Merge reason:
__percpu annotations need the corresponding sparse address
space definition upstream.
tools/perf/util/probe-event.c (trivial)
Avoid kernels from exploding on AMD machines when they have any
lock debugging bits enabled.
A recent commit introduced a preemption warning for
perf_clock(), use raw_smp_processor_id() to avoid this, it
really doesn't matter which cpu we use here.
LKML-Reference: <1267198583.22519.684.camel@laptop>
Cc: <stable@kernel.org>
Even though we don't register the counters until the child is right about
to exec(), we're still going to get at least a few events while the
fork()'d child is still executing 'perf' and in particular we're going to
get the MMAP events.
We can't distinguish the ones in the newly executed process because the
PID will be the same.
One way to solve this would be to have a PERF_RECORD_EXEC event, and when
this is seen 'perf' can flush it's map cache. We can't use
PERF_RECORD_COMM since that's generated by other things, not just exec().
Actually, thinking about it some more, using PERF_RECORD_COMM might be a
good enough approximation.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1267196914-16238-1-git-send-email-acme@infradead.org>
Split amd,p6,intel into separate files so that we can easily deal with
CONFIG_CPU_SUP_* things, needed to make things build now that perf_event.c
relies on symbols from amd.c
LKML-Reference: <new-submission>
Without this patch we get this for need_resched:
[root@mica ~]# perf annotate need_resched
Percent | Source code & Disassembly of vmlinux
: Disassembly of section .text:
: ffffffff810095ed <need_resched>:
: return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p);
: static inline int need_resched(void)
0.00 : ffffffff810095ed: 55 push %rbp
: return unlikely(test_thread_flag(TIF_NEED_RESCHED));
0.00 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi
: static inline struct thread_info *current_thread_info(void)
: struct thread_info *ti;
: ti = (void *)(percpu_read_stable(kernel_stack) +
0.00 : ffffffff810095f3: 65 48 8b 3c 25 48 b5 mov %gs:0xb548,%rdi
0.00 : ffffffff810095fa: 00 00
0.00 : ffffffff810095fc: 48 89 e5 mov %rsp,%rbp
0.00 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi
0.00 : ffffffff81009606: e8 9d ff ff ff callq ffffffff810095a8 <test_ti_thread_flag>
0.00 : ffffffff8100960b: c9 leaveq
0.00 : ffffffff8100960c: 85 c0 test %eax,%eax
0.00 : ffffffff8100960e: 0f 95 c0 setne %al
0.00 : ffffffff81009611: 0f b6 c0 movzbl %al,%eax
: Disassembly of section .vsyscall_0:
: Disassembly of section .vsyscall_fn:
: Disassembly of section .vsyscall_1:
: Disassembly of section .vsyscall_2:
: Disassembly of section .init.text:
: Disassembly of section .altinstr_replacement:
: Disassembly of section .exit.text:
[root@mica ~]#
But from the 'perf report' result we know that there are hits
for need_resched on a 4 way machine mostly doing nothing, so
after adding code to show what is in each hist offset and
collapsing IP hits for what happens between objdump lines we
get, for the same perf.data file:
[root@mica ~]# perf annotate -v need_resched
52.78 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi
9.72 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi
37.50 : ffffffff8100960e: 0f 95 c0 setne %al
[root@mica ~]#
And now 'perf annotate -v', verbose mode, will show the hits per
precise IP, so that one can make sense of the attribution to
each objdumop line:
Looking at the vmlinux_path (5 entries long)
Using /lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux
for symbols annotate_sym: filename=/lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux, sym=need_resched, start=0xffffffff810095ed, end=0xffffffff81009614
ffffffff810095f1: 152
ffffffff81009603: 28
ffffffff8100960f: 55
ffffffff81009610: 53
h->sum: 288
<SNIP same annotation>
LKML-Reference: <1267194194-15670-1-git-send-email-acme@infradead.org>
We re-program the event control register every time we reset the count,
this appears to be superflous, hence remove it.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Since the cpu argument to hw_perf_group_sched_in() is always
smp_processor_id(), simplify the code a little by removing this argument
and using the current cpu where needed.
