When xilinx-xadc is used with hwmon driver to read voltage, offset used
for temperature is always applied whatever the channel.
iio_channel_read must return an error to avoid offset for channel
without IIO_CHAN_INFO_OFFSET property.
Signed-off-by: Fabien Proriol <fabien.proriol@jdsu.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
The ad7991/ad7995/ad7999 does not have a configuration register like the
other devices that can be written and read. The configuration is written as
part of the conversion sequence.
Fixes: 0f7ddcc1bff1 ("iio:adc:ad799x: Write default config on probe and reset alert status on probe")
Tested-by: Mike Looijmans <mike.looijmans@topic.nl>
Set the threshold to low by default. With this thresholds any movement
on the device with this sensor will generate event.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Change event spec direction from
IIO_EV_DIR_RISING | IIO_EV_DIR_FALLING
to
IIO_EV_DIR_EITHER
Suggested-by: Daniel Baluta <daniel.baluta@intel.com>
This chip is capable to identify motion across x, y and z axes. So
send different events.
When mode set fails due to some transient failures, it will atleast
reset the state of runtime usage count and also let the runtime
suspend retry from the driver framework.
to
IIO_EV_DIR_EITHER
Change the mode to push/pull type instead of open drain as some
platforms fails to drive the GPIO pin with open drain.
The mcb_device_id table is supposed to be zero-terminated.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Cc: <Stable@vger.kernel.org>
Currently, we get the new GSEL bits by OR-ing the old values
with the new ones. This only works first time when the old
values are 0.
Startup:
* GSEL0 = 0, GSEL1 = 0
Set range to 4G: (GSEL0 = 1, GSEL1 = 0)
* GSEL0 = 0 | 1 = 1
* GSEL1 = 0 | 0 = 0
* correct
Change range to 2G: (GSEL0 = 0, GSEL1 = 0)
* GSEL0 = 1 | 0 = 1
* GSEL1 = 0 | 0 = 0
* wrong, GSEL0 should be 0
This has the nice effect that we can use the full scale range,
exported in in_accel_scale_available.
Fixes: a735e3d7f03 (iio: accel: kxcjk-1013: Set adjustable range)
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask
in order to retrieve it, that is 0x7F, not 0xCF as it is now.
Fixes: ade7ef7ba (staging:iio: Differential channel handling)
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
"raw" is a property of a channel, but should not be part of the name of
channel.
Cc: <stable@vger.kernel.org>
We should check if a channel is enabled, not if no channels are enabled.
Fixes: 550268ca1111 ("staging:iio: scrap scan_count and ensure all drivers use active_scan_mask")
In older versions of the IIO framework it was possible to pass a completely
different set of channels to iio_buffer_register() as the one that is
assigned to the IIO device. Commit 959d2952d124 ("staging:iio: make
iio_sw_buffer_preenable much more general.") introduced a restriction that
requires that the set of channels that is passed to iio_buffer_register() is
a subset of the channels assigned to the IIO device as the IIO core will use
the list of channels that is assigned to the device to lookup a channel by
scan index in iio_compute_scan_bytes(). If it can not find the channel the
function will crash. This patch fixes the issue by making sure that the same
set of channels is assigned to the IIO device and passed to
iio_buffer_register().
Note that we need to remove the IIO_CHAN_INFO_RAW and IIO_CHAN_INFO_SCALE
info attributes from the channels since we don't actually want those to be
registered.
