Because the sunrpc sysctls don't conflict with any other sysctls the setting
the insert at head flag to register_sysctl has no semantic meaning.
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
register_sysctl_table
There has not been much maintenance on sysctl in years, and as a result is
there is a lot to do to allow future interesting work to happen, and being
ambitious I'm trying to do it all at once :)
The patches in this series fall into several general categories.
- Removal of useless attempts to override the standard sysctls
- Registers of sysctl numbers in sysctl.h so someone else does not use
the magic number and conflict.
- C99 conversions so it becomes possible to change the layout of
struct ctl_table without breaking everything.
- Removal of useless claims of module ownership, in the proc dir entries
- Removal of sys_sysctl support where people had used conflicting sysctl
numbers. Trying to break glibc or other applications by changing the
ABI is not cool. 9 instances of this in the kernel seems a little
extreme.
- General enhancements when I got the junk I could see out.
This patch:
Since x25 uses unique binary numbers inserting yourself at the head of the
search list for sysctls so you can override already registered sysctls is
pointless.
SA_SHIRQ is going away.
Cc: Jeff Garzik <jeff@garzik.org>
The obsolete SA_xxx interrupt flags have been used despite the scheduled
removal. Fixup the remaining users in -mm.
removal. Fixup the remaining users.
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Greg KH <greg@kroah.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: James Simmons <jsimmons@infradead.org>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Replace kmalloc() + memset() pairs with the appropriate kzalloc() calls.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
authentication
AUTH_UNIX authentication (the standard with NFS) has a limit of 16 groups ids.
This causes problems for people in more than 16 groups.
So allow the server to map a uid into a list of group ids based on local
knowledge rather depending on the (possibly truncated) list from the client.
If there is no process on the server responding to upcalls, the gidlist in the
request will still be used.
Signed-off-by: Neil Brown <neilb@suse.de>
Add support for using a filesystem UUID to identify and export point in the
filehandle.
For NFSv2, this UUID is xor-ed down to 4 or 8 bytes so that it doesn't take up
too much room. For NFSv3+, we use the full 16 bytes, and possibly also a
64bit inode number for exports beneath the root of a filesystem.
When generating an fsid to return in 'stat' information, use the UUID (hashed
down to size) if it is available and a small 'fsid' was not specifically
provided.
filehandle
If we are using the same version/fsid as a current filehandle, then there is
no need to verify the the numbers are valid for this export, and they must be
(we used them to find this export).
This allows us to simplify the fsid selection code.
Also change "ref_fh_version" and "ref_fh_fsid_type" to "version" and
"fsid_type", as the important thing isn't that they are the version/type of
the reference filehandle, but they are the chosen type for the new filehandle.
And tidy up some indenting.
Most files in the 'nfsd' filesystem are transactional. When you write, a
reply is generated that can be read back only on the same 'file'.
If the reply has zero length, the 'write' will incorrectly return a value of
'0' instead of the length that was written. This causes 'rpc.nfsd' to give an
annoying warning.
This patch fixes the test.
Driver for the Atmel on-chip SPI master controller.
Tested primarily on AVR32/AT32AP7000/ATSTK1000 using mtd_dataflash and the
jffs2 filesystem. Should also work fine on various AT91 ARM-based chips
like AT91SAM926x and AT91RM9200.
Hardware documentation can be found in the AT32AP7000 data sheet, or its
AT91 siblings, which can be downloaded from
http://www.atmel.com/dyn/products/datasheets.asp?family_id=682
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Add UART support for PNX8330/8550/8950 Philips MIPS-based SoCs.
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Fix the serial header breakage for the PNX8550 MIPS platform.
Since serial devices are powered down when not in use and some of those
devices cannot be accessed when powered down, we need to enable power
around calls to get_mcrtl() when dumping port state via uart_line_info().
This resolves hangs observed on some machines while reading serial device
registers when a port is powered off.
Signed-off-by: George G. Davis <gdavis@mvista.com>
Return failure immediately, so we don't have to test it twice.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Adam Belay <ambx1@neo.rr.com>
The patch below works around a minor bug found in the UART of the remote
management card used in many HP ia64 and parisc servers (aka the Diva
UARTs). The problem is that the UART does not reassert the THRE interrupt
if it has been previously cleared and the IIR THRI bit is re-enabled. This
can produce a very annoying failure mode when used as a serial console,
allowing a boot/reboot to hang indefinitely until an RX interrupt kicks it
into working again (ie. an unattended reboot could stall).