LKML-Reference: <1265890918.5396.3.camel@laptop>
This patch adds correct AMD NorthBridge event scheduling.
NB events are events measuring L3 cache, Hypertransport traffic. They are
identified by an event code >= 0xe0. They measure events on the
Northbride which is shared by all cores on a package. NB events are
counted on a shared set of counters. When a NB event is programmed in a
counter, the data actually comes from a shared counter. Thus, access to
those counters needs to be synchronized.
We implement the synchronization such that no two cores can be measuring
NB events using the same counters. Thus, we maintain a per-NB allocation
table. The available slot is propagated using the event_constraint
structure.
Signed-off-by: Stephane Eranian <eranian@google.com>
LKML-Reference: <4b703957.0702d00a.6bf2.7b7d@mx.google.com>
In certain situations, the kernel may need to stop and start the same
event rapidly. The current PMU callbacks do not distinguish between stop
and release (i.e., stop + free the resource). Thus, a counter may be
released, then it will be immediately re-acquired. Event scheduling will
again take place with no guarantee to assign the same counter. On some
processors, this may event yield to failure to assign the event back due
to competion between cores.
This patch is adding a new pair of callback to stop and restart a counter
without actually release the underlying counter resource. On stop, the
counter is stopped, its values saved and that's it. On start, the value
is reloaded and counter is restarted (on x86, actual restart is delayed
until perf_enable()).
[ added fallback to ->enable/->disable for all other PMUs
fixed x86_pmu_start() to call x86_pmu.enable()
merged __x86_pmu_disable into x86_pmu_stop() ]
LKML-Reference: <4b703875.0a04d00a.7896.ffffb824@mx.google.com>
DaveM reported that currently perf interprets the pgoff value reported by
the MMAP events as a byte range, but the kernel reports it as a page
offset.
Since its broken (and unusable) anyway, change the kernel behaviour (ABI)
to report bytes indeed, avoiding the need for userspace to deal with
PAGE_SIZE things.
Reported-by: David Miller <davem@davemloft.net>
Because symbol->end is not fixed up at symbol_filter time, only
after all symbols for a DSO are loaded, and that, for asm
symbols, may be bogus, causing segfaults when hits happen in
these symbols.
Reported-by: Anton Blanchard <anton@samba.org>
Acked-by: David Miller <davem@davemloft.net>
Cc: <stable@kernel.org> # for .33.x. Does not apply cleanly, needs backport.
LKML-Reference: <20100225155740.GB8553@ghostprotocols.net>
Be more clear about DSO long names and tell from which file
kernel symbols were obtained, all in --verbose mode:
[root@mica ~]# perf report -v > /dev/null
Using /lib/modules/2.6.33-rc8-tip-00777-g0918527-dirty/build/vmlinux for symbols
[root@mica ~]# mv /lib/modules/2.6.33-rc8-tip-00777-g0918527-dirty/build/vmlinux /tmp/dd
Using /proc/kallsyms for symbols
[root@mica ~]#
LKML-Reference: <1266866139-6361-1-git-send-email-acme@infradead.org>
To overcome a silly gcc warning:
cc1: warnings being treated as errors
builtin-top.c: In function ‘lookup_sym_source’:
builtin-top.c:291: warning: not protecting local variables:
variable length buffer make: *** [builtin-top.o] Error 1
make: *** Waiting for unfinished jobs....
That is emitted for this:
const size_t pattern_len = BITS_PER_LONG / 4 + 2;
char pattern[pattern_len + 1];
LKML-Reference: <1266866062-6287-1-git-send-email-acme@infradead.org>
[ -v2: macroify the naming style ]
In function dso__split_kallsyms(), curr_map saves the return value
of map__new2. So check it instead of var map after the call returns.
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1267066851.1726.9.camel@localhost>
syscall_name() helper, which resolves a syscall arch number to
its name, is not yet available as we first need to implement
event injection for it to work.
