The driver leaves the device in power-down state anyway,
so there is nothing to do on suspend.
On resume, we just have to make sure the range and ADC
values are updated in the device since it may have been
powered down in suspend.
Signed-off-by: Bryan Freed <bfreed@chromium.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
If we encounter a leading '+' sign just skip over it.
When parsing a fixed point number IIO stops parsing the string once it has
reached the last requested decimal place. This means that the remainder of the
string is silently accepted regardless, of whether it is part of a valid number
or not. This patch modifies the code to scan the whole string and only accept
valid numbers. Since fract_mult is 0 after the last decimal place any digit that
may follows won't affect the result.
Currently when parsing a fix-point number we silently skip any additional '.'
found in the string. E.g. '1.2.3.4' gets parsed as '1.234'. This patch
disallows this and returns an error if more than one '.' is encountered.
remove unnecessary semicolon from the macro definition
Signed-off-by: Kumar Amit Mehta <gmate.amit@gmail.com>
There is an unlock missing on this error path.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
This reverts commit 45259859492812c8b700ae1d157be01a8d2babfe.
This fixes build error because devm_kcalloc does not exist in current tree.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
The adt7310 is the SPI version of the adt7410, so there is no need to have a
separate driver for it. The register map layout is a bit different, i.e. the
addresses of the register differ, but the individual register layouts are
identical. We solve this by adding a small look-up table, which translates
adt7410 register addresses to ad7310 register addresses.
This patch removes typedef
stLocalSFAddRequestAlt in CmHost.h.
Signed-off-by: Kevin McKinney <klmckinney1@gmail.com>
This patch removes typedef for
stLocalSFAddIndicationAlt, changes the
name of the struct to bcm_add_indication_alt,
and removes a comment. In addition, any
calls to typedef stLocalSFAddIndicationAlt
are changed to call the struct directly.
all protos that are removed does not have a function definition
so remove all of them together
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
remove this header file as no struct or no function is
defined else where in csr.
remove all braces around single statement if blocks
theres no point in checking the col variable,
its always zero, and wont print a new line, actually
its better to have a new line after a set of characters
printed, instead of confusing with the concatenated
characters when called multiple times at a time.
replace spaces at the start of line with tabs
replace spaces at the start of the line with tabs
replace the spaces with the tabs at the start of line
The PHY registers are now being controlled from the connected phydev,
so there shouldn't be any reason for the et131x code to perform any
extra setup. Removing the interrupt setup code, and register defines
that are now unused.
On testing, no changes in behaviour were experienced.
Signed-off-by: Mark Einon <mark.einon@gmail.com>
During a previous refactoring excerise, two NULL pointer assingments
were moved to their respective pointer declarations. Dan Carpenter
correctly points out that these assignments are not needed.
Removing them.
Also two small whitespace changes - rejoining split lines, as they are
now less than 80 chars.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
-Added some extra items to the TODO list.
In nic_rx_pkts() some large chunks of code are indented in 'if (len)'
sections. Refactor the code to remove these indents and re-join longer
split lines.
Several places in et131x.c code is duplicated for fbr[0] and fbr[1].
Remove the duplicate lines and use loops to run over both indicies.
No dependency on plat headers, so only needs Kconfig update to
build for ARCH_MULTIPLATFORM.
Signed-off-by: Rob Clark <rob@ti.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Remove usage of plat/cpu.h and get information from platform data
instead. This enables omapdrm to be built with ARCH_MULTIPLATFORM.
Not actually used anymore.
Casting value returned by k[cmz]alloc to (struct page * *) is useless.
Generated by: scripts/coccinelle/api/alloc/drop_kmalloc_cast.cocci
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
For hardware that does not have DMM/TILER, there is no rotation,
so no point in getting userspace's hopes up.
Change comedi drivers for PCI boards to use the new `auto_attach()`
method instead of the `attach_pci()` method. I plan to remove the
`attach_pci()` and `attach_usb()` methods from `struct comedi_driver`
once nothing is using them.