To solve this problem, a backup timer is introduced that runs alongside the
standard interrupt driven mechanism. This timer wakes up periodically,
checks for a hang condition and gets characters moving again. This backup
mechanism is only enabled if the UART is detected as having this problem,
so systems without these UARTs will have no additional overhead.
This version of the patch incorporates previous comments from Pavel and
removes races in the bug detection code. The test is now done before the
irq linking to prevent races with interrupt handler clearing the THRE
interrupt. Short delays and syncs are also added to ensure the device is
able to update register state before the result is tested.
Aristeu says:
this was tested on the following HP machines and solved the problem:
rx2600, rx2620, rx1600 and rx1620s.
hpa says:
I have seen this same bug in soft UART IP from "a major vendor."
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org>
This patch fixes showing empty config list items if "Option/Show All
Options" is turned on. For example empty items appears on list of 'Block
Layer' menu.
Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com>
Cc: Oleg Verych <olecom@flower.upol.cz>
Add new headers_check_all target for checking all arches in one go.
Useful for distros (and people with too much time on their hands) that support
a ton of architectures, headers_check_all is to headers_check as
headers_install_all is to headers_install
Makefile
Remove references to the deprecated "make prepare-all" target from the
top-level Makefile; use just "make prepare" instead.
Acked-by: Oleg Verych <olecom@flower.upol.cz>
Do "Back" button behaviour normalization so it is enabled starting from
second-level menu only.
qconf does not clear help text in search window if previous search has been
failed.
Signed-off-by: Cyrill V. Gorcunov <gorcunov@mail.ru>
Relocate the qconf search command to the "Edit"->"Find" menu option.
This is per the discussion on my qconf search dialog patch.
In xconfig's display integer and string values are also shown as part of
the config item's descriptive text.
This patch updates the descriptive text, when the corresponding value has
been changed. Fix for http://bugzilla.kernel.org/show_bug.cgi?id=7744
Take2 uses updateList() so config values dependending on the changed value
see the change.
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
This list was built into the git-shortlog tool and has been removed in the
latest version. It should be maintained separately so this is what this
patch does.
A couple more entries were added to the original list as well.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Acked-by: Junio C Hamano <junkio@cox.net>
Cc: Linus Torvalds <torvalds@osdl.org>
Fix a minor bug in mkcompile_h. As one can see, the current locale is used
while getting the version of gcc. This produces problems when a locale
other than C or en_US is used. As an example, my /proc/version contains
Turkish characters in iso-8859-9 encoding.
This patch fixes this issue by making sure that the C locale is used to get
gcc's version.
Check to see if `${CROSS_COMPILE}mkimage` exists and if not, fall back to
the standard `mkimage`
The Blackfin toolchain includes mkimage, but we dont want to namespace
collide with any of the user's system setup, so we prefix it with our
toolchain name.
On ia64, drivers/base/dma-mapping.c doesn't build because it calls
dma_alloc_noncoherent() and dma_free_noncoherent(), which appear to be
terminally broken; the calls end up generating errors like
drivers/base/dma-mapping.c: In function 'dmam_noncoherent_release':
drivers/base/dma-mapping.c:32: error: 'struct ia64_machine_vector' has no member named 'platform_dma_free_coherent'
because the multiple levels of macro expansion in <asm/dma-mapping.h> and
<asm/machvec.h> end up turning a call to dma_free_noncoherent() into
ia64_mv.platform_dma_free_coherent (instead of the intended
ia64_mv.dma_free_coherent).
This patch fixes this by converting dma_{alloc,free}_noncoherent() into
inline functions that call the corresponding coherent functions, instead of
trying to do this with macros.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Tony Luck <tony.luck@intel.com>
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband:
IB/mthca: Always fill MTTs from CPU
IB/mthca: Merge MR and FMR space on 64-bit systems
IB/mthca: Fix access to MTT and MPT tables on non-cache-coherent CPUs
IB/mthca: Give reserved MTTs a separate cache line
IB/mthca: Fix reserved MTTs calculation on mem-free HCAs
RDMA/cxgb3: Add driver for Chelsio T3 RNIC
IB: Remove redundant "_wq" from workqueue names
RDMA/cma: Increment port number after close to avoid re-use
IB/ehca: Fix memleak on module unloading
IB/mthca: Work around gcc bug on sparc64
IPoIB: Connected mode experimental support
IB/core: Use ARRAY_SIZE macro for mandatory_table
IB/mthca: Use correct structure size in call to memset()
* master.kernel.org:/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
[CIFS] on reconnect to Samba - reset the unix capabilities
[CIFS] Allow update of EOF on remote extend of file
[CIFS] POSIX CIFS Extensions (continued) - POSIX Open
[CIFS] Additional POSIX CIFS Extensions infolevels
After temporary server or network failure and reconneciton, we were not
resending the unix capabilities via SetFSInfo - which confused Samba posix
byte range locking code.
