2008-11-13Linux 2.6.27.6v2.6.27.6Greg Kroah-Hartman
2008-11-13HID: fix incorrent length condition in hidraw_write()Jiri Kosina
upstream commit 2b107d629dc0c35de606bb7b010b829cd247a93a From: Jiri Kosina <jkosina@suse.cz> The bound check on the buffer length if (count > HID_MIN_BUFFER_SIZE) is of course incorrent, the proper check is if (count > HID_MAX_BUFFER_SIZE) Fix it. Reported-by: Jerry Ryle <jerry@mindtribe.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Paul Stoffregen <paul@pjrc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13hfs: fix namelength memory corruption (CVE-2008-5025)Eric Sesterhenn
commit d38b7aa7fc3371b52d036748028db50b585ade2e upstream Fix a stack corruption caused by a corrupted hfs filesystem. If the catalog name length is corrupted the memcpy overwrites the catalog btree structure. Since the field is limited to HFS_NAMELEN bytes in the structure and the file format, we throw an error if it is too long. Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13mmc: increase SD write timeout for crappy cardsPierre Ossman
commit 493890e75d98810a3470b4aae23be628ee5e9667 upstream. It seems that some cards are slightly out of spec and occasionally will not be able to complete a write in the alloted 250 ms [1]. Incease the timeout slightly to allow even these cards to function properly. [1] http://lkml.org/lkml/2008/9/23/390 Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13Fix __pfn_to_page(pfn) for CONFIG_DISCONTIGMEM=yRafael J. Wysocki
commit c5d712433ff57a66d8fb79a57a4fc7a7c3467b97 upstream Fix the __pfn_to_page(pfn) macro so that it doesn't evaluate its argument twice in the CONFIG_DISCONTIGMEM=y case, because 'pfn' may be a result of a funtion call having side effects. For example, the hibernation code applies pfn_to_page(pfn) to the result of a function returning the pfn corresponding to the next set bit in a bitmap and the current bit position is modified on each call. This leads to "interesting" failures for CONFIG_DISCONTIGMEM=y due to the current behavior of __pfn_to_page(pfn). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13ALSA: hda: make a STAC_DELL_EQ optionMatthew Ranostay
commit 6b3ab21ef1ac15db4b053ce0ba8eae0ef9361c8a upstream. Add support for explicitly enabling the EQ distortion hack for systems without software biquad support. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13libata: fix last_reset timestamp handlingTejun Heo
commit 19b723218bde79c60a394a3caee9eb156ac2d356 upstream ehc->last_reset is used to ensure that resets are not issued too close to each other. It's initialized to jiffies minus one minute on EH entry. However, when new links are initialized after PMP is probed, new links have zero for this timestamp resulting in long wait depending on the current jiffies. This patch makes last_set considered iff ATA_EHI_DID_RESET is set, in which case last_reset is always initialized. As an added precaution, WARN_ON() is added so that warning is printed if last_reset is in future. This problem is spotted and debugged by Shane Huang. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shane Huang <Shane.Huang@amd.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13KEYS: Make request key instantiate the per-user keyringsDavid Howells
commit 1f8f5cf6e4f038552a3e47b66085452c08556d71 upstream Make request_key() instantiate the per-user keyrings so that it doesn't oops if it needs to get hold of the user session keyring because there isn't a session keyring in place. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Steve French <smfrench@gmail.com> Tested-by: Rutger Nijlunsing <rutger.nijlunsing@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13ARM: 5300/1: fixup spitz reset during bootDmitry Baryshkov
commit 69fc7eed5f56bce15b239e5110de2575a6970df4 upstream Some machines don't have the pullup/down on their reset pin, so configuring the reset generating pin as input makes them reset immediately. Fix that by making reset pin direction configurable. This fixes the boot problem on Sharp Zaurus c3000 Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13ACPI: dock: avoid check _STA methodShaohua Li
commit 8b59560a3baf2e7c24e0fb92ea5d09eca92805db upstream. In some BIOSes, every _STA method call will send a notification again, this cause freeze. And in some BIOSes, it appears _STA should be called after _DCK. This tries to avoid calls _STA, and still keep the device present check. http://bugzilla.kernel.org/show_bug.cgi?id=10431 Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13cpqarry: fix return value of cpqarray_init()Andrey Borzenkov