Fixes the following crash:
Unable to handle kernel NULL pointer dereference at virtual address 00000016
pgd = d2094000
[00000016] *pgd=16e39831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 PID: 1695 Comm: bash Not tainted 3.17.0-06329-g29461ee #9686
task: d7768040 ti: d5bd4000 task.ti: d5bd4000
PC is at iio_compute_scan_bytes+0x38/0xc0
LR is at iio_compute_scan_bytes+0x34/0xc0
pc : [<c0316de8>] lr : [<c0316de4>] psr: 60070013
sp : d5bd5ec0 ip : 00000000 fp : 00000000
r10: d769f934 r9 : 00000000 r8 : 00000001
r7 : 00000000 r6 : c8fc6240 r5 : d769f800 r4 : 00000000
r3 : d769f800 r2 : 00000000 r1 : ffffffff r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 18c5387d Table: 1209404a DAC: 00000015
Process bash (pid: 1695, stack limit = 0xd5bd4240)
Stack: (0xd5bd5ec0 to 0xd5bd6000)
5ec0: d769f800 d7435640 c8fc6240 d769f984 00000000 c03175a4 d7435690 d7435640
5ee0: d769f990 00000002 00000000 d769f800 d5bd4000 00000000 000b43a8 c03177f4
5f00: d769f810 0162b8c8 00000002 c8fc7e00 d77f1d08 d77f1da8 c8fc7e00 c01faf1c
5f20: 00000002 c010694c c010690c d5bd5f88 00000002 c8fc6840 c8fc684c c0105e08
5f40: 00000000 00000000 d20d1580 00000002 000af408 d5bd5f88 c000de84 c00b76d4
5f60: d20d1580 000af408 00000002 d20d1580 d20d1580 00000002 000af408 c000de84
5f80: 00000000 c00b7a44 00000000 00000000 00000002 b6ebea78 00000002 000af408
5fa0: 00000004 c000dd00 b6ebea78 00000002 00000001 000af408 00000002 00000000
5fc0: b6ebea78 00000002 000af408 00000004 bee96a4c 000a6094 00000000 000b43a8
5fe0: 00000000 bee969cc b6e2eb77 b6e6525c 40070010 00000001 00000000 00000000
[<c0316de8>] (iio_compute_scan_bytes) from [<c03175a4>] (__iio_update_buffers+0x248/0x438)
[<c03175a4>] (__iio_update_buffers) from [<c03177f4>] (iio_buffer_store_enable+0x60/0x7c)
[<c03177f4>] (iio_buffer_store_enable) from [<c01faf1c>] (dev_attr_store+0x18/0x24)
[<c01faf1c>] (dev_attr_store) from [<c010694c>] (sysfs_kf_write+0x40/0x4c)
[<c010694c>] (sysfs_kf_write) from [<c0105e08>] (kernfs_fop_write+0x110/0x154)
[<c0105e08>] (kernfs_fop_write) from [<c00b76d4>] (vfs_write+0xbc/0x170)
[<c00b76d4>] (vfs_write) from [<c00b7a44>] (SyS_write+0x40/0x78)
[<c00b7a44>] (SyS_write) from [<c000dd00>] (ret_fast_syscall+0x0/0x30)
Fixes: 959d2952d124 ("staging:iio: make iio_sw_buffer_preenable much more general.")
Signed-off-by: George McCollister <george.mccollister@gmail.com>
Acked-by: Hartmut Knaack <knaack.h@gmx.de>
Because IIO_EV_DIR_* are not bitmasks but enums,
IIO_EV_DIR_RISING | IIO_EV_DIR_FALLING is not equal
with IIO_EV_DIR_EITHER.
This could lead to potential misformatted sysfs attributes
like:
* in_accel_x_thresh_(null)_en
* in_accel_x_thresh_(null)_period
* in_accel_x_thresh_(null)_value
or even memory corruption.
Fixes: b4b491c083 (iio: accel: kxcjk-1013: Support threshold)
Fix the compiler error when the CONFIG_PM_OPS flag is not set.
drivers/iio/light/tsl4531.c:235:8: error: ‘tsl4531_suspend’ undeclared here (not in a function)
drivers/iio/light/tsl4531.c:235:8: error: ‘tsl4531_resume’ undeclared here (not in a function)
Signed-off-by: Dan Murphy <dmurphy@ti.com>
We should disable lradc->clk in the case of errors in the probe function.
Use byte_for_channel as iterator to properly initialize the buffer.
Signed-off-by: Robin van der Gracht <robin@protonic.nl>
Acked-by: Denis Ciocca <denis.ciocca@st.com>
"raw" is the name of a channel property, but should not be part of the
channel name itself.