Tag the functions with `__devinit` where they are not already so tagged,
as they are only called during PCI probe.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Change the usbdux, usbduxfast and usbduxsigma drivers to use the new
`auto_attach()` method instead of the `attach_usb()` method. I plan to
remove the `attach_usb()` and `attach_pci()` methods from `struct
comedi_driver` once nothing is using them.
The eeprom 'type' can be found from the boardinfo when needed.
Finding it when needed also makes it clearer what this value is.
Cc: Ian Abbott <abbotti@mev.co.uk>
Fix the following checkpatch.pl issues:
ERROR: code indent should use tabs where possible
WARNING: please, no spaces at the start of a line
WARNING: line over 80 characters
This file is now checkpatch.pl clean.
Fix the whitespace in the defines. This also fixes a couple
checkpatch.pl issues.
Reformat the driver description comment to use the preferred block
comment style.
The second driver comment block contains the same information as
the first one. Remove it.
Add namespace by renaming this CamelCase function to
addi_eeprom_read_info().
Remove the 'type' parameter. This parameter is a char pointer to the
string name of the eeprom type used on the board. This can be found
when needed using the dev pointer.
Change the parameter order so that the comedi_device pointer is passed
first.
The return value is always 0 and it's never checked. Change it to void.
Use this function to set the private data instead of doing it in the
i_EepromReadMainHeader() function. Keep the eeprom read code #if 0'ed
out for now.
addi_eeprom_read_timer_info().
Remove the unused str_TimerMainHeader and str_TimerDetails structs.
addi_eeprom_read_ai_info().
Refactor the function so that it stores the data from the eeprom directly
in the private data instead of using the a struct to pass the data back
to i_EepromReadMainHeader(). This allows removing the str_AnalogInputHeader
struct.
addi_eeprom_read_ao_info().
to i_EepromReadMainHeader(). This allows removing the str_AnalogOutputHeader
struct.
addi_eeprom_read_do_info().
to i_EepromReadMainHeader(). This allows removing the str_DigitalOutputHeader
struct.
addi_eeprom_read_di_info().
to i_EepromReadMainHeader(). This allows removing the str_DigitalInputHeader
struct.
Leave the reads of the unused eeprom data for now.
Consolidate the two loops used to read the main header data and the
individual function header data from the eeprom.
The structs used to read the main header are not used outside this
function so remove them by reading the eeprom data into local
variables used in the loop.
Consolidate the 'timer' function cases.
All the addi_eeprom_readw() calls have the offset to the start of user
data (0x100) as part of the address calculation. Create a define for this
constant and move it's addition to the address into addi_eeprom_readw().
Add namespace to the function by renaming the CamelCase function to
Rename the CamelCase parameters and local variables.
Use the AMCC_OP_REG_* register offset defines for the magic numbers
used to read the nvram data.
Factor the code that reads the word from the nvram out of the
w_EepromReadWord() function.
Cleanup the factored out code so it's a bit more concise.
addi_eeprom_nvram_wait().
Rename the CamelCase local variable.
Refactor the do {} while to make the code a bit more concise.
addi_eeprom_read_93c76().
Change the return type of the function to unsigned short and just
return the read value instead of passing it through a pointer.
Make addi_eeprom_cmd_93c76() return the last value so it does not
need to be calculated.
Rename the EE_READ and EE76_CMD_LEN defines so they have namespace
associated with the other 93c76 defines.
Cleanup the loop that reads the eeprom bits so it's a bit more concise.
addi_eeprom_cmd_93c76().
addi_eeprom_clk_93c76().
Rename the CamelCase parameter, dw_RegisterValue, to simply 'val'.
Define the magic values used for the clock, chip-select, data out,
and data in signals to the 93c76 eeprom.
This variable is the pointer to the string name of the eeprom type
found on the board. This name comes from the boardinfo of the
driver.
For aesthetic reasons, rename it to simply 'type'.