commit 2197d18ded232ef6eef63cce57b6b21eddf1b7b6 upstream. As reported by Dick Gevers on Compaq ProLiant: Oct 13 18:06:51 dvgcpl kernel: Compaq SMART2 Driver (v 2.6.0) Oct 13 18:06:51 dvgcpl kernel: sys_init_module: 'cpqarray'->init suspiciously returned 1, it should follow 0/-E convention Oct 13 18:06:51 dvgcpl kernel: sys_init_module: loading module anyway... Oct 13 18:06:51 dvgcpl kernel: Pid: 315, comm: modprobe Not tainted 2.6.27-desktop-0.rc8.2mnb #1 Oct 13 18:06:51 dvgcpl kernel: [<c0380612>] ? printk+0x18/0x1e Oct 13 18:06:51 dvgcpl kernel: [<c0158f85>] sys_init_module+0x155/0x1c0 Oct 13 18:06:51 dvgcpl kernel: [<c0103f06>] syscall_call+0x7/0xb Oct 13 18:06:51 dvgcpl kernel: ======================= Make it return 0 on success and -ENODEV if no array was found. Reported-by: Dick Gevers <dvgevers@xs4all.nl> Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwl3945: do not send scan command if channel count zeroReinette Chatre
commit 14b5433606289dbc5b6fd70ced11462f80e95003 upstream. Do not send scan command if no channels to scan. This avoids a Microcode error as reported in: http://www.intellinuxwireless.org/bugzilla/show_bug.cgi?id=1650 http://bugzilla.kernel.org/show_bug.cgi?id=11806 http://marc.info/?l=linux-wireless&m=122437145211886&w=2 Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwl3945: fix deadlock on suspendZhu Yi
commit d54bc4e3fc5c56600a13c9ebc0a7e1077ac05d59 upstream. This patch fixes iwl3945 deadlock during suspend by moving notify_mac out of iwl3945 mutex. This is a portion of the same fix for iwlwifi by Tomas. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13zd1211rw: Add 2 device IDsDaniel Drake
commit 0feec9dfe7b8880ab3b4c38d7cc4107dd706ea7f upstream. 07fa/1196 Bewan BWIFI-USB54AR: Tested by night1308, this device is a ZD1211B with an AL2230S radio. 0ace/b215 HP 802.11abg: Tested by Robert Philippe Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwlwifi: generic init calibrations frameworkTomas Winkler
commit 6e21f2c109edd746a10e08186484bae8168cdd0c upstream This patch allows variable number of init calibrations and allows addition new HW. This patch also fixes critical bug. Only last calibration result was applied. On reception of one calibration result all the calibration was freed. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwlwifi: fix suspend to RAM in iwlwifiTomas Winkler
commit 10d0bd56966571d0324dfd9bbb8aa913a60bef5f upstream This patch fixes suspend to RAM after by moving notify_mac out of iwlwifi mutex http://bugzilla.kernel.org/show_bug.cgi?id=11845 Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Tested-by: Carlos R. Mafra <crmafra2@gmail.com> Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwlwifi: use correct DMA_MASKTomas Winkler
commit 093d874c02e8d3091aa38596faf0ff2bfd4f0ceb upstream Use correct DMA_MASK: 4964 and 5000 support 36 bit addresses for pci express memory access. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-13iwlwifi: don't fail if scan is issued too earlyTomas Winkler
commit 8d09a5e1c36d0dec5728e6c8b0bb5412de09b27b upstream This patch returns success and empty scan on scans requests that were rejected because issued too early. The cached bss list from previous scanning will be returned by mac80211. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwlwifi: remove HT flags from RXON when not in HT anymoreEmmanuel Grumbach
commit 42eb7c644afcdbcd7eac4d862046230856fbf531 upstream. This patch removes the HT flags from RXON when moving from HT to legacy. This avoids keeping those flags set and possibly miss configuring firmware. If we are configured in HT, fat channel: channel 1 above, and move later to legacy channel 11, we need to clear the FAT channel control flags in RXON. If we don't, the firmware will understand this as channel 11 above which is not possible due to regulatory constraints, leading to firmware crash. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwlwifi: allow association on radar channel in power saveEmmanuel Grumbach
commit c90a74bae10dc2a4677d1bd06b6400db229d3e1e upstream This patch disables power save upon association and enables it back after association. This allows to associate to AP on a radar channel if power save is enabled. Radar and passive channels are not allowed for TX (required for association) unless RX is received but PS may close the radio and no RX will be received effectively failing association. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13iwlwifi: allow consecutive scans in unassociated stateRon Rindjunsky