Discovered by jra
Signed-off-by: Steve French <sfrench@us.ibm.com>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[IPSEC]: Fix the address family to refer encap_family
[IPSEC]: changing API of xfrm6_tunnel_register
[IPSEC]: make sit use the xfrm4_tunnel_register
[IPSEC]: Changing API of xfrm4_tunnel_register.
[TCP]: Prevent pseudo garbage in SYN's advertized window
[NET_SCHED]: sch_hfsc: replace ASSERT macro by WARN_ON
[BRIDGE] br_if: Fix oops in port_carrier_check
[NETFILTER]: Clear GSO bits for TCP reset packet
[TG3]: Update copyright, version, and reldate.
[TG3]: Add some tx timeout debug messages.
[TG3]: Use constant for PHY register 0x1e.
[TG3]: Power down 5704 serdes transceiver when shutting down.
[TG3]: 5906 doesn't need to switch to slower clock.
[TG3]: 5722/5756 don't need PHY jitter workaround.
[TG3]: Use lower DMA watermark for 5703.
[TG3]: Save MSI state before suspend.
[XFRM]: Fix IPv4 tunnel mode decapsulation with IPV6=n
[IPV6] HASHTABLES: Use appropriate seed for caluculating ehash index.
* master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: (61 commits)
[POWERPC] Use udbg_early_init() on ppc32
[POWERPC] Open Firmware serial port driver
[POWERPC] Move MPIC smp routines into mpic.c
[POWERPC] Cleanup pseries kexec code
[POWERPC] Cleanup pseries smp initialisation code
[POWERPC] Consolidate pseries platform header files into pseries.h
[POWERPC] 85xx: Drop use of SYNC macro in head_fsl_booke.S
[POWERPC] cell: pm_rtas_activat_signals routine cleanup
[POWERPC] cell: PPU Oprofile cleanup patch
[POWERPC] spufs: avoid accessing kernel memory through mmapped /mem node
[POWERPC] spu sched: static timeslicing for SCHED_RR contexts
[POWERPC] spu sched: use DECLARE_BITMAP
[POWERPC] spu sched: forced preemption at execution
[POWERPC] spu sched: update some comments
[POWERPC] spu sched: simplity spu_remove_from_active_list
[POWERPC] spufs: optimize spu_run
[POWERPC] spufs: runqueue simplification
[POWERPC] spufs: move prio to spu_context
[POWERPC] spufs: state_mutex cleanup
[POWERPC] spufs: simplify state_mutex
udbg_early_init() is a function used on 64 bit systems, which
initializes whichever early udbg backend is configured. This function
is not called on 32-bit, however if btext early debug is enabled it
does have an explicit, inline, #ifdef-ed assignment performing
analagous initialization.
This patch makes things more uniform by folding the btext
initialization as an option into udbg_early_init() and calling that
from the 32-bit setup path.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
This can be used for serial ports that are connected to an
OF platform bus but are not autodetected by the lecacy
serial support.
It will automatically take over devices that come from the
legacy serial detection, which usually is only one device.
In some cases, rtas may be set up to use the serial port
in the firmware, which allows easier debugging before probing
the serial ports. In this case, the "used-by-rtas" property
must be set by the firmware. This patch also adds code to the
legacy serial driver to check for this.
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Move a couple of MPIC smp routines into mpic.c, they're inside an SMP
block in mpic.c - so they're still only built for SMP.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Move all the pseries kexec code into one file, platforms/pseries/kexec.c
Provide helpers for setting up ppc_md.kexec_cpu_down, so that we don't
have to have #ifdef CONFIG_KEXEC in setup.c
Move the initialisation of the ppc_md kexec callbacks into an init routine.
This is well and truly early enough to cause no change in behaviour, we
can't kexec until userspace has given us a kernel to kexec into.
Move some extern declarations from setup.c into the new pseries.h.
