commit 971f10eca186cab238c49da ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
missed that cookie_v4_check() still calls ip_options_echo() which uses
IPCB(). It should use TCPCB() at TCP layer, so call __ip_options_echo()
instead.
Fixes: commit 971f10eca186cab238c49da ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl>
This simplifies the lanai.c driver by using
the module_pci_driver() macro, at the expense
of losing only debugging messages.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
The only thing we need is a forward declaration for 'struct cgroup_sel',
that is inside 'struct perf_evsel'.
Include cgroup.h instead on the tools that support cgroups.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Jean Pihet <jean.pihet@linaro.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/n/tip-b7kuymbgf0zxi5viyjjtu5hk@git.kernel.org
It was being found, by chance, because evsel.h needlessly includes
util/cgroup.h, which will be sorted out in a following patch.
Link: http://lkml.kernel.org/n/tip-xsvxr747wkkpg1ay9dramorr@git.kernel.org
So that when an evsel is embedded into other struct it can free up
resources calling perf_evsel__exit().
Link: http://lkml.kernel.org/n/tip-n1w68pfe9m2vkhm4sqs8y1en@git.kernel.org
On the Haswell platform, a split BAR option to allow creation of 2
32bit BARs (4 and 5) from the 64bit BAR 4. Adding support for this
new option.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Instead of using a module parameter, we should detect the errata via
PCI DID and then set an appropriate flag. This will be used for additional
errata later on.
To simplify some of the platform detection code. Move the platform detection
to a function to be called earlier.