completely different set of channels to iio_buffer_register() as the one
that is assigned to the IIO device. Commit 959d2952d124 ("staging:iio: make
Fixes the follow NULL pointer derefernce kernel crash:
pgd = d53d0000
[00000016] *pgd=1534e831, *pte=00000000, *ppte=00000000
Modules linked in:
CPU: 1 PID: 1626 Comm: bash Not tainted 3.15.0-19969-g2a180eb-dirty #9545
task: d6c124c0 ti: d539a000 task.ti: d539a000
PC is at iio_compute_scan_bytes+0x34/0xa8
LR is at iio_compute_scan_bytes+0x34/0xa8
pc : [<c03052e4>] lr : [<c03052e4>] psr: 60070013
sp : d539beb8 ip : 00000001 fp : 00000000
r10: 00000002 r9 : 00000000 r8 : 00000001
r7 : 00000000 r6 : d6dc8800 r5 : d7571000 r4 : 00000002
r3 : d7571000 r2 : 00000044 r1 : 00000001 r0 : 00000000
Control: 18c5387d Table: 153d004a DAC: 00000015
Process bash (pid: 1626, stack limit = 0xd539a240)
Stack: (0xd539beb8 to 0xd539c000)
bea0: c02fc0e4 d7571000
bec0: d76c1640 d6dc8800 d757117c 00000000 d757112c c0305b04 d76c1690 d76c1640
bee0: d7571188 00000002 00000000 d7571000 d539a000 00000000 000dd1c8 c0305d54
bf00: d7571010 0160b868 00000002 c69d3900 d7573278 d7573308 c69d3900 c01ece90
bf20: 00000002 c0103fac c0103f6c d539bf88 00000002 c69d3b00 c69d3b0c c0103468
bf40: 00000000 00000000 d7694a00 00000002 000af408 d539bf88 c000dd84 c00b2f94
bf60: d7694a00 000af408 00000002 d7694a00 d7694a00 00000002 000af408 c000dd84
bf80: 00000000 c00b32d0 00000000 00000000 00000002 b6f1aa78 00000002 000af408
bfa0: 00000004 c000dc00 b6f1aa78 00000002 00000001 000af408 00000002 00000000
bfc0: b6f1aa78 00000002 000af408 00000004 be806a4c 000a6094 00000000 000dd1c8
bfe0: 00000000 be8069cc b6e8ab77 b6ec125c 40070010 00000001 22940489 154a5007
[<c03052e4>] (iio_compute_scan_bytes) from [<c0305b04>] (__iio_update_buffers+0x248/0x438)
[<c0305b04>] (__iio_update_buffers) from [<c0305d54>] (iio_buffer_store_enable+0x60/0x7c)
[<c0305d54>] (iio_buffer_store_enable) from [<c01ece90>] (dev_attr_store+0x18/0x24)
[<c01ece90>] (dev_attr_store) from [<c0103fac>] (sysfs_kf_write+0x40/0x4c)
[<c0103fac>] (sysfs_kf_write) from [<c0103468>] (kernfs_fop_write+0x110/0x154)
[<c0103468>] (kernfs_fop_write) from [<c00b2f94>] (vfs_write+0xd0/0x160)
[<c00b2f94>] (vfs_write) from [<c00b32d0>] (SyS_write+0x40/0x78)
[<c00b32d0>] (SyS_write) from [<c000dc00>] (ret_fast_syscall+0x0/0x30)
Code: ea00000e e1a01008 e1a00005 ebfff6fc (e5d0a016)
Cc: Stable@vger.kernel.org
Make sure struct eeprom_priv->mac_addr is 2 byte aligned to work with
ether_addr_copy()
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com>
COMEDI_II_PCI20KC needs HAS_IOMEM, so depend on it. The related error (
with allmodconfig under um):
CC [M] drivers/staging/comedi/drivers/ii_pci20kc.o
drivers/staging/comedi/drivers/ii_pci20kc.c: In function ‘ii20k_attach’:
drivers/staging/comedi/drivers/ii_pci20kc.c:442:2: error: implicit declaration of function ‘ioremap’ [-Werror=implicit-function-declaration]
dev->mmio = ioremap(membase, II20K_SIZE);
drivers/staging/comedi/drivers/ii_pci20kc.c:442:12: warning: assignment makes pointer from integer without a cast [enabled by default]
drivers/staging/comedi/drivers/ii_pci20kc.c: In function ‘ii20k_detach’:
drivers/staging/comedi/drivers/ii_pci20kc.c:512:3: error: implicit declaration of function ‘iounmap’ [-Werror=implicit-function-declaration]
iounmap(dev->mmio);
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
`do_cmd_ioctl()`, the handler for the `COMEDI_CMD` ioctl can incorrectly
call the Comedi subdevice's `do_cmd()` handler with a NULL channel list
pointer. This is a regression as the `do_cmd()` handler has never been
expected to deal with that, leading to a kernel OOPS when it tries to
dereference it.
A NULL channel list pointer is allowed for the `COMEDI_CMDTEST` ioctl,
handled by `do_cmdtest_ioctl()` and the subdevice's `do_cmdtest()`
handler, but not for the `COMEDI_CMD` ioctl and its handlers.
Both `do_cmd_ioctl()` and `do_cmdtest_ioctl()` call
`__comedi_get_user_chanlist()` to copy the channel list from user memory
into dynamically allocated kernel memory and check it for consistency.
That function currently returns 0 if the `user_chanlist` parameter
(pointing to the channel list in user memory) is NULL. That's fine for
`do_cmdtest_ioctl()`, but `do_cmd_ioctl()` incorrectly assumes the
kernel copy of the channel list has been set-up correctly.
Fix it by not allowing the `user_chanlist` parameter to be NULL in
`__comedi_get_user_chanlist()`, and only calling it from
`do_cmdtest_ioctl()` if the parameter is non-NULL.
Thanks to Bernd Porr for reporting the bug via an initial patch sent
privately.