commit 681c0050ea3ac2e90c83d5af397d73eed848a372 upstream This patch allows consecutive scans requests when driver is in unassociated state. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Esti Kummer <ester.kummer@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13dca: fixup initialization dependencyDan Williams
commit 1207e795568a368928dfd23d6817e47f2e8097e3 upstream Mark dca_init as a subsys_initcall since it needs to be ready to go before dependent drivers start registering themselves. Reported-and-tested-by: Mark Rustad <mark_rustad@Xiotech.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13I/OAT: fix async_tx.callback checkingMaciej Sosnowski
commit 12ccea24e309d815d058cdc6ee8bf2c4b85f0c5f upstream async_tx.callback should be checked for the first not the last descriptor in the chain. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13I/OAT: fix dma_pin_iovec_pages() error handlingMaciej Sosnowski
commit c2c0b4c5434c0a25f7f7796b29155d53805909f5 upstream Error handling needs to be modified in dma_pin_iovec_pages(). It should return NULL instead of ERR_PTR (pinned_list is checked for NULL in tcp_recvmsg() to determine if iovec pages have been successfully pinned down). In case of error for the first iovec, local_list->nr_iovecs needs to be initialized. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13I/OAT: fix channel resources free for not allocated channelsMaciej Sosnowski
commit c3d4f44f50b65b0b0290e357f8739cfb3f4bcaca upstream If the ioatdma driver is loaded but not used it does not allocate descriptors. Before it frees channel resources it should first be sure that they have been previously allocated. Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Tested-by: Tom Picard <tom.s.picard@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13r8169: wake up the PHY of the 8168Francois Romieu
Upstream as a2de6b89b74b28052e293fdb39975a5a03c432e0 This is typically needed when some other OS puts the PHY to sleep due to the disabling of WOL options in the BIOS of the system. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Tested-by: Chiaki Ishikawa <chiaki.ishikawa@ubin.jp> Cc: Edward Hsu <edward_hsu@realtek.com.tw> Cc: RyanKao <ryankao@realtek.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13r8169: fix RxMissed register accessFrancois Romieu
Upstream as 523a609496dbc3897e530db2a2f27650d125ea00 - the register is defined for the 8169 chipset only and there is no 8169 beyond RTL_GIGA_MAC_VER_06. - only the lower 3 bytes of the register are valid Fixes: 1. http://bugzilla.kernel.org/show_bug.cgi?id=10180 2. http://bugzilla.kernel.org/show_bug.cgi?id=11062 (bits of) Tested by Hermann Gausterer and Adam Huffman. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Edward Hsu <edward_hsu@realtek.com.tw> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13r8169: get ethtool settings through the generic mii helperFrancois Romieu
Upstream as ccdffb9a88b2907b159538d7bfd6256621db4f84 (post 2.6.27). It avoids to report unsupported link capabilities with the fast-ethernet only 8101/8102. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Tested-by: Martin Capitanio <martin@capitanio.org> Fixed-by: Ivan Vecera <ivecera@redhat.com> Cc: Edward Hsu <edward_hsu@realtek.com.tw> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13net: unix: fix inflight counting bug in garbage collectorMiklos Szeredi
commit 6209344f5a3795d34b7f2c0061f49802283b6bdd upstream Previously I assumed that the receive queues of candidates don't change during the GC. This is only half true, nothing can be received from the queues (see comment in unix_gc()), but buffers could be added through the other half of the socket pair, which may still have file descriptors referring to it. This can result in inc_inflight_move_tail() erronously increasing the "inflight" counter for a unix socket for which dec_inflight() wasn't previously called. This in turn can trigger the "BUG_ON(total_refs < inflight_refs)" in a later garbage collection run. Fix this by only manipulating the "inflight" counter for sockets which are candidates themselves. Duplicating the file references in unix_attach_fds() is also needed to prevent a socket becoming a candidate for GC while the skb that contains it is not yet queued. Reported-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13x86: don't use tsc_khz to calculate lpj if notsc is passedAlok Kataria