Remove it from the documentation or tag its references as
unavailable yet. Once it's implemented, we can just revert
the current patch.
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Keiichi KII <k-keiichi@bx.jp.nec.com>
Also small update to perf-trace-perl and perf-trace docs.
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <1264580883-15324-13-git-send-email-tzanussi@gmail.com>
If we know the size of a tuple in advance, there's no need to resize
it - start out with the known size in the first place.
LKML-Reference: <1266822779.6426.4.camel@tropicana>
Adds a set of scripts that aggregate system call totals and system
call errors. Most are Python scripts that also test basic
functionality of the new Python engine, but there's also one Perl
script added for comparison and for reference in some new
Documentation contained in a later patch.
LKML-Reference: <1264580883-15324-8-git-send-email-tzanussi@gmail.com>
Add base support for Python scripting to perf trace.
LKML-Reference: <1264580883-15324-6-git-send-email-tzanussi@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: Set PCI CLS early in boot.
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Fix broken sn2 build
Set the PCI CLS early in the boot process to prevent
device failures. In pcibios_set_master use the new
pci_cache_line_size instead of a hard-coded value.
Signed-off-by: Carlos O'Donell <carlos@codesourcery.com>
Reviewed-by: Grant Grundler <grundler@google.com>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Fix out_le32() macro
microblaze: Fix cache loop function for cache range
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
Revert "block: improve queue_should_plug() by looking at IO depths"
Trailing semicolon causes compilation involving out_le32() to fail.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
I create wrong asm code but none test shows that this part of code is wrong.
I am not convinces that were good idea to create asm optimized macros
for caches. The reason is that there is not optimization with previous code
that's why make sense to add old code and do some benchmarking which
functions are faster.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: bug fix for vlan + gro issue
tc35815: Remove a wrong netif_wake_queue() call which triggers BUG_ON
cdc_ether: new PID for Ericsson C3607w to the whitelist (resubmit)
IPv6: better document max_addresses parameter
MAINTAINERS: update mv643xx_eth maintenance status
e1000: Fix DMA mapping error handling on RX
iwlwifi: sanity check before counting number of tfds can be free
iwlwifi: error checking for number of tfds in queue
iwlwifi: set HT flags after channel in rxon
Traffic (tcp) doesnot start on a vlan interface when gro is enabled.
Even the tcp handshake was not taking place.
This is because, the eth_type_trans call before the netif_receive_skb
in napi_gro_finish() resets the skb->dev to napi->dev from the previously
set vlan netdev interface. This causes the ip_route_input to drop the
incoming packet considering it as a packet coming from a martian source.
I could repro this on 2.6.32.7 (stable) and 2.6.33-rc7.
With this fix, the traffic starts and the test runs fine on both vlan
and non-vlan interfaces.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Patrick McHardy <kaber@trash.net>
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
ACPI: Be in TS_POLLING state during mwait based C-state entry
ACPI: Fix regression where _PPC is not read at boot even when ignore_ppc=0
acer-wmi: Respect current backlight level when loading
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/vmwgfx: Fix queries if no dma buffer thrashing is occuring.
drm/nv50: fix vram ptes on IGPs to point at stolen system memory
drm/nv50: fix instmem binding on IGPs to point at stolen system memory
drm/nv50: improve vram page table construction
drm/nv50: more efficient clearing of gpu page table entries
drm/nv50: make nv50_mem_vm_{bind,unbind} operate only on vram
drm/nouveau: Fix up pre-nv17 analog load detection.
Revert the change made to arch/ia64/sn/kernel/setup.c by commit
204fba4aa303ea4a7bb726a539bf4a5b9e3203d0 as it breaks the build.
Fixing the build the b94b08081fcecf83fa690d6c5664f6316fe72208 way
breaks xpc because genksyms then fails to generate an CRC for
per_cpu____sn_cnodeid_to_nasid because of limitations in the
generic genksyms code.
