2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: take the ACL checks to common code bury posix_acl_..._masq() variants kill boilerplates around posix_acl_create_masq() generic_acl: no need to clone acl just to push it to set_cached_acl() kill boilerplate around posix_acl_chmod_masq() reiserfs: cache negative ACLs for v1 stat format xfs: cache negative ACLs if there is no attribute fork 9p: do no return 0 from ->check_acl without actually checking vfs: move ACL cache lookup into generic code CIFS: Fix oops while mounting with prefixpath xfs: Fix wrong return value of xfs_file_aio_write fix devtmpfs race caam: don't pass bogus S_IFCHR to debugfs_create_...() get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose asus-wmi: ->is_visible() can't return negative fix jffs2 ACLs on big-endian with 16bit mode_t 9p: close ACL leaks ocfs2_init_acl(): fix a leak VFS : mount lock scalability for internal mounts
2011-07-25Merge branch 'next/deletion' of ↵Linus Torvalds
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: mach-loki: delete ARM: mach-s3c2400: delete ARM: mach-s3c24a0: delete
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-25Merge branch 'next/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (35 commits) ARM: msm: platsmp: determine number of CPU cores at boot time ARM: Tegra: Seaboard: Fix I2C bus numbering for ADT7461 ARM: Tegra: Trimslice: Tri-state DAP3 pinmux ARM: orion5x: fixup 5181 MPP mask check ARM: mxs-dma: include <linux/dmaengine.h> ARM: i.MX53: consistently use MX53_UART_PAD_CTRL for uart txd/rxd/rts/cts ARM: i.MX53: UARTn_CTS pin should not change RTS input select ARM: i.MX53: UARTn_TXD pin should not change RXD input select ARM: mx25: Fix typo on CAN1_RX pad setting iomux-mx53: add missing 'IOMUX_CONFIG_SION' for some I2C pad definitions ARM: NUC93X: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: LPC32XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: CNS3XXX: add UL suffix to VMALLOC_END to ensure it is properly typed ARM: i.MX53: Fix IOMUX type o's ARM i.MX dma: Fix burstsize settings mach-mx5: fix the I2C clock parents ARM: mxs/tx28: according to the TX28's datasheet D4-D7 are not used for MMC0 ARM i.MX23/28: platform-mxsfb: Add missing include of linux/dma-mapping.h ARM: mx53: Fix some interrupts marked as reserved. MXC: iomux-v3: correct NO_PAD_CTRL definition ... Fix up trivial conflict in arch/arm/mach-imx/mach-mx31_3ds.c
2011-07-25Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Allow i2c_add_numbered_adapter() to assign a bus id i2c-ali1535: Fix style issues
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25bury posix_acl_..._masq() variantsAl Viro
made static; no callers left outside of posix_acl.c. posix_acl_clone() also has lost all external callers and became static... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25generic_acl: no need to clone acl just to push it to set_cached_acl()Al Viro
In-core acls are copy-on-write, so the reference taken by set_cached_acl() will do just fine. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25reiserfs: cache negative ACLs for v1 stat formatChristoph Hellwig
Always set up a negative ACL cache entry if the inode can't have ACLs. That behaves much better than doing this check inside ->check_acl. Also remove the left over MAY_NOT_BLOCK check. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25xfs: cache negative ACLs if there is no attribute forkChristoph Hellwig
Always set up a negative ACL cache entry if the inode doesn't have an attribute fork. That behaves much better than doing this check inside ->check_acl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-259p: do no return 0 from ->check_acl without actually checkingChristoph Hellwig
If we do not want to use ACLs we at least need to perform normal Unix permission checks. From the comment I'm not quite sure that's what is intended, but if 0p wants to do permission checks entirely on the server it needs to do so in ->permission, not in ->check_acl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25CIFS: Fix oops while mounting with prefixpathPavel Shilovsky
commit fec11dd9a0109fe52fd631e5c510778d6cbff6cc caused a regression when we have already mounted //server/share/a and want to mount //server/share/a/b. The problem is that lookup_one_len calls __lookup_hash with nd pointer as NULL. Then __lookup_hash calls do_revalidate in the case when dentry exists and we end up with NULL pointer deference in cifs_d_revalidate: if (nd->flags & LOOKUP_RCU) return -ECHILD; Fix this by checking nd for NULL. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25xfs: Fix wrong return value of xfs_file_aio_writeMarkus Trippelsdorf
