The "Status" registers are sequential in the enum ni_gpct_register.
Replace this inline CamelCase function with a simple define.
Rename the define for the shared status register.
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
The "Interrupt Acknowledge" registers are sequential in the enum ni_gpct_register.
The "ABZ" registers are sequential in the enum ni_gpct_register.
The "DMA Status" registers are sequential in the enum ni_gpct_register.
The "DMA Config" registers are sequential in the enum ni_gpct_register.
The shared "Status2" registers are sequential in the enum ni_gpct_register.
The shared "Status1" registers are sequential in the enum ni_gpct_register.
The shared "Reset" registers are sequential in the enum ni_gpct_register.
The shared "Status" registers are sequential in the enum ni_gpct_register.
The "Second Gate" registers are sequential in the enum ni_gpct_register.
The "Counting Mode" registers are sequential in the enum ni_gpct_register.
The "Input Select" registers are sequential in the enum ni_gpct_register.
The "LoadB" registers are sequential in the enum ni_gpct_register.
The "LoadA" registers are sequential in the enum ni_gpct_register.
The "Mode" registers are sequential in the enum ni_gpct_register.
The "SW Save" registers are sequential in the enum ni_gpct_register.
The "Command" registers are sequential in the enum ni_gpct_register.
The "AutoIncrement" registers are sequential in the enum ni_gpct_register.
As prefered by the CodingStyle, rename all the CamelCase labels of the
Cleanup all the helper functions in ni_tio_internal.h that used the enum.
The 'counter_index' parameter to all the functions is the ni_gpct_device
'counter_index' which is initialized when the subdevices are setup. This
value is always < 4 so the default: BUG() cases can never happen. For
aesthetics, rename the 'counter_idx' to simply 'idx' and fix the type in
some of the helpers.
Also, remove the unnecessary break statements after the return statements.
InterfaceIdleMode.c.
This patch fixes all the warning related to spacing issues
found by checkpatch.pl script in InterfaceIdleMode.c
Signed-off-by: Gokulnath Avanashilingam <Gokulnath.Avanashilingam@in.bosch.com>
Used the time_after and time_before insted of comparing
the jiffies directly.This will fix the warnings and errors
found by the checkpatch.pl script.
Fixed all the line over 80 characters warning found by
Removed the developer debug prints BCM_DEBUG_PRINT()
as per the TODO list, also removed braces for the
if-statement to match coding style
Add the missing destroy_workqueue() before return from
sep_crypto_setup() and sep_crypto_takedown().
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
In case of error, the function crypto_alloc_hash() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check
should be replaced with IS_ERR().
Checkpatch mentioned that these macros should be defined with a 'do {...} while(0)' statement.
So we used grep to find all files using these macros and we found out that these macros were only used
in rtl819x_Qos.h, in the defines we removed before.
Since the macros are not used anywhere else we decided to remove them from the driver.
Signed-off-by: Andreas Frembs <andreas.frembs@studium.uni-erlangen.de>
Signed-off-by: Matthias Schoepe <matthias.schoepe@studium.uni-erlangen.de>
In rtl819x_Qos.h there were several macros defined but never used.
So we removed this macros.
This patch fixes the following checkpatch errors from rtllib_endianfree.h:
- ERROR: Macros with complex values should be enclosed in parenthesis
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes
From Simon Horman:
Renesas ARM based SoC fixes for v3.13
* r8a7790 (R-Car H1) SoC
- Correct GPIO resources in DT.
This problem has been present since GPIOs were added to the r8a7790 SoC
by f98e10c88aa95bf7 ("ARM: shmobile: r8a7790: Add GPIO controller
devices to device tree") in v3.12-rc1.
* irqchip renesas-intc-irqpin
- Correct register bitfield shift calculation
This bug has been present since the renesas-intc-irqpin driver was
introduced by 443580486e3b9657 ("irqchip: Renesas INTC External IRQ pin
driver") in v3.10-rc1
* Lager board
- Do not build the phy fixup unless CONFIG_PHYLIB is enabled
This problem was introduced by 48c8b96f21817aad
* tag 'renesas-fixes-for-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: r8a7790: Fix GPIO resources in DTS
irqchip: renesas-intc-irqpin: Fix register bitfield shift calculation
ARM: shmobile: lager: phy fixup needs CONFIG_PHYLIB
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Patch queue for 3.13 - 2013-12-18
This fixes some grave issues we've only found after 3.13-rc1:
- Make the modularized HV/PR book3s kvm work well as modules
- Fix some race conditions
- Fix compilation with certain compilers (booke)
- Fix THP for book3s_hv
- Fix preemption for book3s_pr
Alexander Graf (4):
KVM: PPC: Book3S: PR: Don't clobber our exit handler id
KVM: PPC: Book3S: PR: Export kvmppc_copy_to|from_svcpu
KVM: PPC: Book3S: PR: Make svcpu -> vcpu store preempt savvy
KVM: PPC: Book3S: PR: Enable interrupts earlier
Aneesh Kumar K.V (1):
powerpc: book3s: kvm: Don't abuse host r2 in exit path
Paul Mackerras (5):
KVM: PPC: Book3S HV: Fix physical address calculations
KVM: PPC: Book3S HV: Refine barriers in guest entry/exit
KVM: PPC: Book3S HV: Make tbacct_lock irq-safe
KVM: PPC: Book3S HV: Take SRCU read lock around kvm_read_guest() call
KVM: PPC: Book3S HV: Don't drop low-order page address bits
Scott Wood (1):
powerpc/kvm/booke: Fix build break due to stack frame size warning
pingfan liu (1):
powerpc: kvm: fix rare but potential deadlock scene
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen bugfixes from Konrad Rzeszutek Wilk:
- Fix balloon driver for auto-translate guests (PVHVM, ARM) to not use
scratch pages.