Fixes: c6cd0eefb27b ("staging: comedi: comedi_fops: introduce __comedi_get_user_chanlist()")
Reported-by: Bernd Porr <mail@berndporr.me.uk>
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Cc: Bernd Porr <mail@berndporr.me.uk>
Cc: <stable@vger.kernel.org> # 3.15.y 3.16.y 3.17.y
Pull ARM SoC fixes from Olof Johansson:
"A batch of fixes that have come in during the merge window.
Some of them are defconfig updates for things that have now landed,
some errata additions and a few general scattered fixes.
There's also a qcom DT update that adds support for SATA on AP148, and
basic support for Sony Xperia Z1 and CM-QS600 platforms that seemed
isolated enough that we could merge it even if it's late"
* tag 'arm-soc-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
MAINTAINERS: corrected bcm2835 search
ARM: dts: Explicitly set dr_mode on exynos5420-arndale-octa
ARM: dts: Explicitly set dr_mode on exynos Peach boards
ARM: dts: qcom: add CM-QS600 board
ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phone
ARM: dts: qcom: Add SATA support on IPQ8064/AP148
MAINTAINERS: Update Santosh Shilimkar's email id
ARM: sunxi_defconfig: enable CONFIG_REGULATOR
ARM: dts: Disable smc91x on n900 until bootloader dependency is removed
ARM: omap2plus_defconfig: Enable ARM erratum 430973 for omap3
ARM: exynos_defconfig: enable USB gadget support
ARM: exynos_defconfig: Enable Maxim 77693 and I2C GPIO drivers
ARM: mm: Fix ifdef around cpu_*_do_[suspend, resume] ops
ARM: EXYNOS: Fix build with PM_SLEEP=n and ARM_EXYNOS_CPUIDLE=n
ARM: SAMSUNG: Restore Samsung PM Debug functionality
ARM: dts: Fix pull setting in sd4_width8 pin group for exynos4x12
ARM: exynos_defconfig: Enable SBS battery support
ARM: exynos_defconfig: Enable Control Groups support
ARM: exynos_defconfig: Enable Atmel maXTouch support
ARM: exynos_defconfig: Enable MAX77802
Pull audit updates from Eric Paris:
"So this change across a whole bunch of arches really solves one basic
problem. We want to audit when seccomp is killing a process. seccomp
hooks in before the audit syscall entry code. audit_syscall_entry
took as an argument the arch of the given syscall. Since the arch is
part of what makes a syscall number meaningful it's an important part
of the record, but it isn't available when seccomp shoots the
syscall...
For most arch's we have a better way to get the arch (syscall_get_arch)
So the solution was two fold: Implement syscall_get_arch() everywhere
there is audit which didn't have it. Use syscall_get_arch() in the
seccomp audit code. Having syscall_get_arch() everywhere meant it was
a useless flag on the stack and we could get rid of it for the typical
syscall entry.
The other changes inside the audit system aren't grand, fixed some
records that had invalid spaces. Better locking around the task comm
field. Removing some dead functions and structs. Make some things
static. Really minor stuff"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: rename audit_log_remove_rule to disambiguate for trees
audit: cull redundancy in audit_rule_change
audit: WARN if audit_rule_change called illegally
audit: put rule existence check in canonical order
next: openrisc: Fix build
audit: get comm using lock to avoid race in string printing
audit: remove open_arg() function that is never used
audit: correct AUDIT_GET_FEATURE return message type
audit: set nlmsg_len for multicast messages.
audit: use union for audit_field values since they are mutually exclusive
audit: invalid op= values for rules
audit: use atomic_t to simplify audit_serial()
kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0]
audit: reduce scope of audit_log_fcaps
audit: reduce scope of audit_net_id
audit: arm64: Remove the audit arch argument to audit_syscall_entry
arm64: audit: Add audit hook in syscall_trace_enter/exit()
audit: x86: drop arch from __audit_syscall_entry() interface
sparc: implement is_32bit_task
sparc: properly conditionalize use of TIF_32BIT
git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom into fixes
Merge "qcom DT changes for v3.18-3" from Kumar Gala:
Qualcomm ARM Based Device Tree Updates for v3.18-3
* Added Board support for CM-QS600 and Sony Xperia Z1 phone
* Added SATA support on IPQ8064/AP148
* tag 'qcom-dt-for-3.18-3' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom:
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
Pull more fixes from Kukjin Kim:
2nd Samsung fixes for v3.18
- Explicitly set dr_mode on exynos5800-peach-pi, exynos5420-peach-pit
and exynos5420-arndale-octa boards, because the USB dwc3 controller
will not work properly without dr_mode as host on above boards if
the USB host and gadget are enabled in kernel configuration both.
* tag 'samsung-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
Corrected bcm2835 maintainer info by using N: to specify any files with
bcm2835 in are directed to the proper maintainer.
