* introduce 3 new flags to allow a more detailed configuration
of the SSI link :
IMX_SSI_NET : enable Network Mode
IMX_SSI_SYN : enable Synchronous Mode
IMX_SSI_USE_I2S_SLAVE : enable I2S Slave Mode
* new platform can use these settings without breaking actual
platforms.
Signed-off-by: Eric Bénard <eric@eukrea.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
The variable 'state' of structure 's3c_ac97_info' seems no use here,
so this patch is to remove the unnecessary variable.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
The variable 'periods' of structure 'atmel_runtime_data'
seems no use in whole atmel alsa driver,so I make a patch
Use the resource_size function instead of manually calculating the
resource size.This patch can reduce the chance of introducing off-by-one
errors.
Acked-by: Manuel Lauss <manuel.lauss@googlemail.com>
The size calculation is end - start + 1. But,sometimes, the '1' can
be forgotten carelessly, witch will have potential risk, so use resource_size
for {request/release}_mem_region and ioremap here should be good habit.
Acked-by: Daniel Glöckner <dg@emlix.com>
This patch is to modify the ac97 delays to minimum, all these 1000 micro
seconds delays seem over spec for the AC97 interface.
I deleted some unnecessary delays here and changed the AC97 cold and warm reset
delays from 1000us to 100us.
Fix a '#include "nuc900-audio.h' typo, I think it should be 'audio'.
At the same time, this patch renames the 'nuc900-auido.h' file to
'nuc900-audio.h'.
The current implement meant ACTL_ACCON was only accessed once when read or write
proceeding, which is not right, if so,we have to wait the 'timeout=0x10000' to end
every times.
We need to polling the bit AC_R_FINISH and AC_W_FINISH of ACTL_ACCON
register to identify whether read or write is finished or not,so I make
the patch to fix the issue.
This patch is to remove the 'SUBSTREAM_TYPE','PCM_TX' and 'PCM_RX' definition.
There is no need to redefine SNDRV_PCM_STREAM_PLAYBACK as PCM_TX,
the SUBSTREAM_TYPE(substream) can be deleted too, the playback or record can be
judged by 'if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK)' directly rather
than 'if (PCM_TX == stype)', which makes the codes easy to read.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into topic/asoc
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
This patch is adding support for openrd client platforms. It's using
the cs42l51 codec and has one mic and one speaker plugs.
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
This patch enables support for the i2s controller available on kirkwood
platforms
This patch is reponsible for enabling audio on the openrd client board
This patch add audio related definitions and functions
Acked-by: Nicolas Pitre <nico@fluxnic.net>
This patch is adding a ASoC driver for the cs42l51 from Cirrus Logic.
Master mode and spi mode are not supported.
Acked-by: Liam Girdwood <lrg@slimlogic.co.ul>
Some systems codecs need to configure some registers before and after
powering down some of their part. As a convenience add a macro for that.
This patch adds spdif dummy codec driver for using spdif-dit as
a stand-alone. Until this, spdif-dit can be used only with other
codecs like tlv320aci3x in davinci platform.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
Machine driver can instruct the codec driver to reset the
chip registers to their default values at probe time.
If machine driver does not provide setup data, then the
registers are going to be reseted to their defaults, to
be safe.
If the developer on the platform confirms that the register
reset is not needed, than it can be skipped, saving ~20ms
time in probe.
As safety measure do the register reset at remove time also.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Restructure the codec power code in order to be able to hit
off when the codec is not in use.
Since the audio registers are accessible while the codec is powered
down, there is no need for additional safety mechanism.
It seams at least on twl5031 that the ARXR2_APGA_CTL register
does not have the same default value as it is written in
the TRM.
Since the codec part of the PM chip has not been actually
changed according to TI, assuming, that all version has
the same problem, so writing there the TRM value.
Since the twl4030 codec driver supports different version
of the PM chip, a helper function can come handy, which
can check the driver's default versus the chip values.
Since the reg cache now contains the chip default values
for all registers (REG_OPTION is reset to it's default
within this patch), there is no longer need to rewrite
_all_ registers.
Initialize only few selected registers.