The fsync prototype change commit 02c24a82187d accidentally overwrote the ssize_t return value of xfs_file_aio_write with 0 for SYNC type writes. Fix this by checking if an error occured when calling xfs_file_fsync and only change the return value in this case. In addition xfs_file_fsync actually returns a normal negative error, so fix this, too. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25fix devtmpfs raceAl Viro
After we's done complete(&req->done), there's nothing to prevent the scope containing *req from being gone and *req overwritten by any kind of junk. So we must read req->next before that... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25Merge branch 'for-3.1/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/drivers' of git://git.kernel.dk/linux-block: cciss: do not attempt to read from a write-only register xen/blkback: Add module alias for autoloading xen/blkback: Don't let in-flight requests defer pending ones. bsg: fix address space warning from sparse bsg: remove unnecessary conditional expressions bsg: fix bsg_poll() to return POLLOUT properly
2011-07-25Merge branch 'for-3.1/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits) block: strict rq_affinity backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu block: fix patch import error in max_discard_sectors check block: reorder request_queue to remove 64 bit alignment padding CFQ: add think time check for group CFQ: add think time check for service tree CFQ: move think time check variables to a separate struct fixlet: Remove fs_excl from struct task. cfq: Remove special treatment for metadata rqs. block: document blk_plug list access block: avoid building too big plug list compat_ioctl: fix make headers_check regression block: eliminate potential for infinite loop in blkdev_issue_discard compat_ioctl: fix warning caused by qemu block: flush MEDIA_CHANGE from drivers on close(2) blk-throttle: Make total_nr_queued unsigned block: Add __attribute__((format(printf...) and fix fallout fs/partitions/check.c: make local symbols static block:remove some spare spaces in genhd.c block:fix the comment error in blkdev.h ...
2011-07-25iomap: make IOPORT/PCI mapping functions conditionalRandy Dunlap
When CONFIG_PCI is not enabled, CONFIG_EISA=y, and CONFIG_GENERIC_IOMAP=y, drivers/net/3c59x.c build fails due to a recent small change to <asm-generic/iomap.h> that surrounds pci_iomap() and pci_iounmap() with #ifdef CONFIG_PCI/#endif. Since that patch to iomap.h looks correct, add stubs for pci_iomap() and pci_iounmap() with CONFIG_PCI is not enabled to fix the build errors. drivers/net/3c59x.c:1026: error: implicit declaration of function 'pci_iomap' drivers/net/3c59x.c:1038: error: implicit declaration of function 'pci_iounmap' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jonas Bonn <jonas@southpole.se> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25i2c: Allow i2c_add_numbered_adapter() to assign a bus idGrant Likely
Currently, if an i2c bus driver supports both static and dynamic bus ids, it needs to choose between calling i2c_add_numbered_adapter() and i2c_add_adapter(). This patch makes i2c_add_numbered_adapter() redirect to i2c_add_adapter() if the requested bus id is -1. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-25i2c-ali1535: Fix style issuesLABBE Corentin
This is a fix-style patch for i2c-ali1535 (issues reported by checkpatch.pl.) Signed-off-by: LABBE Corentin <corentin.labbe@geomatys.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-07-25Merge branch 'tegra/fixes' of ↵Arnd Bergmann
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into next/fixes
2011-07-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] s5pv210: make needlessly global symbols static [CPUFREQ] exynos4210: make needlessly global symbols static [CPUFREQ] S3C6410: Add some lower frequencies for 800MHz base clock operation [CPUFREQ] S5PV210: Add reboot notifier to prevent system hang [CPUFREQ] S5PV210: Adjust udelay prior to voltage scaling down [CPUFREQ] S5PV210: Lock a mutex while changing the cpu frequency [CPUFREQ] S5PV210: Add pm_notifier to prevent system unstable [CPUFREQ] S5PV210: Add arm/int voltage control support [CPUFREQ] S5PV210: Add additional symantics for "relation" in cpufreq with pm [CPUFREQ] S3C64xx: Notify transition complete as soon as frequency changed [CPUFREQ] S3C6410: Support 800MHz operation in cpufreq [CPUFREQ] s5pv210-cpufreq.c: Add missing clk_put [CPUFREQ] Move compile for S3C64XX cpufreq to /drivers/cpufreq [CPUFREQ] Remove some vi noise that escaped into the Makefile. [CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/ [CPUFREQ/S3C64xx] Move S3C64xx CPUfreq driver into drivers/cpufreq [CPUFREQ] Handle CPUs with different capabilities in acpi-cpufreq