- Fix block API header for ARM32 and ARM64 to have proper layout
- On ARM when mapping guests, stick on PTE_SPECIAL
- When using SWIOTLB under ARM, don't call swiotlb functions twice
- When unmapping guests memory and if we fail, don't return pages which
failed to be unmapped.
- Grant driver was using the wrong address on ARM.
* tag 'stable/for-linus-3.13-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/balloon: Seperate the auto-translate logic properly (v2)
xen/block: Correctly define structures in public headers on ARM32 and ARM64
arm: xen: foreign mapping PTEs are special.
xen/arm64: do not call the swiotlb functions twice
xen: privcmd: do not return pages which we have failed to unmap
XEN: Grant table address, xen_hvm_resume_frames, is a phys_addr not a pfn
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull ftrace fix from Steven Rostedt:
"This fixes a long standing bug in the ftrace profiler. The problem is
that the profiler only initializes the online CPUs, and not possible
CPUs. This causes issues if the user takes CPUs online or offline
while the profiler is running.
If we online a CPU after starting the profiler, we lose all the trace
information on the CPU going online.
If we offline a CPU after running a test and start a new test, it will
not clear the old data from that CPU.
This bug causes incorrect data to be reported to the user if they
online or offline CPUs during the profiling"
* tag 'trace-fixes-v3.13-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ftrace: Initialize the ftrace profiler for each possible cpu
In this patch we fix some "logical" errors in bypass.c of the silicom bypass
driver (in staging).
Checkpatch complains about the following errors:
- unnecessary forward declarations in a source file
- assignment in if condition
In addition to that the __init and __exit macros were missing at the init and
cleanup function.
There are still two warnings left for this file related to too many leadingtabs
at nested blocks. I did not touch this issue becasue the code needs really some
refactoring. And since i do not have the appropriate hardware to test the code,
i do not change the functionality in any way.
Signed-off-by: Michael Hoefler <michael.hoefler@studium.uni-erlangen.de>
Signed-off-by: Christoph Kohl <christoph.kohl@t-online.de>
This patch improves bypass.c (in staging) in terms of coding style. This
includes different issues some of them mentioned by checkpatch:
- a c++ one line comment
- parenthesis at return statementes
- multiple definitions in one line
- missing braces according to the style guide
This patch addresses several problems in bypass.c found by checkpatch.
Furthermore it removes/adds some empty lines to make the code more readable.
The following problems are fixed:
- line over 80 characters
- space after logical operator !
- spaces instead of tabs
- missing empty line after local declarations
- empty line after {
The empty line issues were not discovered by checkpatch but in my opinion these
changes make perfect sense in terms of readability.
rtw_udelay_os
Each instance may bre replaced by udelay
simple mdelay
simple msleep
This wrapper does nothing on Linux. When calls to it were removed, a number of
routines became empty and could also be removed.
Again there are two - _exit_critical() and _exit_critical_ex().
There are two such wrappers - _enter_critical() and _enter_critical_ex().
With this change, a number of variables for storing flags are no longer used.
Some comment lines that mentioned spin_lock_bh() are also removed.
Originally, this driver created it's own allocating
function. This patch removes that function and calls
kzalloc directly.
This patch affects:
- driver.c
- driver.h
- fep5.c
- tty.c
Signed-off-by: Lidza Louina <lidza.louina@gmail.com>
This is a patch to the dgnc_cls.c file that fixes up comparison with
jiffies usage warning found by the checkpatch.pl tool
Signed-off-by: S. Stalin Srinivasan <stalinsrinivasan.s@gmail.com>
This is a patch to the dgnc_cls.c file that fixes up volatile usage
fixes up 80 characters per line and code indent
warnings found by the checkpatch.pl tool.