According to the latest information, the offset cancellation
need to be done only once, when the codec is powered on, so
there is no need for the power up wrapper.
Move all chip initialization code under chip_init, and do
it when the codec is initialized.
Add means for machine drivers to select the path for offset
cancellation.
Reset the reg cache value to the chip reset value at the
same time.
Machine drivers can specify which path need to be used for
offset cancellation via the twl4030_setup.offset_cncl_path.
For paths use the defines from
include/linux/mfd/twl4030-codec.h:
TWL4030_OFFSET_CNCL_SEL_*
There is no need for the power down wrapper.
Reset most of the codec registers to their chip reset
value.
.. and thus endeth the merge window.
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'slub/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
SLUB: Allow full duplication of kmalloc array for 390
slub: move kmem_cache_node into it's own cacheline
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
mutex: Fix optimistic spinning vs. BKL
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tui: Fix last use_browser problem related to .perfconfig
perf symbols: Add the build id cache to the vmlinux path
perf tui: Reset use_browser if stdout is not a tty
ring-buffer: Move zeroing out excess in page to ring buffer code
ring-buffer: Reset "real_end" when page is filled
This partially reverts commit 4ec37de89d8c758ee8115e0e64b3f994910789ee
("[IA64] Fix build breakage"), since the commit that made it necessary
got reverted earlier (see commit 35926ff5fba8, 'Revert "cpusets:
randomize node rotor used in cpuset_mem_spread_node()"')
Even if we ever re-introduce this, there is no reason to make
__node_random be some architecture-specific function.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
mm: export generic_pipe_buf_*() to modules
fuse: support splice() reading from fuse device
fuse: allow splice to move pages
mm: export remove_from_page_cache() to modules
mm: export lru_cache_add_*() to modules
fuse: support splice() writing to fuse device
fuse: get page reference for readpages
fuse: use get_user_pages_fast()
fuse: remove unneeded variable
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig:
kconfig: Hide error output in find command in streamline_config.pl
kconfig: Fix typo in comment in streamline_config.pl
kconfig: Make a variable local in streamline_config.pl
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (47 commits)
mfd: Rename twl5031 sih modules
mfd: Storage class for timberdale should be before const qualifier
mfd: Remove unneeded and dangerous clearing of clientdata
mfd: New AB8500 driver
gpio: Fix inverted rdc321x gpio data out registers
mfd: Change rdc321x resources flags to IORESOURCE_IO
mfd: Move pcf50633 irq related functions to its own file.
mfd: Use threaded irq for pcf50633
mfd: pcf50633-adc: Fix potential race in pcf50633_adc_sync_read
mfd: Fix pcf50633 bitfield logic in interrupt handler
gpio: rdc321x needs to select MFD_CORE
mfd: Use menuconfig for quicker config editing
ARM: AB3550 board configuration and irq for U300
mfd: AB3550 core driver
mfd: AB3100 register access change to abx500 API
mfd: Renamed ab3100.h to abx500.h
gpio: Add TC35892 GPIO driver
mfd: Add Toshiba's TC35892 MFD core
mfd: Delay to mask tsc irq in max8925
mfd: Remove incorrect wm8350 kfree
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
DMAENGINE: DMA40 U8500 platform configuration
DMA: PL330: Add dma api driver
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/qib: Remove DCA support until feature is finished
IB/qib: Use a single txselect module parameter for serdes tuning
IB/qib: Don't rely on (undefined) order of function parameter evaluation
IB/ucm: Use memdup_user()
IB/qib: Fix undefined symbol error when CONFIG_PCI_MSI=n
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
quota: Convert quota statistics to generic percpu_counter
ext3 uses rb_node = NULL; to zero rb_root.