While we're at it, provide dummy implementations for !SMP, to avoid
cluttering the C file with more #ifdefs.
Following the example of platforms/pasemi, consolidate a couple of
tiny header files in platforms/pseries into pseries.h.
This gives us a convenient place to put things that need to be
available to the platform code, but not public. And hopefully will
help people resist the temptation of sticking externs in C files.
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arnd/cell-2.6
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
i2c: Stop using i2c_adapter.class_dev
i2c: Remove the warning on missing adapter device
i2c: Declare more i2c_adapter parent devices
i2c: PA Semi SMBus driver
i2c-amd8111: Proposed cleanups
i2c-parport: Add support for One For All remote JP1 interface
i2c-viapro: Add support for the VIA CX700 south bridge
i2c: Add IDs to adapters
i2c: Update the list of bus IDs
i2c: Add driver suspend/resume/shutdown support
i2c: completion header cleanups
i2c-i801: Document the SMBus unhiding quirk
i2c-i801: Spelling fix
i2c: Fix typo in SMBus Write Word Data description
i2c-piix4: Add support for the ATI SB600
i2c-nforce2: Drop unused reference to pci_dev
i2c/vt8231: Remove superfluous initialization
i2c-ali1563: Fix device initialization
i2c-ali1563: Improve the status messages
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fix sigset_t endianess swapping issues in 32-bit compat code.
[MIPS] Fix uniprocessor Sibyte builds.
[MIPS] Make entry.S a little more readable.
[MIPS] Remove stray instruction from __get_user_asm_ll32.
[MIPS] 32-bit: Fix warning about cast for fetching pointer from userspace.
[MIPS] DECstation: Fix irq handling
[MIPS] signals: make common _BLOCKABLE macro
[MIPS] signal: Move sigframe definition for native O32/N64 into signal.c
[MIPS] signal: Move {restore,setup}_sigcontext prototypes to their user
[MIPS] signal: Fix warnings in o32 compat code.
[MIPS] IP27: Enable N32 support in defconfig.
Revert "[MIPS] Fix warning in get_user when fetching pointer object from userspace."
[MIPS] Don't claim we support dma_declare_coherent_memory - we don't.
[MIPS] Unify dma-{coherent,noncoherent.ip27,ip32}
[MIPS] Improve branch prediction in ll/sc atomic operations.
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: (23 commits)
[WATCHDOG] timers cleanup
[WATCHDOG] ib700wdt.c - convert to platform_device part 2
[WATCHDOG] ib700wdt.c spinlock/WDIOC_SETOPTIONS changes
[WATCHDOG] ib700wdt.c small clean-up's
[WATCHDOG] ib700wdt.c clean-up init and exit routines
[WATCHDOG] ib700_wdt.c stop + set_heartbeat operations
[WATCHDOG] show default value for nowayout in module parameter
[WATCHDOG] advantechwdt.c - convert to platform_device part 2
[WATCHDOG] advantechwdt.c - move set_heartbeat to a seperate function
[WATCHDOG] advantechwdt.c - cleanup before platform_device patches
[WATCHDOG] acquirewdt.c - convert to platform_device part 2
[WATCHDOG] acquirewdt.c - clean before platform_device patches
[WATCHDOG] pcwd_usb.c - get heartbeat from dip switches
[WATCHDOG] pcwd.c - e-mail adres update
[WATCHDOG] pcwd_usb.c - document includes
[WATCHDOG] pcwd_pci.c - spinlock fixes
Somewhere in the rewrite of the work queues my cleanup of SAK handling
got broken. Maybe I didn't retest it properly or possibly the API
was changing so fast I missed something. Regardless currently
triggering a SAK now generates an ugly BUG_ON and kills the kernel.
Thanks to Alexey Dobriyan <adobriyan@openvz.org> for spotting this.
This modifies the use of SAK_work to initialize it when the data
structure it resides in is initialized, and to simply call
schedule_work when we need to generate a SAK. I update both
data structures that have a SAK_work member for consistency.
All of the old PREPARE_WORK calls that are now gone.
If we call schedule_work again before it has processed it
has generated the first SAK it will simply ignore the duplicate
schedule_work request.
Signed-off-by: Andrew Sharp <tigerand@gmail.com>
When CONFIG_PREEMPT is not set, it also moves one branch instruction from
ret_from_irq() to ret_from_exception(). Therefore we favour the return
from irq case which should be more common than the other one.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