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits) bnx2x: use pci_pcie_cap() bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_task bnx2x: enable internal target-read for 57712 and up only bnx2x: count statistic ramrods on EQ to prevent MC assert bnx2x: fix loopback for non 10G link bnx2x: dcb - send all unmapped priorities to same COS as L2 iwlwifi: Fix build with CONFIG_PM disabled. gre: fix improper error handling ipv4: use RT_TOS after some rt_tos conversions via-velocity: remove duplicated #include qlge: remove duplicated #include igb: remove duplicated #include can: c_can: remove duplicated #include bnad: remove duplicated #include net: allow netif_carrier to be called safely from IRQ bna: Header File Consolidation bna: HW Error Counter Fix bna: Add HW Semaphore Unlock Logic bna: IOC Event Name Change bna: Mboxq Flush When IOC Disabled ...
2011-07-24gma500: udlay(20000) is too largeStephen Rothwell
So use mdelay(20) instead. Fixes this build error: ERROR: "__bad_udelay" [drivers/staging/gma500/psb_gfx.ko] undefined! Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ata: PATA_ARASAN_CF depends on DMADEVICES ata: remove unnecessary code [libata] Prevent warning during PMP error recovery ahci: RAID-mode SATA patch for Intel Panther Point DeviceIDs pata_it821x: Fix RAID type display, by adding missing comma sata_dwc_460ex: fix error path ahci: Enable SB600 64bit DMA on Asus M3A libata: report link resume failure as KERN_WARNING instead of ERR ahci: move ahci_sb600_softreset to libahci.c and rename it libata: leave port thawed after reset failure ata: sata_via: Use dev_dbg ata: Add and use ata_print_version_once ata: Convert ata_<foo>_printk(KERN_<LEVEL> to ata_<foo>_<level> ata: Convert dev_printk(KERN_<LEVEL> to dev_<level>(
2011-07-24bnx2x: use pci_pcie_cap()Vladislav Zolotarov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-24bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_taskVladislav Zolotarov
2011-07-24bnx2x: enable internal target-read for 57712 and up onlyShmulik Ravid
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-24bnx2x: count statistic ramrods on EQ to prevent MC assertVladislav Zolotarov
This patch includes: - Counting statistics ramrods as EQ ramrods the way they should be. This accounting is meant to prevent MC asserts in case of software bugs. - Fixes in debug facilities which were added while working on one of such bugs. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-24bnx2x: fix loopback for non 10G linkYaniv Rosner
Also fixes minor formatting in that function. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-24bnx2x: dcb - send all unmapped priorities to same COS as L2Dmitry Kravkov
As a result of DCBX negotiation some priorities maybe untouched and still unmapped to any COS; instead of sending them to COS0 we assign them to the same COS as L2 traffic - to avoid collisions with storage class of service. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-24iwlwifi: Fix build with CONFIG_PM disabled.David S. Miller
2011-07-24Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (237 commits) ARM: 7004/1: fix traps.h compile warnings ARM: 6998/2: kernel: use proper memory barriers for bitops ARM: 6997/1: ep93xx: increase NR_BANKS to 16 for support of 128MB RAM ARM: Fix build errors caused by adding generic macros ARM: CPU hotplug: ensure we migrate all IRQs off a downed CPU ARM: CPU hotplug: pass in proper affinity mask on IRQ migration ARM: GIC: avoid routing interrupts to offline CPUs ARM: CPU hotplug: fix abuse of irqdesc->node ARM: 6981/2: mmci: adjust calculation of f_min ARM: 7000/1: LPAE: Use long long printk format for displaying the pud ARM: 6999/1: head, zImage: Always Enter the kernel in ARM state ARM: btc: avoid invalidating the branch target cache on kernel TLB maintanence ARM: ARM_DMA_ZONE_SIZE is no more ARM: mach-shark: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-sa1100: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-realview: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-pxa: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-h720x: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-davinci: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ...