Signed-off-by: Hedi Berriche <hedi@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
The check-perf-trace script only checks Perl functionality, and
doesn't really need to be listed as as user script anyway.
This only removes the '-report' shell script, so although it doesn't
appear in the listing, the '-record' shell script and the check perf
trace perl script itself is still available and can still be run
manually as such:
$ libexec/perf-core/scripts/perl/bin/check-perf-trace-record
$ perf trace -s libexec/perf-core/scripts/perl/check-perf-trace.pl
Create a scripting-engines directory to contain scripting engine
implementation code, in anticipation of the addition of new scripting
support. Also removes trace-event-perl.h.
LKML-Reference: <1264580883-15324-5-git-send-email-tzanussi@gmail.com>
This stuff is needed by all scripting engines; move it from the Perl
engine source to a more common place.
LKML-Reference: <1264580883-15324-4-git-send-email-tzanussi@gmail.com>
Fix bogus calculation.
LKML-Reference: <1264580883-15324-3-git-send-email-tzanussi@gmail.com>
'perf trace -s list' prints a list of the supported scripting
languages. One problem with it is that it falls through and prints
the trace as well. The use of 'list' for this also makes it easy to
confuse with 'perf trace -l', used for listing available scripts. So
change 'perf trace -s list' to 'perf trace -s lang' and fixes the
fall-through problem.
LKML-Reference: <1264580883-15324-2-git-send-email-tzanussi@gmail.com>
The netif_wake_queue() is called correctly (i.e. only on !txfull
condition) from txdone routine. So Unconditional call to the
netif_wake_queue() here is wrong. This might cause calling of
start_xmit routine on txfull state and trigger BUG_ON.
This bug does not happen when NAPI disabled. After txdone there
must be at least one free tx slot. But with NAPI, this is not
true anymore and the BUG_ON can hits on heavy load.
In this driver NAPI was enabled on 2.6.33-rc1 so this is
regression from 2.6.32 kernel.
Reported-by: Ralf Roesch <ralf.roesch@rw-gmbh.de>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
This patch adds a new vid/pid to the cdc_ether whitelist.
Device added:
- Ericsson Mobile Broadband variant C3607w
Signed-off-by: Torgny Johansson <torgny.johansson@gmail.com>
To unsubscribe from this list: send the line "unsubscribe netdev" in
the body of a message to majordomo@vger.kernel.org
More majordomo info at http://vger.kernel.org/majordomo-info.html
Andrew Morton wrote:
>> >From ip-sysctl.txt file in kernel documentation I can see following description
>> for max_addresses:
>> max_addresses - INTEGER
>> Number of maximum addresses per interface. 0 disables limitation.
>> It is recommended not set too large value (or 0) because it would
>> be too easy way to crash kernel to allow to create too much of
>> autoconfigured addresses.
>> If this parameter applies only for auto-configured IP addressed, please state
>> it more clearly in docs or rename the parameter to show that it refers to
>> auto-configuration.
It did mention autoconfigured in the text, but the below makes it more obvious.
More clearly document IPv6 max_addresses parameter.
Signed-off-by: Brian Haley <brian.haley@hp.com>
I am no longer with Marvell.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Check for error return from pci_map_single/pci_map_page and clean up.
With this and the previous patch the driver was able to handle a significant
percentage of errors (I set the fault injection rate to 10% and could still
download large files at a reasonable speed).
This reverts commit fb1e75389bd06fd5987e9cda1b4e0305c782f854.
"Benjamin S." <sbenni@gmx.de> reports that the patch in question
causes a big drop in sequential throughput for him, dropping from
200MB/sec down to only 70MB/sec.
Needs to be investigated more fully, for now lets just revert the
offending commit.
include/linux/blkdev.h
Intercept query commands and apply relocations to their guest pointers.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
* 'nouveau/for-airlied' of ../drm-nouveau-next:
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
MIPS: BCM47xx: Fix 128MB RAM support
MIPS: Highmem: Fix build error