commit 70de9a97049e0ba79dc040868564408d5ce697f9 upstream Impact: fix udelay when "notsc" boot parameter is passed With notsc passed on commandline, tsc may not be used for udelays, make sure that we do not use tsc_khz to calculate the lpj value in such cases. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Alok N Kataria <akataria@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13MTD: [NOR] Fix cfi_send_gen_cmd handling of x16 devices in x8 mode (v4)Eric W. Biederman
commit 467622ef2acb01986eab37ef96c3632b3ea35999 upstream For "unlock" cycles to 16bit devices in 8bit compatibility mode we need to use the byte addresses 0xaaa and 0x555. These effectively match the word address 0x555 and 0x2aa, except the latter has its low bit set. Most chips don't care about the value of the 'A-1' pin in x8 mode, but some -- like the ST M29W320D -- do. So we need to be careful to set it where appropriate. cfi_send_gen_cmd is only ever passed addresses where the low byte is 0x00, 0x55 or 0xaa. Of those, only addresses ending 0xaa are affected by this patch, by masking in the extra low bit when the device is known to be in compatibility mode. [dwmw2: Do it only when (cmd_ofs & 0xff) == 0xaa] v4: Fix stupid typo in cfi_build_cmd_addr that failed to compile I'm writing this patch way to late at night. v3: Bring all of the work back into cfi_build_cmd_addr including calling of map_bankwidth(map) and cfi_interleave(cfi) So every caller doesn't need to. v2: Only modified the address if we our device_type is larger than our bus width. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13ARM: xsc3: fix xsc3_l2_inv_rangeDan Williams
commit c7cf72dcadbe39c2077b32460f86c9f8167be3be upstream When 'start' and 'end' are less than a cacheline apart and 'start' is unaligned we are done after cleaning and invalidating the first cacheline. So check for (start < end) which will not walk off into invalid address ranges when (start > end). This issue was caught by drivers/dma/dmatest. 2.6.27 is susceptible. Cc: <stable@kernel.org> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Lothar Wafmann <LW@KARO-electronics.de> Cc: Lennert Buytenhek <buytenh@marvell.com> Cc: Eric Miao <eric.miao@marvell.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13JFFS2: Fix lack of locking in thread_should_wake()David Woodhouse
commit b27cf88e9592953ae292d05324887f2f44979433 upstream The thread_should_wake() function trawls through the list of 'very dirty' eraseblocks, determining whether the background GC thread should wake. Doing this without holding the appropriate locks is a bad idea. OLPC Trac #8615 Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13JFFS2: fix race condition in jffs2_lzo_compress()Geert Uytterhoeven
commit dc8a0843a435b2c0891e7eaea64faaf1ebec9b11 upstream deflate_mutex protects the globals lzo_mem and lzo_compress_buf. However, jffs2_lzo_compress() unlocks deflate_mutex _before_ it has copied out the compressed data from lzo_compress_buf. Correct this by moving the mutex unlock after the copy. In addition, document what deflate_mutex actually protects. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13md: fix bug in raid10 recovery.Neil Brown
commit a53a6c85756339f82ff19e001e90cfba2d6299a8 upstream Adding a spare to a raid10 doesn't cause recovery to start. This is due to an silly type in commit 6c2fce2ef6b4821c21b5c42c7207cb9cf8c87eda and so is a bug in 2.6.27 and .28-rc. Thanks to Thomas Backlund for bisecting to find this. Cc: Thomas Backlund <tmb@mandriva.org> Cc: George Spelvin <linux@horizon.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13md: linear: Fix a division by zero bug for very small arrays.Andre Noll
commit f1cd14ae52985634d0389e934eba25b5ecf24565 upstream Date: Thu, 6 Nov 2008 19:41:24 +1100 Subject: md: linear: Fix a division by zero bug for very small arrays. We currently oops with a divide error on starting a linear software raid array consisting of at least two very small (< 500K) devices. The bug is caused by the calculation of the hash table size which tries to compute sector_div(sz, base) with "base" being zero due to the small size of the component devices of the array. Fix this by requiring the hash spacing to be at least one which implies that also "base" is non-zero. This bug has existed since about 2.6.14. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13cciss: new hardware supportMike Miller
commit 77ca7286d10b798e4907af941f29672bf484db77 upstream cciss: new hardware support Add support for 2 new SAS/SATA controllers. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13cciss: fix sysfs broken symlink regressionMike Miller