2011-07-24Documentation: Update augmented rbtree documentationSasha Levin
Current documentation referred to the old method of handling augmented trees. Update documentation to correspond with the changes done in commit b945d6b2554d ("rbtree: Undo augmented trees performance damage and regression"). Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: David Woodhouse <David.Woodhouse@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24XZ: Fix missing <linux/kernel.h> includeLasse Collin
<linux/kernel.h> is needed for min_t. The old version happened to work on x86 because <asm/unaligned.h> indirectly includes <linux/kernel.h>, but it didn't work on ARM. <linux/kernel.h> includes <asm/byteorder.h> so it's not necessary to include it explicitly anymore. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: stable <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (21 commits) [S390] use siginfo for sigtrap signals [S390] dasd: add enhanced DASD statistics interface [S390] kvm: make sigp emerg smp capable [S390] disable cpu measurement alerts on a dying cpu [S390] initial cr0 bits [S390] iucv cr0 enablement bit [S390] race safe external interrupt registration [S390] remove tape block docu [S390] ap: toleration support for ap device type 10 [S390] cleanup program check handler prototypes [S390] remove kvm mmu reload on s390 [S390] Use gmap translation for accessing guest memory [S390] use gmap address spaces for kvm guest images [S390] kvm guest address space mapping [S390] fix s390 assembler code alignments [S390] move sie code to entry.S [S390] kvm: handle tprot intercepts [S390] qdio: clear shared DSCI before scheduling the queue handler [S390] reference bit testing for unmapped pages [S390] irqs: Do not trace arch_local_{*,irq_*} functions ...
2011-07-24Merge branch 'for-upstream' of git://openrisc.net/jonas/linuxLinus Torvalds
* 'for-upstream' of git://openrisc.net/jonas/linux: (24 commits) OpenRISC: Add MAINTAINERS entry OpenRISC: Miscellaneous OpenRISC: Library routines OpenRISC: Headers OpenRISC: Traps OpenRISC: Module support OpenRISC: GPIO OpenRISC: Scheduling/Process management OpenRISC: Idle/Power management OpenRISC: System calls OpenRISC: IRQ OpenRISC: Timekeeping OpenRISC: DMA OpenRISC: PTrace OpenRISC: Build infrastructure OpenRISC: Signal handling OpenRISC: Memory management OpenRISC: Device tree OpenRISC: Boot code iomap: make IOPORT/PCI mapping functions conditional ...
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: Fix modpost's license checking V3 module: add /sys/module/<name>/uevent files module: change attr callbacks to take struct module_kobject modules: make arch's use default loader hooks modules: add default loader hook implementations param: fix return value handling in param_set_*
2011-07-24Merge branch 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits) KVM: IOMMU: Disable device assignment without interrupt remapping KVM: MMU: trace mmio page fault KVM: MMU: mmio page fault support KVM: MMU: reorganize struct kvm_shadow_walk_iterator KVM: MMU: lockless walking shadow page table KVM: MMU: do not need atomicly to set/clear spte KVM: MMU: introduce the rules to modify shadow page table KVM: MMU: abstract some functions to handle fault pfn KVM: MMU: filter out the mmio pfn from the fault pfn KVM: MMU: remove bypass_guest_pf KVM: MMU: split kvm_mmu_free_page KVM: MMU: count used shadow pages on prepareing path KVM: MMU: rename 'pt_write' to 'emulate' KVM: MMU: cleanup for FNAME(fetch) KVM: MMU: optimize to handle dirty bit KVM: MMU: cache mmio info on page fault path KVM: x86: introduce vcpu_mmio_gva_to_gpa to cleanup the code KVM: MMU: do not update slot bitmap if spte is nonpresent KVM: MMU: fix walking shadow page table KVM guest: KVM Steal time registration ...