Also corrected minor mispelling of ARCHITECTURE in 2 comment locations.
Signed-off-by: Scott Branden <sbranden@broadcom.com>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Pull ntb (non-transparent bridge) updates from Jon Mason:
"Add support for Haswell NTB split BARs, a debugfs entry for basic
debugging info, and some code clean-ups"
* tag 'ntb-3.18' of git://github.com/jonmason/ntb:
ntb: Adding split BAR support for Haswell platforms
ntb: use errata flag set via DID to implement workaround
ntb: conslidate reading of PPD to move platform detection earlier
ntb: move platform detection to separate function
NTB: debugfs device entry
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Highlights from the I2C subsystem for 3.18:
- new drivers for Axxia AM55xx, and Hisilicon hix5hd2 SoC.
- designware driver gained AMD support, exynos gained exynos7 support
The rest is usual driver stuff. Hopefully no lowlights this time"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: i801: Add Device IDs for Intel Sunrise Point PCH
i2c: hix5hd2: add i2c controller driver
i2c-imx: Disable the clock on probe failure
i2c: designware: Add support for AMD I2C controller
i2c: designware: Rework probe() to get clock a bit later
i2c: designware: Default to fast mode in case of ACPI
i2c: axxia: Add I2C driver for AXM55xx
i2c: exynos: add support for HSI2C module on Exynos7
i2c: mxs: detect No Slave Ack on SELECT in PIO mode
i2c: cros_ec: Remove EC_I2C_FLAG_10BIT
i2c: cros-ec-tunnel: Add of match table
i2c: rcar: remove sign-compare flaw
i2c: ismt: Use minimum descriptor size
i2c: imx: Add arbitration lost check
i2c: rk3x: Remove unlikely() annotations
i2c: rcar: check for no IRQ in rcar_i2c_irq()
i2c: rcar: make rcar_i2c_prepare_msg() *void*
i2c: rcar: simplify check for last message
i2c: designware: add support of platform data to set I2C mode
i2c: designware: add support of I2C standard mode
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Here are a collection of small fixes after 3.18 merge.
The urgent one is the fix for kernel panics with linked PCM substream
triggered by the recent nonatomic PCM ops support. Other two fixes
(emu10k1 and bebob) are stable fixes, and one easy PCI ID addition for
a new Intel HD-audio controller"
* tag 'sound-fix-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda_intel: Add Device IDs for Intel Sunrise Point PCH
ALSA: emu10k1: Fix deadlock in synth voice lookup
ALSA: pcm: Fix referred substream in snd_pcm_action_group() unlock loop
ALSA: bebob: Fix failure to detect source of clock for Terratec Phase 88
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull second round of input updates from Dmitry Torokhov:
"Mostly simple bug fixes, although we do have one brand new driver for
Microchip AR1021 i2c touchscreen.
Also there is the change to stop trying to use i8042 active
multiplexing by default (it is still possible to activate it via
i8042.nomux=0 on boxes that implement it)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: xpad - add Thrustmaster as Xbox 360 controller vendor
Input: xpad - add USB ID for Thrustmaster Ferrari 458 Racing Wheel
Input: max77693-haptic - fix state check in imax77693_haptic_disable()
Input: xen-kbdfront - free grant table entry in xenkbd_disconnect_backend
Input: alps - fix v4 button press recognition
Input: i8042 - disable active multiplexing by default
Input: i8042 - add noloop quirk for Asus X750LN
Input: synaptics - gate forcepad support by DMI check
Input: Add Microchip AR1021 i2c touchscreen
Input: cros_ec_keyb - add of match table
Input: serio - avoid negative serio device numbers
Input: avoid negative input device numbers
Input: automatically set EV_ABS bit in input_set_abs_params
Input: adp5588-keys - cancel workqueue in failure path
Input: opencores-kbd - switch to using managed resources
Input: evdev - fix EVIOCG{type} ioctl
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/RDMA updates from Roland Dreier:
- large set of iSER initiator improvements
- hardware driver fixes for cxgb4, mlx5 and ocrdma
- small fixes to core midlayer
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (47 commits)
RDMA/cxgb4: Fix ntuple calculation for ipv6 and remove duplicate line
RDMA/cxgb4: Add missing neigh_release in find_route
RDMA/cxgb4: Take IPv6 into account for best_mtu and set_emss
RDMA/cxgb4: Make c4iw_wr_log_size_order static
IB/core: Fix XRC race condition in ib_uverbs_open_qp
IB/core: Clear AH attr variable to prevent garbage data
RDMA/ocrdma: Save the bit environment, spare unncessary parenthesis
RDMA/ocrdma: The kernel has a perfectly good BIT() macro - use it