commit 404443081ce5e6f68b5f7eda16c959835ff200c0 upstream Regression introduced by commit 6ae5ce8e8d4de666f31286808d2285aa6a50fa40 ("cciss: remove redundant code"). This patch fixes a broken symlink in sysfs that was introduced by the above commit. We broke it in 2.6.27-rc on or about 20080804. Some installers are broken if this symlink does not exist and they may not detect the logical drives configured on the controller. It does not require being backported into 2.6.26.x or earlier kernels. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13cciss: fix regression firmware not displayed in procfsMike Miller
commit 22bece00dc1f28dd3374c55e464c9f02eb642876 upstream This regression was introduced by commit 6ae5ce8e8d4de666f31286808d2285aa6a50fa40 ("cciss: remove redundant code"). This patch fixes a regression where the controller firmware version is not displayed in procfs. The previous patch would be called anytime something changed. This will get called only once for each controller. Signed-off-by: Mike Miller <mike.miller@hp.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13hugetlbfs: handle pages higher order than MAX_ORDERAndy Whitcroft
commit 69d177c2fc702d402b17fdca2190d5a7e3ca55c5 upstream When working with hugepages, hugetlbfs assumes that those hugepages are smaller than MAX_ORDER. Specifically it assumes that the mem_map is contigious and uses that to optimise access to the elements of the mem_map that represent the hugepage. Gigantic pages (such as 16GB pages on powerpc) by definition are of greater order than MAX_ORDER (larger than MAX_ORDER_NR_PAGES in size). This means that we can no longer make use of the buddy alloctor guarentees for the contiguity of the mem_map, which ensures that the mem_map is at least contigious for maximmally aligned areas of MAX_ORDER_NR_PAGES pages. This patch adds new mem_map accessors and iterator helpers which handle any discontiguity at MAX_ORDER_NR_PAGES boundaries. It then uses these to implement gigantic page versions of copy_huge_page and clear_huge_page, and to allow follow_hugetlb_page handle gigantic pages. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-13hugetlb: pull gigantic page initialisation out of the default pathAndy Whitcroft
commit 18229df5b613ed0732a766fc37850de2e7988e43 upstream As we can determine exactly when a gigantic page is in use we can optimise the common regular page cases by pulling out gigantic page initialisation into its own function. As gigantic pages are never released to buddy we do not need a destructor. This effectivly reverts the previous change to the main buddy allocator. It also adds a paranoid check to ensure we never release gigantic pages from hugetlbfs to the main buddy. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13cgroups: fix invalid cgrp->dentry before cgroup has been completely removedLi Zefan
commit 24eb089950ce44603b30a3145a2c8520e2b55bb1 upstream This fixes an oops when reading /proc/sched_debug. A cgroup won't be removed completely until finishing cgroup_diput(), so we shouldn't invalidate cgrp->dentry in cgroup_rmdir(). Otherwise, when a group is being removed while cgroup_path() gets called, we may trigger NULL dereference BUG. The bug can be reproduced: # cat test.sh #!/bin/sh mount -t cgroup -o cpu xxx /mnt for (( ; ; )) { mkdir /mnt/sub rmdir /mnt/sub } # ./test.sh & # cat /proc/sched_debug BUG: unable to handle kernel NULL pointer dereference at 00000038 IP: [<c045a47f>] cgroup_path+0x39/0x90 .. Call Trace: [<c0420344>] ? print_cfs_rq+0x6e/0x75d [<c0421160>] ? sched_debug_show+0x72d/0xc1e .. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13x86: fix macro with bad_bios_dmi_tableYinghai Lu
commit a8b71a2810386a5ac8f43d2095fe3355f0d8db37 upstream. DMI tables need a blank NULL tail. fixes the crash on Ingo's test box. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13x86: fix CONFIG_X86_RESERVE_LOW_64K=yYinghai Lu
commit 2216d199b1430d1c0affb1498a9ebdbd9c0de439 upstream The bad_bios_dmi_table() quirk never triggered because we do DMI setup too late. Move it a bit earlier. Also change the CONFIG_X86_RESERVE_LOW_64K quirk to operate on the e820 table directly instead of messing with early reservations - this handles overlaps (which do occur in this low range of RAM) more gracefully. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13x86: add X86_RESERVE_LOW_64KIngo Molnar