2011-07-24Merge branch 'upstream/xen-tracing2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/xen-tracing2' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen/trace: use class for multicall trace xen/trace: convert mmu events to use DECLARE_EVENT_CLASS()/DEFINE_EVENT() xen/multicall: move *idx fields to start of mc_buffer xen/multicall: special-case singleton hypercalls xen/multicalls: add unlikely around slowpath in __xen_mc_entry() xen/multicalls: disable MC_DEBUG xen/mmu: tune pgtable alloc/release xen/mmu: use extend_args for more mmuext updates xen/trace: add tlb flush tracepoints xen/trace: add segment desc tracing xen/trace: add xen_pgd_(un)pin tracepoints xen/trace: add ptpage alloc/release tracepoints xen/trace: add mmu tracepoints xen/trace: add multicall tracing xen/trace: set up tracepoint skeleton xen/multicalls: remove debugfs stats trace/xen: add skeleton for Xen trace events
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (34 commits) crypto: caam - ablkcipher support crypto: caam - faster aead implementation crypto: caam - structure renaming crypto: caam - shorter names crypto: talitos - don't bad_key in ablkcipher setkey crypto: talitos - remove unused giv from ablkcipher methods crypto: talitos - don't set done notification in hot path crypto: talitos - ensure request ordering within a single tfm crypto: gf128mul - fix call to memset() crypto: s390 - support hardware accelerated SHA-224 crypto: algif_hash - Handle initial af_alg_make_sg error correctly crypto: sha1_generic - use SHA1_BLOCK_SIZE hwrng: ppc4xx - add support for ppc4xx TRNG crypto: crypto4xx - Perform read/modify/write on device control register crypto: caam - fix build warning when DEBUG_FS not configured crypto: arc4 - Fixed coding style issues crypto: crc32c - Fixed coding style issue crypto: omap-sham - do not schedule tasklet if there is no active requests crypto: omap-sham - clear device flags when finishing request crypto: omap-sham - irq handler must not clear error code ...
2011-07-24caam: don't pass bogus S_IFCHR to debugfs_create_...()Al Viro
it will be replaced with S_IFREG anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-24get rid of create_proc_entry() abuses - proc_mkdir() is there for purposeAl Viro
2011-07-24asus-wmi: ->is_visible() can't return negativeAl Viro
It's mode_t; return 0 (no access) on error. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-24fix jffs2 ACLs on big-endian with 16bit mode_tAl Viro
casting int * to mode_t * is not a good thing - on a *lot* of big-endian architectures mode_t happens to be smaller than int and there it breaks quite spectaculary... Fucked-up-by: commit cfc8dc6f6f69ede939e09c2af06a01adee577285 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-249p: close ACL leaksAl Viro
2011-07-24ocfs2_init_acl(): fix a leakAl Viro
2011-07-24VFS : mount lock scalability for internal mountsTim Chen
For a number of file systems that don't have a mount point (e.g. sockfs and pipefs), they are not marked as long term. Therefore in mntput_no_expire, all locks in vfs_mount lock are taken instead of just local cpu's lock to aggregate reference counts when we release reference to file objects. In fact, only local lock need to have been taken to update ref counts as these file systems are in no danger of going away until we are ready to unregister them. The attached patch marks file systems using kern_mount without mount point as long term. The contentions of vfs_mount lock is now eliminated. Before un-registering such file system, kern_unmount should be called to remove the long term flag and make the mount point ready to be freed. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