RDMA/ocrdma: Don't memset() buffers we just allocated with kzalloc()
RDMA/ocrdma: Remove a unused-label warning
RDMA/ocrdma: Convert kernel VA to PA for mmap in user
RDMA/ocrdma: Get vlan tag from ib_qp_attrs
RDMA/ocrdma: Add default GID at index 0
IB/mlx5, iser, isert: Add Signature API additions
Target/iser: Centralize ib_sig_domain setting
IB/iser: Centralize ib_sig_domain settings
IB/mlx5: Use extended internal signature layout
IB/iser: Set IP_CSUM as default guard type
IB/iser: Remove redundant assignment
IB/mlx5: Use enumerations for PI copy mask
Pull more perf updates from Ingo Molnar:
"A second (and last) round of late coming fixes and changes, almost all
of them in perf tooling:
User visible tooling changes:
- Add period data column and make it default in 'perf script' (Jiri
Olsa)
- Add a visual cue for toggle zeroing of samples in 'perf top'
(Taeung Song)
- Improve callchains when using libunwind (Namhyung Kim)
Tooling fixes and infrastructure changes:
- Fix for double free in 'perf stat' when using some specific invalid
command line combo (Yasser Shalabi)
- Fix off-by-one bugs in map->end handling (Stephane Eranian)
- Fix off-by-one bug in maps__find(), also related to map->end
handling (Namhyung Kim)
- Make struct symbol->end be the first addr after the symbol range,
to make it match the convention used for struct map->end. (Arnaldo
Carvalho de Melo)
- Fix perf_evlist__add_pollfd() error handling in 'perf kvm stat
live' (Jiri Olsa)
- Fix python test build by moving callchain_param to an object linked
into the python binding (Jiri Olsa)
- Document sysfs events/ interfaces (Cody P Schafer)
- Fix typos in perf/Documentation (Masanari Iida)
- Add missing 'struct option' forward declaration (Arnaldo Carvalho
de Melo)
- Add option to copy events when queuing for sorting across cpu
buffers and enable it for 'perf kvm stat live', to avoid having
events left in the queue pointing to the ring buffer be rewritten
in high volume sessions. (Alexander Yarygin, improving work done
by David Ahern):
- Do not include a struct hists per perf_evsel, untangling the
histogram code from perf_evsel, to pave the way for exporting a
minimalistic tools/lib/api/perf/ library usable by tools/perf and
initially by the rasd daemon being developed by Borislav Petkov,
Robert Richter and Jean Pihet. (Arnaldo Carvalho de Melo)
- Make perf_evlist__open(evlist, NULL, NULL), i.e. without cpu and
thread maps mean syswide monitoring, reducing the boilerplate for
tools that only want system wide mode. (Arnaldo Carvalho de Melo)
- Move exit stuff from perf_evsel__delete to perf_evsel__exit, delete
should be just a front end for exit + free (Arnaldo Carvalho de
Melo)
- Add support to new style format of kernel PMU event. (Kan Liang)
and other misc fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits)
perf script: Add period as a default output column
perf script: Add period data column
perf evsel: No need to drag util/cgroup.h
perf evlist: Add missing 'struct option' forward declaration
perf evsel: Move exit stuff from __delete to __exit
kprobes/x86: Remove stale ARCH_SUPPORTS_KPROBES_ON_FTRACE define
perf kvm stat live: Enable events copying
perf session: Add option to copy events when queueing
perf Documentation: Fix typos in perf/Documentation
perf trace: Use thread_{,_set}_priv helpers
perf kvm: Use thread_{,_set}_priv helpers
perf callchain: Create an address space per thread
perf report: Set callchain_param.record_mode for future use
perf evlist: Fix for double free in tools/perf stat
perf test: Add test case for pmu event new style format
perf tools: Add support to new style format of kernel PMU event
perf tools: Parse the pmu event prefix and suffix
Revert "perf tools: Default to cpu// for events v5"
perf Documentation: Remove Ruplicated docs for powerpc cpu specific events
perf Documentation: sysfs events/ interfaces
Pull sparc fixes from David Miller:
"Here we have two bug fixes:
1) The current thread's fault_code is not setup properly upon entry to
do_sparc64_fault() in some paths, leading to spurious SIGBUS.
2) Don't use a zero length array at the end of thread_info on sparc64,
otherwise end_of_stack() isn't right"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc64: Do not define thread fpregs save area as zero-length array.
sparc64: Fix corrupted thread fault code.
Pull networking fixes from David Miller:
"A quick batch of bug fixes:
1) Fix build with IPV6 disabled, from Eric Dumazet.
2) Several more cases of caching SKB data pointers across calls to
pskb_may_pull(), thus referencing potentially free'd memory. From
Li RongQing.