quota: Fixup dquot_transfer
reiserfs: Fix resuming of quotas on remount read-write
pohmelfs: Remove dead quota code
ufs: Remove dead quota code
udf: Remove dead quota code
quota: rename default quotactl methods to dquot_
quota: explicitly set ->dq_op and ->s_qcop
quota: drop remount argument to ->quota_on and ->quota_off
quota: move unmount handling into the filesystem
quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers
quota: move remount handling into the filesystem
ocfs2: Fix use after free on remount read-only
Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, cpufeature: Unbreak compile with gcc 3.x
x86, pat: Fix memory leak in free_memtype
x86, k8: Fix section mismatch for powernowk8_exit()
lib/atomic64_test: fix missing include of linux/kernel.h
x86: remove last traces of quicklist usage
x86, setup: Phoenix BIOS fixup is needed on Dell Inspiron Mini 1012
x86: "nosmp" command line option should force the system into UP mode
arch/x86/pci: use kasprintf
x86, apic: ack all pending irqs when crashed/on kexec
If there's only one CPU online when disable_nonboot_cpus() is called,
the error variable will not be initialized and that may lead to
erroneous behavior. Fix this issue by initializing error in
disable_nonboot_cpus() as appropriate.
Fix a bunch of new rapidio kernel-doc warnings:
Warning(include/linux/rio.h:123): No description found for parameter 'comp_tag'
Warning(include/linux/rio.h:123): No description found for parameter 'phys_efptr'
Warning(include/linux/rio.h:123): No description found for parameter 'em_efptr'
Warning(include/linux/rio.h:123): No description found for parameter 'pwcback'
Warning(include/linux/rio.h:247): No description found for parameter 'set_domain'
Warning(include/linux/rio.h:247): No description found for parameter 'get_domain'
Warning(drivers/rapidio/rio-scan.c:1133): No description found for parameter 'rdev'
Warning(drivers/rapidio/rio-scan.c:1133): Excess function parameter 'port' description in 'rio_init_em'
Warning(drivers/rapidio/rio.c:349): No description found for parameter 'rdev'
Warning(drivers/rapidio/rio.c:349): Excess function parameter 'mport' description in 'rio_request_inb_pwrite'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'port'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'local'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'destid'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'hopcount'
Warning(drivers/rapidio/rio.c:393): Excess function parameter 'rdev' description in 'rio_mport_get_physefb'
Warning(drivers/rapidio/rio.c:845): Excess function parameter 'local' description in 'rio_std_route_clr_table'
Cc: Alexandre Bounine <alexandre.bounine@idt.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: Call pagefault_disable/pagefault_enable in kmap_atomic/kunmap_atomic
parisc: Remove unnecessary macros from entry.S
parisc: LWS fixes for syscall.S
parisc: Delete unnecessary nop's in entry.S
parisc: Avoid interruption in critical region in entry.S
parisc: invoke oom-killer from page fault
parisc: clear floating point exception flag on SIGFPE signal
parisc: Use of align_frame provides stack frame.
This reverts commit 0ac0c0d0f837c499afd02a802f9cf52d3027fa3b, which
caused cross-architecture build problems for all the wrong reasons.
IA64 already added its own version of __node_random(), but the fact is,
there is nothing architectural about the function, and the original
commit was just badly done. Revert it, since no fix is forthcoming.
Requested-by: Stephen Rothwell <sfr@canb.auug.org.au>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: clean up on forwarded aborted mds request
ceph: fix leak of osd authorizer
ceph: close out mds, osd connections before stopping auth
ceph: make lease code DN specific
fs/ceph: Use ERR_CAST
ceph: renew auth tickets before they expire
ceph: do not resend mon requests on auth ticket renewal
ceph: removed duplicated #includes
ceph: avoid possible null dereference
ceph: make mds requests killable, not interruptible
sched: add wait_for_completion_killable_timeout
Commit 756dee75872a2a764b478e18076360b8a4ec9045 ("SLUB: Get rid of dynamic DMA
kmalloc cache allocation") makes S390 run out of kmalloc caches. Increase the
number of kmalloc caches to a safe size.
Cc: <stable@kernel.org> [ .33 and .34 ]
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Based on the generic implementation of kmap_atomic and kunmap_atomic,
we should call pagefault_disable and pagefault_enable in our PA8000
implementation.
The define for kmap_atomic_prot was also missing, and I updated
kmap_atomic_pfn to use the generic implementation because of the
change to kmap_atomic.
I believe that this change is needed to fix the fork copy-on-write
bug.
Signed-off-by: John David Anglin <dave.anglin@nrc-cnrc.gc.ca>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