commit fc38151947477596aa27df6c4306ad6008dc6711 upstream. This bugzilla: http://bugzilla.kernel.org/show_bug.cgi?id=11237 Documents a wide range of systems where the BIOS utilizes the first 64K of physical memory during suspend/resume and other hardware events. Currently we reserve this memory on all AMI and Phoenix BIOS systems. Life is too short to hunt subtle memory corruption problems like this, so we try to be robust by default. Still, allow this to be overriden: allow users who want that first 64K of memory to be available to the kernel disable the quirk, via CONFIG_X86_RESERVE_LOW_64K=n. Also, allow the early reservation to overlap with other early reservations. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13x86: reserve low 64K on AMI and Phoenix BIOS boxenIngo Molnar
commit 1e22436eba84edfec9c25e5a25d09062c4f91ca9 upstream there's multiple reports about suspend/resume related low memory corruption in this bugzilla: http://bugzilla.kernel.org/show_bug.cgi?id=11237 the common pattern is that the corruption is caused by the BIOS, and that it affects some portion of the first 64K of physical RAM. So add a DMI quirk This will waste 64K RAM on 'good' systems too, but without knowing the exact nature of this BIOS memory corruption this is the safest approach. This might as well solve a wide range of suspend/resume breakages under Linux. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13x86: add DMI quirk for AMI BIOS which corrupts address 0xc000 during resumeIngo Molnar
commit 5649b7c30316a51792808422ac03ee825d26aa5e upstream Alan Jenkins and Andy Wettstein reported a suspend/resume memory corruption bug and extensively documented it here: http://bugzilla.kernel.org/show_bug.cgi?id=11237 The bug is that the BIOS overwrites 1K of memory at 0xc000 physical, without registering it in e820 as reserved or giving the kernel any idea about this. Detect AMI BIOSen and reserve that 1K. We paint this bug around with a very broad brush (reserving that 1K on all AMI BIOS systems), as the bug was extremely hard to find and needed several weeks and lots of debugging and patching. The bug was found via the CONFIG_X86_CHECK_BIOS_CORRUPTION=y debug feature, if similar bugs are suspected then this feature can be enabled on other systems as well to scan low memory for corrupted memory. Reported-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Reported-by: Andy Wettstein <ajw1980@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13ext3: wait on all pending commits in ext3_sync_fsArthur Jones
commit c87591b719737b4e91eb1a9fa8fd55a4ff1886d6 upstream In ext3_sync_fs, we only wait for a commit to finish if we started it, but there may be one already in progress which will not be synced. In the case of a data=ordered umount with pending long symlinks which are delayed due to a long list of other I/O on the backing block device, this causes the buffer associated with the long symlinks to not be moved to the inode dirty list in the second phase of fsync_super. Then, before they can be dirtied again, kjournald exits, seeing the UMOUNT flag and the dirty pages are never written to the backing block device, causing long symlink corruption and exposing new or previously freed block data to userspace. This can be reproduced with a script created by Eric Sandeen <sandeen@redhat.com>: #!/bin/bash umount /mnt/test2 mount /dev/sdb4 /mnt/test2 rm -f /mnt/test2/* dd if=/dev/zero of=/mnt/test2/bigfile bs=1M count=512 touch /mnt/test2/thisisveryveryveryveryveryveryveryveryveryveryveryveryveryveryveryverylongfilename ln -s /mnt/test2/thisisveryveryveryveryveryveryveryveryveryveryveryveryveryveryveryverylongfilename /mnt/test2/link umount /mnt/test2 mount /dev/sdb4 /mnt/test2 ls /mnt/test2/ umount /mnt/test2 To ensure all commits are synced, we flush all journal commits now when sync_fs'ing ext3. Signed-off-by: Arthur Jones <ajones@riverbed.com> Cc: Eric Sandeen <sandeen@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-07Linux 2.6.27.5v2.6.27.5Greg Kroah-Hartman
2008-11-07net: Fix recursive descent in __scm_destroy().David Miller
commit f8d570a4745835f2238a33b537218a1bb03fc671 and 3b53fbf4314594fa04544b02b2fc6e607912da18 upstream (because once wasn't good enough...) __scm_destroy() walks the list of file descriptors in the scm_fp_list pointed to by the scm_cookie argument. Those, in turn, can close sockets and invoke __scm_destroy() again. There is nothing which limits how deeply this can occur. The idea for how to fix this is from Linus. Basically, we do all of the fput()s at the top level by collecting all of the scm_fp_list objects hit by an fput(). Inside of the initial __scm_destroy() we keep running the list until it is empty. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