3) DSA phy code tests operation presence improperly, instead of going:
if (x->ops->foo)
r = x->ops->foo(args);
it was going:
if (x->ops->foo(args))
Fix from Andew Lunn"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
Net: DSA: Fix checking for get_phy_flags function
ipv6: fix a potential use after free in sit.c
ipv6: fix a potential use after free in ip6_offload.c
ipv4: fix a potential use after free in gre_offload.c
tcp: fix build error if IPv6 is not enabled
The check for the presence or not of the optional switch function
get_phy_flags() called the function, rather than checked to see if it
is a NULL pointer. This causes a derefernce of a NULL pointer on all
switch chips except the sf2, the only switch to implement this call.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Fixes: 6819563e646a ("net: dsa: allow switch drivers to specify phy_device::dev_flags")
Cc: Florian Fainelli <f.fainelli@gmail.com>
This breaks the stack end corruption detection facility.
What that facility does it write a magic value to "end_of_stack()"
and checking to see if it gets overwritten.
"end_of_stack()" is "task_thread_info(p) + 1", which for sparc64 is
the beginning of the FPU register save area.
So once the user uses the FPU, the magic value is overwritten and the
debug checks trigger.
Fix this by making the size explicit.
Due to the size we use for the fpsaved[], gsr[], and xfsr[] arrays we
are limited to 7 levels of FPU state saves. So each FPU register set
is 256 bytes, allocate 256 * 7 for the fpregs area.
Reported-by: Meelis Roos <mroos@linux.ee>
Every path that ends up at do_sparc64_fault() must install a valid
FAULT_CODE_* bitmask in the per-thread fault code byte.
Two paths leading to the label winfix_trampoline (which expects the
FAULT_CODE_* mask in register %g4) were not doing so:
1) For pre-hypervisor TLB protection violation traps, if we took
the 'winfix_trampoline' path we wouldn't have %g4 initialized
with the FAULT_CODE_* value yet. Resulting in using the
TLB_TAG_ACCESS register address value instead.
2) In the TSB miss path, when we notice that we are going to use a
hugepage mapping, but we haven't allocated the hugepage TSB yet, we
still have to take the window fixup case into consideration and
in that particular path we leave %g4 not setup properly.
Errors on this sort were largely invisible previously, but after
commit 4ccb9272892c33ef1c19a783cfa87103b30c2784 ("sparc64: sun4v TLB
error power off events") we now have a fault_code mask bit
(FAULT_CODE_BAD_RA) that triggers due to this bug.
FAULT_CODE_BAD_RA triggers because this bit is set in TLB_TAG_ACCESS
(see #1 above) and thus we get seemingly random bus errors triggered
for user processes.
Fixes: 4ccb9272892c ("sparc64: sun4v TLB error power off events")
Pull slave-dmaengine updates from Vinod Koul:
"For dmaengine contributions we have:
- designware cleanup by Andy
- my series moving device_control users to dmanegine_xxx APIs for
later removal of device_control API
- minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma
etc"
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits)
serial: atmel: add missing dmaengine header
dmaengine: remove FSLDMA_EXTERNAL_START
dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method
carma-fpga: move to fsl_dma_external_start()
carma-fpga: use dmaengine_xxx() API
dmaengine: freescale: add and export fsl_dma_external_start()
dmaengine: add dmaengine_prep_dma_sg() helper
video: mx3fb: use dmaengine_terminate_all() API
serial: sh-sci: use dmaengine_terminate_all() API
net: ks8842: use dmaengine_terminate_all() API
mtd: sh_flctl: use dmaengine_terminate_all() API
mtd: fsmc_nand: use dmaengine_terminate_all() API
V4L2: mx3_camer: use dmaengine_pause() API
dmaengine: coh901318: use dmaengine_terminate_all() API
pata_arasan_cf: use dmaengine_terminate_all() API
dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause()
dmaengine: dw: export probe()/remove() and Co to users
dmaengine: dw: enable and disable controller when needed
dmaengine: dw: always export dw_dma_{en,dis}able
dmaengine: dw: introduce dw_dma_on() helper
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev updates from Tomi Valkeinen:
- new 6x10 font
- various small fixes and cleanups
* tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits)
fonts: Add 6x10 font
videomode: provide dummy inline functions for !CONFIG_OF
video/atmel_lcdfb: Introduce regulator support
fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume
framebuffer: fix screen corruption when copying
framebuffer: fix border color
arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb
arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss
video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info
video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info
video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info
video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info
video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info
video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info
video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy
video: valkyriefb: Fix unused variable warning in set_valkyrie_clock()
video: fbdev: use %*ph specifier to dump small buffers
video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT
video: fbdev: au1200fb: delete double assignment
video: fbdev: sis: delete double assignment
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
Pull second batch of changes for KVM/{arm,arm64} from Marc Zyngier:
"The most obvious thing is the sizeable MMU changes to support 48bit
VAs on arm64.
Summary:
- support for 48bit IPA and VA (EL2)
- a number of fixes for devices mapped into guests
- yet another VGIC fix for BE
- a fix for CPU hotplug
- a few compile fixes (disabled VGIC, strict mm checks)"
[ I'm pulling directly from Marc at the request of Paolo Bonzini, whose
backpack was stolen at Düsseldorf airport and will do new keys and
rebuild his web of trust. - Linus ]
* tag 'kvm-arm-for-3.18-take-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm:
arm/arm64: KVM: Fix BE accesses to GICv2 EISR and ELRSR regs
arm: kvm: STRICT_MM_TYPECHECKS fix for user_mem_abort
arm/arm64: KVM: Ensure memslots are within KVM_PHYS_SIZE
arm64: KVM: Implement 48 VA support for KVM EL2 and Stage-2
arm/arm64: KVM: map MMIO regions at creation time
arm64: kvm: define PAGE_S2_DEVICE as read-only by default
ARM: kvm: define PAGE_S2_DEVICE as read-only by default
arm/arm64: KVM: add 'writable' parameter to kvm_phys_addr_ioremap
arm/arm64: KVM: fix potential NULL dereference in user_mem_abort()
arm/arm64: KVM: use __GFP_ZERO not memset() to get zeroed pages
ARM: KVM: fix vgic-disabled build
arm: kvm: fix CPU hotplug
Pull MIPS updates from Ralf Baechle:
"This is the MIPS pull request for the next kernel:
- Zubair's patch series adds CMA support for MIPS. Doing so it also
touches ARM64 and x86.
- remove the last instance of IRQF_DISABLED from arch/mips
- updates to two of the MIPS defconfig files.
- cleanup of how cache coherency bits are handled on MIPS and
implement support for write-combining.
- platform upgrades for Alchemy
- move MIPS DTS files to arch/mips/boot/dts/"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (24 commits)
MIPS: ralink: remove deprecated IRQF_DISABLED
MIPS: pgtable.h: Implement the pgprot_writecombine function for MIPS
MIPS: cpu-probe: Set the write-combine CCA value on per core basis
MIPS: pgtable-bits: Define the CCA bit for WC writes on Ingenic cores
MIPS: pgtable-bits: Move the CCA bits out of the core's ifdef blocks
MIPS: DMA: Add cma support
x86: use generic dma-contiguous.h
arm64: use generic dma-contiguous.h
asm-generic: Add dma-contiguous.h
MIPS: BPF: Add new emit_long_instr macro
MIPS: ralink: Move device-trees to arch/mips/boot/dts/
MIPS: Netlogic: Move device-trees to arch/mips/boot/dts/
MIPS: sead3: Move device-trees to arch/mips/boot/dts/
MIPS: Lantiq: Move device-trees to arch/mips/boot/dts/
MIPS: Octeon: Move device-trees to arch/mips/boot/dts/
MIPS: Add support for building device-tree binaries
MIPS: Create common infrastructure for building built-in device-trees
MIPS: SEAD3: Enable DEVTMPFS
MIPS: SEAD3: Regenerate defconfigs
MIPS: Alchemy: DB1300: Add touch penirq support
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull powerpc fix from Michael Ellerman:
"There was a bit of a misunderstanding between us and the ARM guys in
the device tree PCI code, which is breaking virtio on powerpc.
This is the minimal fix until we can sort it out properly"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux:
powerpc/pci: Fix IO space breakage after of_pci_range_to_resource() change
Pull cifs/smb3 updates from Steve French:
"Improved SMB3 support (symlink and device emulation, and remapping by
default the 7 reserved posix characters) and a workaround for cifs
mounts to Mac (working around a commonly encountered Mac server bug)"
* 'for-linus' of git://git.samba.org/sfrench/cifs-2.6:
[CIFS] Remove obsolete comment
Check minimum response length on query_network_interface
Workaround Mac server problem
Remap reserved posix characters by default (part 3/3)
Allow conversion of characters in Mac remap range (part 2)
Allow conversion of characters in Mac remap range. Part 1
mfsymlinks support for SMB2.1/SMB3. Part 2 query symlink
Add mfsymlinks support for SMB2.1/SMB3. Part 1 create symlink
Allow mknod and mkfifo on SMB2/SMB3 mounts
add defines for two new file attributes
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm
Pull dlm fix from David Teigland:
"This includes a single commit fixing a missing endian conversion"
* tag 'dlm-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm:
dlm: fix missing endian conversion of rcom_status flags
